查看: 2920|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 15.0 Driver Win32/64Eng NI-CANopen仪器通信驱动程序15.0
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-20 00:11:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    Win32/64Eng
    15.0
    文件大小: 613109536 字节 (584.71 MB)
    修改日期: 2015-08-03 22:06
    MD5: b660f08fa5b3c2d70d44f4a754a8ea3c(官方正确)
    SHA1: cc51eba94fbc92181bb44c5d718f7208be90c445
    SHA256: 8d2aa0a39b4dfc59de32e0b849d9e38931249c70678ac0072c2c1a3aef996ab1
    CRC32: b6f5552d
    CANopen15.0.txt (640 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for CANopen 15.0 Readme
    June 2015
    This file contains information about the NI-Industrial Communications for CANopen software, including system requirements, installation instructions, new features and changes, a partial list of bugs fixed, and how to access the help and examples.
    Caution   The NI-Industrial Communications for CANopen 14.5 software or later requires the NI 9881 module with the updated firmware. When you upgrade the software to the 14.5 version, check the software version of the media that shipped with the NI 9881 module. If the version is not 14.5 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for CANopen 14.5 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete one of the following tasks to upgrade the firmware.
    • If you are using NI cRIO-9081/9082/9111/9112/9113/9114/9116/9118 with LabVIEW 2012 or later, double-click ModuleFirmwareUpdate.exe in the National Instruments\NI-IndCom for CANopen\Utilities directory and follow the instructions in this utility to update the firmware.
    • If you are using other chassis with LabVIEW 2014 or later, double-click Firmware_Update_Instructions.html in the National Instruments\NI-IndCom for CANopen directory and follow the instructions to use a LabVIEW example project to update the firmware.
    CANopen 15.0
    CANopen 14.5
    CANopen 1.0.3
    CANopen 1.0.2
    CANopen 1.0.1
    CANopen 1.0
    Driver Version Naming Changes
    The NI-Industrial Communications for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. You can deploy the applications to RT targets. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    You can install and run this version of the NI-Industrial Communications for CANopen software on the following operating systems:
    • Windows 8.1/8.0/7/Vista
    • Windows XP SP3 (32-bit)
    Notes  The following list describes restrictions for using NI-Industrial Communications for CANopen on Windows:
    • The NI-Industrial Communications for CANopen installer does not support Windows 2000/NT/Me/98/95 or Windows XP x64.
    • If you upgrade your system from a previous version of Microsoft Windows to Microsoft Windows Vista, you must uninstall all NI software prior to performing the upgrade. After the upgrade is complete, you can reinstall your NI software.
    • Upgrading Windows 8.0 to Windows 8.1 with the NI-Industrial Communications for CANopen software installed might result in device configuration information damage and ostensible disconnection between devices. NI recommends that you reinstall the NI-Industrial Communications for CANopen software after upgrading the operating system.
    Refer to Supported Hardware and Software for NI-Industrial Communications for CANopen, for a complete list of NI hardware and software supported by each NI CANopen interface.
    Before installing the NI-Industrial Communications for CANopen software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for CANopen software setup program must have Administrator privileges, because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for CANopen software:
    • Insert the NI-Industrial Communications for CANopen software media into your computer. The installer launches if your computer plays the media automatically. If the installer does not launch automatically, navigate to the media using Windows Explorer and launch the autorun.exe file from the media.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for CANopen software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking the Cancel button.
    • When the installation is complete, click the Finish button.
    Installing the Software on an RT Target
    Complete the following steps to install the NI-Industrial Communications for CANopen software on an RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select Custom software installation.
    • Select NI-Industrial Communications for CANopen x from the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    New FeaturesCANopen 15.0
    • Added support for LabVIEW 2015 (32-bit)
    • Added support for NI sbRIO-9607/9627 and NI RMC-9697
    CANopen 14.5
    • Added support for LabVIEW 2014 SP1 (32-bit)
    • Added support for NI cRIO-9030/9031/9033/9035/9036/9038/9039/9063/9064/9065/9066/9067
    CANopen 1.0.3
    • Added support for LabVIEW 2013 (32-bit)
    • Added support for NI cRIO-9068
    CANopen 1.0.2
    • Added support for LabVIEW 2012 (32-bit)
    CANopen 1.0.1
    • Added support for LabVIEW 2011 (32-bit)
    • Added support for NI cRIO-9081/9082
    • The CANopen VIs palette includes the following changed polymorphic VI instance:
      • CANopen Interface Create—Includes an optional termination? input that enables or disables the onboard termination. The termination is a 120 Ω resistor.
    CANopen 1.0
    • First release to support NI CANopen hardware that includes NI PCI-8531, NI PXI-8531, and NI 9881
    • Released a common high-level API across NI PCI, NI PXI, and CompactRIO targets running either a Windows or LabVIEW Real-Time OS
    NI-Industrial Communications for CANopen versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-Industrial Communications for CANopen 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-Industrial Communications for CANopen 1.0.3. The first version released under the new numbering scheme is NI-Industrial Communications for CANopen 14.5.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-Industrial Communications for CANopen.
    The following table contains the ID and title of the issue fixed in the NI-Industrial Communications for CANopen 15.0. This table is not an exhaustive list of issues fixed in this version of NI-Industrial Communications for CANopen.
    533911NI-Industrial Communications for CANopen 14.5 reads TPDO incorrectly
    The following table contains the ID and title of the issue fixed in the NI-Industrial Communications for CANopen 14.5. This table is not an exhaustive list of issues fixed in this version of NI-Industrial Communications for CANopen.
    511845Add error codes to report issues when using CANopen 14.5 on the NI 9881 module with outdated files
    The following table contains the ID and title of the issue fixed in the NI-Industrial Communications for CANopen 1.0.2. This table is not an exhaustive list of issues fixed in this version of NI-Industrial Communications for CANopen.
    335637LabVIEW crashes when some EDS files are being parsed
    351959The SDO confirmation frame should be ignored if its index/subindex is wrong
    The following table contains the ID and title of the issue fixed in the NI-Industrial Communications for CANopen 1.0.1. This table is not an exhaustive list of issues fixed in this version of NI-Industrial Communications for CANopen.
    310647Allow users to choose whether to enable onboard termination
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen from the pull-down menu in LabVIEW, for information about using the NI-Industrial Communications for CANopen software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Finding All Programs
    NI-Industrial Communications for CANopen Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for CANopen will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for CANopen that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2011–2015 National Instruments. All rights reserved.
    375165B-01
    GMT+8, 2025-12-6 05:35
