查看: 3088|回复: 0
[NI驱动程序] NI FlexRIO Adapter Module Support 3.1.1 Driver Win32Eng NI FlexRIO适配器模块支持驱动软件3.1.1下载
    10 小时前
    发表于 2020-12-30 23:19:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI FlexRIO适配器模块支持
    NI FlexRIO Adapter Module Support为FlexRIO适配器模块提供LabVIEW支持。
    NI FlexRIO Adapter Module Support是一款驱动软件,可支持并访问FlexRIO适配器模块的I/O,包括数字化仪、收发仪、信号发生器、射频和DIO适配器模块。该软件还提供示例来帮助用户开始使用各种FlexRIO适配器模块。必须安装NI-FlexRIO才可使用该软件。
    Win32Eng
    3.1.1
    文件大小: 219912528 字节 (209.72 MB)
    修改日期: 2012-11-29 04:00
    MD5: 6e44ca7a2eb169a1bbab2275b2edb45a(官方正确)
    SHA1: dc3a421fc9aca5c6f6aa6a74ad4aa13a6ebfa584
    SHA256: 23b69a410fc1a07f277d6759f8fb3cb7934c83f68b671ad92042e9c8caef65eb
    CRC32: 02919420
    FlixeRIOAMS3.1.1.txt (624 Bytes, 下载次数: 0, 售价: 10 圆)
    NI FlexRIO™ Adapter Module Support Readme
    Version 3.1
    Thank you for using NI FlexRIO Adapter Module (FAM) Support. This file contains important information about the NI FlexRIO Adapter Module Support software, and it is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Application Development Environments (ADEs)
    • Installing NI FlexRIO Adapter Module Support 3.1
    • Supported Platforms
    • Uninstalling/Modifying NI FlexRIO Adapter Module Support
    • Bug Fixes
    • Documentation
    NI FlexRIO Adapter Module Support 3.1 includes the following new features:
    • Added support for the NI 5791 FAM
    NI FlexRIO Adapter Module Support software supports the following NI FlexRIO adapter modules:
    • NI 5731
    • NI 5732
    • NI 5733
    • NI 5734
    • NI 5751
    • NI 5752
    • NI 5761
    • NI 5762
    • NI 5771
    • NI 5772
    • NI 5781
    • NI 5791
    • NI 6581
    • NI 6583
    • NI 6584
    • NI 6585
    • NI 6587
    FAM Support 3.1 supports the following operating systems:
    Note  FAM Support 3.1 does not support Windows Server non-R2 editions.
    FAM Support 3.1 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 7/Windows Vista: 512 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 7/Windows Vista: 1 GB
    • LabVIEW 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 (32-bit), or 2012 (64-bit)
    Installing NI FlexRIO Adapter Module Support 3.1 with LabVIEW 2010 SP1 Examples
    Complete the following steps to install NI FlexRIO Adapter Module Support 3.1:
    • Install LabVIEW 2010 SP1.
    • (Optional) Install LabVIEW Real-Time 2010 SP1.
    • Install LabVIEW FPGA 2010 SP1.
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    • Install NI-RIO 12.0.
    • Install NI FlexRIO Adapter Module Support 3.1.
    Installing NI FlexRIO Adapter Module Support 3.1 with LabVIEW 2011 Examples
    • Install LabVIEW 2011.
    • (Optional) Install LabVIEW Real-Time 2011.
    • Install LabVIEW FPGA 2011.
    Installing NI FlexRIO Adapter Module Support 3.1 with LabVIEW 2012 Examples
    • Install LabVIEW 2012.
    • (Optional) Install LabVIEW Real-Time 2012.
    • Install LabVIEW FPGA 2012.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    Supported Platforms
    NI FlexRIO Adapter Module Support 3.1 supports the following platforms:
    • Windows 7 Professional (32-bit and 64-bit)
    • Windows Vista Business (32-bit and 64-bit)
    • Windows XP Professional (32-bit)
    • Click Change/Remove.
    • Select NI FlexRIO Adapter Module Support 3.1 from the dialog box that appears.
    • Updated CLIP for the 575x adapter modules fixes the compile issue on Linux Workers.
    The product documentation is available at Start»All Programs臧ational Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation. The documentation set is composed of the following documents:
    • NI FlexRIO FPGA Module Installation Guide and Specifications
    • NI FlexRIO FPGA Module Specifications
    • FlexRIO adapter module (FAM) User Manuals and Specifications
    • NI FlexRIO Adapter Module Support
    • NI FlexRIO Help
    • Getting Results manuals for FPGA modules
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Refer to ni.com/flexrio for additional NI FlexRIO product support and information.
    Important Information
    © 2008–2012 National Instruments Corporation. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    GMT+8, 2025-12-8 19:53
