查看: 3537|回复: 0
[NI驱动程序] NI-DMM 19.5 Driver Win32/64Eng NI数字万用表驱动程序19.5下载
    10 小时前
    发表于 2021-1-15 00:06:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    19.5
    文件大小: 2091925504 字节 (1.95 GB)
    修改日期: 2019-10-25 22:30
    MD5: 26b2aa5d1b08eef9073782fca6018459(官方正确)
    SHA1: b8f978e7f609e3c22095338387c5827831f7d6e4
    SHA256: 79fcc8e878fe46769d369fcf65addb5e8c930accbae37b580f91c1372fbc1969
    CRC32: c2e93bd5
    DMM19.5.txt (598 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DMM 19.5 Readme
    September 2019
    This file contains important information about NI-DMM, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-DMM is an NI instrument driver that communicates with all NI programmable digital multimeters (DMMs). NI-DMM is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the DMM and includes an interactive soft front panel and examples.
    NI-DMM 19.5 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DMM 19.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-DMM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DMM 19.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DMM 19.5 to an unsupported OS. Additionally, after installing NI-DMM 19.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Refer to NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI-DMM 19.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DMM
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module2016, 2017, 2018, 2019
    LabVIEW NXG4.0
    LabWindows/CVI Real-Time Module2013 and later
    If you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DMM installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-DMM using NI Package Manager. If you do not already have NI software installed, NI-DMM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for NI-DMM 19.5.
    • Click NI-DMM 19.5 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    • NI-DMM 19.5 adds support for LabVIEW NXG 4.0.
    The following list details the hardware models supported in NI-DMM 19.5.
    PXI Amplifier Module
    • PXI-4022
    PXI Digital Multimeter
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4072
    • PXI-4071
    • PXI-4070
    • PXI-4065
    Digital Multimeter Device
    • PCI-4070
    • PCIe-4065
    • PCI-4065
    • USB-4065
    • NI-DMM 19.0 drops support for Traditional DAQ (NI-DAQ) and the PCI/PXI-4060 and DAQCard-4050 (PCMCIA-4050) digital multimeters.
    • NI-DMM 19.0 drops support for Express VIs in LabVIEW. Existing code created with earlier versions of NI-DMM and that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box.
      To reconfigure an Express VI, right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code that you can configure on the block diagram. NI recommends converting Express VIs to code before using the Code Conversion Utility in LabVIEW NXG to convert code for LabVIEW NXG.
    You can access the software and documentation known issues list online. Visit NI-DMM 19.5 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in NI-DMM. This is not an exhaustive list of issues fixed in the current version of NI-DMM. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DMM 19.1 from NI-DMM 19.0.
    726548Fixed an issue in which the PXIe‑4080, PXIe‑4081, and PXIe‑4082 could use an incorrect default value for the Settle Time property after setting the Range property to -3.0 (Auto Range Once).
    The following items are changes in NI-DMM 18.1 from NI-DMM 18.0.
    575369Fixed an issue affecting the PXIe‑4080, PXIe‑4081, and PXIe‑4082 that caused additional trigger latency in waveform mode.
    682078Fixed an issue affecting the PXI/PCI/PCIe/USB‑4065 when the Range property was set to Auto Range Once that caused the device to perform an autorange each time the Read or Initiate VIs were called rather than for only the first measurement of an acquisition.
    Refer to the NI Digital Multimeters Help, accessible from Start»All Programs»National Instruments»NI-DMM»NI-DMM Documentation, for information about NI-DMM.
    You can access all the installed NI-DMM examples at Start»All Programs»National Instruments»NI-DMM»NI-DMM Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DMM are located in the LabVIEW XXXX\examples\instr\niDMM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
    The following sections detail considerations for using LabVIEW NXG with NI-DMM.
    LabVIEW NXG Hardware Support
    407x, 406x, and 4050 DMMs
    • PCI-4065
    • PCI-4070
    • PCIe-4065
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • USB-4065
    408x DMMs
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-DMM no longer installs IVI Compliance Package. NI-DMM supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-DMM will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2007–2019 National Instruments. All rights reserved.
    376310L-01
    GMT+8, 2025-12-8 19:46
