查看: 2788|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2.9 Win32/64Eng NI仪器驱动程序NI-RFSA 2.9
    10 小时前
    发表于 2021-2-27 23:42:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    Win32/64
    2.9
    文件大小: 3237583596 字节 (3.02 GB)
    修改日期: 2014-08-05 00:19
    MD5: 698d0bbae2a56be06f37cfd4e5afc869(官方正确)
    SHA1: 0efec018eab7332b460f70209a28c1590c91941e
    SHA256: 8acc9139f315e82af3b837633365496d6cc54b239eaf8c38bb55d809f7013db4
    CRC32: c613ab04
    RFSA2.9.txt (551 Bytes, 下载次数: 0, 售价: 10 圆)
    NI RF Signal Analyzers Readme
    Version 2.9
    February 2014
    Thank you for using NI-RFSA. This file contains important information about NI-RFSA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI RF Signal Analyzers Software
    The software installation provides support for customers using NI RF signal analyzer hardware, as specified in the Supported Hardware section. To program your NI RF signal analyzer, use the NI–RFSA instrument driver or NI-RFSA Soft Front Panel (SFP) APIs.
    The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal analyzer, as indicated in the Documentation section.
    NI-RFSA 2.9 includes the following new features:
    • Support for the NI 5646R vector signal transceiver
    • Support for SFP session access
    • Support for downloading custom bitstreams to VST devices
    • NI-RFSA Soft Front Panel 2.9, which includes the following new features:
      • Additional RBW filter types for zero span, transmit power, and CCDF measurements
      • Support for the preceding new features listed for NI-RFSA
    NI-RFSA 2.7.5 adds support for LabVIEW 2013 (32-bit) and LabVIEW 2013 (64-bit)
    NI-RFSA 2.7 adds support for the NI PXIe-5644R/5645R vector signal transceivers
    NI-RFSA 2.6 includes the following new features:
    • Support for NI 5667 3.6 GHz and 7 GHz devices
    • NI-RFSA Soft Front Panel 2.6, which includes the following new features:
      • Noise correction in adjacent channel power measurement
      • Ability to specify y-axis range as an alternative to /Div
      • Power spectral density in adjacent channel power measurement
      • Quick save/recall of SFP configurations
      • Enhanced print capabilities
      • Peak search in zero span
      • Enhanced readability of saved configuration files
    The following NI RF signal analyzer hardware products are supported in Windows 8.1 (32-bit and 64-bit)/8 (32-bit and 64-bit)/7 (32-bit and 64-bit)/Vista (32-bit and 64-bit)/Windows XP1:
    Hardware ProductNI-RFSANI-RFSA Soft Front Panel
    NI 5600
    NI 5601
    NI 5603
    NI 5605
    NI 5661
    NI 5663/5663E
    NI 5665
    NI 5667
    NI 5644R
    NI 5645R
    NI 5646R
    1 MXI Express and MXI-4 are supported on Windows 8.1/8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    NI-RFSA/NI-RFSA Soft Front Panel 2.9 and later support the following operating systems:
    • Windows 8.1 (32-bit or 64-bit)
    • Windows 8 (32-bit or 64-bit)
    • Windows 7 (32-bit or 64-bit)
    • Windows Vista (32-bit or 64-bit)
    Note  NI-RFSA/NI-RFSA Soft Front Panel 2.9 and later do not support Windows Server non-R2 editions.
    NI-RFSA 2.9 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum RunTime/Deployment System
    • Processor—Intel Pentium 4 or equivalent
    • RAM—
      • Windows 8.1/8/7/Vista: 1 GB*
      • Windows XP Service Pack 3 (SP3): 512 MB*
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    * Depending on the amount of data acquired and/or processed a larger amount of memory may be required.
    Additional Minimum Requirements for NI-RFSA Soft Front Panel
    The NI-RFSA Soft Front Panel has the following minimum requirements in addition to the minimum requirements for NI-RFSA:
    • RAM—1 GB (all operating systems)
    Recommended Development System
    • RAM—
      • Windows 8.1/8/7/Vista: 4 GB*
      • Windows XP SP3: 2 GB*
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    Note: Guest accounts are not supported under any OS.
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for ADEs installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again.
    • LabVIEW 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 SP1 (32-bit), or 2013 SP1 (64-bit)
    • LabVIEW Real-Time Module 2010 SP1, 2011 SP1, 2012 SP1, or 2013 SP1
    • LabWindows/CVI 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    • Any C compiler capable of calling a 32-bit or 64-bit DLL
    Note: The NI Spectral Measurements Toolkit must be installed for proper operation of NI RF vector signal analyzers. Install the Spectral Measurements Toolkit after installing NI-RFSA. Refer to the getting started guide for your device for more information about software and hardware installation.
    Note: MXI users must install the software included with the MXI hardware.
      • Windows 8.1/8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
    • is an alias for the following VISA file folder location:
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\VISA
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\VISA
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\National Instruments
      • Windows 8.1 (64-bit)/8 (64-bit) /7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments
      • Windows 8.1/8/7/Vista/XP: \LabVIEW
    Note: If you upgraded an installation of VISA, your folder may be located at C:\VXIPNP.
    FilesInstalled Location on Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-RFSA\Drivers\niRFSA
    NI-RFSA Function Panel\Drivers\niRFSA\nirfsa.fp
    NI-RFSA Examples\NI-RFSA\examples
    NI-RFSA Header file\Include
    NI-RFSA Import Library files\lib
    NI-RFSA DLL (32-bit)\Bin
    TDM Excel Add-In for Microsoft Excel VI\\vi.lib\Utility\tdmsutil.lib
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-RFSA Header files\Include
    NI-RFSA Import Library files (64-bit)\Lib_x64
    NI-RFSA DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel to launch the NI-RFSA Soft Front Panel.
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI RF Vector Signal Analyzers HelpHTML/Windows HelpContains primary help content for NI RF signal analyzer products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI RF signal analyzers
    • Hardware device information
    • A complete reference for all NI RF signal analyzer programming functions and VIs
    Maintain Forced-Air Cooling Note to UsersPrintedContains important cooling information for NI vector signal analyzers.
    Read Me First: Safety and Electromagnetic CompatibilityPrintedContains safety instructions and electromagnetic compatibility (EMC) information about the hardware it accompanies.
    NI–RFSA palette VIs are available from the Functions»Measurement I/O»NI–RFSA palette.
    NI–RFSA functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSA\niRFSA.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–RFSA examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSA and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFSA or by directory structure at instr»niRFSA.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSA" to locate all NI RF signal analyzer examples.
    You can also access all the installed NI–RFSA examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–RFSA»Examples.
    Examples also are available online that demonstrate integrating NI RF signal analyzers with NI RF signal generators and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Visit ni.com/critical-updates for information about critical updates and security notifications from National Instruments.
    Uninstalling/Modifying NI–RFSA
    • Click Change/Remove.
    • Select NI-RFSA 2.9 from the dialog box that appears.
    • Select Driver Run-Time.
    • Click Remove to uninstall the product(s); click Modify to change the components that are installed.
    For Windows 8.1/8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-RFSA 2.9 installation, the following software is installed. To completely remove the NI-RFSA 2.9 installation from your system, you must also remove all of the following packages:
    • NI-RFSA Run-Time 2.9
    • NI-DAQmx 9.6.1
    • NI-SCOPE 4.0.5
    • NI IVI Compliance Package 4.6
    • NI Measurement & Automation Explorer (MAX) 5.6
    • NI-RFSG 1.9.7
    • NI-FGEN Run-Time 2.9.4
    • NI IO Trace 3.0.2
    • NI System Configuration Runtime 5.6.0
    • NI-RIO 13.1
    • NI-RFSA 2.9/NI-RFSG 1.9.7 Run-Time Support for NI PXIe-5644R/5645R/5646R
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSA 2.9 and the NI-RFSA Soft Front Panel.
    • NI-RFSA Known Issues
    Bug FixesRFSA Driver Bug Fixes
    The following items are changes from NI-RFSA 2.7 to NI-RFSA 2.9.
    401891Fixed an issue in which upgrading from a previous version of the driver left express VIs unusable.
    387728Fixed an issue in which the NI-P2P attributes test failed on some controller and OS combinations with the NI 5663E.
    375643Fixed an issue in which changing the Reference Trigger type from IQ power edge to None caused errors with the NI 5661.
    387196Fixed an issue in which a RIO device was not listed in the Device Resource name control for the niRFSA Initialize VI even though it was present on the system.
    The following items are changes from NI-RFSA 2.6 to NI-RFSA 2.7.
    394079Fixed an issue in which the NI 5601 revision E modules do not behave properly with NI-RFSA 2.6.
    384602Fixed an issue in which an error occurs for certain configurations when you set the span, resolution bandwidth, and number of spectral lines properties or attributes.
    383183Fixed an issue in which calling Initialize and Close in parallel on the same device can cause the OS to deadlock.
    The following items are changes from NI-RFSA 2.5.2 to NI-RFSA 2.6.
    378277Fixed an issue in which NI-RFSA does not correct for magnitude only equalization when performing in-band retuning in spectrum acquisition mode.
    358210Fixed an issue in which NI-RFSA has a type mismatch in Fetch calls between LabVIEW and CVI.
    312899Fixed an issue in which handle leaks can occur when using the Spectral Measurements Toolkit 2.6.1 or the Modulation Toolkit 4.3.1 and earlier with the NI PXI-5660 API.
    343973Fixed an issue in which specifying a non-zero external gain with input isolation enabled causes the driver to return incorrect amplitude parameters.
    The following items are changes from NI-RFSA 2.5 to NI-RFSA 2.5.2.
    313126Fixed an issue in which NI-RFSA Express VIs in LabVIEW 2010 (64-bit) does not code generate if a later version of LabVIEW (64-bit) is installed at the same time.
    311302Fixed an issue in which NI-RFSA cannot reconfigure an acquisition session from I/Q mode to spectrum mode for the NI PXIe-5663E using NI-RFSA 2.4 or later.
    324569Fixed an issue in which testing the device resources in MAX causes the chassis controller to crash and restart for the NI PXI-5600.
    330425Fixed an issue in which EVM and MER measurements are degraded when using RF list mode for NI-RFSA versions 2.3 and later.
    The following items are changes from NI-RFSA 2.4.2 to NI-RFSA 2.5.
    304436Fixed an issue in which calling the NI-RFSA Commit VI before setting the attenuation-related properties results in incorrect gain scaling coefficients on the NI PXIe-5663 and NI PXIe-5665.
    301761Fixed an issue in which calling the NI-RFSA Reset Device VI on the NI PXIe-5622 can cause a blue screen in some instances.
    297868Fixed an issue in which users may get an undefined warning with code 88000 while using the NI PXI-5600 and changing clocking configurations.
    296450Fixed an issue in which the NI PXIe-5622 digitizer may incorrectly report a warning that the PLL came unlocked or may experience initial accuracy issues.
    288143Fixed an issue in which the NI PXIe-5622 (25 MHz) digitizer in a real-time setup does not appear under the chassis in MAX.
    287752Fixed an issue in which execution times with multiple NI-RFSA sessions is slower than expected.
    285185Fixed an issue in which NI-RFSA, with NI-SCOPE, writes incorrect calibration values to the NI PXIe-5622 during external calibration.
    279084Fixed an issue in which calling the NI-DAQmx Reset VI after calling the NI-RFSA Commit VI may cause the NI PXI-5600 firmware to return an error.
    275798Fixed an issue in which the NI PXI-5600 may hang at cold temperatures at driver initialization or reset.
    The following items are changes from NI-RFSA 2.4 to NI-RFSA 2.4.2
    305024Fixed an issue where NI-RFSA was falsely reporting temperature sensor errors for the NI PXIe-5603.
    305281Fixed an issue where NI PXIe-5603 devices calibrated with a later version of NI-RFSA do not initialize with NI-RFSA 2.4.
    NI-RFSA Soft Front Panel Bug Fixes
    The following items are changes in NI RFSA SFP 2.9 from NI RFSA SFP 2.6.1.
    Bug IDFixed Issue
    379030Fixed an issue in which the displayed offset was incorrect for offsets 13 to 15 in adjacent channel power and spectrum emission mask measurements.
    379671Fixed an issue in which the digital Start Trigger was not cleared when switching to I/Q acquisition mode.
    387636Fixed an issue in which setting the transmit power trigger level below 0 dBm incorrectly caused an error stating that the trigger level was too high.
    375392Fixed an issue in which the SFP incorrectly waited for a trigger to occur after the trigger was coerced to free run.
    369876Fixed an issue in which the values in the measurement display were not updated when recalling a file saved in an error state.
    The following item is the change in NI RFSA SFP 2.6.1 from NI RFSA SFP 2.6.
    Bug IDFixed Issue
    387363Fixed an issue in which the reference level could not be set below 0 dBm when the IQ Power Edge Trigger is enabled.
    The following items are changes in NI RFSA Soft Front Panel 2.6 from NI RFSA Soft Front Panel 2.5.5.
    Bug IDFixed Issue
    346134Fixed an issue in which the user could not set the delta marker in CCDF to a trace different from the reference marker.
    346699Fixed an issue in Zero Span with a marker enabled in which the keypad could not change the marker position if the user changed the acquisition time.
    347833Fixed an issue in spectral emission mask measurement in which the SFP sometimes disabled the I/Q Power Edge softkey when it should not.
    349655Fixed an issue in spectral emission mask measurement in which RBW and step frequency could be set lower than the minimum limit.
    356088Fixed an issue in which there was a mismatch between the analyzed range and visual indication on the user interface when the user set the Delay for an I/Q power edge trigger to a non zero value.
    345649Fixed an issue in which the SFP did not display a warning when the user recalled a configuration with the RF Coupling softkey set to DC.
    345782Fixed an issue in spectral emission mask measurement in which the SFP did not coerce the integration bandwidth when the user set the span of the reference channel to a value less than the integration BW.
    330388Fixed an issue in which a Windows command prompt window opened while closing the SFP.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI RF Signal Analyzers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI RF Signal Analyzers will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-RFSA and NI-RFSA Soft Front Panel that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:29
