查看: 2938|回复: 0
[RTE运行引擎] NI RF Signal Analyzers 15.6 Runtime Win32/64Eng NI仪器驱动程序NI-RFSA 15.6运行版
    9 小时前
    发表于 2021-2-27 23:59:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    Win32/64
    15.6RTE
    文件大小: 819999296 字节 (782.01 MB)
    修改日期: 2016-05-31 23:10
    MD5: 74c1e5be0b30acab6754c23634e50f45(官方正确)
    SHA1: 677ab248fea67c3bae2c13bb37f798643db9148b
    SHA256: e4dc3884fb0405c935f50f5a03e981942821c590dfa80c6581273e5a96fa6c16
    CRC32: 889d6c24
    RFSA15.6RTE.txt (562 Bytes, 下载次数: 0, 售价: 5 圆)
    NI RF Signal Analyzers (NI-RFSA 15.6) Readme
    April 2016
    Thank you for using NI-RFSA. This file contains important information about NI-RFSA and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI RF Signal Analyzers Software
    NI-RFSA 15.6 includes the following new features:
    • Support for the NI 5698 RF preamplifier module
    • NI-RFSA Soft Front Panel 15.6 including support for NI-RFSA Soft Front Panel 64-bit
    NI-RFSA 15.0.2 includes the following new features:
    • Improvements in NI-RFSA fetch performance
    • Improvements to the self-calibration procedure for NI 5644R/5645R/5646R devices
    NI-RFSA 15.0 includes the following new features:
    • Support for selectively omitting steps during software reset operations
    • NI-RFSA Soft Front Panel 15.0
    NI-RFSA 14.5 adds support for LabVIEW 2014 SP1 (32- and 64-bit)
    NI-RFSA 14.1 includes the following new features:
    • Support for the NI 5668R vector signal analyzer
    • Support for additional FFT window types: Gaussian and Kaiser Bessel
    • Support for overlapping subspans to remove analyzer-generated spurs
    • Support for setting Reference Trigger delay for NI 5644R/5645R/5646R devices
    • NI-RFSA Soft Front Panel 14.1, which includes the following new features:
      • Support for NI-RFSA Soft Front Panel (SFP) debug configuration
      • Support for reverting changes made in NI-RFSA SFP Control (Local) mode
      • Support for the preceding new features listed for NI-RFSA
    NI-RFSA 14.0 adds support for LabVIEW 2014 (32- and 64-bit)
    NI-RFSA 2.9 includes the following new features:
    • Support for the NI 5646R vector signal transceiver
    • Support for NI-RFSA SFP session access
    • Support for downloading custom bitstreams to VST devices
    • NI-RFSA Soft Front Panel 2.9, which includes the following new features:
      • Additional RBW filter types for zero span, transmit power, and CCDF measurements
    The following NI RF signal analyzer hardware products are supported in Windows 10 (32-bit and 64-bit)/Windows 8.1 (32-bit and 64-bit)/7 (32-bit and 64-bit)/Server 2008 (64-bit)/Server 2012 (64-bit).
    Hardware ProductNI-RFSANI-RFSA Soft Front Panel
    NI 5600
    NI 5601
    NI 5603
    NI 5605
    NI 5606
    NI 5661
    NI 5663/5663E
    NI 5665
    NI 5667
    NI 5668R
    NI 5644R
    NI 5645R
    NI 5646R
    NI 5693
    NI 5694
    NI 5698
    1 MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    NI-RFSA 15.6 and NI-RFSA Soft Front Panel 15.6 support the following operating systems:
    Note  NI-RFSA 15.6 and NI-RFSA Soft Front Panel 15.6 do not support Windows Server non-R2 editions.
    NI-RFSA 15.6 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Note  When using NI-RFSA, the NI 5644R/5645R/5646R/5668R device does not support the LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module.
    Minimum System Requirements
    • Processor—Intel Pentium 4 or equivalent
    • RAM—Windows 10/8.1/7: 1 GB*
    • Screen resolution—
      • NI-RFSA: 800 x 600
      • NI-RFSA SFP: 1,024 x 768
    • Color depth—256 colors
    Recommended System
    • RAM—Windows 10/8.1/7: 4 GB*
    Note  If you are running your application on an RT target, 128 MB of memory or more is recommended.
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for ADEs installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again.
    • LabVIEW 2012 SP1 (32- and 64-bit), 2013 SP1 (32- and 64-bit), 2014 SP1 (32- and 64-bit), or 2015 SP1 (32- and 64-bit)
    • LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, or 2015 SP1
    • LabWindows/CVI 2010 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    • Any C compiler capable of calling a 32-bit or 64-bit DLL
    Note  The NI Spectral Measurements Toolkit must be installed for proper operation of NI RF vector signal analyzers. Install the Spectral Measurements Toolkit after installing NI-RFSA. Refer to the getting started guide for your device for more information about software and hardware installation.
    Note  When using NI-RFSA, the NI 5644R/5645R/5646R/5668R device does not support LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module.
      • Windows 10/8.1/7: Users\Public\Documents\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\IVI Foundation\IVI\
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\IVI\
        • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\IVI\
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files\IVI Foundation\IVI\
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\National Instruments
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • Windows 10/8.1/7: \LabVIEW
    FilesInstalled Location on Windows 10/8.1/7
    NI-RFSA\Drivers\niRFSA
    NI-RFSA Function Panel\Drivers\niRFSA\niRFSA.fp
    NI-RFSA Examples\NI-RFSA\examples
    NI-RFSA Header file\Include
    NI-RFSA Import Library files\lib
    NI-RFSA DLL (32-bit)\Bin
    TDM Excel Add-In for Microsoft Excel VI\vi.lib\Utility\tdmsutil.lib
    Additional File Locations for Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)
    ItemInstalled Location on Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)
    NI-RFSA Header files\Include
    NI-RFSA Import Library files (64-bit)\Lib_x64
    NI-RFSA DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel to launch the NI-RFSA SFP.
    DocumentFormatDescription
    NI RF Vector Signal Analyzers HelpHTML/Windows HelpContains primary help content for NI RF signal analyzer products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI RF signal analyzers
    • Hardware device information
    • A complete reference for all NI RF signal analyzer programming functions and VIs
    NI–RFSA palette VIs are available from the Functions»Measurement I/O»NI–RFSA palette.
    NI–RFSA functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSA\niRFSA.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–RFSA examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSA and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFSA or by directory structure at instr»niRFSA.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSA" to locate all NI RF signal analyzer examples.
    You can also access all the installed NI–RFSA examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–RFSA»NI-RFSA Examples.
    Examples also are available online that demonstrate integrating NI RF signal analyzers with NI RF signal generators and NI toolkit software, including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-RFSA versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-RFSA 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme was NI-RFSA 2.9.1. The first version released under the new numbering scheme was NI-RFSA 14.0.
    Uninstalling/Modifying NI–RFSA
    • Select NI-RFSA 15.6 from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Click the Uninstall button.
    For Windows 10, complete the following steps:
    • Click the Start button.
    As part of the NI-RFSA 15.6 installation, the following software is installed. To completely remove the NI-RFSA 15.6 installation from your system, you must also remove all of the following packages:
    • NI-RFSA Runtime 15.6
    • NI-DAQmx Config 15.0.1
    • NI-SCOPE 15.1.1
    • NI IVI Compliance Package 15.0
    • NI Measurement & Automation Explorer (MAX) 15.0
    • NI-RFSG 15.0.3
    • NI-FGEN Runtime 15.0
    • NI IO Trace 15.0
    • NI System Configuration Runtime 15.0
    • NI-RIO 15.0
    • NI-RFSA/NI-RFSG Runtime 15.0.2 for NI VST
    • NI IF Digitizers Software-Designed Instrument Runtime 15.0
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSA 15.6 and the NI-RFSA SFP.
    • NI-RFSA Known Issues
    Bug FixesNI-RFSA Driver Bug Fixes
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSA instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI–RFSA.
    The following items are changes from NI-RFSA 15.0 to NI-RFSA 15.6.
    566038Fixed an issue in which large temperature changes on the NI 5665 and NI 5668R did not force new settings to deploy, causing deviations from spec performance.
    The following items are changes from NI-RFSA 14.1 to NI-RFSA 14.5.
    509550Fixed an issue in which spurs were observed every 385 kHz for low reference level measurements.
    458168Fixed an issue in which read power spectrum returned incorrect data when called continuously.
    489736Fixed an issue in which the system displayed an ambiguous error when setting the IQ Power Edge Reference Trigger in a multispan acquisition.
    501291Fixed an issue in which the niRFSA_GetRelayOperationsCount function was not supported by NI 5606/5668R devices.
    505948Fixed an issue in which an unexpected data overflow error occurred with sample rates greater than 500 MS/s on NI 5606/5668R devices.
    The following items are changes from NI-RFSA 14.0 to NI-RFSA 14.1.
    492490Fixed an issue in which the proper LabVIEW Run-Time Engine was not installed.
    The following items are changes from NI-RFSA 2.9.1 to NI-RFSA 14.0.
    465141Fixed an issue in which fetch performance on VST devices degrades.
    The following items are changes from NI-RFSA 2.9 to NI-RFSA 2.9.1.
    459297Fixed an issue in which the IQ IN Single Ended vertical range was incorrectly limited to 1 Vpk-pk.
    The following items are changes from NI-RFSA 2.7 to NI-RFSA 2.9.
    401891Fixed an issue in which upgrading from a previous version of the driver left express VIs unusable.
    387728Fixed an issue in which the NI-P2P attributes test failed on some controller and OS combinations with the NI 5663E.
    375643Fixed an issue in which changing the Reference Trigger type from IQ power edge to None caused errors with the NI 5661.
    387196Fixed an issue in which a RIO device was not listed in the Device Resource name control for the niRFSA Initialize VI even though it was present on the system.
    NI-RFSA Soft Front Panel Bug Fixes
    There are no behavior changes in NI-RFSA SFP 15.6 from NI-RFSA SFP 14.1 other than the new features previously listed.
    The following items are changes in NI-RFSA SFP 14.1 from NI-RFSA SFP 14.0
    453860Fixed an issue in which the automatic video bandwidth value in NI-RFSA SFP Control (Local) mode was being incorrectly calculated.
    442518Fixed an issue in which clicking preset after closing a device session in NI-RFSA SFP Control (Local) mode returned an error.
    486765Fixed an issue in which the NI-RFSA SFP Launcher example for NI TestStand did not automatically enable NI-RFSA SFP session access.
    485420Fixed an issue in which certain NI-RFSA SFP trigger coercion warnings were automatically cleared when entering NI-RFSA SFP Control (Local) mode.
    There are no behavior changes in NI-RFSA SFP 14.0 from NI-RFSA SFP 2.9 other than the new features previously listed.
    The following items are changes in NI-RFSA SFP 2.9 from NI-RFSA SFP 2.6.1.
    379030Fixed an issue in which the displayed offset was incorrect for offsets 13 to 15 in adjacent channel power and spectrum emission mask measurements.
    379671Fixed an issue in which the digital Start Trigger was not cleared when switching to I/Q acquisition mode.
    387636Fixed an issue in which setting the transmit power trigger level below 0 dBm incorrectly caused an error stating that the trigger level was too high.
    375392Fixed an issue in which the NI-RFSA SFP incorrectly waited for a trigger to occur after the trigger was coerced to free run.
    369876Fixed an issue in which the values in the measurement display were not updated when recalling a file saved in an error state.
    NI RF Signal Analyzers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFSA drops support for Microsoft Windows Vista, Windows XP, and Windows Server 2003. NI-RFSA 15.6 and later will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2016 National Instruments. All rights reserved.
    374797F-01
    GMT+8, 2025-12-8 18:58
