查看: 3132|回复: 0
[NI驱动程序] NI-Industrial Controller Device Drivers 15.7 Win32Eng NI工业控制器设备驱动程序15.7
    1 小时前
  • 签到天数: 3746 天
    连续签到: 73 天
    发表于 2021-1-20 23:58:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI工业控制器设备驱动程序软件为客户使用NI工业控制器提供支持。
    NI工业控制器设备驱动程序是用于配置和编程工业控制器的驱动程序软件。该软件还可用于控制工业控制器的数字I/O。除了LabVIEW、LabVIEW Real-Time模块或NI自动化检测视觉生成器之外,您还必须安装此驱动程序才能开始编程工业控制器。
    Win32Eng
    15.7
    文件大小: 1750851168 字节 (1.63 GB)
    修改日期: 2016-06-10 23:25
    MD5: 1500127079e50dd76b3bc409388dc770(官方正确)
    SHA1: 8f882fb8855f581a759a2230b9ad680c68a0a702
    SHA256: 5cd19e9187f83dc226a986ee213595f68aedab660eba3519f89f063418860c33
    CRC32: c52e4a00
    INDCTRL15.7.txt (631 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Industrial Controller Device Drivers Release Notes
    May 2016
    This file contains important information about National Instruments Industrial Controller Device Drivers, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    NI Industrial Controller Device Drivers allows you to configure Industrial Controller devices and control their digital I/O. This release supports the following hardware:
    • IC-3120
    • IC-3121
    • IC-3171
    • IC-3172
    • IC-3173
    Refer to the NI Industrial Controller website at ni.com/industrial-controller for the latest information about NI Industrial Controller Device Drivers.
    The development computer must meet the following requirements to run NI Industrial Controller Device Drivers:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    1.5 GB
    Operating System
    • Windows 8.1 (32- and 64-bit)
    • Windows 7 SP1 (32- and 64-bit)
    • Windows Vista SP1 (32- and 64-bit)
    • Windows XP SP3 (32-bit)
    • Windows Server 2008 R2 SP2 (64-bit)
    • Windows Server 2003 R2 SP2 (32-bit)
    NI Application and Driver Software Support
    The following table lists the NI application and driver software versions, including service packs, supported by the NI Industrial Controller Device Drivers. The installer specifically allows side-by-side installations of NI Industrial Controller Device Drivers for each of the supported versions of LabVIEW, enabling you to use the NI Industrial Controller Device Drivers with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Industrial Controller Device Drivers.
    NI Application Software or Driver SoftwareVersions Supported by NI Industrial Controller Device Drivers
    NI LabVIEW
    2014, 2015
    NI LabVIEW Real-Time Module
    2014, 2015
    NI LabVIEW FPGA Module
    2014, 2015
    NI Vision Development Module
    2015 SP1 or later
    NI Vision Acquisition Software
    February 2016 or later
    NI Vision Builder for Automated Inspection
    2015 or later
    This release of NI Industrial Controller Device Drivers includes the following new features.
    • Support for IC-3171 and IC-3172 Industrial Controllers
    • Support for hardware-based Precision Time Protocol (PTP) / IEEE 1588-2008 on IC-3171, IC-3172, and IC-3173 running Linux RT with NI-TimeSync 15.5 or later installed
    The following list describes issues in previous versions of NI Industrial Controller Device Drivers that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Industrial Controller Device Drivers.
    419849On Linux RT industrial controllers, port settings for configuring serial ports are not available in MAX.
    569514The Vision RIO API VIs may load as broken if a system has NI-IMAQ I/O 15.5 (from Vision Acquisition Software February 2016) and NI Industrial Controller Device Drivers 15.5 installed with LabVIEW support, and you uninstall the NI Industrial Controller Device Drivers.
    571307NI Industrial Controller Device Drivers does not install error codes for the Vision RIO API.
    576611On a system with no NI software previously installed, MAX configuration support for industrial controllers is not selected by default for installation.
    Complete the following steps to install NI Industrial Controller Device Drivers:
    Note: You must have administrator access to install NI Industrial Controller Device Drivers.
    • Insert the NI Industrial Controller Device Drivers installation media.
    NI Industrial Controllers Device Drivers integrate with NI Measurement & Automation Explorer (MAX), the National Instruments utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Industrial Controller Device Drivers.
    • On Linux RT industrial controllers, switching serial transceiver configuration between RS-485 and RS-232 is not available in MAX. The port can be switched between these modes in the BIOS.
    • System temperature monitoring is only available for IC-3171, IC-3172, and IC-3173 targets running Linux RT.
    • IC-3120, IC-3121, and IC-3171 Linux RT targets cannot reload or downgrade target firmware to version 3.5 or earlier.
    Documentation is installed onto your hard drive with NI Industrial Controller Device Drivers. To view the documentation, select Start»All Programs»National Instruments»Industrial Controller, or navigate to \Public\Public Documents\National Instruments.
    • Refer to the National Instruments Web site for information about the IEEE 1588 time synchronization capabilities of the Industrial Controllers.
    • IC-3120 Getting Started Guide, IC-3120 Specifications, and IC-3120 User Manual—These documents explain how to install and configure the IC-3120, and contain specifications and electrical and mechanical information.
    • IC-3121 Getting Started Guide, IC-3121 Specifications, and IC-3121 User Manual—These documents explain how to install and configure the IC-3121, and contain specifications and electrical and mechanical information.
    • IC-317x Getting Started Guide, IC-3171 Specifications, IC-3172 Specifications, IC-3173 Specifications, and IC-317x User Manual—These documents explain how to install and configure the IC-317x, and contain specifications and electrical and mechanical information.
    • Vision RIO VI Reference Help—This document contains reference information about NI Vision RIO VIs. Vision RIO VIs provide basic tools to configure input and output on FPGA-enabled devices to synchronize image acquisition with process control.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, click the down arrow on the bottom left of the screen.
    NI Industrial Controller Device Drivers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Industrial Controller Device Drivers will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Industrial Controller Device Drivers that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2016 National Instruments. All rights reserved.
    375780B-01
    GMT+8, 2025-12-18 09:31
