查看: 3614|回复: 0
[NI驱动程序] NI-DNET 1.6.7 Drvier Win32Eng NI-DeviceNet驱动软件1.6.7下载
    昨天 08:28
  • 签到天数: 3719 天
    连续签到: 46 天
    发表于 2021-1-4 22:11:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DNET
    NI-DNET用于支持DeviceNet系统中的设备。
    NI-DNET是一款驱动软件,用于帮助配置和控制DeviceNet接口设备、PXI DeviceNet接口模块和C系列DeviceNet接口模块等DeviceNet硬件。该软件使用面向对象的概念表示DeviceNet系统中的组件。NI-DNET使用Measurement & Automation Explorer (MAX)作为配置和工具的中心节点。NI-DNET可用于监控DeviceNet网络,验证有关连接设备的信息,管理设备参数,并根据DeviceNet协议解读控制区域网(CAN)消息。NI-DNET功能还可用于开发和调试基于LabVIEW、LabWindows/CVI、Microsoft Visual C/C ++、Borland C/C ++、Visual Basic或其他编程语言的应用程序。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    1.6.7
    文件大小: 426412544 字节 (406.66 MB)
    修改日期: 2012-08-07 05:07
    MD5: a1ae124649b3c7907a19c643ac25af7e(官方正确)
    SHA1: 8bba0cd822fd10c38717835300b286adce704c4b
    SHA256: d3871e3f70284c63d2d0821e9e458b460baabe90062f80700bfa2765118df2d8
    CRC32: 242b0ebb
    发布日期
    2012/8/5
    受支持的操作系统
    Windows 7
    Phar Lap ETS
    Windows Vista
    Windows XP 32-bit
    DNET1.6.7.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DNET Readme
    Version 1.6.7
    June 2012
    This file contains important information about NI-DNET for Windows and LabVIEW Real-Time, including documentation, the supported hardware and software, the installation and upgrade issues, and additional programming topics.
    Changes in Version 1.6
    Additional Programming Topics
    The NI-DNET Hardware and Software for Windows Installation Guide included with your NI-DNET CD includes instructions for installing your National Instruments CAN hardware and NI-DNET software.
    The NI-DNET User Manual provides an introduction to DeviceNet, hardware specifications, and information about how to get started with application development.
    The NI-DNET Programmer Reference Manual is a complete reference for all NI-DNET functions.
    All manuals are in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at www.adobe.com.
    Open the documents from Start»All Programs»National Instruments»NI-DNET.
    Within the National Instruments LabVIEW and LabWindows™/CVI™ development environments, links to the NI-DNET Programmer Reference Manual are in the online help for each NI-DNET function.
    Online help for NI-DNET features within Measurement & Automation Explorer (MAX), including the NI-DNET Configurator and Analyzer help, is in the MAX Help Topics menu.
    You must install and run the NI-DNET software on the following operating systems:
    • Windows XP (32-bit)
    The NI-DNET software supports the following National Instruments DeviceNet hardware on Windows 7 32-bit/Windows Vista 32-bit/Windows XP 32-bit:
    • PCI-DNET
    • PCMCIA-DNET
    • PXI-8461/D
    The NI-DNET software supports the following National Instruments DeviceNet hardware on Windows 7 64-bit/Windows Vista 64-bit:
    • PCI-DNET
    • PXI-8461/D
    The NI-DNET software supports the following National Instruments DeviceNet hardware on LabVIEW Real-Time:
    • PXI-8461/D
    The NI-DNET software also supports the following National Instruments CAN hardware:
    • High-Speed Series 1 CAN interfaces
    Although you can use the 2-port CAN card, you can use only the top port with NI-DNET.
    This version of NI-DNET does not support some types of National Instruments Series 1 CAN hardware. Install NI-DNET version 1.4.1 (available at ni.com) to support the following hardware products:
    • PCI-CAN (pre-1998 CAN card, part numbers 183887A-01 and 183887B-01)
    • PCI-CAN/2 (pre-1998 CAN card, part numbers 183887A-02 and 183887B-02)
    • PCMCIA-CAN (pre-1998 CAN card, part numbers 184272A-01, 184272B-01, and 184272C-01)
    • PCMCIA-CAN/2 (pre-1998 CAN card, part numbers 184272A-02, 184272B-02, and 184272C-02)
    The NI-DNET software does not support Series 2 CAN hardware products. For information about CAN hardware support limitations, refer to the NI-DNET Hardware Overview chapter of the NI-DNET User Manual.
    The NI-DNET software supports the following development environments:
    • LabVIEW 2009 (32-bit), 2010 (32-bit), 2011 (32-bit), and 2012 (32-bit)
    • LabVIEW Real-Time (ETS) 2009, 2010, 2011, and 2012
    • LabWindows/CVI 8.0 (or newer)
    • Microsoft Visual Basic 6.0
    • Microsoft Visual C/C++ 6.0
    • Borland C/C++
    • Support for the 32 and 64-bit versions of the Microsoft Windows Vista operating system.
    • Support for the MAX Report Generation utility.
    • (NI-DNET 1.6.1) Support for LabVIEW 8.5 and LabVIEW Real-Time 8.5.
    • (NI-DNET 1.6.2) Dropped the support of LabVIEW 8.0 and LabVIEW Real-Time 8.0.
    • (NI-DNET 1.6.2) Support for LabVIEW 8.6 and LabVIEW Real-Time 8.6.
    • (NI-DNET 1.6.3) Updated the firmware; resolved a connection timeout error on slow slave devices.
    • (NI-DNET 1.6.3) Updated the user manual; added the requirement to connect the Shield pin to comply with a new set of compliance regulations.
    • (NI-DNET 1.6.3) Support for LabVIEW 8.6.1 and LabVIEW Real-Time 8.6.1.
    • (NI-DNET 1.6.4) Support for LabVIEW 2009 and LabVIEW Real-Time 2009.
    • (NI-DNET 1.6.5) Support for LabVIEW 2010 and LabVIEW Real-Time 2010.
    • (NI-DNET 1.6.6) Support for LabVIEW 2011 and LabVIEW Real-Time 2011.
    • (NI-DNET 1.6.7) Support for LabVIEW 2012 and LabVIEW Real-Time 2012.
    Additional Programming TopicsImportant Changes to Existing NI-DNET Applications
    To improve NI-DNET integration into the overall National Instruments product framework, NI-DNET version 1.4 and later uses a different error code format than previous NI-DNET versions.
    This new error code format may require minor changes to your existing NI-DNET application code. For example, some existing C/C++ files with NI-DNET code report compiler errors until you make the appropriate changes.
    The changes to your code entail:
    • Code simplification to convert an NI-DNET error to a useful description.
    • Replacing constants used in comparisons for specific errors.
    For details of the changes required to update your NI-DNET code, go to ni.com and search for KnowledgeBase article 3A2E8THR, Changes in Error Codes as of NI-DNET Version 1.4.
    Important Information
    ©1998–2012 National Instruments. All rights reserved.
    The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-11-22 07:23
