查看: 2850|回复: 0
[NI驱动程序] NI RF Signal Analyzers 19.2.1 Win64Eng NI仪器驱动程序NI-RFSA 19.2.1
    10 小时前
    发表于 2021-2-28 00:36:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    Win64
    19.2.1
    文件大小: 4566417408 字节 (4.25 GB)
    修改日期: 2020-02-15 00:49
    MD5: e318c30de438e76c769bb0958e149c9d(官方正确)
    SHA1: 7e2f311f158f83dfd26c137a7c09886459460a06
    SHA256: 0da5582db8f5b91850c8c0ab6a08670aecda7527e7ed77f0bab6e87db0c05eba
    CRC32: 9ee32345
    RFSA19.2.1.txt (592 Bytes, 下载次数: 0, 售价: 10 圆)
    NI RF Signal Analyzers (NI-RFSA 19.2.1) Readme
    February 2020
    This file contains important information about NI-RFSA, including new features, supported hardware, a partial list of bugs fixed for NI-RFSA 19.2.1, and known issues.
    NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 19.2.1 includes support for configuring the pulse width of the user source signals
    NI-RFSA 19.2 includes support for the PXIe-5841 with PXIe-5655
    NI-RFSA 19.1.6 includes improvements for the PXIe-5831 in the Semiconductor Test System
    NI-RFSA 19.1.5 includes support for the PXIe-5841
    NI-RFSA 19.1 includes the following new features:
    • Support for the PXIe-5830/5831
    • Support for LO sharing on the PXIe-5830/5831 to improve phase noise performance
    NI-RFSA 19.0 includes support for LabVIEW 2019
    NI-RFSA 18.2 includes the following new features:
    • Support for specifying digital gain on the PXIe-5820/5840
    • Support for de-embedding measurements on the PXIe-5840
    • Improvements to communication performance on the PXIe-5820/5840
    • Support for specifying external calibration date for the PXIe-5644/5645/5646 and PXIe-5820/5840 in System Configuration API and MAX
    NI-RFSA 18.1 includes the following new features:
    • Support for NI-TClk on the PXIe-5668
    • Support for the PXIe-5840 with PXIe-5653 in the NI-RFSA SFP
    • Added Fetch IQ (1D I16 Data Ref) for improved fetch and streaming performance
    • Improvements to initiate performance on the PXIe-5820/5840
    • Support for associating the PXIe-5840 with the PXIe-5653 LO source
    • Support for controlling the RF OUT LO OUT terminal on the PXIe-5840
    • Support for PXIe-5820/5840 self-calibration in System Configuration API
    • Support for modifying temperature resolution for automatic thermal correction
    • Support for modifying DMA buffer size to improve NI-RFSA fetch performance
    • Support for clearing self calibrate range data on the PXIe-5644/5645/5646
    NI-RFSA 18.0 includes the following new features:
    • Added support for LabVIEW 2018
    • Added the NI-RFSA .NET Class Library and NI-RFSA .NET examples to the installer
    NI-RFSA 17.1 includes the following new features:
    • Support for the PXIe-5820
    • Support for RF list mode on the PXIe-5820/5840
    • Support for System Configuration API and MAX for module temperature and self-calibration date and time
    • NI-RFSA SFP debug with 64-bit support
    • Support for sub-sample trigger and event resolution on the PFI line for the PXIe-5820/5840
    Hardware ProductHardware ModelNI-RFSANI-RFSA Soft Front Panel
    RF Signal DownconverterPXI-5600
    PXIe-5601
    PXIe-5603
    PXIe-5605
    PXIe-5606
    Vector Signal AnalyzerPXI-5661
    PXIe-5663/5663E
    PXIe-5665
    PXIe-5667
    PXIe-5668
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5840
    RF Analog Signal Generator
    PXIe-5841
    RF Preselector ModulePXIe-5693
    IF Conditioning ModulePXIe-5694
    RF AmplifierPXIe-5698
    MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5840/5841 if you choose to install the runtimes independently.
    Note  For best memory performance on the PXIe-5831, NI recommends using only 64-bit applications.
    • 4 GB RAM*
    NI-RFSA 19.2.1 and NI-RFSA SFP 19.2 support the following operating systems:
    • Windows 10, 8.11, 7 SP12 (64-bit)
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  In 2019 NI-RFSA dropped support for all 32-bit Windows operating systems. NI-RFSA will not install or run on an unsupported OS. Refer to NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Application SoftwareVersions Supported by NI-RFSA
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    LabVIEW Real-Time Module2016, 2017, 2018 SP1, or 2019
    LabWindows/CVI2010 to current
    LabWindows/CVI Real-Time Module2010 to current
    Note  When using NI-RFSA with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5668, and PXIe-5820/5830/5831/5840/5841 are not supported.
    NI installs NI-RFSA using NI Package Manager. If you do not already have NI software installed, NI-RFSA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    DocumentFormatDescription
    • Hardware device overviews
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    The following are behavior changes in NI-RFSA 18.2 from NI-RFSA 18.1:
    • Support was removed for the PXIe-5653 Test Panel in MAX.
    • The NI-RFSA Express VIs are now obsolete and are no longer installed.
    • The NI-RFSA RF Out LO Export Enabled property no longer requires the NI-RFSG LO Out Export Configure From RFSA property to be set to Enabled. NI-RFSA can change the export state of NI-RFSG without an open NI-RFSG session on the PXIe-5840. Ensure the NI-RFSG LO out export is generating a useful signal before using that signal for NI-RFSA operations.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSA 19.2.1 and the NI-RFSA SFP 19.2.
    • NI-RFSA Known Issues
    Bug FixesNI-RFSA Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSA instrument driver revisions. This is not an exhaustive list of issues fixed in the current version of NI-RFSA.
    NI-RFSA 19.2.1
    Bug 955129Fixed an issue in which initializing the PXIe-5820 with RFmx failed.
    NI-RFSA 19.1.6
    Bug 192172Fixed an issue in which some PXIe-5831 modules timed out during Initiate.
    NI-RFSA 19.1.5
    CAR 742917Fixed an issue in which a PXIe-5840 configured to use an external LO rounded the external frequency if set through the Downconverter Center Frequency property or Downconverter Frequency Offset property instead of the LO Frequency property.
    NI-RFSA 19.1
    CAR 733780Fixed an issue in which the PXIe-5820/5840 did not hold Reference Clock and LO export terminal reservations after calling Commit.
    NI-RFSA 18.2
    CAR 721449Fixed an issue in which initiating a spectrum acquisition with averaging enabled on multiple PXIe-5644/5645/5646 devices caused the computed spectrum to mix between the devices.
    CAR 670356Fixed an issue in which NI-RFSA returned a power level error if the PXIe-5840 temperature drift exceeded 10 °C from the last self-calibration temperature.
    CAR 728932Fixed an issue in which digital gain was not applied to the PXIe-5644/5645/5646 when List mode was enabled.
    NI-RFSA 18.1
    CAR 412860Fixed an issue in which synchronization examples for the PXIe-5663/5663E displayed a PLL lock error.
    CAR 527859Fixed an issue in which software triggers were delayed for the PXIe-5820/5840.
    CAR 550256Fixed an issue in which NI-RFSA would crash MAX.
    CAR 604266Fixed an issue in which I/Q power triggers were delayed across I/Q rates for the PXIe-5668.
    CAR 604856Fixed an issue in which error message text contained multiple unrelated warnings and errors.
    CAR 649030Fixed an issue in which the PXIe-5820/5840 always returned 0 as the value for t0.
    CAR 660046Fixed an issue in which the Reference Trigger delay was ignored when using NI-TClk with the PXIe-5820/5840.
    CAR 666113Fixed an issue in which automatic routing between the PXIe-5668 and another device resulted in an error.
    CAR 668974Fixed an issue in which the PXIe-5840 amplitude accuracy degraded after calling Perform Thermal Correction.
    CAR 682389Fixed an issue in which the PXIe-5820/5840 trigger alignment was imprecise when using the PXI trigger lines.
    CAR 685044Fixed an issue where calling Reset on the PXIe-5840 reset the LO source to Onboard, even if the LO source was specified in the driver setup string.
    CAR 689717Fixed an issue in which the PXIe-5644/5645/5646 and PXIe-5820/5840 showed an incorrect calibration time in MAX when the system timezone was greater than UTC+0.
    CAR 697475Fixed an issue in which setting the calibration due date or retrieving the last date of external calibration for the PXIe-5820/5840 was not possible.
    CAR 679890Fixed an issue in which using the PXIe-5668 intermittently caused the system to hang.
    NI-RFSA 17.1.2
    CAR 664698Fixed an issue in which a timeout error occurred when TClk was used with PXIe-5820/5840 devices using the WLAN Toolkit.
    NI-RFSA 17.1
    CAR 589447Fixed an issue in which an incomplete error description was returned if the value of the Spectrum OSP Sampling Ratio property or the NIRFSA_ATTR_OSP_SAMPLING_RATIO attribute was invalid for the PXIe-5840.
    CAR 601860Fixed an issue in which an error occurred when changing the device name of the PXIe-5840 in MAX.
    CAR 456000Fixed an issue in which an installer built with LabVIEW Application Builder and NI-RFSA 2.7.5 failed.
    CAR 642621Fixed an issue in which the PXIe-5668 could not initiate before settling was complete when switching IF filters or settling configurations.
    CAR 640124Fixed an issue in which the PXIe-5840 could show a slow phase drift below 400 MHz.
    CAR 541356Fixed an issue in which attribute names did not show up correctly in I/O trace.
    CAR 361166Fixed an issue in which passing NULL as the value for some parameters caused exceptions.
    NI-RFSA SFP
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSA SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSA SFP.
    NI-RFSA SFP 18.1
    CAR 660985Fixed an issue in which an NI-RFSA SFP debug session for the PXIe-5840 did not work from a C/C++ session.
    NI-RFSA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    374797Y-01
    GMT+8, 2025-12-8 19:29
