查看: 3119|回复: 0
[NI驱动程序] NI-CAN 2.5 Driver Win32Eng NI控制器局域网驱动软件2.5下载
    8 小时前
  • 签到天数: 3820 天
    连续签到: 13 天
    发表于 2021-1-2 22:36:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-CAN
    NI-CAN用于支持开发和部署多个控制器局域网(CAN)应用程序。
    NI-CAN驱动软件适用于多种类型的CAN硬件应用程序,如高速CAN、容错CAN和LIN接口。NI-CAN具有强大的底层框架API和上层通道,可实现快速开发。NI-CAN用于为LabVIEW、LabWindows/CVI和ANSI C/C++提供本地支持。此外,NI-CAN还包括通道测试面板、总线监控器和记录器以及数据库编辑器等工具。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    Win32Eng
    2.5
    文件大小: 185096992 字节 (176.52 MB)
    修改日期: 2010-04-25 04:18
    MD5: 755e772c141f62d2dd83f64f9e9944c8(官方正确)
    SHA1: 87458600ab61bcfd2ca1a282a06302e8a18a5b48
    SHA256: b5021dc2b84b3ae8af9a0a17054657eabdd848abeeda0c89944de9fdb8090e6d
    CRC32: 88bcd9ca
    CAN2.5.txt (547 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-CAN 2.5 Readme
    February 2007
    ni.com/support
    This file contains information on the NI-CANTM Software for Windows 2000/Vista/XP and LabVIEWTM Real-Time (RT). Information in this file is organized in the following sections:
    • Documentation
    • Supported Operating Systems
    • Supported Hardware
    • Supported Development Environments
    • New Features as Compared to 2.4
    • Changes from NI-CAN 2.4
    • Release Notes
    The Installation Guide: CAN Hardware and NI-CAN Software for Windows document included with the NI-CAN CD provides instructions for installing National Instruments CAN hardware and software.
    The NI-CAN Hardware and Software Manual is the primary document for NI CAN products. This manual includes an introduction to CAN, specifications for hardware, information on how to get started with application development, and a complete reference for all NI-CAN functions.
    The NI-CAN Hardware and Software Manual is provided in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the manual from your Start menu in:
      Start » All Programs » National Instruments » NI-CAN
    Links to the NI-CAN Hardware and Software Manual are provided in the online help for each NI-CAN function within the National Instruments LabVIEW and Lab Windows/CVITM development environments.
    Online help for the NI-CAN features within Measurement & Automation Explorer (MAX) is located in the MAX Help Topics menu. The MAX Help Topics for NI-CAN also include a link to the NI-CAN Hardware and Software Manual.
    Back to Top
    You must install and run this version of the NI-CAN software on the following operating systems:
    • Windows 2000 Service Pack 3
    • Windows XP, 32-bit
      For more information on using National Instruments hardware and software products with Windows Vista, visit ni.com/vista.
    National Instruments recomends using Service Pack 2 when using the USB-847x interfaces in hyper-thread or multi-core/cpu environments on Microsoft Windows XP.
    Back to Top
    This version of the NI-CAN software supports the following National Instruments hardware products on Windows and LabVIEW RT:
    • PCI-CAN, PCI-CAN/2 (High-Speed; Series 1 and 2)
    • PCI-CAN/LS, PCI-CAN/LS2 (Low-Speed/Fault-Tolerant; Series 1 and 2)
    • PCI-CAN/DS, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
    • PCI-CAN/XS, PCI-CAN/XS2, (Software-Selectable HS/LS/SW; Series 2)
    • PXI-8460, one-port or two-port (Low-Speed/Fault-Tolerant; Series 1 and 2)
    • PXI-8461, one-port or two-port (High-Speed; Series 1 and 2)
    • PXI-8462, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
    • PXI-8464, one-port or two-port (Software- Selectable HS/LS/SW; Series 2)
    This version of the NI-CAN software supports the following National Instruments hardware products on Windows:
    • USB-8472 (Low-Speed/Fault-Tolerant CAN)
    • USB-8472s (Low-Speed/Fault-Tolerant CAN with synchronization)
    • USB-8473 (High-Speed CAN)
    • USB-8473s (High-Speed CAN with synchronization)
    • USB-8476 (LIN)
    • USB-8476s (LIN with synchronization)
    • PCMCIA-CAN, PCMCIA-CAN/2 (Series 1 and 2)
    Please note: PCMCIA-CAN and PCMCIA-CAN/2 interfaces are not supported on the 64-bit version of Windows Vista!
    Several National Instruments Series 1 CAN hardware are not supported in this version of NI-CAN. Install NI-CAN version 2.2 for support of the following hardware products (available on ni.com):
    • PCI-CAN, (pre-1998 CAN card, part numbers: 183887A-01, 183887B-01)
    • PCI-CAN/2, (pre-1998 CAN card, part numbers: 183887A-02, 183887B-02)
    • PCMCIA-CAN, (pre-1998 CAN card, part numbers: 184272A-01, 184272B-01, 184272C-01)
    • PCMCIA-CAN/2, (pre-1998 CAN card, part numbers: 184272A-02, 184272B-02, 184272C-02)
    Install NI-CAN version 2.1.3 for support of the following AT (ISA) hardware products (available on ni.com):
    • AT-CAN
    • AT-CAN/2, (ISAPNP cards; High Speed; Series 1)
    The NI-CAN software supports only National Instruments CAN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Back to Top
    This version of the NI-CAN software supports the following development environments:
    • LabVIEW 7.1, 8.0, and 8.2
    • LabVIEW Real-Time (RT) 7.1, 8.0, and 8.2
    • LabWindows/CVI 7.1 and higher
    • Microsoft Visual Basic 6.0
    • Microsoft Visual C/C++ 6.0
    • Borland C/C++
    Back to Top
    New Features as Compared to NI-CAN 2.4
    The NI-CAN 2.5 release adds the following features:
    • Support for the 32 and 64-bit versions of the Microsoft Windows Vista operating system.
    • Support for report generation within Measurement and Automation Explorer (MAX).
    Back to Top
    The following list describes changes in the NI-CAN software compared to NI-CAN 2.4:
    • Added support for Microsoft Windows Vista 32 and 64 bit support.
    • Synchronization with Traditional NI-DAQ is supported only on Windows 2000 and Windows XP.
    • The API VIs and examples for the LabVIEW 8.2 development environment are mass compiled to LabVIEW 8.2.1.
    Back to Top
    Additional Programming TopicsSupport of CANdb (*.DBC) Files
    NI-CAN provides support for CANdb network files created using the Vector CANdb or CANdb++ editor. The information from the CANdb file can be used in the Measurement & Automation Explorer (MAX) or with the NI-CAN Channel API. For more information, refer to the Using the Channel API chapter in the NI-CAN Hardware and Software Manual.
    NI-CAN supports CANdb network files created using the CAN module of Vector products. NI-CAN does not provide complete support of CANdb files created using modules for higher-layer CAN protocols, such as J1939, ISO11783, or NMEA2000. In order to view the set of features supported for these modules, import the CANdb file into MAX. NI-CAN will display an error dialog for any unsupported object, and will display those objects with a red mark. For example, the J1939 protocol for multi-frame messages (greater than 8 bytes) is not supported in the current version of NI-CAN.
    Updating get/Set Attribute in Frame API for LabVIEW
    NI-CAN 2.4 (or newer) includes several new Frame API attributes. If you have a LabVIEW VI written for an earlier version of NI-CAN, upgrading to NI-CAN 2.4 (or newer) will not automatically update constants or controls for the AttrId input. To use the new attributes, replace your older constants and controls using the AttrId input of the updated NI-CAN VIs.
    If you do not want to use new Frame API attributes, you can continue to use the older constants and controls for compatibility.
    This issue does not apply to the Channel API for LabVIEW. Because the Get/Set Property functions are provided as polymorphic VIs, they are automatically updated.
    Back to Top
    Release Notes
    • For USB-LIN interfaces, the LIN bus must be terminated. This is typically done at the master node. For information on how to enable or disable termination on the USB-LIN, refer to the ncSetAttribute attribute function with the Frame API.
    • The USB-LIN interfaces require external power from 8-18V. For more details on the power requirements, refer to the USB-LIN specifications sections within the NI-CAN Hardware and Software Manual.
    • The USB LED will quickly switch between green and amber when the hardware is first detected.
    • Fatal errors may cause the USB LED to flash in an error code pattern. Count the number of long and short flashes, then contact National Instruments support.
    • If using the USB CAN or LIN products with a USB hub, the hub must be powered.
    • Due to the inherent latencies of the Universal Serial Bus (USB), data or states received by the NI USB 847x Series devices might be processed by the driver on the host side later than data from a plug-in (PCI, PXI, PCMCIA) interface. This does not affect the timestamps as those are generated on the hardware, but could cause time-out failures with the NI USB 847x Series devices that won't happen on plug-in hardware. To avoid those, increase the timeout value for functions that perform a wait for a certain state.
    Back to Top
    © 1996-2007 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-9 16:41
