查看: 3149|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 18.0.3 Win32/64Eng NI数字向量仪器驱动程序18.0.3下载
    7 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-5 22:35:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Win32/64ENG
    18.0.3
    文件大小: 865644544 字节 (825.54 MB)
    修改日期: 2019-11-26 00:08
    MD5: f559660c1cb89de8fd06d76c3ab4e207(官方正确)
    SHA1: fd40d3f48832267debe701f84093ea540596bcfa
    SHA256: a748aed66207c8e462f012434f5f9bc28c64c7c258af4ac4cc6692c9aa78422d
    CRC32: bf5d6875
    Digital18.0.3.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor 18.0 Readme
    May 2018
    This file contains important information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor including supported hardware, system requirements, and supported application development environments.
    Accessing Documentation
    Use the Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    System RequirementsMinimum System Requirements
    • RAM—4 GB
    Recommended System
    • RAM—8 GB
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
    • Windows 10 (64-bit)
    • Windows 7 SP11 (64-bit)
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note:  The NI-Digital Pattern Driver and the Digital Pattern Editor support only 64-bit operating systems for development. You can deploy runtime solutions on Windows 10 (32-bit and 64-bit) and Windows 7 (32-bit and 64-bit). Refer to your ADE documentation for more information about creating a runtime deployment:
    • LabVIEW - "Building and Distributing Applications"
    • NI TestStand - "Deploying TestStand Systems"
    • Microsoft Visual Studio - "Deploying the .NET Framework and Applications"
    Note:  The Digital Pattern Editor does not support Guest user accounts on Windows. The Digital Pattern Editor supports Administrator and Limited accounts on Windows 7.
    Note:  NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/info and enter the Info Code mshotfix for more information about Microsoft Hotfix 2588507.
    Install Application Development Environments (ADEs), such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
    NI-Digital Pattern Driver and Digital Pattern Editor 18.0 support the following ADE versions:
    Application SoftwareVersions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 18.0
    LabVIEW2018, 2017, 2016, 2015 (32-bit and 64-bit)
    LabVIEW NXG2.0, 2.1
    NI TestStand2016 (64-bit), 2016 SP1
    NI TestStand Semiconductor Module™2016 f1 patch (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)1
    Note:  You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note:  You must install the NI-Sync driver to access NI-Sync-related functionality.
    1If you are using the NI-Digital .NET Class Library, the .NET 4.0 Framework (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or the .NET 4.5 Framework.
    Ensure that you select .NET Framework 4.0 Support or .NET Framework 4.5 Support in the NI-Digital Pattern Driver installer to install .NET support for the NI-Digital Pattern Driver software.
    Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following locations:
    • LabVIEW 2015—Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    • LabVIEW 2016 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    • LabVIEW NXG 2.0 and later—On the Diagram, Hardware Interfaces»NI-Digital palette
    .NET Class Library
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files (x86)\IVI Foundation\IVI\Bin\niDigital_32.dll for 32-bit development or to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    Refer to the What's New in 18.0 topics in the Digital Pattern Help for detailed information about new features and other changes since NI-Digital Pattern Driver and Digital Pattern Editor 17.5. Refer to the What's New topics for previous versions of the NI-Digital Pattern Driver and Digital Pattern Editor in the Digital Pattern Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    The NI-Digital Pattern Driver supports the following NI products:
    • PXIe-6570
    • PXIe-6571
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues.
    Documentation for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor is available from the Start menu by navigating to NI Digital Pattern Documentation in the National Instruments folder. The documentation set is composed of the following documents:
    • Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor Readme (this file)—Contains information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor, including where to go for support, supported hardware, system requirements, operating systems, known issues, and legal notices.
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    Digital pattern instrument manuals are also available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    Finding ExamplesGetting Started Examples
    Use the getting started examples, located by default in the <;Public Documents>\National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    LabVIEW Examples
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    The following sections detail considerations for using LabVIEW NXG 2.0 and later with NI-Digital.
    LabVIEW NXG Hardware Support
    • PXIe-6570
    • PXIe-6571
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2015-2018 National Instruments. All rights reserved.
    376615E-01
    GMT+8, 2025-12-5 16:02
