查看: 3111|回复: 0
[NI驱动程序] NI-ATCA Driver 16.0 Win32/64Eng NI高级电信计算架构驱动程序16.0
    10 小时前
    发表于 2021-1-5 23:32:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-ATCA
    NI-ATCA为用户使用ATCA FPGA模块提供支持。
    NI-ATCA是NI的一个仪器驱动程序,可帮助您使用高级电信计算架构(ATCA)硬件创建LabVIEW FPGA应用程序。它包含LabVIEW VI、示例和产品文档。
    Win32/64Eng
    16.0
    文件大小: 2334111412 字节 (2.17 GB)
    修改日期: 2017-03-30 05:45
    MD5: f2964c03b55adedc5e2fd084ce1e3702(官方一致)
    SHA1: c8c41735291af8d44a003322ff54545b098c2027
    SHA256: a9a89ab6f86b697eca68d5f6be774823c8fb500ba12ba118e7e2f80d49d81b19
    CRC32: 12ff0e98
    ATCA16.0.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI ATCA FPGA Modules 16.0 Readme
    March 2017
    This file contains important information about NI ATCA FPGA Modules and is organized into the following sections:
    Uninstalling/Modifying NI ATCA FPGA Modules
    NI ATCA FPGA Modules 16.0 includes the following new features:
    • Support for LabVIEW 2016
    • Support for the following devices:
      • ATCA-3671 FPGA Module for ATCA
      • RTM-3661 PCI Express Rear Transition Module for ATCA
      • AIO-3681 Digitizer Module for FMC
      • AIO-3682 Signal Generator Module for FMC
      • AIO-3691 High-Speed Serial Adapter Module
    Note  NI ATCA FPGA Modules 16.0 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    Note  You should install an ADE, such as LabVIEW, before installing NI ATCA FPGA Modules. To add support for ADEs installed after installing NI ATCA FPGA Modules, modify your NI ATCA FPGA Modules installation or launch the NI ATCA FPGA Modules installer again.
    • LabVIEW 2016
      • (32-bit) Program Files\National Instruments\
      • (64-bit) Program Files (x86)\National Instruments\
    Item
    Installed Location
    NI ATCA FPGA Modules Examples\LabVIEW \examples\instr\ATCA
    The documentation set is composed of the following documents.
    Document
    Format
    Description
    Location
    NI ATCA FPGA Modules HelpHTML/Windows HelpContains primary help content for NI ATCA FPGA Modules products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI ATCA FPGA Modules
    • Hardware device information
    • A complete reference for all NI ATCA FPGA Modules programming functions and VIs
    Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Documentation
    Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.Available at ni.com/manuals
    Specifications for your devicePDFLists technical specifications for your device.Available at ni.com/manuals
    NI ATCA FPGA Modules 16.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Documentation
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI ATCA FPGA Modules examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI ATCA FPGA Modules and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»ATCA or by directory structure at instr»niDriver.
    • Click the Search tab to search all installed examples by keyword. For example, search for "ATCA" to locate all NI ATCA FPGA Modules examples.
    You can also access all the installed NI ATCA FPGA Modules examples for LabVIEW at Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Examples.
    • Select NI ATCA FPGA Modules 16.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI ATCA FPGA Modules 16.0 installation, the following software is installed. To completely remove the NI ATCA FPGA Modules 16.0 installation from your system, you must also remove all of the following packages:
    • FlexRIO 16.1 LabVIEW Support
    • FlexRIO Adapter Module Support 16.1.0
    • FlexRIO Runtime 16.1
    • NI ATCA FPGA Modules LabVIEW 2016 Support (32-bit)
    • NI ATCA FPGA Modules LabVIEW 2016 Support (64-bit)
    • NI ATCA FPGA Modules Runtime
    • NI Measurement & Automation Explorer 16.0.0
    • NI PXI Platform Services Runtime 16.0
    • NI System Configuration Runtime 16.0.0
    • NI Update Service 16.0
    • NI-RIO 16.0.1
    You can access the software and documentation known issues list online. Refer to the NI ATCA FPGA Modules 16.0 Known Issues at ni.com/info and enter the Info Code exw365 for an up-to-date list of known issues in NI ATCA FPGA Modules 16.0.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2017 National Instruments. All rights reserved.
    376642A-01
    GMT+8, 2025-12-8 20:15
