查看: 3338|回复: 0
[NI驱动程序] NI-DMM 2.4.5 Driver Win32/64Eng NI数字万用表驱动程序2.4.5下载
    1 小时前
  • 签到天数: 3792 天
    连续签到: 43 天
    发表于 2021-1-14 23:09:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng
    2.4.5
    文件大小: 35608512 字节 (33.96 MB)
    修改日期: 2010-04-25 03:59
    MD5: 6703a3b9102bd84587a88ff1dac1bea0(官方正确)
    SHA1: 4aeea33ecaadab1cc4b0dc3749a11629e407e97f
    SHA256: b16bbcdc4aeb88f631c8522e71493f7c263a1983e9e5f282e42544ef989a059d
    CRC32: 97cf8536
    DMM2.4.5.txt (568 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-DMM Readme File
    Trademarks: CVI, FlexDMM, LabVIEW, Measurement Studio, National Instruments, ni.com, and NI-DMM are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    © Copyright 2005 National Instruments Corporation. All rights reserved.
    Version 2.4.5
    Thank you for using NI-DMM.
    This file contains important information about NI-DMM and is organized into the following sections:
    • New Features in NI-DMM 2.4.5
    • Supported Hardware
    • System Requirements
    • Installation Instructions
      • Software
      • Documentation
    • Uninstalling/Modifying NI-DMM 2.4.5
    • Examples
    • Obsolete VIs/Functions
    • Known Issues
    • Changes by Release
    • Support for the NI PXI-4071.
    • Introduction of the NI-DMM Express VI.
    • Support for NI SignalExpress 1.1.
    • Introduction of the niDMM Config Measurement VI and the niDMM_ConfigureMeasurementDigits and niDMM_ConfigureMeasurementAbsolute functions.
    NI-DMM 2.4.5 and later supports the following DMMs:
    • NI PXI-4072
    • NI PXI-4071
    • NI PXI-4070
    • NI PCI-4070
    • NI PXI-4060
    • NI PCI-4060
    • NI PCMCIA-4050
    System RequirementsMinimum System Requirements
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • Windows 2000/NT/XP, with all available critical updates and service packs
    Recommended System
    The performance of waveform acquisitions at full rate (1.8 MS/s) on the NI PXI-4070/4071/4072 depends highly on system-specific factors such as CPU speed, memory architecture, and system chipset characteristics. Simultaneous acquisitions on multiple NI PXI-4070/4071/4072 devices or acquisitions of longer durations may require a faster processor or more memory. Other applications running at the same time may also affect performance.
    • RAM—256 MB
    Application Development Environments
    • LabVIEW 7.0 or later (LabVIEW 7.1 or later is required to use the NI-DMM Express VI)
    • LabVIEW Real-Time Module 7.1
    • LabWindowsTM/CVITM 6.0 or later
    • Microsoft Visual Basic 6.0
    The NI-DMM 2.4.5 Web installation requires the following software components, which can be downloaded from ni.com:
    • NI-DAQ version 7.4 or higher.
    • NI-VISA or NI-VISA Run-Time Engine version 2.6.0 or higher.
    • IVI Compliance Package 2.0 or higher.
    • NI LabVIEW 7.1 Run-Time Engine.
    Installed File Names and LocationsSoftware
    ItemInstalled Location
    NI-DMMProgram Files\IVI\Drivers\niDMM
    DocumentationProgram Files\IVI\Drivers\niDMM\Documentation
    NI-DMM LabVIEW support\instr.lib\niDMM
    NI-DMM LabVIEW Examples\examples\instr\niDMM
    NI-DMM CVI 6.0 supportVXIpnp\WinNT\NIDMM
    NI-DMM CVI 7.0 supportProgram Files\IVI\Drivers\niDMM
    NI-DMM CVI Examples\samples\niDMM
    NI-DMM C/C++ Examples\VC\Examples\niDMM
    NI-DMM Measurement Studio 6.0 Examples\VC\Examples\niDMM
    NI-DMM Measurement Studio 7.0 Examples\VCNET\Examples\niDMM
    NI-DMM VB Examples\VB\Samples\niDMM
    DMM-SFP (Soft Front Panel)Program Files\IVI\Drivers\niDMM
    LabVIEW Run-Time Engine 7.1Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1
    NI-DAQ 7.3Program Files\National Instruments\NI-DAQ\
    IVI Compliance Package 2.1Program Files\National Instruments\IVI
    NI-VISA 3.2WINDOWS\system32
    Most documentation is available at Start籔rograms籒ational Instruments籒I-DMM籇ocumentation. The documentation set is composed of the following documents:
    NI-DMM Readme FileNI Digital Multimeters Getting Started Guide
    Printed and PDF format. Includes safety, hardware & software installation, configuration in MAX, and wiring for common measurements information.
    NI Digital Multimeters Help
    HTML help format. Inlcudes DMM fundamentals, device overviews, programming information, tutorials, LabVIEW reference, and C/C++/CVI/VB reference sections.
    NI-DMM Instrument Driver Quick Reference Guide
    Printed and PDF formats. Lists the VIs/functions, parameters, and parameter types available with NI-DMM 2.4.5.
    Specifications for the NI PCMCIA-4050Specifications for the NI PXI/PCI-4060NI 4070/4072 SpecificationsNI 4071 SpecificationsNI 4070/4072 61/2 Digit FlexDMM Calibration Procedure
    NI 4071 71/2—Digit FlexDMM Calibration ProcedureUninstalling/Modifying NI-DMM 2.4.5
    For Windows 2000/NT/XP, perform the following procedure to uninstall NI-DMM 2.4.5:
    • Open the Control Panel from the Start\Settings\Control Panel Menu and select Add\Remove Programs.
    • Select National Instruments Software from the list provided and click Change or Remove.
    • Select NI-DMM from the list provided and choose the appropriate action.
    Examples
    Refer to Start籔rograms籒ational Instruments籒I-DMM籈xamples for the examples for each ADE.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    A complete example list is available in the NI Digital Multimeters Help at Start籔rograms籒ational Instruments籒I-DMM籇ocumentation籒I Digital Multimeters Help.
    Any C and VB examples installed by a previous version of NI-DMM are copied to VXIpnp\WinNT\NIDMM\Examplesxx, where xx is the previous version number of NI-DMM. You can delete this directory if you do not need the old examples.
    The following functions are obsolete, and no maintenance is provided for these functions:
    Obsolete
    niDMM Calculate Accuracy
    niDMM Clear Error Info
    niDMM Get Error Info
    niDMM Configure Auto Zero Mode (LabVIEW only)
    • The default aperture times listed in the NI Digital Multimeters Help are incorrect for the NI PXI-4071 on the 100 V DC range.燭he correct values are 1.6 millisecond for 5½ digits and 50 microseconds for 4½ digits.
    • The recommended aperture times listed in the Maximizing DC Reading Rate examples are incorrect for the NI PXI-4071 on the 100 V DC range for 4½ and 5½ digits.
    • Upgrading from NI-DMM 1.5 to NI-DMM 2.3 on a Windows NT 4.0 system can result in one or more error messages. To completely install NI-DMM 2.3 on such a system, you must acknowledge these error messages by clicking the OK dialog boxes.
    • The IVI Configuration Store file format now requires that all names be case-sensitive. If you use logical names, driver session names, or virtual names in your program, make sure that the name you use matches the name defined in the IVI Configuration Store file exactly, without any variations in the case of the characters in the name.
    • The NI 4070/4071/4072 can be programmed only with NI-DMM. NI-DAQ function calls and DAQ virtual channels are not supported by the NI 4070/4071/4072. Using NI-DAQ with the NI 4070/4071/4072 can cause an error that requires a system reboot.
    • In MAX under the Configuring Device window for the NI 4070/4071/4072, Run Test Panels is grayed out.
    • In MAX under the Configuring Device window for the NI 4070/4071/4072, Test Resources always indicates that the device has passed the test regardless of the condition of the device.
    • If you are replacing the NI PXI-4060 with the NI PXI-4070/4071/4072 in an application that uses triggering, consider the following differences in behavior:
      • The NI 4060 configured as an SCXI controller automatically sets the Measurement Complete (MC) destination to the location where SCXI is configured (external or internal PXI/SCXI trigger lines).
      • The NI 4070/4071/4072 configured as an SCXI controller automatically sets the MC destination to NONE.
      If your application relies on the routing behavior of the NI 4060 by not explicitly calling niDMM Configure Measurement Complete Destination, you must modify your application by calling the VI/function. Alternately, the NI 4070/4071/4072 can emulate NI 4060 routing behavior by specifying the following registry key:
      HKEY_LOCAL_MACHINE\Software\National Instruments\NI-DMM\CurrentVersion\legacyMCRoute
      where the value is a DWORD set to 1.
      Without this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to NONE for the NI 4070/4071/4072. With this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to the location where SCXI communication is configured in the application.
    • There are known DLL collision issues with the Visual Basic debugger and National Instruments device drivers. A support DLL used by NI-DMM fails to load if Visual Basic has already loaded another DLL into the same address space. More information on this issue and solution are documented in KnowledgeBase entry 2Q1HG8A6. Refer to ni.com/support to access the KnowledgeBase.
    Changes by ReleaseChanges since NI-DMM 2.3
    • Support for the NI PXI-4071 has been added.
    Changes in NI-DMM 2.3 from NI-DMM 2.2
    • Support for the NI PXI-4072 has been added.
    • Support for the LabVIEW Real-Time Module has been added. For more information about using NI-DMM with the LabVIEW Real-Time Module, launch the NI Digital Multimeters Help and select Programming with NI-DMM»Getting Started»Using NI-DMM in LabVIEW»Considerations for Using the LabVIEW Real-Time Module.
    • Inclusion of Measurement Studio C++ interface to NI-DMM.
    Changes in NI-DMM 2.2 from NI-DMM 2.1
    • Support for the NI PCI-4070 has been added.
    • Support for the NI PXI/PCI-4070 devices to control an SCXI chassis that contains NI-DAQmx SCXI modules has been added (NI PXI/PCI-4070 only).
    • Support in MAX for the Self-Test and Self-Calibrate buttons for NI-DAQmx devices has been added (NI PXI/PCI-4070 only).
    • Support for the "break-on-library-error" feature in LabWindows/CVI (CVI user protection).
    • NI-DMM removes Offset Compensation Ohms capability for ranges 100 kΩ and greater.
    • NI-DMM corrects the resistance reference adjustment function of the external calibration procedure.
    Changes in NI-DMM 2.1 from NI-DMM 2.0
    • Self-test and simulation have been added for the NI PXI-4070.
    • The 1 MΩ input resistance value is no longer valid for DC voltage measurements on the NI PXI-4070.
    • AC voltage measurements using the DC coupling on the NI PXI-4070 have been improved to account for a computational error.
    • A new error code, NIDMM_ERROR_INVALID_MEAS_COMP_DEST has been created. This error is returned if an Input Trigger or Sample Trigger source is set to the same value as the Measurement Complete (MC) destination.
    • The self-calibration algorithm for the NI PXI-4070 has been updated to improve the gain correction.
    • Resistance measurements have been improved for low resolutions that enable both ADC calibration and offset compensated ohms.
    GMT+8, 2026-2-3 09:19
