查看: 3046|回复: 0
[NI驱动程序] NI-DMM 17.1 Driver Win32/64Eng NI数字万用表驱动程序17.1下载
    10 小时前
    发表于 2021-1-14 23:55:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    文件大小: 1891741576 字节 (1.76 GB)
    修改日期: 2017-12-07 03:25
    MD5: ba0f333ae2aa718f9d39479b4234e69f(官方正确)
    SHA1: cd1fd8df6fca24fa8c6af1362973ead3e28a7c4f
    SHA256: b981985b1128ff62094669ebf6bb0a81c57a38c94f437ab7a5d9c7459344fb45
    CRC32: 4f4ff15a
    DMM17.1.txt (573 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DMM 17.1 Readme
    July 2017
    This file contains important information about NI-DMM, including installation instructions, new features, a partial list of bugs fixed for NI-DMM 17.1, and known issues.
    NI-DMM is an NI instrument driver that communicates with all NI programmable digital multimeters (DMMs). NI-DMM is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the DMM and includes an interactive soft front panel and examples.
    System RequirementsMinimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DMM supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-DMM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DMM 17.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DMM 17.1 to an unsupported OS. Additionally, after installing NI-DMM 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DMM supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DMM
    LabVIEW2014 SP1, 2015 SP1, 2016, 2017
    LabVIEW Real-Time Module2014 SP1, 2015, 2016, 2017
    LabWindows™/CVI™2014 and later
    LabWindows/CVI Real-Time Module2014 and later
    If you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    NI-DMM 17.1:
    • Support for Auto Range while using digital or software triggers for the PXIe-4080, PXIe-4081, and PXIe-4082
    • Support for Auto Range ONCE (-3) and OFF (-2) for the PXIe-4080, PXIe-4081, and PXIe-4082
    NI-DMM 17.0:
    • Support for LabVIEW 2017 (32- and 64-bit)
    • Support for LabVIEW NXG 1.0
    NI-DMM 16.0:
    NI-DMM 15.2:
    • Support for the PXIe-4080, PXIe-4081, and PXIe-4082
    NI-DMM 15.1:
    • Support for debugging an NI-DMM device while in use by another application, by monitoring or controlling the device in the NI-DMM Soft Front Panel
      Note  NI-DMM 15.1 Soft Front Panel no longer supports IVI device simulation
    NI-DMM 14.0:
    • Support for LabVIEW 2014 (32- and 64-bit)
    The following list details the hardware models supported in NI-DMM 17.1.
    PXI Amplifier Module
    • PXI-4022
    PXI Digital Multimeter
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4072
    • PXI-4071
    • PXI-4070
    • PXI-4065
    Digital Multimeter Device
    • PCI-4070
    • PCIe-4065
    • PCI-4065
    • USB-4065
    The following items are changes in behavior for 15.2.
    • Express VIs are not supported with PXIe-408x hardware. For more information on differences between PXI-407x hardware and PXIe-408x hardware, visit ni.com/info and enter Info Code exbgsi.
    • The following triggers have been renamed in NI-DMM 15.2.
    NI-DMM C/CVI/VB Trigger Naming Changes[tr][/tr]
    Former nameNew name
    NIDMM_VAL_TTL0NIDMM_VAL_PXI_TRIG0
    NIDMM_VAL_TTL1NIDMM_VAL_PXI_TRIG1
    NIDMM_VAL_TTL2NIDMM_VAL_PXI_TRIG2
    NIDMM_VAL_TTL3NIDMM_VAL_PXI_TRIG3
    NIDMM_VAL_TTL4NIDMM_VAL_PXI_TRIG4
    NIDMM_VAL_TTL5NIDMM_VAL_PXI_TRIG5
    NIDMM_VAL_TLL6NIDMM_VAL_PXI_TRIG6
    NIDMM_VAL_TTL7NIDMM_VAL_PXI_TRIG7
    NIDMM_VAL_LBR_TRIG_0NIDMM_VAL_LBR_TRIG0
    NIDMM_VAL_LBR_TRIG_1NIDMM_VAL_LBR_TRIG1
    NIDMM_VAL_AUX_TRIG_1NIDMM_VAL_AUX_TRIG1
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DMM 17.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-DMM. This is not an exhaustive list of issues fixed in the current version of NI-DMM. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DMM 15.2 from NI-DMM 14.0.
    507445Fixed an issue in NI-DMM 14.0 where the Capacitance, Susceptance, Resistance, and Reactance attributes had incorrect IDs and wrote to the incorrect attributes in the NI-DMM property node. The attributes have been fixed with the correct IDs and now write to the correct attribute. The Susceptance and Resistance attributes were incorrectly set as integer types, producing an IVI_ERROR_TYPES_DO_NOT_MATCH error. The attributes have been fixed to doubles.
    Refer to the NI Digital Multimeters Help, accessible from the Start menu under National Instruments and NI-DMM Documentation, for information about NI-DMM.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DMM examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DMM examples) and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
    You can also access all the installed NI–DMM examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DMM»Examples.
    Examples also are available online that demonstrate NI-DMM functionality. Refer to ni.com/examples for these examples and for more information.
    NI-DMM no longer installs IVI Compliance Package. NI-DMM supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    The following sections detail considerations for using LabVIEW NXG with NI-DMM.
    LabVIEW NXG Hardware Support
    407x, 406x, and 4050 DMMs
    • PCI-4065
    • PCI-4070
    • PCIe-4065
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • USB-4065
    408x DMMs
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    Installing NI-DMM for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-DMM for LabVIEW NXG.
    • Click Download LabVIEW NXG 1.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 1.0 and NI-DMM.
    • Complete the installer instructions to download LabVIEW NXG 1.0 and NI-DMM.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2007–2017 National Instruments. All rights reserved.
    376310D-01
    GMT+8, 2025-12-8 19:46
