查看: 3297|回复: 0
[NI驱动程序] NI-mmWave 15.3.1 Driver Win64Eng NI毫米波收发仪系统驱动软件15.3.1下载
    10 小时前
    发表于 2021-1-21 23:13:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-mmWave
    NI-mmWave用于支持毫米波收发仪系统,以简化软件开发和通信研究。
    NI-mmWave是一个NI仪器驱动,用于帮助用户使用毫米波收发仪系统创建LabVIEW FPGA应用程序,适用于实时无线毫米波通信研究。该驱动还可帮助用户根据研究目标和目的来优化代码。
    Win64Eng
    15.3.1
    文件大小: 2870104656 字节 (2.67 GB)
    修改日期: 2018-03-17 04:11
    版本: 18.1.0.0
    MD5: 9c3a63db34a50d2dc8999b9c4c70c7a1(官方正确)
    SHA1: 793694b35a03f1d1330e6707ac5e61308549ba52
    SHA256: 229f7e97eb15811dcd22fb8f0b59c709ebe39494d63e3b17bd2315088ad80bff
    CRC32: 5569ed4c
    MMWave15.3.1.txt (577 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-mmWave 15.3.1 Readme
    March 2018
    This file contains important information about NI-mmWave, including new features, a partial list of bugs fixed for NI-mmWave 15.3.1, and known issues.
    Using with mmRH-3602/3642/3652 Radio Heads
    PXI Trigger Routing and Reservation
    Updating the FPGA VI in Existing Projects
    Accessing VIs and Functions
    Finding Examples and the Reference Project
    This software installation provides support for customers using the mmWave Transceiver System and mmWave Radio Heads, as specified in the Supported Hardware section. To program your mmWave Transceiver System with or without the mmWave Radio Heads, use the NI-mmWave instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using the mmWave Transceiver System with or without radio heads.
    NI-mmWave 15.3.1 adds support for recent revisions of the mmRH-3602/3642/3652 mmWave Radio Heads
    NI-mmWave 15.3 includes the following new features:
    • Support for the following devices:
      • mmRH-3602
      • mmRH-3642
      • mmRH-3652
    • Support for fast configuration of gain and mmWave port switches
    • Automatic detection of mmWave radio heads
    NI-mmWave 15.1 includes the following new features:
    • Support for NI LabVIEW 2015 SP1
      • mmWave Transceiver System
        • PXIe-3610 Waveform Generator
        • PXIe-3620 RF Upconverter and Downconverter Module
        • PXIe-3630 Digitizer
        • PXIe-7902 High-Speed Serial Instrument
      • mmRH-3647 mmWave Radio Head
      • mmRH-3657 mmWave Radio Head
      • PXIe-7902 High Speed Serial Instrument
    • mmRH-3602 mmWave Radio Head
    • mmRH-3642 mmWave Radio Head
    • mmRH-3652 mmWave Radio Head
    NI-mmWave has the following requirements:
    • PXIe-1085 Chassis with a PXIe-8135/8880 Controller
    • RAM—8 GB RAM
    NI-mmWave supports Windows 10/8.11/7 SP12 (64-bit).
    NI-mmWave supports the following application software versions, including service packs. You should install application software, such as LabVIEW, before installing NI-mmWave. To add support for application software installed after installing NI-mmWave, modify your NI-mmWave installation or launch the NI-mmWave installer again.
    Application SoftwareVersions Supported by NI-mmWave
    LabVIEW2015 SP1
    The following sections describe issues to be aware of when you upgrade to NI-mmWave 15.3.1 from NI-mmWave 15.1.
    Using with mmRH-3602/3642/3652 Radio HeadsIf you are updating existing code for use with the mmRH-3602/3642/3652 radio heads, you must use the Open Session 2 VI. This VI is introduced in NI-mmWave 15.3 and automatically detects all mmWave radio heads that are connected to the PXIe-3620 module. After calling the Open Session 2 VI, you must call the Configure Active mmWave Adapter VI to use the system in RF mode.
    The NI mmWave Reference Project reserves PXI_Trig4, PXI_Trig5, PXI_Trig6, and PXI_Trig7 for device synchronization. When using files copied from the NI mmWave Reference Project in projects created in NI-mmWave 15.1 or earlier, you must change the reservation settings for those PXI triggers in Measurement and Automation Explorer (NI MAX) at Start»All Programs»NI MAX by completing the following steps.
    • In NI MAX, navigate to Devices and Interfaces» "Chassis ".
    • Select the Triggers tab.
    • Clear the Reservations checkboxes for PXI_Trig4, PXI_Trig5, PXI_Trig6, and PXI_Trig7 and ensure that they are set to Dynamic routing. Leaving the checkboxes selected while using files from the NI mmWave Reference Project will result in an error.
    If you are using existing code that includes the FPGA VI and recompiling the FPGA bitfile, you must configure the clock configuration for the socketed CLIP on the FPGA target. NI recommends that you remove the JESD MGT Config loop from the FPGA VI. Refer to the NI mmWave Reference Project as a configuration example.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-mmWave 15.3.1.
    There are no changes in NI-mmWave 15.3.1 from NI-USRP 15.3.
    The following items are the IDs and titles of a subset of issues fixed in NI-mmWave 15.3. This is not an exhaustive list of issues fixed in the current version of NI-mmWave 15.3. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    600897Fixed an issue that caused an installation error to occur when upgrading NI Linux Real-Time Support for NI-mmWave devices.
    583667Fixed an issue that caused NI-mmWave to incorrectly report the coerced value for out-of-bounds frequencies when using external LO.
    582873Fixed an issue that caused the PXIe-3620 session to be invalid after aborting the session.
    580686Fixed an issue that caused NI MAX to expose unsupported features for the PXIe-7902 module.
    Refer to the NI-mmWave documentation set for information about NI-mmWave. The documentation set for NI-mmWave is composed of the following documents.
    DocumentFormatDescriptionLocation
    Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, signal connection, and information on how to get started with application development for your device.Available at ni.com/manuals
    Specifications for your devicePDFLists technical specifications for your device.Available at ni.com/manuals
    NI-mmWave 15.3 ManualOnline helpContains information on how to use the reference project, as well as conceptual information about instrument driver features.Visit ni.com/info and enter the Info Code mmwavemanual
    NI-mmWave ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»NI-mmWave»Documentation
    NI-mmWave palette VIs are available on the LabVIEW Functions palette at Functions»Instrument I/O»Instrument Drivers»NI mmWave.
    NI-mmWave includes a reference project and several example applications for LabVIEW. You can access the installed NI mmWave Reference Project and examples at Program Files (x86)\National Instruments\LabVIEW 2015\examples\instr\niMmWave for 32-bit programs and Program Files\National Instruments\LabVIEW 2015\examples\instr\niMmWave for 64-bit programs.
    Note  The NI Example Finder does not include NI-mmWave examples.
    Note  Installed examples are not sample projects. You must copy the example to a new location before modifying any files. Otherwise, your changes may be overwritten.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI MAX, and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2016–2018 National Instruments. All rights reserved.
    376436C-01
    GMT+8, 2025-12-8 19:47
