查看: 2918|回复: 0
[NI驱动程序] NI-ATCA Driver 18.0 Win32/64Eng NI高级电信计算架构驱动程序18.0
    10 小时前
    发表于 2021-1-5 23:33:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-ATCA
    NI-ATCA为用户使用ATCA FPGA模块提供支持。
    NI-ATCA是NI的一个仪器驱动程序,可帮助您使用高级电信计算架构(ATCA)硬件创建LabVIEW FPGA应用程序。它包含LabVIEW VI、示例和产品文档。
    Win32/64Eng
    18.0
    文件大小: 3289681328 字节 (3.06 GB)
    修改日期: 2018-09-08 04:26
    版本: 18.5.0.0
    MD5: e51369bc4735afe829cefd30d90ff96f(官方一致)
    SHA1: a0fcd5077cb2635bd4a696e22fe68f5e3bd0fa4e
    SHA256: 97ef79cdfbb7a9e066b5e5d6fa6f763cf9750b9557c5432686fcbcb274bd5496
    CRC32: d5e28997
    ATCA18.0.txt (624 Bytes, 下载次数: 0, 售价: 10 圆)
    NI ATCA FPGA Modules 18.0 Readme
    September 2018
    This file contains important information about NI ATCA FPGA Modules, including installation instructions, new features, and known issues.
    Uninstalling/Modifying NI ATCA FPGA Modules
    NI ATCA FPGA Modules 18.0 includes the following new features:
    • Support for LabVIEW 2018
    • Stand-alone ATCA deployment
    • Support for Vivado Project Export
    • Support for ChipScope debugging using JTAG
    • Usability enhancements and new examples
    NI ATCA FPGA Modules 16.0 includes the following new features:
    • Support for LabVIEW 2016
    • Support for the following devices:
      • ATCA-3671 FPGA Module for ATCA
      • RTM-3661 PCI Express Rear Transition Module for ATCA
      • AIO-3681 Digitizer Module for FMC
      • AIO-3682 Signal Generator Module for FMC
      • AIO-3691 High-Speed Serial Adapter Module
    • ATCA-3671
    • RTM-3661
    • AIO-3681
    • AIO-3682
    • AIO-3691
    NI ATCA FPGA Modules has the following requirements:
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2016 and 2018.
    NI ATCA FPGA Modules 18.0 supports Windows 10/8.11/7 SP12 (32-bit and 64-bit).
    Note  NI ATCA FPGA Modules 16.0 and later does not support Windows Server non-R2 editions.
    The following table lists the NI application software versions, including service packs, supported by NI ATCA FPGA Modules.
    NI Application Software
    Versions Supported by NI ATCA FPGA Modules
    NI LabVIEW2016, 2018
    LabVIEW FPGA Module™/CVI™2016, 2018
    Note  You should install an ADE, such as LabVIEW, before installing NI ATCA FPGA Modules. To add support for ADEs installed after installing NI ATCA FPGA Modules, modify your NI ATCA FPGA Modules installation or launch the NI ATCA FPGA Modules installer again.
    NI ATCA FPGA Modules palette VIs are available in LabVIEW from the Functions»Instrument I/O»Instr Drivers»ATCA palette.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI ATCA FPGA Modules examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI ATCA FPGA Modules and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»ATCA or by directory structure at instr»ATCA.
    • Click the Search tab to search all installed examples by keyword. For example, search for ATCA to locate all NI ATCA FPGA Modules examples.
    You can also access all the installed NI ATCA FPGA Modules examples for LabVIEW at Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Examples.
    Documentation for NI ATCA FPGA Modules is located at Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI ATCA FPGA Modules HelpHTML/Windows HelpContains primary help content for NI ATCA FPGA Modules products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI ATCA FPGA Modules
    • Hardware device information
    • A complete reference for all NI ATCA FPGA Modules programming functions and VIs
    ATCA-3671 Getting Started GuidePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    NI ATCA FPGA Modules 18.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Complete the following steps to install NI ATCA FPGA Modules.
    • Ensure that LabVIEW and LabVIEW FPGA are installed on your system.
    • Visit ni.com/info and enter Info Code atcadriver to access the driver download page for the latest NI ATCA FPGA Modules driver software.
    • Download the NI ATCA FPGA Modules driver software.
    • Follow the instructions in the installation prompts.
      Note  Windows users may see access and security messages during installation. Accept the prompts to complete installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
      • (32-bit) Program Files\National Instruments\
      • (64-bit) Program Files (x86)\National Instruments\
    Item
    Installed Location
    NI ATCA FPGA Modules Examples\LabVIEW \examples\instr\ATCA
    NI ATCA FPGA Modules Default CLIP Files\LabVIEW \Targets\NI\FPGA\ATCA\CLIP
    • Select NI ATCA FPGA Modules 18.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI ATCA FPGA Modules 18.0 installation, the following software is installed. To completely remove the NI ATCA FPGA Modules 18.0 installation from your system, you must also remove all of the following packages:
    • FlexRIO 18.0 LabVIEW Support
    • FlexRIO Adapter Module Support 18.0.0
    • FlexRIO Runtime 18.0
    • NI ATCA FPGA Modules LabVIEW 2018 Support (32-bit)
    • NI ATCA FPGA Modules LabVIEW 2018 Support (64-bit)
    • NI ATCA FPGA Modules LabVIEW 2016 Support (32-bit)
    • NI ATCA FPGA Modules LabVIEW 2016 Support (64-bit)
    • NI ATCA FPGA Modules Runtime
    • NI Measurement & Automation Explorer 18.0.0
    • NI PXI Platform Services Runtime 18.0
    • NI System Configuration Runtime 18.0.0
    • NI Update Service 17.0.1
    • NI-RIO 18.0.0
    You can access the software and documentation known issues list online. Refer to the NI ATCA FPGA Modules 18.0 Known Issues at ni.com/info and enter the Info Code exefik for an up-to-date list of known issues in NI ATCA FPGA Modules 18.0.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2017-2018 National Instruments. All rights reserved.
    376642B-01
    GMT+8, 2025-12-8 20:12
