查看: 3241|回复: 0
[NI软件产品] NI-FBUS Monitor Software 3.0.1 Win32/64Eng NI现场总线监控软件3.0.1
  • 签到天数: 3582 天
    连续签到: 2 天
    发表于 2021-1-15 23:56:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FBUS Monitor Software可帮助您使用现场总线接口设备调试、监测和分析现场总线(FBUS)数据通信。
    NI-FBUS Monitor Software是一款应用软件,可用于检测通信并捕获FBUS设备之间传递的数据包。使用此软件,您可以使用现场总线接口设备来诊断H1网络通信并进行设备开发调试。您还可以解码来自FBUS的数据包,监测实时列表并执行数据包分析。该软件还提供可配置的多窗口显示。NI-FBUS Monitor软件具有可配置的多窗口显示功能,您可以过滤数据包并实时查看列表和总线统计信息。
    Win32/64Eng
    3.0.1
    文件大小: 28964128 字节 (27.62 MB)
    修改日期: 2007-10-01 23:30
    MD5: f422bfd2080aab3f7c8d9c15900f605f
    SHA1: 5ad2db8b0c310e4e3281d59e6e066ee5d453c8e9
    SHA256: d27f9388b535ea226df1ba6c1c442a93bc11994f186ecee43fb4d1c9a847f58f
    CRC32: 67f2ba47
    FBUS监控软件3.0.1.txt (582 Bytes, 下载次数: 0, 售价: 10 元)
    NI-FBUS Monitor 3.0.1 Readme
    May 2007
    The NI-FBUS Monitor 3.0.1 is an update to the NI-FBUS Monitor 3.0. This file contains the following important information that you need to understand before using the NI-FBUS Monitor.
    Supported Platforms
    Installation Requirements
    Resources
    Supported Platforms
    The NI-FBUS Monitor supports Windows Vista, the 32-bit version; Windows XP Service Pack 2; and Windows 2000 Service Pack 4. The NI-FBUS Monitor does not support Windows Vista x64 Edition, the 64-bit version.
    To use the NI-FBUS Monitor, you must ensure that the computer meets the following minimum requirements:
    • Pentium III 600 MHz processor
    • 256 MB of RAM
    • 250 MB of free hard drive space
    If you want to achieve optimal performance of the NI-FBUS Monitor, National Instruments recommends the following configurations:
    • Pentium III 1.2 GHz processor
    • 512 MB of RAM
    • 400 MB of free hard drive space
    Complete the following steps to install the NI-FBUS Monitor.
    • Log in as an administrator or as a user with administrator privileges.
    • Insert the NI-FBUS Monitor installation CD and follow the instructions that appear on the screen.
      If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from the CD.
      The interactive setup program guides you through the necessary steps to install the NI-FBUS Monitor. You can go back and change values where appropriate by clicking the Back button. You can exit the setup by clicking the Cancel button.
    • Restart the computer when the setup is complete.
    Note: Install the NI-FBUS software before you install hardware such as the PCMCIA-FBUS, PCMCIA-FBUS Series 2, and PCI-FBUS/2 cards. Refer to the Installing the Hardware section of the NI-FBUS Hardware and Software User Manual for information about installing and configuring the NI-FBUS hardware. You can access this manual by opening the NI-FBUS HW SW Manual.pdf file in the National Instruments\NI-FBUS\Manual directory.
    If you have the NI-FBUS Monitor 3.0 installed on the computer, you do not need to uninstall that version before installing the NI-FBUS Monitor 3.0.1. If you have the NI-FBUS Monitor 2.2 or earlier installed on the computer, you first must uninstall that previous version from the computer before installing the NI-FBUS Monitor 3.0.1.
    If you have both the NI-FBUS Software 3.2 and the NI-FBUS Monitor 3.0 installed on the same computer, you must upgrade the existing software to the NI-FBUS Configurator 3.2.1 and NI-FBUS Monitor 3.0.1.
    Complete the following steps to upgrade the existing software:
    • Uninstall the NI-FBUS Monitor 3.0.
    • Upgrade the NI-FBUS Configurator from version 3.2 to version 3.2.1.
    • Install the NI-FBUS Monitor 3.0.
    • Upgrade the NI-FBUS Monitor from version 3.0 to version 3.0.1.
    Note: If you have both the NI-FBUS Monitor and the NI-FBUS Configurator installed on the same computer, uninstalling the NI-FBUS Monitor might cause the NI-FBUS Configurator not to work properly. To ensure that the NI-FBUS Configurator works properly, you must reinstall the NI-FBUS Configurator after uninstalling the NI-FBUS Monitor.
    (Windows Vista) If you uninstalled the NI-FBUS hardware from the computer and want to reinstall the hardware, the computer might fail to find the driver files for the hardware. To resolve this problem, manually install the driver files located in the National Instruments\NI-FBUS\Staging directory.
    The NI-FBUS Monitor 3.0.1 includes the following new features:
    • Support for Windows Vista, the 32-bit version
    • Some major inconvenience issues are fixed
    Refer to the Installation Guide for NI-FBUS for information about installing the National Instruments FOUNDATION Fieldbus hardware and software. You can find this document in the NI-FBUS Monitor CD kit.
    Refer to the NI-FBUS Monitor User Manual for information about using the NI-FBUS Monitor. You can find this document by navigating to Start»All Programs»National Instruments»NI-FBUS»Manuals»NI-FBUS Monitor User Manual.
    The NI-FBUS Monitor supports the following National Instruments hardware products:
    • PCI-FBUS/2
    • PCMCIA-FBUS
    • PCMCIA-FBUS/2
    • PCMCIA-FBUS Series 2
    • PCMCIA-FBUS/2 Series 2
    Resources
    Refer to the Fieldbus Foundation Web site for more information about FOUNDATION Fieldbus.
    Refer to the National Instruments Web site for more information about National Instruments FOUNDATION Fieldbus products.
    Send an email to fieldbus.support@ni.com for support with National Instruments FOUNDATION Fieldbus products.
    © 2007 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-2 11:28
