查看: 3077|回复: 0
[NI驱动程序] NI-HSDIO 1.2.1 Driver Win32Eng NI高速数字输入输出仪器驱动程序1.2.1
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
    发表于 2021-1-18 23:48:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32Eng
    1.2.1
    文件大小: 38526464 字节 (36.74 MB)
    修改日期: 2010-04-25 02:58
    MD5: c13cc0a5e4d2d72d5c9138a5b153f7ef(官方正确)
    SHA1: 1342de6e8c438114217b1b64a4d88e74e96aaae3
    SHA256: 64c3280c8a3933fe3bd5f96eca7be59ff6299943f4108ced68ea534598b5cedd
    CRC32: d3fd9429
    HSDIO1.2.1.txt (550 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-HSDIO Instrument Driver Readme
    IVI™, CVI™, LabVIEW™, Measurement Studio™, National Instruments™, ni.com™, NI-DAQ™, NI-VISA™, and RTSI™ are trademarks of National Instruments Corporation.
    Product and company names mentioned herein are trademarks or trade names of their respective companies.
    (c) 2003—2004 National Instruments Corporation. All rights reserved.
    Version 1.2.1
    Thank you for using NI-HSDIO for Windows 2000/NT 4.0/XP. This file contains important information regarding NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Software Files
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    NI-HSDIO 1.2.1 includes the following new features:
    • Support for the LabVIEW Real-Time Module 7.1. For more information about using NI-HSDIO with the LabVIEW Real-Time Module, launch the NI Digital Waveform Generator Help and select Programming»Getting Started with NI-HSDIO»Using NI-HSDIO with LabVIEW»Considerations for using the LabVIEW Real-Time Module.
    • Initializing a generation or acquisition session now closes any other sessions open in the same process, starting a fresh session. If a calibration session is open, all new sessions will return an error.
    • Removed support for exporting triggers and events other than the Onboard Reference Clock (PCI devices only) to PXI trigger line 7/RTSI 7, although you can still use this channel to import triggers and events.
    NI-HSDIO 1.2 includes the following new features:
    • Support for LabVIEW 7.1
    • Acquisition and Generation Express VIs for NI-HSDIO (LabVIEW 7.1 only).
    • Support for NI 654X products
    • Support for multiple script triggers
    • Support for multiple markers
    • Support for performing pattern match triggering on a specifed edge
    • Additional functions and VIs for voltage calibration
    • Modified fetching behavior
    • Removed support for saving HWS files as a waveform data type then reading them back in U32 format
    NI-HSDIO supports the following NI digital waveform generator/analyzers:
    • NI PXI/PCI-6551
    • NI PXI/PCI-6552
    • NI PXI/PCI-6541
    • NI PXI/PCI-6542
    Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    Minimum System Requirements
    • Processor: Pentium 200 MHz or equivalent
    • RAM: 64 MB
    • A screen resolution of 800×600 with 256 colors (required for the NI Script Editor)
    Recommended System
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM: 256 MB
      • Windows 2000
      • Windows NT 4.0 Service Pack 6a
      • Windows XP
    • One of the following application development environments (ADEs):
      • LabVIEW 7.0 or later (Express VIs for NI-HSDIO LabVIEW 7.1 or later only)
      • LabVIEW Real-Time Module 7.1
      • LabWindowsTM/CVITM 6.0 or later
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    Installed File Names and LocationsSoftware Files
    Most NI-HSDIO files are installed in the <;Program Files>\IVI\Drivers\niHSDIO\ directory.
    The niHSDIO folder contains the documentation, examples, license files, and FPGA files for NI-HSDIO and the associated hardware.
    The niHSDIO\Examples\ directory contains links to all of the examples.
    LabVIEW examples are installed in the \examples\instr\niHSDIO\ directory unless you select a different location during installation.
    LabWindows™/CVI™ examples are installed in the \samples\niHSDIO\ directory.
    C examples are installed in the <;Program Files>\IVI\Drivers\niHSDIO\Examples\c\ directory.
    The Script Editor is installed in the /Script Editor directory.
    Product Documentation
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals to find the latest versions of product documentation. The documentation for NI-HSDIO and NI  Digital Waveform Generator/Analyzer modules include the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide–Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help–Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • NI 655x Specifications–Contains specifications for the capabilities and valid operating conditions of NI 655x devices.
    Uninstalling/Modifying the Instrument Driver
    For Windows 2000/NT/XP, complete the following steps:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change or Modify.
    • Select NI-HSDIO 1.2.1.
    • Click Uninstall.
    As part of the NI-HSDIO installation, the following list of software was installed. To completely remove NI-HSDIO from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 2.1.2
    • NI LabVIEW Run-Time Engine 7.0
    • NI Measurement & Automation Explorer 3.1
    • NI-DAQ 7.3
    • NI-SWITCH 2.3
    • NI-VISA 3.1
    The MAX test panel for NI 655X devices allows voltage ranges between -0.5 V and 5.5 V. The device is capable of voltage ranges between -2.0 V and 5.5 V (with frequency restrictions). The full voltage range of the device is supported in the NI-HSDIO API.
    Note  Review the specifications document at Start» Programs»National Instruments»NI-HSDIO»Documentation to ensure that the clock and trigger signals you connect to the instrument meet the amplitude, jitter, and duty cycle requirements of your device.
    GMT+8, 2025-9-10 05:04
