TA的每日心情 | 奋斗 7 小时前 |
签到天数: 3733 天 连续签到: 60 天 [LV.Master]2000FPS
NI-Digital Pattern Driver 17.0.3 Win32/64Eng NI数字向量仪器驱动程序17.0.3下载
Win32/64ENG
17.0.3
文件大小: 915906440 字节 (873.48 MB)
修改日期: 2018-09-25 22:10
MD5: 1a67e0fff30b02b5efe324c8390400eb(官方正确)
SHA1: 4e040a77d53b360cab57a5150b4f9128a9403764
SHA256: 2edc65d27283d048a99bf96ca143733e1761fc705f4fc2818d17e665021242fb
CRC32: 62d8d026
Digital17.0.3.txt
(623 Bytes, 下载次数: 0, 售价: 10 圆)
Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor 17.0 Readme
May 2017
This file contains important information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor including supported hardware, system requirements, and supported application development environments.
Supported Application Development Environments
Accessing Documentation
Use the Digital Pattern Editor with the Digital Pattern Instrument (PXIe-6570) and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
System RequirementsMinimum System Requirements
RAM—4 GB
A screen resolution of 1024 x 768
Recommended System
RAM—8 GB
The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
Windows 10 (64-bit)
Windows 7 SP11 (64-bit)
1 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
Note: The NI-Digital Pattern Driver and the Digital Pattern Editor support only 64-bit operating systems for development. You can deploy runtime solutions on Windows 10 (32-bit and 64-bit) and Windows 7 (32-bit and 64-bit). Refer to your ADE documentation for more information about creating a runtime deployment:
LabVIEW - "Building and Distributing Applications"
NI TestStand - "Deploying TestStand Systems"
Microsoft Visual Studio - "Deploying the .NET Framework and Applications"
Note: The Digital Pattern Editor does not support Guest user accounts on Windows. The Digital Pattern Editor supports Administrator and Limited accounts on Windows 7.
Note: NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/info and enter the Info Code mshotfix for more information about Microsoft Hotfix 2588507.
Supported Application Development Environments (ADEs)
Install ADEs, such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
NI-Digital Pattern Driver and Digital Pattern Editor 17.0 support the following ADE versions:
Application Software Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 17.0
LabVIEW 2017, 2016, 2015, 2014 (32-bit and 64-bit)
NI TestStand 2016 (64-bit)
NI TestStand Semiconductor Module 2016 f1 patch (64-bit)
Microsoft Visual Studio 2010 and later (.NET versions 4.0 and 4.5)1
1If you are using the NI-Digital .NET Class Library, the .NET 4.0 Framework (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or the .NET 4.5 Framework. Ensure that you select .NET Framework 4.0 Support or .NET Framework 4.5 Support in the NI-Digital Pattern Driver installer to install .NET support for the NI-Digital Pattern Driver software.
Note: You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
Note: You must install the NI-Sync driver to access NI-Sync-related functionality.
Accessing the APILabVIEW
The NI–Digital Pattern Driver palette VIs are available from the following locations:
LabVIEW 2015 and earlier—Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
LabVIEW 2016 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
.NET Class Library
C
You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files (x86)\IVI Foundation\IVI\Bin\niDigital_32.dll for 32-bit development or to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
The NI-Digital Pattern Driver supports the following NI product:
PXIe-6570
You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues.
Documentation for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor is available from the Start menu by navigating to NI Digital Pattern Documentation in the National Instruments folder. The documentation set is composed of the following documents:
Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor Readme (this file)—Contains information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor, including where to go for support, supported hardware, system requirements, operating systems, known issues, and legal notices.
Digital Pattern Help—Contains information about using the Digital Pattern Editor with the Digital Pattern Instrument (PXIe-6570) and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties as well as the NI-Digital Pattern .NET Class Library.
NI-Digital Pattern Driver Function Reference—Includes references for the NI-Digital Pattern C API functions.
PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
Digital pattern instrument manuals are also available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
Finding ExamplesGetting Started Examples
Use the getting started examples, located by default in the <;Public Documents>\National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
LabVIEW Examples
Microsoft .NET Examples
The Microsoft .NET examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
C Examples
The C examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
© 2015-2017 National Instruments. All rights reserved.
Notices are located in the \_Legal Information and directories.
EULAs are located in the \Shared\MDF\Legal\license directory.
Review \_Legal Information.txt for information on including legal information in installers built with NI products.
376615B-01 |
