查看: 3145|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 17.0 Driver Win32/64Eng NI-CANopen仪器通信驱动程序17.0
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-1-20 00:14:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    Win32/64Eng
    17.0
    文件大小: 633078664 字节 (603.75 MB)
    修改日期: 2017-04-13 13:05
    MD5: 43a0d8a8a09696246b7f5420f337d87f(官方正确)
    SHA1: 2e7004cbc48b8025142d3cfb2fccc978d0e66be7
    SHA256: 3715a34184d14cac649eb615e32d829bea10633b65e820971877b56a5eac7a68
    CRC32: c9b9ce5d
    CANopen17.0.txt (648 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for CANopen 17.0 Readme
    March 2017
    This file contains important information about the NI-Industrial Communications for CANopen, including system requirements, installation instructions, new features and changes, a partial list of bugs fixed, and how to access the help and examples.
    Caution   The NI-Industrial Communications for CANopen 14.5 software or later requires the NI 9881 module with the updated firmware. When you upgrade the software to the 14.5 version or later, check the software version of the media that shipped with the NI 9881 module. If the version is not 14.5 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for CANopen 14.5 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete one of the following tasks to upgrade the firmware.
    • If you are using NI cRIO-9081/9082/9111/9112/9113/9114/9116/9118 with LabVIEW 2014 or later, double-click ModuleFirmwareUpdate.exe in the \NI-IndCom for CANopen\Utilities directory and follow the instructions in this utility to update the firmware.
    • If you are using other chassis with LabVIEW 2014 or later, double-click Firmware_Update_Instructions.html in the \NI-IndCom for CANopen directory and follow the instructions to use a LabVIEW example project to update the firmware.
    The NI-Industrial Communications for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. You can deploy the applications to RT targets. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    Refer to Supported Hardware and Software for NI-Industrial Communications for CANopen, for a complete list of NI hardware and software supported by each NI CANopen interface.
    NI-Industrial Communications for CANopen supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-Industrial Communications for CANopen dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for CANopen 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for CANopen 17.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for CANopen 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Notes  Upgrading Windows 8.0 to Windows 8.1 with the NI-Industrial Communications for CANopen software installed might result in device configuration information damage and ostensible disconnection between devices. NI recommends that you reinstall the NI-Industrial Communications for CANopen software after upgrading the operating system.
    Before installing the NI-Industrial Communications for CANopen software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for CANopen software setup program must have Administrator privileges, because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for CANopen software:
    • Insert the NI-Industrial Communications for CANopen software media. The installer launches automatically. If the installer does not launch automatically, navigate to the media and launch the autorun.exe file.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for CANopen software.
    Installing the Software on an RT Target
    Complete the following steps to install the NI-Industrial Communications for CANopen software on an RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select Custom software installation.
    • Select NI-Industrial Communications for CANopen x from the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    New FeaturesCANopen 17.0
    • Added support for LabVIEW 2017 (32-bit)
    CANopen 16.0
    • Added support for LabVIEW 2016 (32-bit)
    • Added support for NI cRIO-9032/9035 (Sync)/9037/9039 (Sync)
    CANopen 15.0
    • Added support for LabVIEW 2015 (32-bit)
    • Added support for NI sbRIO-9607/9627 and NI RMC-9697
    CANopen 14.5
    • Added support for LabVIEW 2014 SP1 (32-bit)
    • Added support for NI cRIO-9030/9031/9033/9035/9036/9038/9039/9063/9064/9065/9066/9067
    CANopen 1.0.3
    • Added support for LabVIEW 2013 (32-bit)
    • Added support for NI cRIO-9068
    CANopen 1.0.2
    • Added support for LabVIEW 2012 (32-bit)
    CANopen 1.0.1
    • Added support for LabVIEW 2011 (32-bit)
    • Added support for NI cRIO-9081/9082
    • The CANopen VIs palette includes the following changed polymorphic VI instance:
      • CANopen Interface Create—Includes an optional termination? input that enables or disables the onboard termination. The termination is a 120 Ω resistor.
    CANopen 1.0
    • First release to support NI CANopen hardware that includes NI PCI-8531, NI PXI-8531, and NI 9881
    • Released a common high-level API across NI PCI, NI PXI, and CompactRIO targets running either a Windows or LabVIEW Real-Time OS
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-Industrial Communications for CANopen.
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 15.0. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    533911NI-Industrial Communications for CANopen 14.5 reads TPDO incorrectly
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 14.5. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    511845Add error codes to report issues when using CANopen 14.5 on the NI 9881 module with outdated files
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 1.0.2. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    335637LabVIEW crashes when some EDS files are being parsed
    351959The SDO confirmation frame should be ignored if its index/subindex is wrong
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 1.0.1. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    310647Allow users to choose whether to enable onboard termination
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen in LabVIEW, for information about using the NI-Industrial Communications for CANopen software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET 4.0 reboot, install .NET separately before you install NI software.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2011–2017 National Instruments. All rights reserved.
    375165D-01
    GMT+8, 2025-12-6 05:35
