查看: 3484|回复: 0
[NI驱动程序] NI RF Signal Generators 1.9.5 Win32/64Eng NI RF信号发生器NI-RFSG1.9.5
    3 小时前
  • 签到天数: 3734 天
    连续签到: 61 天
    发表于 2021-3-1 23:36:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    1.9.5
    文件大小: 2436357644 字节 (2.27 GB)
    修改日期: 2013-08-20 01:02
    MD5: c46667d5ad0e686dcede1fa707a1cd7c(官方正确)
    SHA1: 4532d0c158cc25cc24d37164dbd859dab56e5c73
    SHA256: f8d9a6f4297bb2c79589b937d38cf26a7693c33ac5cd702123a6c4393172d776
    CRC32: 53c1f227
    RFSA1.9.5.txt (557 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG Readme
    2013
    Version 1.9.5
    Thank you for using the NI–RFSG instrument driver for Windows 8/7/Vista/XP. NI–RFSG 1.9.5 includes support for NI RF signal generators.
    This file contains important information about this release and is organized into the following sections:
    • NI RF Signal Generators Software
    • New Features
    • Supported Hardware
    • System Requirements
      • VIs and Functions
      • Examples
      • Documentation
    • Installing the NI–RFSG Instrument Driver
    • Updates and Notifications
    • Uninstalling/Modifying the NI–RFSG Instrument Driver
    • Known Issues
    • Behavior Changes and Upgrade Notes
    • Bug Fixes
    • How to Use NI Software with Microsoft Windows 8
    • NI-RFSG Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    • Important Information
    The software installation provides support for customers using NI RF signal generator hardware, as specified in the Supported Hardware section. To program the NI RF signal generator, use the NI–RFSG API.
    The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal generator.
    NI–RFSG 1.9.5 includes the following new features:
    • Support for LabVIEW 2013 (32-bit), 2013 (64-bit)
    • Support removed for LabVIEW 2009
    NI–RFSG 1.9 includes the following new features:
    • Support for the NI PXIe-5644R/5645R vector signal transceivers
    • Includes the NI-RFSG Soft Front Panel (SFP) in the NI-RFSG installer
    • Improved the Measurement & Automation Explorer (MAX) test panel to use the NI-RFSG SFP
    • Improved representation of multiple-module devices in MAX
    NI–RFSG 1.8.5 includes the following new features:
    • Support for LabVIEW 2012 (32-bit), 2012 (64-bit)
    • Support for LabVIEW 2011 SP1 (32-bit), 2011 SP1 (64-bit)
    • Support removed for LabVIEW 8.6.1
    NI–RFSG 1.8 includes the following new features:
    • Support for streaming write timeout.
    • Improved I/Q rate reconfiguration time.
    • Support for NI-RFSG run-time custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI RF signal generators.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using MAX.
      • The run-time installer does not support upgrading from NI-RFSG 1.8.x or earlier, NI-FGEN 2.8.x or earlier, or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-RFSG Run-Time installer.
    • Support for saving per-waveform properties and attributes
    • Support for NI PXI/PXIe-5650/5651/5652 external calibration
    • Support for NI PXI-5670/5671 and NI PXIe-5672 terminal names
    NI–RFSG 1.7.3 includes the following new features:
    • Support for LabVIEW 2011 (32-bit), 2011 (64-bit)
    • Support removed for LabVIEW 8.5
    NI–RFSG 1.7 includes the following new features:
    • Support for peer-to-peer streaming with the NI PXIe-5673E. This feature requires updating the firmware on the NI PXIe-5450/5451. Refer to the following bullet for more information about updating the firmware.
    • New firmware for the NI PXIe-5450/5451. This firmware upgrade is required for all NI PXIe-5450/5451 devices. After driver installation, refer to the Upgrading Firmware section of the NI-FGEN Instrument Driver Readme at Start»All Programs»National Instruments»NI-FGEN»Documentation.
    • Support for the NI PXIe-5653 synthesizer
    • Support for LabVIEW 2009 (64-bit), 2010 (32-bit), and 2010 (64-bit)
    • Support for list mode for the NI PXIe-5650/5651/5652
    • Simulation support for the NI PXIe-5673.
    • Support to reset writeable properties and attributes to driver default values
    • Support for RF list mode DMA
    • Support removed for LabWindows™/CVI™ 7.1.1
    NI–RFSG 1.6.4 includes the following new features:
    • Support for LabVIEW 2010 (32-bit)
    • Support removed for LabVIEW 8.2.1 and 8.2
    NI–RFSG 1.6.2 includes the following fixes:
    • Fixed the fatal issue when upgrading NI-RFSG on Windows 7 (64-bit) and Windows Server 2008 R2
    NI–RFSG 1.6.1 includes the following new features:
    • Support NI PXIe-5650/5651/5652 RF signal generator
    • Improved tuning time
    • Improved harmonics
    • Support for external clocking configuration
    • Support removed for LabVIEW 8.0
    The following NI RF signal generator hardware products are supported in Windows 8 (32-bit and 64-bit)1/Windows 7 (32-bit and 64-bit)/Windows Vista (32-bit and 64-bit)/Windows XP:
    • NI PXI-5610
    • NI PXIe-5611
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXI/PXIe-5650
    • NI PXI/PXIe-5651
    • NI PXI/PXIe-5652
    • NI PXIe-5653
    • NI PXI-5670
    • NI PXI-5671
    • NI PXIe-5672
    • NI PXIe-5673/5673E
    1 Notice that MXI-4 is supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP. MXI Express is supported on Windows 8/7/Vista/XP.
    NI–RFSG supports most National Instruments RF signal generator modules on Real-Time targets. When using NI-RFSG, the NI 5644R/5645R device does not support LabVIEW Real-Time or LabWindows/CVI Real-Time Modules.
    NI-RFSG 1.9.5 supports the following operating systems:
    Note  NI-RFSG 1.9.5 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    NI-RFSG 1.9.5 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Note:When using NI-RFSG, the NI 5644R/5645R device does not support LabVIEW Real-Time or LabWindows/CVI Real-Time Modules.
    Minimum Runtime/Deployment System
    • RAM—
      • Windows 8/7/Vista: 1 GB
      • Windows XP Service Pack 3 (SP3): 512 MB
      Note:Depending on the amount of data generated or processed, a larger amount of RAM may be required.
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended Development System
    • RAM—
      • Windows 8/7/Vista: 4 GB
      • Windows XP SP3: 2 GB
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    • Guest accounts are not supported under any OS.
    Application Development Environments
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again.
    • LabVIEW 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 (32-bit), or 2013 (64-bit)
    • LabVIEW Real-Time Module 2010 SP1, 2011 SP1, 2012 SP1 or 2013
    • LabWindows/CVI 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    Note:The NI 5644R/5645R device is not supported when using 64-bit LabVIEW, LabVIEW Real-Time Module, or LabWindows/CVI Real-Time Module.
    Verify that LabVIEW or LabWindows/CVI is installed on your system prior to installing the NI–RFSG instrument driver software. Install NI–RFSG by inserting the driver software DVD into your drive and click setup.exe.
    Note:Install any toolkits or add-on software you intend to use with the NI–RFSG instrument driver after NI–RFSG installation is complete.
    Note:MXI users must install the software included with the MXI hardware.
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files\Lib
    NI-RFSG DLL\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-RFSG Function Panel\Drivers\niRFSG\nirfsg.fp
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    VIs and FunctionsNI–RFSG palette VIs are available from the Functions»Measurement I/O»NI–RFSG palette.
    NI–RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSG function panel (fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSG\niRFSG.fp.Examples
    LabVIEW users can use the NI Example Finder to search or browse examples. NI–RFSG examples are classified by keyword, so you can search for a particular device or measurements function. With LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    LabVIEW and LabWindows/CVI users also can access all the installed NI–RFSG examples at Start»All Programs»National Instruments»NI–RFSG»Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to the NI Developer Zone on the Web at ni.com/examples for these examples and for more information.
    Documentation is available at Start»All Programs»National Instruments»NI–RFSG»Documentation. The documentation set is composed of the following documents:
    • NI-RFSG Readme (this document)
    • NI RF Signal Generators Help—HTML help format. Includes RF fundamentals, hardware device overviews, programming information, LabVIEW reference and C function reference sections.
    • Getting started guide for your device—Printed and PDF format. Contains hardware and software installation, MAX configuration, and troubleshooting information.
    • Specifications for your device—Printed and PDF format. Lists specifications for your device.
    • Calibration procedures for your device—Available at ni.com/calibration.
    Note:To view many of these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Visit ni.com/manuals to find the latest versions of product documentation.
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    • Click Change/Remove.
    • Select NI–RFSG 1.9.5 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Right-click the Start screen.
    • Click the Uninstall button.
    • Select NI-RFSG 1.9.5 from the dialog box that appears.
    As part of the NI–RFSG installation, the following software is installed. To completely remove the NI–RFSG installation from your system, you must also remove all of the following packages:
    • NI-RFSG Run-Time 1.9.5
    • NI-DAQmx 9.6.1
    • NI-FGEN Run-Time 2.9.3
    • NI-VISA Run-Time 5.0
    • NI Measurement & Automation Explorer (MAX) 5.4
    • NI I/O Trace 3.0.2
    • NI System Configuration Runtime 5.4.0
    • NI Hierarchical Waveform Storage 1.5.1
    • NI-RIO 12.0
    • NI-RFSA 2.7/NI-RFSG 1.9 Run-Time Support for PXIe-5644R/5645R
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Note:Do not attempt to uninstall by manually deleting files.
    You can access the software and documentation known issues list online. Refer to the NI-RFSG known issues at ni.com for an up-to-date list of known issues in NI-RFSG 1.9.5.
    NI–RFSG 1.9
    • The NI-RFSG Soft Front Panel (SFP) replaces the MAX test panel functionality for your device. In NI-RFSG 1.8.5 and earlier, you could use the MAX test panel with LabVIEW Real-Time targets. NI-RFSG SFP 1.9.5 does not support Real-Time applications.
    • The NI-RFSG SFP 1.9.5 does not support the NI PXI-5610 with an external arbitrary waveform generator (AWG) module. In NI-RFSG 1.8.5 and earlier, the MAX test panel supported the NI PXI-5610 with an external AWG module.
    NI–RFSG 1.8
    • The rfsg_Complex Multitone II example generates correct power levels when using mirror-image.
    NI–RFSG 1.7
    • When RF list mode was introduced in NI-RFSG 1.6, if the device was committed, setting the Output Enabled property or NIRFSG_ATTR_OUTPUT_ENABLE attribute to FALSE immediately affected the output. In RFSG 1.7 and later, you must call the niRFSG Commit VI or niRFSG_Commit function to apply property or attribute changes while list mode is active.
    • The awgModel driver setup string keyword is deprecated and is now an alias for the keyword awg. In NI-RFSG 1.6.1 and earlier, you could specify which type of arbitrary waveform generator (AWG) to use in a simulated composite device session using the awgModel keyword. The keyword awg now suffices for both real and simulated sessions. Programs that use the deprecated awgModel continue to work, but if you specify both awg and awgModel, the following error message is returned:
      -1074117644: The 'DriverSetup' entry in the Option String is invalid.
    NI–RFSG 1.6.1
    • The NI PXIe-5673/5673E automatically enables the Compensate for Filter Group Delay property or NIFGEN_ATTR_OSP_COMPENSATE_FOR_FILTER_GROUP_DELAY attribute, and the timing between events and analog output changes. This behavior causes any prior customization of a filter group delay to be invalid. To revert to the original behavior, disable the property in the NI-FGEN property node or attribute with an NI-FGEN Set function during your NI-FGEN session. If an NI PXIe-5450 with module revisions A or B is used as part of your NI PXIe-5673/5673E, the NI-FGEN Compensate for Filter Group Delay property is disabled if the requested I/Q rate is less than 1.5 MS/s.
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSG driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI–RFSG.
    NI–RFSG 1.9.5
    392343Fixed an issue where errors occur during IVI simulation of NI 5610- or NI 5611-based devices.
    NI–RFSG 1.9
    376578Fixed an issue where verification on the NI PXI/PXIe-5650/5651/5652 devices fails at low power levels after an external calibration.
    378637Fixed an issue where nominal frequencies are returned rather than coerced values during NI PXI/PXIe-5650/5651/5652 external calibration.
    325416Fixed an issue where the Reference clock can not be exported to REF OUT2 connector of the NI 5673E.
    NI–RFSG 1.8
    313067Fixed an issue where peak envelope power erroneously returns a value of negative inifinity.
    308426Fixed an issue where the FPGA on the NI PXI/PXIe-5650/5651/5652 can fail to transition out of Configuration mode due to the slow rise time of the FPGA DONE signal.
    248280Fixed an issue where changing the value on the Modulation Waveform Type parameter or NIRFSG_ATTR_MODULATION_WAVEFORM_TYPE attribute sometimes shows no modulation.
    216961Fixed an issue where the niRFSG Self Calibration VI crashes when running the NI PXI-5671 on an RT target.
    117342Fixed an issue where generating scripts using scripting on the NI PXI-5670/5671 takes an increasingly long time.
    NI–RFSG 1.7.3
    308247Fixed an issue where occasionally some NI PXI/PXIe-5650/5651/5652 modules fail to power on properly during system startup.
    NI–RFSG 1.7
    252863Fixed an issue where some NI PXI/PXIe-5652 devices fail to meet specifications for subharmonics at 4.2 GHz.
    241656Fixed NI PXIe-5450/5451 firmware to synchronize power supplies for improved phase noise performance. Firmware upgrade is required for all NI PXIe-5450/5451 devices.
    241512Fixed an issue where switching from CW generation mode to script generation mode causes an unspecified script error.
    231741Fixed an issue where the LabVIEW Meta Deployment Framework does not deploy NI-RFSG on Windows 64-bit when created on Windows 32-bit.
    237039Fixed an issue where the NI PXI-5650/5651/5652 returned incorrect module revisions.
    233386Fixed an issue where no self-calibration is available on the NI PXI-5610 in Measurement & Automation Explorer.
    NI-RFSG 1.6.3
    229602Fixed an issue with clock configuration that can cause memory corruption or bluescreen with certain NI PXIe-5450 boards.
    212209Fixed an incorrect calibration DAC setting that could cause self-calibration to fail on the NI PXIe-5451.
    NI–RFSG 1.6.2
    209051Fixed the fatal issue when upgrading NI-RFSG on Windows 7 (64-bit) and Windows Server 2008 R2
    NI–RFSG 1.6.1
    169736Fixed an issue where checking if the output of an NI 5673 has settled returns early in some cases.
    156921Fixed the LabVIEW Call Library nodes to minimize mass compile errors when VIs are moved to different folders.
    158076Fixed an issue where the NI 5673 requires a commit to read the last calibration date and time.
    Using NI Launcher
    Finding All Programs
    NI-RFSG Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-RFSG will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-RFSG that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-6 15:32
