查看: 3191|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 2.3 Driver Win32Eng NI-DNet工业通信软件驱动程序2.3下载
    昨天 08:28
  • 签到天数: 3719 天
    连续签到: 46 天
    发表于 2021-1-4 22:47:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    Win32Eng
    2.3
    文件大小: 446780192 字节 (426.08 MB)
    修改日期: 2013-09-16 23:11
    MD5: 63f105f92a67f32d53aae8b032286c19(官方正确)
    SHA1: 588f240fd2c21e2a8edf9a64da9d03bdbc27bab1
    SHA256: 22c6ca8c056aad13b82b0fb37009fca972331d0eca446bb24cafe0b28301363d
    CRC32: 005f99eb
    DNET2.3.txt (614 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet 2.3 Readme
    August 2013
    This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time environment, including new features and changes, the installation and upgrade issues, compatibility issues, and a partial list of bug fixes.
    Note   The NI-IndCom for DeviceNet 2.3 software requires the NI 9882 module with the upgraded firmware. When you upgrade your software to the 2.3 version, check the software version of the CD that shipped with your NI 9882 module.
    If the version is not 2.3 or you are not sure of the version number, National Instruments recommends that you upgrade the firmware. Otherwise, when you use NI-IndCom for DeviceNet 2.3, firmware images corrupt or get mismatched.
    Make sure you have appropriate hardware and software installed and complete one of the following tasks to upgrade the firmware.
    • If you are using cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, cRIO-9118, cRIO-9081, or cRIO-9082 with LabVIEW 2012 or later, double-click ModuleFirmwareUpgrade.exe in the National Instruments\NI-IndCom for DeviceNet\Utilities directory and follow the instructions in this utility to upgrade the firmware.
    • If you are using other chassis with LabVIEW 2013 or later, double-click Firmware_Upgrade_Instructions.html in the National Instruments\NI-IndCom for DeviceNet directory and follow the instructions to use a LabVIEW example project to upgrade the firmware.
    New Features and Changes
    DeviceNet 2.3
    DeviceNet 2.2
    DeviceNet 2.1
    DeviceNet 2.0.2
    DeviceNet 2.0.1
    DeviceNet 2.0
    Compatibility with NI-DNET 1.x
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    New Features and ChangesDeviceNet 2.3
    • Added FPGA VIs to operate the NI 9882 modules on the NI-RIO targets
    • Added support for cRIO-9068
    • Added support for LabVIEW 2013 (32-bit) and LabVIEW 2013 Real-Time Module
    DeviceNet 2.2
    • Added slave support for NI 9882, PCI-8532, and PXI-8532
    • Added VIs for reading and writing the raw CAN frames
    • Added an example VI for monitoring and analyzing DeviceNet packets
    • Added support for LabVIEW 2012 (32-bit) and LabVIEW 2012 Real-Time Module
    DeviceNet 2.1
    • Added support for NI 9882 1-Port DeviceNet Module for NI CompactRIO
    • Added NI-DNET 1.x compatible LabVIEW VIs
    DeviceNet 2.0.2
    • Added support for LabVIEW 2011 (32-bit) and LabVIEW 2011 Real-Time Module
    DeviceNet 2.0.1
    • Added support for LabVIEW 2010 (32-bit) and LabVIEW 2010 Real-Time Module
    DeviceNet 2.0
    • Supported NI DeviceNet hardware: PCI-8532 and PXI-8532
    • Supported LabVIEW 2009 (32-bit) and LabVIEW 2009 Real-Time Module
    You must install and run the NI-IndCom for DeviceNet software on the following operating systems:
    • Windows XP SP3 (32-bit)
    The NI-IndCom for DeviceNet installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Refer to KB 6CCA8MEG, Supported Hardware and Software for NI-Industrial Communications for DeviceNet, for a complete list of NI hardware and software supported by each version of the NI-IndCom for DeviceNet.
    The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, you may connect 64 devices to the network.
    Caution  The NI-IndCom for DeviceNet software does not support the previous generation of the DeviceNet hardware products such as PCI-DNET, PCMCIA-DNET, and PXI-8461/D. Those products require an NI-DNET 1.x driver.
    Before installing the NI-IndCom for DeviceNet software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for DeviceNet software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for DeviceNet software:
    • Insert the NI-IndCom for DeviceNet software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for DeviceNet software CD.
    • The installation wizard guides you through the necessary steps to install the NI-IndCom for DeviceNet software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking the Cancel button.
    • When the installation is complete, click the Finish button.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-IndCom for DeviceNet software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select the Custom software installation option.
    • Select the NI-IndCom for DeviceNet item in the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    NI-IndCom for DeviceNet Updates and Notifications
    Refer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet in LabVIEW, for information about using the NI-IndCom for DeviceNet software.
    LabVIEW examples for the NI-IndCom for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    The following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.1. This table is not an exhaustive list of issues fixed in the current version of NI-IndCom for DeviceNet.
    198387Explicit messaging function block help does not explain how to write attributes
    185016PCI/PXI 8532 boards manual lacks hardware specifications section
    The following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.0.2. This table is not an exhaustive list of issues fixed in this version of NI-IndCom for DeviceNet.
    288931DeviceNet deployment executable fails to execute on a machine without LabVIEW
    NI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two products can be installed on the same system side by side. DeviceNet 2.1 or later provides NI-DNET 1.x compatible VIs, so the application using NI-DNET 1.x VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change.
    Using NI Launcher
    Finding All Programs
    NI-IndCom for DeviceNet Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-IndCom for DeviceNet will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-IndCom for DeviceNet that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    ©2009–2013 National Instruments. All rights reserved.
    GMT+8, 2025-11-22 07:22
