查看: 4116|回复: 0
[NI驱动程序] NI-FGEN 17.1.0 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序17.1.0
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-17 23:40:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    Win32/64Eng/Jpn
    17.1
    文件大小: 2215005834 字节 (2.06 GB)
    修改日期: 2017-05-17 03:35
    MD5: f8271c8e103a5c8724a3beb926d5f79b(重复一致)
    SHA1: 4288853f886d03b8ad0e9c031f704572afb589a2
    SHA256: ab381552ea0fb0ca85964a68ee22b1880ed595ad311f34c249bd378590944804
    CRC32: aead7f36
    FGEN17.1.0.txt (592 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN 17.1 Readme
    May 2017
    This file contains important information about NI-FGEN, including installation instructions, new features, a partial list of bugs fixed for NI-FGEN 17.1, and known issues.
    Upgrading Firmware
    NI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples.
    NI-FGEN has the following requirements:
    • Windows 10/8.1/7 with all available critical updates and service packs
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    NI-FGEN supports the following operating systems:
    Note  In 2016 NI-FGEN dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-FGEN 17.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-FGEN 17.1 to an unsupported OS. Additionally, after installing NI-FGEN 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-FGEN supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-FGEN
    LabVIEW2014, 2015, 2016, 2017
    LabVIEW Real-Time Module32014, 2015, 2016, 2017
    LabWindows™/CVI™2014 and later
    LabWindows™/CVI™ Real-Time Module32014 and later
    3No support for PXI/PCI-5401/5411/5431 devices.
    If you are using the NI-FGEN .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-FGEN .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    Installation InstructionsInstalling NI-FGEN for LabVIEW
    You can install all of your LabVIEW products—including NI-FGEN—using the LabVIEW 2017 Platform media.
    NI-FGEN no longer installs IVI Compliance Package. NI-FGEN supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    Upgrading Firmware
    The PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    • NI-FGEN 17.1 adds support for PXIe-5413, PXIe-5423, and PXIe-5433 waveform generators.
    The following list details the hardware models supported in NI-FGEN.
    [tr][/tr]
    Hardware ProductSupported Under Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)1
    NI-DAQmx-Based Waveform Generators
    PXI/PCI-5401
    X2
    X2
    PXI/PCI-5402
    PXI-5404
    √3
    √3
    PXI/PCI-5406
    PXI/PCI-5411
    X2
    X2
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI/PCI-5431
    X2
    X2
    PXIe–5413
    PXIe–5423
    PXIe–5433
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    NI 5413, 5423, and 5433 Waveform Generators
    PXIe–5413
    PXIe–5423
    PXIe–5433
    1 MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2Simulating these devices is also not supported on Windows 8.1/7, using either NI-FGEN or the FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    3 Windows 8.1/7 support for the PXI-5404 does not include support for external calibration. Perform external calibration for the PXI-5404 on Windows XP operating systems.
    You can access the software and documentation known issues list online. Refer to the NI-FGEN 17.1 Known Issues at ni.com/info and enter the Info Code the ex4f7h for an up-to-date list of known issues in NI-FGEN.
    The following items are the IDs and titles of a subset of issues fixed in NI-FGEN. This is not an exhaustive list of issues fixed in the current version of NI-FGEN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-FGEN 17.1 from NI-FGEN 17.0.
    626928Fixed an issue in which C examples failed to compile in Visual Studio 2015.
    The following items are changes in NI-FGEN 16.0.1 from NI-FGEN 16.0.
    585040Fixed an issue in which a timeout occurred in systems with a high number of PXI modules.
    Refer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»Documentation, for information about NI-FGEN.
    NI–FGEN examples are classified by keyword, so you can search for a particular device or measurement function.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all NI waveform generator examples.
    You can also access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples.
    Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the labview\examples\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2007–2017 National Instruments. All rights reserved.
    374945E-01
    GMT+8, 2025-12-6 09:12
