查看: 2683|回复: 0
[NI驱动程序] NI-HSDIO 1.6.1 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序1.6.1(DCD Aug09)
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2021-1-19 00:03:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    1.6.1
    文件大小: 234713088 字节 (223.84 MB)
    修改日期: 2020-12-14 02:10
    MD5: 7d39c504fc89f368057e1303f12d4ce8
    SHA1: c2a7144bc42c0ec9714dc3867293b5f4202edcfd
    SHA256: 572b56afed4d1a6de821674d7df8b25cc48420c5d4ab5387dae919acd4d4f0c9
    CRC32: f5eba52a
    HSDIO1.6.1.txt (1.09 KB, 下载次数: 0, 售价: 20 元)
    NI-HSDIO Instrument Driver Readme
    Version 1.6.1
    Thank you for using NI-HSDIO for Windows Vista/XP/2000. This file contains important information regarding NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    • Bug Fixes
    NI-HSDIO 1.6.1 includes the following new features:
    • Support for LabVIEW 2009 (32-bit)
    • Support removed for LabVIEW 7.1.1
    NI-HSDIO 1.6 includes the following new features:
    • Support for the NI 6544/6545/6547/6548 devices
    • Added localized Japanese software and documentation
    • Desktop PC support for the LabVIEW Real-Time Module
    • Support for detecting NI Modular Instrument devices in LabWindowsTM/CVITM
    • Support to continuously stream data while using the Pause trigger
    • New source synchronous acquisition and generation examples for LabVIEW and LabWindows/CVI
    • Added fetch optimizations for NI-HSDIO dynamic acquisitions
    • Support for generation Stop trigger
    NI-HSDIO 1.5.4 includes the following new features:
    • Support for LabVIEW 8.6
    • Support was removed for LabVIEW 8.0
    NI-HSDIO 1.5.3 includes the following new features:
    • Support for acquiring up to 2,147,483,647 records
    NI-HSDIO 1.5.2 adds support for LabVIEW 8.5
    NI-HSDIO 1.5.1 includes the following new features:
    • Bug fixes for the NI-HSDIO SignalExpress steps and niHSDIO Express VIs
    NI-HSDIO 1.5 includes the following new features:
    • Support for streaming waveforms and Direct DMA
    • NI-HSDIO Stimulus/Response express step and integration with NI LabVIEW SignalExpress 2.0
    • Support for generating waveforms using the NI Digital Waveform Editor and NI LabVIEW SignalExpress 2.0
    • Support for Windows Vista. For more information about Microsoft Windows Vista and NI products, refer to ni.com/vista.
    • Support for LabVIEW 8.2.1
    NI-HSDIO 1.4.3 adds support for LabVIEW 8.2.
    NI-HSDIO 1.4 includes the following new features:
    • Support for open collector generation on the NI 6541/6542/655x devices
    • Support for per cycle, per pin tristate for NI 655x devices
    • Addition of real-time hardware comparison of actual response data with expected response data.
    • Support for using the waveform data type (WDT) in C application development environments
    • Addition of an "if/else/end if" instruction in the supported scripting language
    • Addition of the niHSDIO_WriteNamedWaveformFromFileHWS function and a Write from HWS File instance of the niHSDIO Write Named Waveform VI
    • Changes to the possible values of input impedance for NI 655x devices; refer to device specifications for details
    • Changes to recommended input voltage thresholds; refer to device specifications for details
    NI-HSDIO supports the following NI digital waveform generator/analyzers:
    • NI PXI/PCI-6541
    • NI PXI/PCI-6542
    • NI PXIe-6544
    • NI PXIe-6545
    • NI PXIe-6547
    • NI PXIe-6548
    • NI PXI/PCI-6551
    • NI PXI/PCI-6552
    • NI PXI/PCI-6561
    • NI PXI/PCI-6562
    Note:  If you are using a PXI product, notice that MXI-4 is supported on Windows Vista/XP/2000, but MXI-3 is supported only on Windows XP/2000.
    Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    This section lists the minimum system and the recommended system for using NI-HSDIO.
    Minimum System Requirements
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM:
      • Windows 2000/XP: 128 MB
      • Windows Vista: 512 MB
    • Windows Vista/XP/2000, with all available critical updates and service packs
    Recommended System
    • Processor: Pentium 4 or equivalent
    • RAM:
      • Windows 2000/XP: 256 MB
      • Windows Vista: 1 GB
    • One of the following application development environments (ADEs):
      • LabVIEW 8.2.1, 8.5.1, 8.6.1, or 2009 (32-bit)
      • LabVIEW Real-Time Module 8.2.1, or later
      • LabWindows™/CVI™ 7.1, or later
      • LabWindows/CVI Real-Time Module 8.0 or later
    • If you are running your application on a RT target, 128 MB of memory or more is required.
    FilesInstallation Location on Windows XP/2000 and
    Windows Vista (32-bit version)
    Installation Location on Windows Vista x64 Edition (64-bit version)
    VIsProgram Files\National Instruments\\instr.lib\niHSDIOProgram Files (x86)\National Instruments\\instr.lib\niHSDIO
    LabVIEW ExamplesProgram Files\National Instruments\\examples\instr\niHSDIOProgram Files (x86)\National Instruments\\examples\instr\niHSDIO
    C ExamplesProgram Files\IVI\Drivers\niHSDIO\Examples\cProgram Files (x86)\IVI\Drivers\niHSDIO\Examples\c
    LabWindows/CVI ExamplesProgram Files\National Instruments\\samples\niHSDIOProgram Files (x86)\National Instruments\\samples\niHSDIO
    Documentation FilesProgram Files\IVI\Drivers\niHSDIO\DocumentationProgram Files (x86)\IVI\Drivers\niHSDIO\Documentation
    Script EditorProgram Files\National Instruments\Script EditorProgram Files (x86)\National Instruments\Script Editor
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI  Digital Waveform Generator/Analyzer modules include the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide—Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help—Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device.
    Uninstalling/Modifying the Instrument Driver
    For Windows 2000/XP, complete the following steps:
    • Click Change/Remove.
    • Select NI-HSDIO 1.6.1 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    As part of the NI-HSDIO installation, the following list of software was installed. To completely remove NI-HSDIO from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.0
    • NI Measurement & Automation Explorer 4.6
    • NI-DAQ 8.9.5
    • NI-VISA 4.5
    • NI Spy 2.7
    • When linking to a topic in the NI Digital Waveform Generator/Analyzer Help from the context help or opening the help file from a VI within LabVIEW, the NI Digital Waveform Generator/Analyzer Help launches and the relevant topic displays, but the location of the topic might not be highlighted in the table of contents.
    • If you click a topic link in the C/C++ Reference section of the NI Digital Waveform Generator/Analyzer Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • For the NI PXIe-6544/6545/6547/6548, internal error -219001 may occur intermittently when synchronizing multiple acquisitions using NI-TClk at rates below 5 MHz. If this error occurs, consider oversampling by configuring your acquisition with a higher sample rate.
    • In rare cases, the NI PXIe-6544/6545/6547/6548 may not utilize the full bandwidth of the PXI Express bus. These modules are x4 PXI Express devices, which are capable of using up to four 2.5 Gbps bus data lanes. Start-time negotiation between the PXI Express controller and the device may result in the device using only one or two data lanes. The result is reduced performance when reading or writing large amounts of waveform data. This situation is normally corrected the next time you restart your system. For more information, visit ni.com/kb and enter the code 4X4A86ZD.
    • NI-HSDIO generates an error with an unknown status code when allocating streaming waveforms with sizes that are not 128-byte aligned.
    • Multiple devices that are synchronized with NI-TClk and that use external clocks must all use the same clock rate.
    • The acquisition Advance trigger is not NI-TClk synchronized.
    • Attempting to generate or acquire data in SDR mode on channels 16 to 31 with a data width of 2 returns an error.
    • Clicking hyperlinks inside the context help windows of the NI-HSDIO function panel produces errors. To access the relevant function reference documentation, open the NI Digital Waveform Generator/Analyzer Help and navigate to Programming» Reference» C/C++ Reference.
    • NI-HSDIO devices might not be visible in Measurement & Automation Explorer (MAX) when deploying to a LabVIEW Real-Time target. For more information, search ni.com/kb using the code 4RCAMBD4.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any NI-HSDIO operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • The NI-HSDIO Express steps that ship with NI-HSDIO 1.6 were designed for use with NI SignalExpress 1.1 or later. The NI-HSDIO Express steps are compatible with NI SignalExpress 1.0 with the exception that software Start triggers are not supported.
    • For the NI 6544/6545/6547/6548, the Configure Sample Clock VI requires an input clock rate. If you are using NI-HSDIO 1.5.4 or earlier and did not provide this input, you will automatically have a constant (50 MHz) wired into the input.
    • The error and self-test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    • Review the specifications document at Start» Programs»National Instruments»NI-HSDIO»Documentation to ensure that the clock and trigger signals you connect to the instrument meet the amplitude, jitter, and duty cycle requirements of your device.
    The following items are the IDs and titles of a subset of issues fixed between NI–HSDIO 1.5.4 and NI–HSDIO 1.6. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
    62395Fixed an issue in which the NI 6561/6562 incorrectly returns all zeros or ones when the data width is set to 1 byte.
    61846Fixed an issue in which changing the frequency of an external clock on an NI 6552 device causes an error.
    58841Fixed an error in which the niHSDIO Initialize VI took a long time to assert on NI 6541/6542 devices.
    56467The niHSDIO Initialize VI and the niHSDIO Close VI are now re-entrant.
    55321Fixed a Test Panel issue in which the plot did not display the first sample on Ch0.
    © 2003–2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-2 08:30
