查看: 2889|回复: 0
[NI驱动程序] NI-HSDIO 1.5.2 Driver Win32/62Eng NI高速数字输入输出仪器驱动程序1.5.2(DCD Aug07)
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
    发表于 2021-1-18 23:57:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng
    1.5.2
    文件大小: 1655894676 字节 (1.54 GB)
    修改日期: 2019-06-25 03:09
    MD5: f1a6520de9ada19b63875b2de89b785a(官方正确)
    SHA1: e2bb7c56cc9d09c352c4a623e499079604edc989
    SHA256: bc75520f96a8e801dd4ef6702b0b47c726b9f25ffb842eab5b50a3416bc7c769
    CRC32: 75aeca1f
    HSDIO1.5.2.txt (556 Bytes, 下载次数: 0, 售价: 20 圆)
    NI-HSDIO Instrument Driver Readme
    Version 1.5.2
    June 2007
    Thank you for using NI-HSDIO for Windows Vista/XP/2000. This file contains important information regarding NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    NI-HSDIO 1.5.2 adds support for LabVIEW 8.5
    NI-HSDIO 1.5.1 includes the following new features:
    • Bug fixes for the NI-HSDIO SignalExpress steps and niHSDIO Express VIs
    NI-HSDIO 1.5 includes the following new features:
    • Support for streaming waveforms and Direct DMA
    • NI-HSDIO Stimulus/Response express step and integration with NI LabVIEW SignalExpress 2.0
    • Support for generating waveforms using the NI Digital Waveform Editor and NI LabVIEW SignalExpress 2.0
    • Support for Windows Vista. For more information about Microsoft Windows Vista and NI products, refer to ni.com/vista.
    • Support for LabVIEW 8.2.1
    NI-HSDIO 1.4.3 adds support for LabVIEW 8.2.
    NI-HSDIO 1.4 includes the following new features:
    • Support for open collector generation on the NI 654X/655X devices
    • Support for per cycle, per pin tristate for NI 655X devices
    • Addition of real-time hardware comparison of actual response data with expected resposne data. For more information on this feature, visit ni.com/info and enter the info code nsi5410
    • Support for using the waveform data type (WDT) in C application development environments
    • Addition of an "if/else/end if" instruction in the supported scripting language
    • Addition of the niHSDIO_WriteNamedWaveformFromFileHWS function and a Write from HWS File instance of the niHSDIO Write Named Waveform VI
    • Changes to the possible values of input impedance for NI 655X devices; refer to device specifications for details
    • Changes to recommended input voltage thresholds; refer to device specifications for details
    NI-HSDIO supports the following NI digital waveform generator/analyzers:
    • NI PXI/PCI-6541
    • NI PXI/PCI-6542
    • NI PXI/PCI-6551
    • NI PXI/PCI-6552
    • NI PXI/PCI-6561
    • NI PXI/PCI-6562
    Note:  If you are using a PXI product, notice that MXI-4 is supported on Windows Vista/XP/2000, but MXI-3 is supported on only Windows XP/2000.
    Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    Minimum System Requirements
    • Processor: Pentium 200 MHz or equivalent
    • RAM: 64 MB
    • A screen resolution of 800×600 with 256 colors (required for the NI Script Editor)
    Recommended System
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM: 256 MB
      • Windows Vista
      • Windows XP
      • Windows 2000
    • One of the following application development environments (ADEs):
      • LabVIEW  7.1, 8.0, 8.2, 8.2.1, or 8.5
      • LabVIEW Real-Time Module 7.1.1 or later
      • LabWindows™/CVI™ 7.1, 8.0, or 8.2
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    FilesInstallation Location on Windows XP/2000 and
    Windows Vista (32-bit version)
    Installation Location on Windows Vista x64 Edition (64-bit version)
    VIsProgram Files\National Instruments\\instr.lib\niHSDIOProgram Files (x86)\National Instruments\\instr.lib\niHSDIO
    LabVIEW ExamplesProgram Files\National Instruments\\examples\instr\niHSDIOProgram Files (x86)\National Instruments\\examples\instr\niHSDIO
    C ExamplesProgram Files\IVI\Drivers\niHSDIO\Examples\cProgram Files (x86)\IVI\Drivers\niHSDIO\Examples\c
    CVI ExamplesProgram Files\National Instruments\\samples\niHSDIOProgram Files (x86)\National Instruments\\samples\niHSDIO
    Documentation FilesProgram Files\IVI\Drivers\niHSDIO\DocumentationProgram Files (x86)\IVI\Drivers\niHSDIO\Documentation
    Script EditorProgram Files\National Instruments\Script EditorProgram Files (x86)\National Instruments\Script Editor
    Product Documentation
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI  Digital Waveform Generator/Analyzer modules include the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide–Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help–Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • Specifications document for your device–Contains specifications for the capabilities and valid operating conditions of your NI device.
    Uninstalling/Modifying the Instrument Driver
    For Windows 2000/XP, complete the following steps:
    • Click Change/Remove.
    • Select NI-HSDIO 1.5.2 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    As part of the NI-HSDIO installation, the following list of software was installed. To completely remove NI-HSDIO from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 3.1
    • NI LabVIEW Run-Time Engine 7.1.1
    • NI Measurement & Automation Explorer 4.3
    • NI-DAQ 8.6
    • NI-VISA 4.2
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • If for some reason you need to downgrade from NI-HSDIO 1.5 to a previous version of NI-HSDIO, the MAX data store may become corrupted. Refer to Knowledgebase 3L9AK06E for information about how to resolve this issue. To access this Knowledgebase entry, visit ni.com/zone, and type 3L9AK06E in the Search KnowledgeBase Documents textbox.
    • When using NI-HSDIO 1.4 with the LabVIEW Real-Time Module, the text of some error descriptions are not returned by NI-HSDIO. Error codes that are returned are returned correctly. Refer to Knowledgebase 3OOFLT0Q for information about how to resolve this issue.
    • NI-HSDIO Express steps in NI Signal Express 1.0—The NI-HSDIO Express steps that ship with NI-HSDIO 1.3.1 were designed for use with NI SignalExpress 1.1 or later. The NI-HSDIO Express steps are compatible with NI SignalExpress 1.0 with the exception that software start triggers are not supported.
    • Review the specifications document at Start» Programs»National Instruments»NI-HSDIO»Documentation to ensure that the clock and trigger signals you connect to the instrument meet the amplitude, jitter, and duty cycle requirements of your device.
    © 2003–2007 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-9-10 05:00
