查看: 3654|回复: 0
[NI驱动程序] NI FlexRIO Adapter Module Support 4.1 Driver Win32Eng NI FlexRIO适配器模块支持驱动软件4.1下载
    10 小时前
    发表于 2020-12-30 23:24:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI FlexRIO适配器模块支持
    NI FlexRIO Adapter Module Support为FlexRIO适配器模块提供LabVIEW支持。
    NI FlexRIO Adapter Module Support是一款驱动软件,可支持并访问FlexRIO适配器模块的I/O,包括数字化仪、收发仪、信号发生器、射频和DIO适配器模块。该软件还提供示例来帮助用户开始使用各种FlexRIO适配器模块。必须安装NI-FlexRIO才可使用该软件。
    Win32Eng
    4.1
    文件大小: 342585189 字节 (326.71 MB)
    修改日期: 2014-04-01 05:50
    MD5: 4abbfcbe858b957a700394f232e61c12(官方正确)
    SHA1: 382249aa6f9c0cd80af896919f5c7168b695dc85
    SHA256: 24405d5a9f9ae512e299d6551966b0068ef64c8ae87a3032e0f5b6c1848ec070
    CRC32: f7f32cbe
    FlixeRIOAMS4.1.txt (627 Bytes, 下载次数: 0, 售价: 10 圆)
    NI FlexRIO™ Adapter Module Support Readme
    Version 4.1
    Thank you for using NI FlexRIO Adapter Module (FAM) Support. This file contains important information about the NI FlexRIO Adapter Module Support software, and it is organized into the following sections:
    • New Features
    • Supported Software
    • Supported Hardware
    • System Requirements
    • Application Development Environments (ADEs)
    • Installing NI FlexRIO Adapter Module Support 4.1
    • Supported Platforms
    • Uninstalling/Modifying NI FlexRIO Adapter Module Support
    • Bug Fixes
    • Documentation
    FAM Support 4.1 includes the following new features:
    • Added Kintex-7 support for the following NI FlexRIO adapter modules:
      • NI 5761*
      • NI 5782
    *Kintex-7 support is available for the NI 5761 Multiple Sample CLIP and NI 5761 Single Sample CLIP only. Kintex-7 support is not available for the NI 5761 Low Speed CLIP.
    Supported Software
    FAM Support 4.1 supports the following software:
    • LabVIEW 2013 (32-bit and 64-bit)
    • LabVIEW 2012 (32-bit and 64-bit)
    NI FlexRIO Adapter Module Support software supports the following NI FlexRIO adapter modules:
    • NI 5731
    • NI 5732
    • NI 5733
    • NI 5734
    • NI 5751
    • NI 5752
    • NI 5761
    • NI 5762
    • NI 5771
    • NI 5772
    • NI 5781
    • NI 5782
    • NI 5791
    • NI 5792
    • NI 5793
    • NI 6581
    • NI 6583
    • NI 6584
    • NI 6585
    • NI 6587
    FAM Support 4.1 supports the following operating systems:
    Operating System64-bit32-bit
    Windows 8.x
    Windows 7 Professional
    Windows Vista Business
    Windows XP Professional SP3
    Windows Server 2012 R2
    Windows Server 2008 R2
    Windows Server 2003 R2
    Note  FAM Support 4.1 does not support Windows Server non-R2 editions.
    FAM Support 4.1 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 8.1/8/7/Windows Vista: 512 MB
    • Windows 8.1/8/7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8/7/Windows Vista: 1 GB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    NI FlexRIO Adapter Module (FAM) Support 4.1 supports the following ADEs:
    • LabVIEW 2012 (32-bit or 64-bit) and LabVIEW 2013 (32-bit or 64-bit)
    Installing NI FlexRIO Adapter Module Support 4.1 with LabVIEW 2012 Examples
    • Install LabVIEW 2012 SP1.
    • (Optional) Install LabVIEW Real-Time 2012 SP1.
    • Install LabVIEW FPGA 2012 SP1.
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    • (Optional) Install NI-RIO 12.1.
    • Install NI FlexRIO Adapter Module Support 4.1.
    Installing NI FlexRIO Adapter Module Support 4.1 with LabVIEW 2013 Examples
    • Install LabVIEW 2013.
    • (Optional) Install LabVIEW Real-Time 2013.
    • Install LabVIEW FPGA 2013.
    • (Optional) Install NI-RIO 13.1.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    Supported Platforms
    NI FlexRIO Adapter Module Support 4.1 supports the following platforms:
    • Windows 7 Professional (32-bit and 64-bit)
    • Windows Vista Business (32-bit and 64-bit)
    • Windows XP Professional (32-bit)
    • Click Change/Remove.
    • Select NI FlexRIO Adapter Module Support 4.1 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    • Fixed a clocking issue with the NI 5782 that caused inconsistent data arrival times in LabVIEW
    You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 4.0 or later), you may need to perform additional steps before or during a silent installation of NI software.
    The product documentation is available at Start»All Programs臧ational Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation. The documentation set is composed of the following documents:
    • NI FlexRIO FPGA Module Installation Guide and Specifications
    • NI FlexRIO Adapter Module (FAM) User Manuals and Specifications
    • NI FlexRIO Adapter Module Support
    • NI FlexRIO Help
    • Getting Results manuals for FPGA modules
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Refer to ni.com/flexrio for additional NI FlexRIO product support and information.
    Important Information
    © 2008–2014 National Instruments Corporation. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    GMT+8, 2025-12-8 19:56
