查看: 3145|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 17.0 Driver Win32Eng NI-DNet工业通信软件驱动程序17.0下载
    昨天 08:28
  • 签到天数: 3719 天
    连续签到: 46 天
    发表于 2021-1-4 22:54:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    Win32Eng
    17.0
    文件大小: 575676808 字节 (549.01 MB)
    修改日期: 2017-04-13 13:06
    MD5: 5f2b3124a026185e357707c5077a6da9(官方正确)
    SHA1: a3ba4600272c7219bd33aa8cce1107a0fcc5c2f5
    SHA256: a7edce3cc4a6a00bc13ff5ee640fff238fc557487adcc2ae0dc5ee2e410fe803
    CRC32: 5e34bcc3
    DNET17.0.txt (620 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet 17.0 Readme
    March 2017
    This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time environment, including new features, installation and upgrade issues, compatibility issues, and a partial list of bug fixes.
    Caution   The NI-Industrial Communications for DeviceNet 2.3 software or later requires the NI 9882 module with the updated firmware. When you upgrade your software to the 2.3 version or later, check the software version of the media shipped with your NI 9882 module. If the version is not 2.3 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for DeviceNet 2.3 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete one of the following tasks to update the firmware.
    • If you are using NI cRIO-9081/9082/9111/9112/9113/9114/9116/9118 with LabVIEW 2014 or later, double-click ModuleFirmwareUpdate.exe in the \NI-IndCom for DeviceNet\Utilities directory and follow the instructions in this utility to update the firmware.
    • If you are using other chassis with LabVIEW 2014 or later, double-click Firmware_Update_Instructions.html in the \NI-IndCom for DeviceNet directory and follow the instructions to use a LabVIEW example project to update the firmware.
    Compatibility with NI-DNET 1.x
    The NI-Industrial Communications for DeviceNet software provides the DeviceNet driver and VIs for you to configure and control DeviceNet devices on a DeviceNet network and to communicate with FPGA targets.
    NI-Industrial Communications for DeviceNet supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-Industrial Communications for DeviceNet dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for DeviceNet 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for DeviceNet 17.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for DeviceNet 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Notes  Upgrading Windows 8 to Windows 8.1 with the NI-Industrial Communications for DeviceNet software installed might result in device configuration information damage and ostensible disconnection between devices. NI recommends that you reinstall the NI-Industrial Communications for DeviceNet software after upgrading the operating system.
    Refer to KB 6CCA8MEG, Supported Hardware and Software for NI-Industrial Communications for DeviceNet, for a complete list of NI hardware and software supported by each version of the NI-Industrial Communications for DeviceNet.
    The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, you may connect 64 devices to the network.
    Caution  The NI-Industrial Communications for DeviceNet software does not support the previous generation of the DeviceNet hardware products such as NI PCI-DNET, NI PCMCIA-DNET, and NI PXI-8461/D. Those products require an NI-DNET 1.x driver.
    Before installing the NI-Industrial Communications for DeviceNet software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for DeviceNet software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for DeviceNet software:
    • Insert the NI-Industrial Communications for DeviceNet software media. The installer launches automatically. If the installer does not launch automatically, navigate to the media and launch the autorun.exe file.
    • Follow the installation wizard to install the NI-Industrial Communications for DeviceNet software.
    Installing the Software on the RT Target
    Complete the following steps to install the NI-Industrial Communications for DeviceNet software on the RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand the RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select the Custom software installation option.
    • Select the NI-IndCom for DeviceNet item in the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    New FeaturesDeviceNet 17.0
    • Added support for LabVIEW 2017 (32-bit) and LabVIEW 2017 Real-Time Module
    DeviceNet 16.0
    • Added support for LabVIEW 2016 (32-bit) and LabVIEW 2016 Real-Time Module
    • Added support for NI cRIO-9032/9035 (Sync)/9037/9039 (Sync)
    DeviceNet 15.0
    • Added support for LabVIEW 2015 (32-bit) and LabVIEW 2015 Real-Time Module
    • Added support for NI sbRIO-9607/9627 and NI RMC-9697
    DeviceNet 14.5
    • Added support for LabVIEW 2014 SP1(32-bit) and LabVIEW 2014 Real-Time Module
    • Added support for NI cRIO-9030/9031/9033/9035/9036/9039/9063/9064/9065/9066/9067
    DeviceNet 2.3
    • Added FPGA VIs to operate the NI 9882 modules on the NI-RIO targets
    • Added support for NI cRIO-9068
    • Added support for LabVIEW 2013 (32-bit) and LabVIEW 2013 Real-Time Module
    DeviceNet 2.2
    • Added slave support for NI 9882, NI PCI-8532, and NI PXI-8532
    • Added VIs for reading and writing the raw CAN frames
    • Added an example VI for monitoring and analyzing DeviceNet packets
    • Added support for LabVIEW 2012 (32-bit) and LabVIEW 2012 Real-Time Module
    DeviceNet 2.1
    • Added support for NI 9882 1-Port DeviceNet Module for CompactRIO
    • Added NI-DNET 1.x compatible LabVIEW VIs
    DeviceNet 2.0.2
    • Added support for LabVIEW 2011 (32-bit) and LabVIEW 2011 Real-Time Module
    DeviceNet 2.0.1
    • Added support for LabVIEW 2010 (32-bit) and LabVIEW 2010 Real-Time Module
    DeviceNet 2.0
    • Supported NI DeviceNet hardware: NI PCI-8532 and NI PXI-8532
    • Supported LabVIEW 2009 (32-bit) and LabVIEW 2009 Real-Time Module
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for DeviceNet 14.5. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for DeviceNet. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    504396The maximum IO length for Poll, COS and Cyclic should be 255 instead of 240
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for DeviceNet 2.1. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for DeviceNet. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    198387Explicit messaging function block help does not explain how to write attributes
    185016PCI/PXI 8532 boards manual lacks hardware specifications section
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for DeviceNet 2.0.2. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for DeviceNet. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    288931DeviceNet deployment executable fails to execute on a machine without LabVIEW
    Refer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet in LabVIEW, for information about using the NI-Industrial Communications for DeviceNet software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two products can be installed on the same system side by side. DeviceNet 2.1 or later provides NI-DNET 1.x compatible VIs, so the application using NI-DNET 1.x VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2009–2017 National Instruments. All rights reserved.
    375166D-01
    GMT+8, 2025-11-22 07:23
