查看: 3320|回复: 0
[NI驱动程序] NI-FGEN 19.6.0 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序19.6.0
    10 小时前
    发表于 2021-1-17 23:56:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    Win32/64Eng/Jpn
    19.6
    文件大小: 2313611264 字节 (2.15 GB)
    修改日期: 2020-02-18 14:02
    MD5: 98bc696d3c7a6d7036db84a77a676dc3(官方正确)
    SHA1: 3faa8bbc4199162be5a7011e2dfb1ffe2cbc4951
    SHA256: 40612cb999070626273131858a0f486aeceeac086dc3c33d59b067aa2d1570cd
    CRC32: 47681e54
    FGEN19.6.0.txt (602 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN 19.6 Readme
    November 2019
    This file contains important information about NI-FGEN, including installation instructions, supported operating systems and application software, a partial list of bugs fixed, and known issues.
    Upgrading Firmware
    NI-FGEN Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples.
    NI-FGEN 19.6 has the following requirements:
    • Windows 10/8.1/7 with all available critical updates and service packs
    NI-FGEN 19.6 supports the following operating systems:
    Note  In 2016 NI-FGEN dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-FGEN 19.6 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-FGEN 19.6 to an unsupported OS. Additionally, after installing NI-FGEN 19.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to Why Does my NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    Note  Refer to NI-FGEN Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI-FGEN 19.6 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-FGEN
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module32016, 2017, 2018, 2019
    LabVIEW NXG4.0
    LabWindows™/CVI™ Real-Time Module32013 and later
    3No support for PXIe-5413/5423/5433 waveform generators.
    If you are using the NI-FGEN .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-FGEN .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-FGEN installer to install the the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-FGEN 19.6 using NI Package Manager. If you do not already have NI software installed, NI-FGEN 19.6 installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads/drivers and search for NI-FGEN.
    • Select 19.6 from the Version drop-down list and then click Download.
    • Run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    NI-FGEN no longer installs IVI Compliance Package (ICP). NI-FGEN supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    Upgrading Firmware
    The PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    The following list details the hardware models supported in NI-FGEN 19.6:
    Hardware ProductSupported Under Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)Supported Under Windows 10 (64-bit)1/8.1 (64-bit)1/7 (64-bit)1
    NI-DAQmx-Based Waveform Generators
    PXI/PCI-5402
    PXI-5404
    √2
    √2
    PXI/PCI-5406
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    NI 5413, 5423, and 5433 Waveform Generators
    PXIe–5413
    PXIe–5423
    PXIe–5433
    1 With 64-bit installations of Windows, InstrumentStudio is installed instead of an NI-FGEN soft front panel. Use InstrumentStudio to control and monitor your NI-FGEN device.
    2 Windows 8.1/7 support for the PXI-5404 does not include support for external calibration. Perform external calibration for the PXI-5404 on Windows XP operating systems.
    • NI-FGEN 19.0 drops support for Traditional DAQ (NI-DAQ) and the PCI/PXI-5401, PCI/PXI-5411, and PCI/PXI-5431 waveform generators.
    • NI-FGEN 19.0 drops support for Express VIs in LabVIEW. Existing code created with earlier versions of NI-FGEN and that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box.
      To reconfigure an Express VI, right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code that you can configure on the block diagram. NI recommends converting Express VIs to code before using the Code Conversion Utility in LabVIEW NXG to convert code for LabVIEW NXG.
    You can access the software and documentation known issues list online. Visit NI-FGEN 19.6 Known Issues for an up-to-date list of known issues in NI-FGEN 19.6.
    The following items are the IDs and titles of a subset of issues fixed in NI-FGEN. This is not an exhaustive list of issues fixed in the current version of NI-FGEN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-FGEN 18.1.1 from NI-FGEN 18.1.
    26171Fixed an issue in which PXIe-5413/5423/5433 analog output settings were not reset to a known state of outputting 0 V after device reset.
    The following items are changes in NI-FGEN 18.1 from NI-FGEN 18.0.
    686813A clocking problem intermittently caused markers to be misaligned on PXIe-5413/5423/5433 waveform generators after reboot.
    678387Calling Clear User Waveform on channel 1 of a PXIe-5413/5423/5433 waveform generator caused LabVIEW or the NI-FGEN Soft Front Panel to crash.
    643170Calling NI-FGEN Get Hardware State on PXIe-5413/5423/5433 waveform generators returned an error (-1074135023).
    658865NI-FGEN returned an error (-1074135024) when using Arbitrary Waveform output mode if the Standard Function attribute for DC Offset was set to anything other than 0.
    434355Querying current temperature of an NI-DAQmx-based waveform generator using the System Configuration API resulted in memory leakage.
    645379The clocking status of PXIe-5413/5423/5433 waveform generators was not checked with NI-FGEN Commit, Initiate Generation, Is Done, or Abort calls.
    648798An empty string was returned for the invalid session handle error.
    660993The C prototype documentation for the niFgen_InitializeWithChannels function incorrectly listed parameters.
    Refer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Documentation, for information about NI-FGEN.
    You can access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples and online at ni.com/examples. Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the LabVIEW XXXX\examples\instr\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all waveform generator examples.
    The following sections detail considerations for using LabVIEW NXG with NI-FGEN.
    LabVIEW NXG Hardware Support[tr][/tr]
    Hardware ProductSupported Under Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)
    PXI/PCI-5402
    PXI-5404
    √1
    PXI/PCI-5406
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    PXIe–5413
    PXIe–5423
    PXIe–5433
    1 External calibration of this module is not supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-FGEN will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2007–2019 National Instruments. All rights reserved.
    374945U-01
    GMT+8, 2025-12-8 19:47
