查看: 3170|回复: 0
[RTE运行引擎] NI-FGEN 14.0.0 Runtime Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序14.0.0运行版
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-17 23:32:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    Win32/64Eng/Jpn
    14.0RTE
    文件大小: 368898393 字节 (351.81 MB)
    修改日期: 2019-06-25 03:08
    MD5: 2e801a69a52b19837963792668e3d6e6(官方正确)
    SHA1: 7e4f58504bce7b2d84f5c0099a8bb88de234d30f
    SHA256: a5dcbb4c1449c4915b0c7b463200cf192774282fbf5bcad65f4625458705ce00
    CRC32: 344e4e2f
    FGEN14.0.0RTE.txt (596 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-FGEN Readme
    Version 14.0
    Thank you for using NI-FGEN. This file contains important information about NI-FGEN and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-FGEN
    Upgrading Firmware
    NI-FGEN 14.0 adds support for LabVIEW 2014 (32- and 64-bit).
    NI-FGEN 2.9.4 includes the following new features:
    • Enhanced support for filter group delay compensation for NI PXIe-5442 Rev D or higher.
    • Support for allowing I/Q rates up to 400 MS/s when using onboard signal processing mode on the NI PXIe-5450/5451.
    NI-FGEN 2.9.3 adds support for LabVIEW 2013 (32- and 64-bit).
    NI-FGEN 2.9.1 adds support for LabVIEW 2012 (32- and 64-bit).
    NI-FGEN 2.9 includes the following new features:
    • Support for streaming write timeout.
    • Improved I/Q rate reconfiguration time for the NI PXIe-5450 and NI PXIe-5451.
    • Support for including NI-FGEN run-time in custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI signal generators.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX), SignalExpress, or the FGEN Soft Front Panel.
      • The run-time installer does not support upgrading from NI-FGEN 2.8.x or earlier, or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-FGEN run-time installer.
      • The run-time installer does not support the NI 5401, NI 5411, or NI 5431.
    NI-FGEN 2.8.1 adds support for LabVIEW 2011 (32- and 64-bit).
    NI-FGEN 2.8 includes the following new features:
    • Support for peer-to-peer streaming with the NI PXIe-5450 (module revision C only) and NI PXIe-5451.
    • New firmware for the NI PXIe-5450 and NI PXIe-5451. This firmware upgrade is required for all NI PXIe-5450 and NI PXIe-5451 devices. Refer to Upgrading Firmware for more information about this new firmware.
    • Support to reset writeable attributes to driver default values. In C, call the niFgen_ResetAttribute function. In LabVIEW, right-click the niFgen Property Node, and select Change To»Default Value.
    • Support for stream n script instruction.
    The following table shows which hardware products are supported in this release under particular operating systems.
    Hardware ProductSupported Under
    Windows 8/7/Vista1
    Supported Under
    Windows XP1
    NI PXI/PCI-5401 Function Generator
    X2
    NI PXI/PCI-5402 Function Generator
    NI PXI-5404 Frequency Generator
    √3
    NI PXI/PCI-5406 Function Generator
    NI PXI/PCI-5411 Arbitrary Waveform Generator
    X2
    NI PXI/PCI-5412 Arbitrary Waveform Generator
    NI PXI/PCI-5421 Arbitrary Waveform Generator
    NI PXI-5422 Arbitrary Waveform Generator
    NI PXI/PCI-5431 Video Signal Generator
    X2
    NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5442 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5450 Dual-Channel I/Q Generator with Onboard Signal Processing
    NI PXIe–5451 Dual-Channel Arbitrary Waveform Generator with Onboard Signal Processing
    1 MXI Express and MXI-4 are supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    2Simulating these devices is also not supported on Windows 8/7/Vista, using either the NI-FGEN or the FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    3 Windows 8/7/Vista support for the NI 5404 does not include support for external calibration. Perform external calibration for the NI 5404 on Windows XP operating systems.
    Device-specific information about these signal generators is included in the NI Signal Generators Help.
    NI-FGEN 14.0 and later supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    Note  NI-FGEN 14.0 does not support Windows Server non-R2 editions.
    NI-FGEN 14.0 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows 8/7/Vista: 512 MB
      • Windows XP Service Pack 3 (SP3): 128 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows 8/7/Vista: 1 GB
      • Windows XP SP3: 256 MB
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-FGEN. To add support for ADEs installed after installing NI-FGEN, modify your NI-FGEN installation or launch the NI-FGEN installer again.
    • NI LabVIEW 2011 SP1 (32- and 64-bit), 2012 SP1 (32- and 64-bit), 2013 (32- and 64-bit), 2014 (32- and 64-bit)
    • NI LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013 SP1, or 2014 (no support for NI PXI/PCI-5401/5411/5431 devices)
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later (no support for NI PXI/PCI-5401/5411/5431 devices)
    • Measurement Studio 6.0 or later
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        If you upgraded an installation of IVI, your files may be in the following location:
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-FGEN\Drivers\niFgen
    NI-FGEN Function Panel\Drivers\niFgen\nifgen.fp
    NI-FGEN Examples\NI-FGEN\Examples
    NI-FGEN Header files\Include
    NI-FGEN Import Library files\Lib
    NI-FGEN DLL\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8/7 (64-bit)/Vista (64-bit)
    NI-FGEN Import Library files (64-bit)\Lib_x64
    NI-FGEN DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-FGEN to launch the NI-FGEN Soft Front Panel.
    Documentation is located at Start»All Programs»National Instruments»NI-FGEN»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Signal Generators HelpHTML/Windows HelpContains complete reference material for NI-FGEN products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-FGEN
    • Hardware device information
    • A complete reference for all NI-FGEN programming functions and VIs
    NI-FGEN ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI–FGEN palette VIs are available from the Functions»Measurement I/O»NI–FGEN palette.
    NI–FGEN functions are available in LabWindows/CVI from the Instrument menu. To load the NI–FGEN function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niFGEN\niFgen.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–FGEN examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all NI signal generator examples.
    You can also access all the installed NI–FGEN examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–FGEN»Examples.
    Examples also are available online that demonstrate integrating NI signal generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-FGEN versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-FGEN 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-FGEN 2.9.4. The first version released under the new numbering scheme is NI-FGEN 14.0.
    Perform the following procedure to uninstall NI-FGEN 14.0:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-FGEN 14.0 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Right-click the Start screen.
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    As part of the NI-FGEN 14.0 installation, the following list of software was installed. To completely remove NI-FGEN 14.0 from your system, you must remove all of these packages:
    • NI-FGEN Run-Time 14.0
    • NI Hierarchical Waveform Storage 14.0
    • NI Measurement & Automation Explorer 5.4
    • Traditional NI-DAQ 7.4.4 (Windows XP only)
    • NI-DAQmx 9.1.7
    • NI-VISA Run-Time 5.0
    • NI I/O Trace 3.0
    Upgrading Firmware
    The NI PXIe-5442, NI PXIe-5450, and NI PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    You can access the software and documentation known issues list online. Refer to the NI-FGEN 14.0 Known Issues List at ni.com for an up-to-date list of known issues in NI-FGEN 14.0.
    The following items are fixed in NI-FGEN 2.9.1 from NI-FGEN 2.9.
    Bug IDFixed Issue
    317520Fixed an issue in which an error occured when trying to build an installer in LabVIEW for an NI-FGEN 2.9 executable.
    The following items are fixed in NI-FGEN 2.9 from NI-FGEN 2.8.1.
    Bug IDFixed Issue
    242645Fixed an issue in which NI-FGEN does not report the correct error when LabVIEW FPGA 2010 is installed. You must install LabVIEW FPGA 2010 SP1 for this bug fix.
    240183Fixed an issue in which using dynamic FPGA interfaces in the LabVIEW FPGA Module were not supported when using peer-to-peer streaming. You must install NI-RIO 3.5.1 for this bug fix.
    280577Fixed an issue in which NI-FGEN returns an incorrect error description when an invalid session handle is passed into NI-FGEN VIs.
    314922Fixed an issue in which NI-FGEN returns an incorrect maximum waveform size after you call the niFgen Clear Arbitrary Memory VI on NI PXIe-5450 and NI PXIe-5451.
    313189Fixed an issue in which LabVIEW could crash when reading the Gain DAC Value property.
    N/AFixed an issue in which NI-FGEN could return an unrecoverable error when transitioning to the Committed state by calling the niFgen Commit VI, the niFgen_Commit function, or calling a create or write waveform VI or function. You must install NI-DAQmx 9.0 or later for this bug fix.
    The following items are fixed in NI-FGEN 2.8 from NI-FGEN 2.7.4.
    Bug IDFixed Issue
    241656Fixed firmware to synchronize power supplies for improved phase noise performance.
    199899Fixed an issue in which calling calibration utility functions in a normal NI-FGEN session affected output by disabling self-calibration constants.
    182502Fixed an issue in which running test panels for the NI PXIe-5450 and NI PXIe-5451 using the LabVIEW Real-Time Module did not write waveform data. This issue caused the output signal to be random.
    183093Fixed an issue in which waking from sleep mode could crash the operating system in some configurations, especially if the video, network, or other drivers were out of date.
    187791An issue was fixed in which LabVIEW 2009 (64-bit) could crash if you created more than one session using the same resource name. You must install LabVIEW 2009 SP1 (64-bit) for this bug fix.
    The following items are fixed in NI-FGEN 2.7.4 from NI-FGEN 2.7.3.
    Bug IDFixed Issue
    228650Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows/CVI, or NI TestStand does not deploy NI-FGEN or its dependent user applications on a 64-bit OS.
    The following items are fixed in NI-FGEN 2.7.3 from NI-FGEN 2.7.2.
    Bug IDFixed Issue
    229602Fixed an issue with clock configuration that can cause memory corruption or blue screen with certain NI PXIe-5450 devices.
    212209Fixed an incorrect calibration DAC setting that could cause self-calibration to fail on the NI PXIe-5451.
    The following items are fixed in NI-FGEN 2.7.2 from NI-FGEN 2.7.
    Bug IDFixed Issue
    209051Fixed an issue in which the installer did not stop service nidevldu before upgrading binaries.
    The following items are fixed in NI-FGEN 2.7 from NI-FGEN 2.6.3.
    Bug IDFixed Issue
    179935Fixed a streaming issue on the NI PXIe-5442/5450. Streaming with certain combinations of chassis and controllers caused the device to return an invalid thermal error and detach itself from the system. You must upgrade your firmware for this solution.
    157714Fixed a memory leak that occurred when a session was opened and closed dynamically using VI server on LabVIEW Real-Time targets.
    118345Toggle markers are now allowed below 200 MS/s sample rates on the NI PXIe-5450.
    39796An error is now returned when PXI_STAR is used as a trigger source for the NI PXIe-5442. This configuration is not supported.
    118500The NI PXIe-5450 now supports the Oscillator Phase DAC property and NIFGEN_ATTR_OSCILLATOR_PHASE_DAC_VALUE attribute for external Sample clocks.
    Using NI Launcher
    Finding All Programs
    NI-FGEN Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-FGEN will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-FGEN that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-6 09:12
