查看: 3329|回复: 0
[NI驱动程序] NI-HSDIO 2.0 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序2.0
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2021-1-19 00:14:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    2.0
    文件大小: 1990860267 字节 (1.85 GB)
    修改日期: 2014-11-06 06:43
    MD5: ea7c9461d0cb45080290fb16f0e00489(官方正确)
    SHA1: 318e8ee31383ed548f58415b78d2897b5ead1601
    SHA256: d34b80571e2b73ced5775f8a67373bb3490832e682e3396808401f5103b1cd57
    CRC32: 9f6565c5
    HSDIO2.0.txt (573 Bytes, 下载次数: 0, 售价: 10 元)
    NI-HSDIO Readme
    Version 2.0
    Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Updates and Notifications
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    • Bug Fixes
    NI-HSDIO 2.0 includes the following new features:
    • Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
    • New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
      • Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
      • Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
    • Support for NI-HSDIO run-time custom installers built using NI application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI digital waveform generator/analyzers.
      Notes:
      The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      The run-time installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Run-Time installer.
    NI-HSDIO 1.9 includes the following new features:
    • Support for NI PXIe-6555 devices.
    NI-HSDIO 1.8.3 includes the following new features:
    • Support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
    NI-HSDIO 1.8.1 includes the following new features:
    • Support for NI PXIe-6556 devices.
    • Support for PPMU force and sense functionality.
    NI-HSDIO 1.7.5 includes the following new features:
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    NI-HSDIO 1.7.3 includes the following new features:
    • Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    NI-HSDIO 1.7.1 includes the following new features:
    • Fixed fatal issue when upgrading NI-HSDIO on Windows 7 (64-bit) and Windows Server 2008 R2.
    NI-HSDIO 1.7 includes the following new features:
    • Support for LabVIEW 2009 (64-bit).
    • Support for 64-bit user mode.
    • Support for multibank data delay on NI 6547/6548 devices only.
    • Additional support for hardware comparison on NI 6547/6548 devices.
    • Additional support for per pin, per cycle tristate on NI 6547/6548 devices.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP1Supported Under Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI PXI/PCI-6541
    NI PXI/PCI-6542
    NI PXIe-6544
    NI PXIe-6545
    NI PXIe-6547
    NI PXIe-6548
    NI PXI/PCI-6551
    NI PXI/PCI-6552
    NI PXIe-6555
    NI PXIe-6556
    NI PXI/PCI-6561
    NI PXI/PCI-6562
    1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    NI-HSDIO 2.0 and later supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    Note:  NI-HSDIO 2.0 and later do not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-HSDIO 1.7.2 or earlier.
    NI-HSDIO 2.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8/7/Vista: 1 GB
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again.
    • NI LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
    • LabVIEW Real-Time Module 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/Windows 7 (32-bit)/Vista (32-bit)/XP
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Function Panel\Drivers\niHSDIO\niHSDIO.fp
    NI-HSDIO Examples\niHSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit)
    NI-HSDIO DLL (64-bit)\Bin
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI Digital Waveform Generator/Analyzer modules includes the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide—Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help—Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device.
    NI-HSDIO Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    Uninstalling/Modifying the Instrument Driver
    Perform the following procedure to uninstall NI-HSDIO 2.0:
    • Click Change/Remove.
    • Select NI-HSDIO 2.0 from the dialog box that appears.
    For Windows 8/7/Vista, complete the following steps:
    As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following packages:
    • NI-HSDIO Runtime 2.0
    • NI LabVIEW SignalExpress 2012 (optional)
    • NI Measurement & Automation Explorer 5.4
    • NI-DAQmx 9.1.7
    • Traditional NI-DAQ 7.4.4 (optional)
    • NI-VISA 5.0
    • NI Spy 2.7.2
    Obsolete Properties and Attributes
    The Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute.
    You can access the software and documentation known issues list online. Refer to the NI-HSDIO 2.0 Known Issues List at ni.com for an up-to-date list of known issues in NI-HSDIO 2.0
    The following items are changes in NI–HSDIO 2.0 from NI–HSDIO 1.9. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
    333216Fixed an issue where intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz.
    373229Fixed an issue where calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors.
    394554Fixed an issue where PFI lines 24 through 31 were not defined in nihsdio.h.
    Using NI Launcher
    Finding All Programs
    Important Information
    © 2003–2013 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-7-2 03:55
