查看: 3676|回复: 0
[NI驱动程序] NI-Industrial Controller Device Drivers 17.1.1 Win32Eng NI工业控制器设备驱动程序17.1.1
    1 小时前
  • 签到天数: 3746 天
    连续签到: 73 天
    发表于 2021-1-21 00:03:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI工业控制器设备驱动程序软件为客户使用NI工业控制器提供支持。
    NI工业控制器设备驱动程序是用于配置和编程工业控制器的驱动程序软件。该软件还可用于控制工业控制器的数字I/O。除了LabVIEW、LabVIEW Real-Time模块或NI自动化检测视觉生成器之外,您还必须安装此驱动程序才能开始编程工业控制器。
    Win32Eng
    17.1.1
    文件大小: 2525082516 字节 (2.35 GB)
    修改日期: 2017-07-12 22:36
    MD5: e22594bf3bb1563067db5a710e5c1046(官方正确)
    SHA1: 0c344ea9b14374cf75dfdbc8629a042c4c9f3af4
    SHA256: 2c0be05dcc9142a1fde5b170b5210889b31bef4e09924346b0e0656a34bfbab9
    CRC32: 34dd1fd5
    INDCTRL17.1.1.txt (629 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Industrial Controller Device Drivers 17.1.1 Readme
    July 2017
    This file contains important information about National Instruments Industrial Controller Device Drivers, including installation instructions, new features, fixed issues, and known issues.
    NI Application and Driver Software Support
    Updates and Improvements
    NI Industrial Controller Device Drivers allows you to configure Industrial Controller devices and control their digital I/O. This release supports the following hardware:
    • IC-3120
    • IC-3121
    • IC-3171
    • IC-3172
    • IC-3173
    Refer to the NI Industrial Controller website at ni.com/industrial-controller for the latest information about NI Industrial Controller Device Drivers.
    The development computer must meet the following requirements to run NI Industrial Controller Device Drivers:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    1.5 GB
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    Note  NI Industrial Controller Device Drivers 16.0 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Industrial Controller Device Drivers 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Industrial Controller Device Drivers 16.0 or later to an unsupported OS. Additionally, after installing NI Industrial Controller Device Drivers 16.0 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the NI application and driver software versions, including service packs, supported by the NI Industrial Controller Device Drivers. The installer specifically allows side-by-side installations of NI Industrial Controller Device Drivers for each of the supported versions of LabVIEW, enabling you to use the NI Industrial Controller Device Drivers with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Industrial Controller Device Drivers.
    NI Application Software or Driver SoftwareVersions Supported by NI Industrial Controller Device Drivers
    NI LabVIEW
    2014, 2015, 2016, 2017
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI Vision Development Module
    2015 SP1 or later
    NI Vision Acquisition Software
    February 2016 or later
    NI Vision Builder for Automated Inspection
    IC-3120, 3121, and 3173—2015 or later
    IC-3171 and 3172—2015 f1 or later
    The following list describes the new features in NI Industrial Controller Device Drivers 17.1.1
    • Recommended Software Set add-on support for IEEE 802.1AS-2011 on real-time IC-317x targets
    • Recommended Software Set add-on support for NI-TSN 17.0 Early Access Release on real-time IC-317x targets
    • Installers for deploying IEEE 802.1AS-2011 and IEEE 1588-2008 support on real-time IC-317x targets are included with NI Industrial Controller Device Drivers
    • Recommended Software Set support for Linux-based IC-312x devices—see the Updates and Improvements section
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI Industrial Controller Device Drivers.
    The following list contains potential high severity issues that you may want to review before using this product. Refer to the previous link to determine if any known issues have been resolved in a subsequent update.
    • Installing or reinstalling certain drivers, including Vision RIO support, on top of previous installations on a Linux Real-Time target can put the target in an unreachable state unless you force it into safe mode using the reset button or manually reassociate driver dependencies on the target. To avoid this issue, format the target prior to installing or reinstalling software, or only perform reinstallations using a Recommended Software Set. To learn more about this issue and additional recovery options, visit ni.com/info and enter the Info Code nikalEmbeddedReinstall.
    Complete the following steps to install NI Industrial Controller Device Drivers:
    Note: You must have administrator access to install NI Industrial Controller Device Drivers.
    • Insert the NI Industrial Controller Device Drivers installation media.
    NI Industrial Controllers Device Drivers integrate with NI Measurement & Automation Explorer (MAX), the National Instruments utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Industrial Controller Device Drivers.
    Documentation is installed onto your hard drive with NI Industrial Controller Device Drivers. To view the documentation, select Start»All Programs»National Instruments»Industrial Controller, or navigate to \Public\Public Documents\National Instruments.
    • Refer to the National Instruments Web site for information about the IEEE 1588 time synchronization capabilities of the Industrial Controllers.
    • IC-3120 Getting Started Guide, IC-3120 Specifications, and IC-3120 User Manual—These documents explain how to install and configure the IC-3120, and contain specifications and electrical and mechanical information.
    • IC-3121 Getting Started Guide, IC-3121 Specifications, and IC-3121 User Manual—These documents explain how to install and configure the IC-3121, and contain specifications and electrical and mechanical information.
    • IC-317x Getting Started Guide, IC-3171 Specifications, IC-3172 Specifications, IC-3173 Specifications, and IC-317x User Manual—These documents explain how to install and configure the IC-317x, and contain specifications and electrical and mechanical information.
    • Vision RIO VI Reference Help—This document contains reference information about NI Vision RIO VIs. Vision RIO VIs provide basic tools to configure input and output on FPGA-enabled devices to synchronize image acquisition with process control.
    © 2017 National Instruments. All rights reserved.
    375780C-01
    GMT+8, 2025-12-18 09:32
