查看: 3212|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 20.6 Win32/64Eng NI数字向量仪器驱动程序20.6下载
    7 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-5 22:42:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Win32/64ENG
    20.6
    文件大小: 1064042496 字节 (1014.75 MB)
    修改日期: 2020-12-08 08:31
    MD5: 0a00d9c457cda736066b5342d837a5d0(官方正确)
    SHA1: 6377ec5325db29fcf4c95ac83441dd78f4c2b0e1
    SHA256: ec7208b45c7bcf0ff637c2c024ecba887520f45cd0938263b4947754348912fb
    CRC32: 720be212
    Digital20.6.txt (628 Bytes, 下载次数: 1, 售价: 10 圆)
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor 20.6 Readme
    November 2020
    This file contains important information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor including supported hardware, system requirements, and supported application development environments.
    Accessing Documentation
    NI-Digital Drops Support for Windows 7 (32- and 64-Bit) and All 32-Bit Windows Operating Systems in 2021
    Use the Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    System RequirementsMinimum System Requirements
    • RAM—4 GB
    Recommended System
    • RAM—8 GB
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
    • Windows 10 (64-bit)
    • Windows 7 SP11 (64-bit)
    Note:  The NI-Digital Pattern Driver and the Digital Pattern Editor support only 64-bit operating systems for development. You can deploy runtime solutions on Windows 10 (32-bit and 64-bit) and Windows 7 (32-bit and 64-bit). Refer to your ADE documentation for more information about creating a runtime deployment:
    • LabVIEW - "Building and Distributing Applications"
    • NI TestStand - "Deploying TestStand Systems"
    • Microsoft Visual Studio - "Deploying the .NET Framework and Applications"
    Note:  The Digital Pattern Editor does not support Guest user accounts on Windows. The Digital Pattern Editor supports Administrator and Limited accounts on Windows 7.
    Note:  NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/info and enter the Info Code mshotfix for more information about Microsoft Hotfix 2588507.
    Note  Refer to NI-Digital Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Install Application Development Environments (ADEs), such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
    NI-Digital Pattern Driver and Digital Pattern Editor 20.6 support the following ADE versions:
    Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 20.6
    LabVIEW2017, 2018, 2019, and 2020 (32-bit and 64-bit)
    LabVIEW NXG5.1
    NI TestStand2016 and later (64-bit)
    NI TestStand Semiconductor Module™2016 and later (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)
    Note:  You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note:  You must install the NI-Sync driver to access NI-Sync-related functionality.
    If you are using the NI-Digital .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    NI installs the NI-Digital Pattern Driver and Digital Pattern Editor using NI Package Manager. If you do not already have NI software installed, the NI-Digital Pattern Driver and Digital Pattern Editor install NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI-Digital Pattern Driver and Digital Pattern Editor. For more information on NI-Digital Pattern Driver and Digital Pattern Editor activation, refer to NI Software Activation.
    Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following locations:
    • LabVIEW 2017 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    • LabVIEW NXG 3.0 and later—On the Diagram, Hardware Interfaces»NI-Digital palette
    .NET Class Library
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files (x86)\IVI Foundation\IVI\Bin\niDigital_32.dll for 32-bit development or to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    Refer to the What's New topics in the Digital Pattern Help for detailed information about new features and other changes in the NI-Digital Pattern Driver and Digital Pattern Editor. Refer to the What's New topics for previous versions of the NI-Digital Pattern Driver and Digital Pattern Editor in the Digital Pattern Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    The following list details the hardware models supported in NI-Digital 20.6:
    • PXIe-6570
    • PXIe-6571
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues.
    Documentation for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor is available from the Start menu by navigating to NI Digital Pattern Documentation in the National Instruments folder. The installed documentation set is composed of the following documents:
    • Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor Readme (this file)—Contains information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor, including where to go for support, supported hardware, system requirements, operating systems, known issues, and legal notices.
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    Digital Pattern Instrument manuals are available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Digital Pattern Instrument manuals include the following documents:
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6570 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    • PXIe-6571 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6571.
    Use the getting started examples, located by default in the <;Public Documents>\National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    LabVIEW Examples
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    The following sections detail considerations for using LabVIEW NXG with NI-Digital.
    LabVIEW NXG Hardware Support
    • PXIe-6570
    • PXIe-6571
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-Digital will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2015–2020 National Instruments Corporation. All rights reserved.
    376615H-01
    GMT+8, 2025-12-5 16:02
