查看: 2389|回复: 0
[NI驱动程序] NI RF Signal Analyzers 18.0 Win32/64Eng NI仪器驱动程序NI-RFSA 18.0
    6 小时前
  • 签到天数: 3775 天
    连续签到: 26 天
    发表于 2021-2-28 00:18:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    Win32/64
    18.0
    文件大小: 4279423155 字节 (3.99 GB)
    修改日期: 2018-06-29 00:51
    MD5: a738cdff79ef0eb41918ec816c443911(官方正确)
    SHA1: 048988939672f03ce38d107608c999a2926fb142
    SHA256: 1d1cadd1a010e273c23a644a078f2ddc4da8c6e308f1c06d06bc031ea9aa2c55
    CRC32: 23b55987
    RFSA18.0.txt (557 Bytes, 下载次数: 0, 售价: 10 圆)
    NI RF Signal Analyzers (NI-RFSA 18.0) Readme
    May 2018
    This file contains important information about NI-RFSA, including new features, supported hardware, a partial list of bugs fixed for NI-RFSA 18.0, and known issues.
    This software installation provides support for customers using vector signal analyzer hardware, as specified in the Supported Hardware section. To program your vector signal analyzer, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using a vector signal analyzer.
    NI-RFSA 18.0 adds support for LabVIEW 2018 (32- and 64-bit)
    NI-RFSA 17.1 includes the following new features:
    • Support for the PXIe-5820
    • Support for RF list mode on the PXIe-5820/5840
    • Support for System Configuration API and Measurement & Automation Explorer (MAX) for module temperature and self-calibration date and time
    • NI-RFSA Soft Front Panel (SFP) debug with 64-bit support
    • Support for sub-sample trigger and event resolution on the PFI line for the PXIe-5820/5840
    NI-RFSA 17.0 adds support for LabVIEW 2017 (32- and 64-bit)
    NI-RFSA 16.0 includes the following new features:
    • Support for the PXIe-5840
    • Improvements to initiate the performance for the PXIe-5644/5645/5646
    Hardware ProductHardware ModelNI-RFSANI-RFSA Soft Front Panel
    RF Signal DownconverterPXI-5600
    PXIe-5601
    PXIe-5603
    PXIe-5605
    PXIe-5606
    Vector Signal AnalyzerPXI-5661
    PXIe-5663/5663E
    PXIe-5665
    PXIe-5667
    PXIe-5668
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5840
    RF Preselector ModulePXIe-5693
    IF Conditioning ModulePXIe-5694
    RF AmplifierPXIe-5698
    Note  MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    • 4 GB RAM*
    NI-RFSA 18.0 and NI-RFSA Soft Front Panel 18.0 support the following operating systems:
    • Windows 10, 8.11, 7 SP12
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  In 2016 NI-RFSA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-RFSA 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSA 18.0 to an unsupported OS. Additionally, after installing NI-RFSA 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by NI-RFSA
    LabVIEW2015 SP1, 2016, 2017 SP1, or 2018
    LabVIEW Real-Time Module2015 SP1, 2016, 2017, or 2018
    LabWindows/CVI2010 and later
    LabWindows/CVI Real-Time Module2010 and later
    Note  When using NI-RFSA with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5668, and PXIe-5820/5840 are not supported.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to:
    • (32-bit) Program Files\IVI Foundation\IVI\Bin\niRFSA.dll
    • (64-bit) Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    To launch the NI-RFSA Soft Front Panel, navigate to the following location:
    • (32-bit) Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    • (64-bit) Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel (64-bit)
    DocumentFormatDescription
    • Hardware device overviews
    NI-RFSA no longer installs IVI Compliance Package. NI-RFSA supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSA 18.0 and the NI-RFSA SFP 18.0.
    • NI-RFSA Known Issues
    Bug FixesNI-RFSA Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSA instrument driver revisions. This is not an exhaustive list of issues fixed in the current version of NI-RFSA.
    NI-RFSA 17.1.2
    664698Fixed an issue in which a timeout error occurred when TClk was used with PXIe-5820/5840 devices using the WLAN Toolkit.
    NI-RFSA 17.1
    589447Fixed an issue in which an incomplete error description was returned if the value of the Spectrum OSP Sampling Ratio property or the NIRFSA_ATTR_OSP_SAMPLING_RATIO attribute was invalid for the PXIe-5840.
    601860Fixed an issue in which an error occurred when changing the device name of the PXIe-5840 in MAX.
    456000Fixed an issue in which an installer built with LabVIEW Application Builder and NI-RFSA 2.7.5 failed.
    642621Fixed an issue in which the PXIe-5668 could not initiate before settling was complete when switching IF filters or settling configurations.
    640124Fixed an issue in which the PXIe-5840 could show a slow phase drift below 400 MHz.
    541356Fixed an issue in which attribute names did not show up correctly in I/O trace.
    361166Fixed an issue in which passing NULL as the value for some parameters caused exceptions.
    NI-RFSA 16.0
    577048Fixed an issue in which NI-RFSA caused an exception with I/O trace enabled.
    579468Fixed an issue in which NI-RFSA returned a ADC or DSP overflow warning multiple times when the niRFSA Check Acquisition Status VI was called after an acquisition was complete.
    576744Fixed an issue in which simulation caused the PXIe-5644/5645/5646 devices to return an invalid reference error.
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSA SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSA SFP.
    NI-RFSA SFP 16.0
    581172Fixed an issue in which Classic NI-RFSA SFP launched from the MAX Tools Menu instead of the new NI-RFSA SFP (64-bit).
    NI-RFSA SFP 14.1
    453860Fixed an issue in which the automatic video bandwidth value in NI-RFSA SFP Control (Local) mode was being incorrectly calculated.
    442518Fixed an issue in which clicking preset after closing a device session in NI-RFSA SFP Control (Local) mode returned an error.
    486765Fixed an issue in which the NI-RFSA SFP Launcher example for NI TestStand did not automatically enable NI-RFSA SFP session access.
    485420Fixed an issue in which certain NI-RFSA SFP trigger coercion warnings were automatically cleared when entering NI-RFSA SFP Control (Local) mode.
    © 2004–2018 National Instruments. All rights reserved.
    374797L-01
    GMT+8, 2026-1-17 16:35
