查看: 3948|回复: 0
[NI软件产品] NI RFIC Test Software 20.0.0 Win64Eng NI-RFIC测试软件20.0.0
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2021-1-24 00:33:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFIC测试软件
    RFIC测试软件简化了宽带RF IC的特性分析。
    RFIC测试软件是一款应用软件,可帮助您分析功率放大器(PA)和前端模块(FEM)等RFIC的特性。如果要对PA进行线性化,有多种针对特定应用的数字预失真(DPD)算法可供选择,例如查找表(LUT)、记忆多项式(MP)和广义记忆多项式(GMP)。此外,您还可以集成并运行NI联盟伙伴的线性化算法或技术。当使用像PXI矢量信号收发仪这样的NI仪器时,您还可以使用该软件来分析包络跟踪(ET)等功率效率优化技术。您可以使用GUI来保存手动配置和执行,以便重复使用这些配置和执行或与其他测试平台共享。National Instruments Alliance Partner(NI联盟伙伴)是独立于NI的商业实体,与NI之间不存在代理、合伙或合资关系。
    Win64ENG
    20.0
    文件大小: 707098624 字节 (674.34 MB)
    修改日期: 2020-07-29 17:01
    MD5: 118de4ddcd355e91a4dd0f232f11087b(官方正确)
    SHA1: 029dcfc58c68a0ae76c4d55c90cf2f5306c6d035
    SHA256: f1984819d41bbf10b035ce7221c586f16535fb41b2daf9b4a1aabca4beb3e419
    CRC32: 79d32132
    RFICts20.0.0.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    RFIC Test Software 20.0 Readme
    July 2020
    This file contains important information about RFIC Test Software, including new features, supported hardware, a partial list of bugs fixed for RFIC Test Software 20.0, and known issues.
    Driver and Add-On Requirements
    Accessing the APIs
    RFIC Test Software Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    RFIC Test Software enables you to explore testing advanced RF integrated circuit (RFIC) devices featuring envelope tracking (ET), digital predistortion (DPD), and hardware-accelerated power servoing. Available measurements include adjacent channel power (ACP), spectral emission mask (SEM), error vector magnitude (EVM), AM-to-AM, and AM-to-PM. To set up measurements for your device, use the installed examples or the RFIC Test Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    RFIC Test Software has the following minimum requirements:
    • Processor—Intel Pentium 4 or equivalent
    • 1 GB RAM*
    • A screen resolution of 1,024 x 768 with 256 colors
    NI recommends the following requirements:
    • 4 GB RAM*
    • A screen resolution of 1,600 x 1,200
    * Depending on the amount of data acquired and/or processed a larger amount of memory may be required.
    RFIC Test Software 20.0 supports Windows 10/8.11/7 SP12 and is available only in 64-bit.
    RFIC Test Software supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Note  Install application software, such as LabVIEW or Microsoft Visual Studio, before installing RFIC Test Software. To add support for application software installed after installing RFIC Test Software, modify your RFIC Test Software installation or launch the RFIC Test Software installer again.
    Versions Supported by RFIC Test Software
    LabVIEW64-bit of 2017, 2017 SP1, 2018, 2018 SP1, 2019, 2019 SP1, and 2020
    Microsoft Visual Studio2010 SP1 and later
    TestStand2019
    Note  RFIC Test Software will not operate correctly without the service packs previously mentioned.
    If you are using the RFIC Test Software .NET Class Library, .NET Framework 4.5 (minimum) is required.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    RFIC Test Software requires the following driver and add-on versions:
    Note  NI recommends using the latest available version.
    • NI-RFSG 19.2.1 or later
    • NI-RFSA 19.2.1 or later
    • NI-FGEN 19.5.1 or later
    • NI-DCPower 19.5.0 or later
    • NI-SCOPE 19.5 or later
    • NI-RFmx SpecAn 19.1 or later
    • NI-RFmx Demod 19.1 or later
    • NI-RFmx LTE 19.11 or later
    • NI-RFmx NR 19.11 or later
    • NI-RFmx WLAN 19.11 or later
    • NI-RFSG Playback Library 19.1 or later
    • (Optional) RF Power Amplifier Linearizer 1.6 or later2
    1 Installation and licensing are only required for standard-specific measurements.
    2 Requires a valid license.
    Note  The run-time versions of these products are sufficient to run the RFIC Test SFP.
    NI installs RFIC Test Software using NI Package Manager. If you do not already have NI software installed, RFIC Test Software installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFIC Test Software 20.0 includes the following new features:
    • Support for impedance tuning using Focus Microwaves load pull tuners
    • Support for frequency sweep testing
    • Support for NanoSemi dual-band DPD measurements. You must install the RF Power Amplifier Linearizer 2.0 or later and have a valid license. Use NI Package Manager to install the RF Power Amplifier Linearizer.
    The following table shows which hardware products are supported in RFIC Test Software. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware Product
    Hardware Model
    Application
    Vector Signal TransceiverPXIe-5646
    Hardware-accelerated power servoing
    PXIe-5830
    PXIe-5831
    PXIe-5840
    PXIe-5841
    PXIe-5820
    Envelope waveform generation when testing ET devices under test (DUTs)
    Waveform GeneratorPXIe-5451
    Envelope waveform generation when testing ET DUTs
    Note  For DEVM measurements, use the PXIe-5820.
    OscilloscopePXIe-5162
    • PAE measurements
    • (Optional) Recommended for envelope waveform/delay analysis when testing ET DUTs
    PXIe-5185
    PXIe-5186
    Source Measure UnitPXIe-4139
    (Optional) Vcc sourcing and system PAE measurements
    PXIe-414x
    Accessing the APIsLabVIEW
    ETSync VIs are available in LabVIEW from the Functions»Addons»ET palette.
    Power Servo VIs are available in LabVIEW from the Functions»User Libraries»NI Power Servoing IP palette.
    NanoSemi Linearizer VIs and NanoSemi Dual Band VIs are available in LabVIEW from the Functions»User Libraries»NanoSemi Linearizer and NanoSemi Dual Band palettes.
    .NET Framework
    You can use the ETSync .NET Class library by adding a reference to niETSync.cs, niETUtil.cs, and niFGEN.cs from C:\Users\Public\Public Documents\National Instruments\NI-ETSync\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    You can use the Power Servo .NET Class library by adding a reference to niVSTPowerServo.cs, niRFSA.cs, and niInteropCommon.cs from C:\Users\Public\Public Documents\National Instruments\FPGA Power Servo\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the ETSync C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niETSync_64.dll.
    You can use the Power Servo C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niVSTPowerServo_64.dll.
    RFIC Test SFP
    To launch the RFIC Test SFP, navigate to Start»National Instruments»RFIC Test Soft Front Panel.
    In RFIC Test Software 19.2 and later, examples for LabVIEW, .NET, and TestStand are available via the RFIC Test Automation Wizard, accessible from Start»National Instruments»RFIC Test Automation Wizard.
    In RFIC Test Software 19.1 and earlier, examples for LabVIEW and .NET are referred to as "Legacy Examples" and accessible from Start»National Instruments»RFIC Legacy Examples.
    Refer to the RFIC Test Software User Manual located at Start»National Instruments»RFIC Documentation. The manual includes the following information:
    • RFIC Test Soft Front Panel information and examples
    • How to get started with the Test Automation Wizard
    • How to configure hardware for use with the ETSync API and reference for the ETSync VIs
    • Theory of operation information on power servoing and reference for the Power Servo VIs
    For information about your device, such as how to getting started, technical specifications, and calibration instructions, refer to the documentation for your device. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals.
    You can access the software and documentation known issues list online. Visit RFIC Test Software 20.0 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFIC Test Software. This is not an exhaustive list of issues fixed in the current version of RFIC Test Software. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    1041903[RFIC Test Soft Front Panel] NR TDD AMPM not working properly. When Idle Duration Present is TRUE, NanoSemi DPD iteration fails.
    1013545[RFIC Test Soft Front Panel] RFIC Test SFP 19.2 crashes during NanoSemi DPD.
    RFIC Test Software will drop support for Windows 7 (64-bit) and Windows Server 2008 operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    377985F-01
    GMT+8, 2025-9-6 03:08
