查看: 3297|回复: 0
[NI驱动程序] NI PXI MultiComputing 16.0 Driver Win32Eng NI-PXImc远程控制模块驱动程序16.0
    10 小时前
    发表于 2021-1-23 23:49:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-PXImc
    NI-PXImc为使用NI PXI MultiComputing远程控制模块的客户提供支持。
    NI-PXImc是一个NI仪器驱动程序,可让两个或更多智能系统利用非透明(NT)桥接技术,通过PCI Express进行数据交换。NI-PXImc驱动程序抽象了PXI MultiComputing (PXImc)接口的底层细节,并提供了一种简单有效的API来进行数据传输。
    Win32Eng
    16.0
    文件大小: 467197832 字节 (445.55 MB)
    修改日期: 2016-12-10 07:25
    MD5: f7ec8148c22d2ec1d2549811e9a04ca7(重复一致)
    SHA1: e0c1aaf3ba199dd642a789b91eab28e300b7906e
    SHA256: ffa7806be9b74371472d50a10b0949c345f3c49d2d760d3cd4a541f25e04dda5
    CRC32: f3786e8a
    PXImc16.0.txt (548 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-PXImc™ Readme
    Version 16.0
    November 2016
    This file contains information about the NI-PXImc software for Microsoft Windows and LabVIEW Real-Time (RT). Information in this file is organized in the following sections:
    NI-PXImc General Considerations
    Driver Version Naming Changes
    The NI-PXImc software enables you to create customized applications for your PXImc hardware (NI PXIe-8383mc and NI PXIe-8830mc) either in LabVIEW or C/C++.
    You can install and run this version of the NI-PXImc software on the following operating systems:
    • Microsoft Windows 10 (32- and 64-bit)
    • Microsoft Windows 8.1 (32- and 64-bit)
    • Microsoft Windows 7 (32- and 64-bit).
      Note: National Instruments recommends Windows 10/8.1/7 (64-bit) for best performance.
    • NI LabVIEW Real-Time (ETS)
      Note:   The only operating system supported on the NI PXIe-8830mc Processor Module is NI LabVIEW Real-Time 2013 SP1, NI LabVIEW Real-Time 2014 SP1, NI LabVIEW Real-Time 2015 SP1, NI LabVIEW Real-Time 2016.
    Note:  National Instruments recommends 3 GB or more RAM for Windows 10/8.1/7 (32-bit) and LabVIEW Real-Time (ETS), and a minimum 8 GB RAM for Windows 10/8.1/7 (64-bit). Refer to System RAM for more information.
    The following table lists the NI application software versions, including service packs, supported by NI-PXImc. If you are not using NI application software, refer to microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by NI-PXImc
    NI LabVIEW2012 SP1 (32- or 64-bit), 2013 SP1 (32- or 64-bit), 2014 SP1 (32- or 64-bit), 2015 SP1(32- or 64-bit), 2016 (32- or 64-bit)
    NI LabVIEW Real-Time Module
    NI PXIe-8383mc module:
    2012 SP1, 2013 SP1, 2014 SP1, 2015 SP1, 2016
    Note: The Real-Time Module is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    NI PXIe-8830mc module:
    NI LabWindows™/CVI™2012 and later
    The NI-PXImc software currently supports the following hardware products:
    • NI PXIe-8383mc PXImc Adapter Module
    • NI PXIe-8830mc PXImc Processor Module
    The NI PXIe-8383mc PXImc adapter modules and the NI PXIe-8830mc PXImc processor modules utilize a x8 PCI Express 2.0 interface for transferring data. National Instruments recommends using the NI PXImc modules with a PXI-Express chassis and controller combination that provide high PCI Express bandwidth. If you are using the NI PXIe-8383mc or NI PXIe-8830mc module in a chassis with an NI embedded controller, then you must update the BIOS software on that embedded controller to the latest released BIOS software prior to connecting the hardware. For more information, refer to KnowledgeBase 2GIGKD0Z, Determining and Upgrading PXI and VXI Embedded Controller BIOS Versions.
    Bandwidth experienced when using NI-PXImc may be affected by bandwidth capabilities of the controller or the chassis. If you experience lower than expected bandwidth when using NI-PXImc, check that your controller and chassis are capable of supporting the desired bandwidth, and that your PXImc adapter module is inserted into an appropriate chassis slot to obtain the best performance. Consult your chassis and controller documentation for specific information relevant to your hardware configuration.
    Note: National Instruments recommends an NI high performance PXIe embedded controller be used both as the system controller and as the controller connected to the front panel of the PXImc module. Refer to NI-PXImc General Considerations for more information.
    The following sections include important information about installing the NI-PXImc software.
    You can run the NI-PXImc installer on the following operating systems:
    • Windows 10/8.1/7 (32-bit and 64-bit)
    Before installing the NI-PXImc software, log on as Administrator or as a user with Administrator privileges. The NI-PXImc software setup program must have Administrator privileges because the program modifies the configuration registry of your system.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches.
    Downloading燦I-PXImc from the Web
    Complete the following steps to install the NI-PXImc software from a web download:
    • Download the NIPXImc160.exe爁ile, and then run it.
      Note  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installation is complete, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    Installing from the CD
    Complete the following steps to install the NI-PXImc software from the installation media:
    • Insert the NI-PXImc software media. If you have autorun enabled,autorun.exe runs automatically. Otherwise, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-PXImc software media.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-PXImc software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • Select NI-PXImc in the feature list and click Next.
    • Follow the remaining installation instructions until installation is complete.
    NI-PXImc General ConsiderationsUpgrading from NI-PXImc 1.0/14.0
    NI-PXImc 16.0 is not compatible with NI-PXImc 1.0/14. You must upgrade all systems, including the host machine and any PXImc hardware modules, to version 16.0 of the software.
    NI Embedded Controller BIOS Versions
    For proper operation with NI-PXImc, all NI Embedded Controllers must be running the latest BIOS. For more information, refer to KnowledgeBase 2GIGKD0Z, Determining and Upgrading PXI and VXI Embedded Controller BIOS Versions.
    Recommended NI Embedded Controllers
    National Instruments recommends an NI high performance PXIe embedded controller be used both as the system controller and as the controller connected to the front panel of the PXImc module. If you are connecting the PXImc module to an NI PXIe embedded controller, you must update the BIOS software on that embedded controller to the latest released BIOS software prior to connecting the hardware. Refer to NI Embedded Controller BIOS Versions for information about updating the BIOS.
    Bandwidth experienced when using NI-PXImc may be affected by bandwidth limitations in the controller or on the chassis backplane. If you experience lower than expected bandwidth when using NI-PXImc, check that your controller and chassis are capable of supporting the desired bandwidth, and that your PXImc card is inserted into an appropriate chassis slot to obtain the best performance. Consult your chassis and controller documentation for specific information relevant to your hardware configuration.
    System RAM
    National Instruments recommends a minimum 3 GB RAM for Windows 10/8.1/7 (32-bit) and LabVIEW Real-Time (ETS), and a minimum of 8 GB RAM for Windows 10/8.1/7 (64-bit). To maximize the available PXImc buffer, National Instruments recommends either Windows 10/8.1/7 (64-bit) or LabVIEW Real-Time (ETS).
    Note  The available PXImc buffer will likely be reduced if the above recommendations are not followed. Refer to Setting an Appropriate Buffer Size in the NI-PXImc Help for more information about buffer size.
    User Mode and Factory Mode Settings for the NI PXIe-8383mc Module
    National Instruments recommends setting the hardware Mode DIP switch (Switch 4) to User Mode for optimal performance. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for information about the DIP switch functionality and location. Refer to the Hardware Configuration section in the NI-PXImc Help for more information about the differences between the two modes.
    NI PXIe-8383mc Power Sequence
    The PXIe chassis that contains the NI PXIe-8383mc module must be powered on before the system connected to the front panel connector is powered on. Furthermore, the PXIe chassis that contains the NI PXIe-8383mc module must be continuously powered while the system connected to the front panel connector is powered on. If it is necessary to turn off the chassis containing the PXIe-8383mc, the system connected to the front panel must be powered off first. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for more information about power sequence.
    Using Third-Party Controllers with the NI PXIe-8383mc Module
    Many third-party PXI Express controllers, both PXIe embedded controllers and desktop PCs, have been observed to have BIOS issues that prevent the enumeration of some PXIe modules. If you have boot or device enumeration issues, set the hardware Mode DIP switch (Switch 4) on your PXImc modules to Factory mode and try again. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for information about the DIP switch functionality and location. If you continue to have issues, either contact your controller vendor for a BIOS fix or upgrade your controller to a National Instruments high performance PXIe embedded controller.
    Module Count for the NI PXIe-8383mc Module
    When configuring the NI PXIe-8383mc module in "User" mode, NI recommends no more than six modules be connected to a single system running 64-bit Windows 10, Windows 8.1 or Windows 7, and no more than four modules be connected to a system running 32-bit Windows 8.1 or Windows 7, either directly in the system or connected through the PXImc module front panel connector. If you are using the NI PXIe-8383mc or NI PXIe-8830mc in a system with LabVIEW Real-Time (ETS) OS, NI recommends no more than four modules to a single system, either directly in the system or connected through the front panel connector. If your system needs more than the recommended number of modules, either change Switch 4 to the "FACT" position for all modules or contact National Instruments support.
    Module Count for the NI PXIe-8830mc Module
    NI recommends no more than six NI PXIe-8830mc modules be placed in a single system with the embedded controller running Windows 10/8.1/7(64-bit), and no more than four modules be placed in a system running Windows 10/8.1/7 (32-bit) on the host/embedded controller. If you are using the NI PXIe-8830mc in a system with the embedded controller running LabVIEW Real-Time (ETS) OS, NI recommends no more than four NI PXI-8830mc modules be in the system. If your system needs more than the recommended number of modules contact National Instruments support.
    NI-PXImc versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-PXImc 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-PXImc 1.0. The first version released under the new numbering scheme is NI-PXImc 14.0.0.
    Refer to the NI-PXImc Help, accessible by selecting Help»NI-PXImc Help from the pull-down menu in LabVIEW, for information about using the NI-PXImc software.
    LabVIEW examples for the NI-PXImc software are in the labview\examples\NI-PXImc folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    Using NI Launcher
    Finding All Programs
    © 2013–2016 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:46
