查看: 3017|回复: 0
[NI驱动程序] NI RF Signal Generators 16.0 Win32/64Eng NI RF信号发生器NI-RFSG16.0
    3 小时前
  • 签到天数: 3734 天
    连续签到: 61 天
    发表于 2021-3-1 23:50:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    16.0
    文件大小: 3527569600 字节 (3.29 GB)
    修改日期: 2016-12-15 05:10
    MD5: 13e07f218e9737d0b22acc188ac7ef68(官方正确)
    SHA1: 18b7c033795e545031b8263da5c5a5d00d7f2d6c
    SHA256: 099c1a090652929f4a3827318545d65c7e5d4efdded29450a3e98ef31574f96b
    CRC32: 040a9eee
    RFSA16.0.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 16.0 Readme
    August 2016
    This file contains important information about NI-RFSG and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-RFSG
    NI RF Signal Generators Software
    This software installation provides support for customers using NI RF signal generator hardware, as specified in the Supported Hardware section. To program your NI RF signal generator, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal generator.
    NI-RFSG 16.0 includes the following new features:
    • Support for the NI PXIe-5840 vector signal transceiver (VST)
    • Improvements to the initiate performance on the NI 5644R/5645R/5646R devices
    • NI-RFSG Soft Front Panel 16.0, which includes the following new features:
      • Support for configuring I/Q impairments and external gain for NI 5644R/5645R/5646R devices
      • Support for the preceding new features listed for NI-RFSG
    NI-RFSG 15.0.3 includes the following new features:
    • Improvements to the external calibration procedure for the NI 5650/5651/5652 devices
    • NI-RFSG Soft Front Panel 15.0.3, which includes the following new features:
      • Improvements to the self-calibration procedure for the NI 5670/5671/5672 devices
      • Support for reading and downloading a single precision waveform from a TDMS file in Arb Waveform generation mode
    NI-RFSG 15.0.2 includes the following new features:
    • Improvements to the self-calibration procedure for NI 5644R/5645R/5646R devices
    NI-RFSG 15.0 includes the following new features:
    • Support removed for LabVIEW 2011
    NI-RFSG 14.5 includes the following new features:
    • Support for the NI PXIe-5654 RF signal generator
    • Support for the NI PXIe-5654 with NI PXIe-5696 amplitude extender (AE)
    • Support for LabVIEW 2014 SP1 (32- and 64-bit)
    • Support for I/Q impairments with VST devices
    • NI-RFSG Soft Front Panel 14.5, which includes the following new features:
      • Support for Arb Waveform generation mode with the NI 5644R/5645R/5646R and NI 5673E
    NI-RFSG 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit)
    • Support removed for LabVIEW 2010
    • NI-RFSG Soft Front Panel 14.0
    NI-RFSG 1.9.7 includes the following new features:
    • Support for the NI PXIe-5646R VST
    • Support for downloading a custom bitfile to a VST device
    • Support for 64-bit application software with VST devices
    • NI-RFSG Soft Front Panel 1.9.7, which includes support for the other new features in NI-RFSG 1.9.7
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductNI-RFSGNI-RFSG SFP
    NI PXI-5610
    NI PXIe-5611
    NI PXIe-5644R
    NI PXIe-5645R
    NI PXIe-5646R
    NI PXI/PXIe-5650
    NI PXI/PXIe-5651
    NI PXI/PXIe-5652
    NI PXIe-5653
    NI PXIe-5654
    NI PXI-5670
    NI PXI-5671
    NI PXIe-5672
    NI PXIe-5673/5673E
    NI PXIe-5840
    Note  Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime.
    Note  MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    NI-RFSG 16.0 and NI-RFSG Soft Front Panel 16.0 support the following operating systems:
    Note  NI-RFSG 16.0 does not support Windows Server non-R2 editions.
    NI-RFSG 16.0 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Note:When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the NI 5644R/5645R/5646R/5654/5654 with NI 5696 devices are not supported.
    Minimum Runtime/Deployment System
      Note:Depending on the amount of data generated or processed, a larger amount of RAM may be required.
    • Guest accounts are not supported under any OS.
    Application Development Environments
    Note:You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again.
    NI Application SoftwareVersions Supported by NI-RFSG
    NI LabVIEW2013 SP1, 2014 SP1, 2015 SP1, or 2016
    NI LabVIEW Real-Time Module2013 SP1, 2014 SP1, 2015 SP1, or 2016
    NI LabWindows/CVI2010 or later
    NI LabWindows/CVI Real-Time Module2010 or later
    Note:Install any toolkits or add-on software you intend to use with the NI-RFSG instrument driver after NI-RFSG installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    Note:MXI users must install the software included with the MXI hardware.
      • (32-bit) Program Files\IVI Foundation\IVI\
      • (64-bit) Program Files (x86)\IVI Foundation\IVI\
        • (32-bit) Program Files\IVI\
        • (64-bit) Program Files (x86)\IVI\
      • (64-bit) Program Files\IVI Foundation\IVI\
    ItemInstalled Location
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files (32-bit)\Lib
    NI-RFSG DLL (32-bit)\Bin
    NI-RFSG SFP\Drivers\niRFSG
    NI-RFSG SFP Example Waveforms\NI-RFSG Soft Front Panel\examples\Waveforms
    Additional File Locations for 64-bit Operating Systems
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • An introduction to RF Fundamentals
    • Hardware device overviews
    • A complete reference for all NI-RFSG programming VIs and functions
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    NI-RFSG ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI-RFSG function panel (.fp), select Instrument»Load, and navigate to \Drivers\niRFSG\niRFSG.fp or \Drivers\niRFSG\niRFSG.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFSG examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI-RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI-RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    You can also access all the installed NI-RFSG examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFSG»Examples.
    Examples are also available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-RFSG 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFSG drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFSG 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG 16.0 to an unsupported OS. Additionally, after installing NI-RFSG 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-RFSG 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-RFSG 1.9.8. The first version released under the new numbering scheme is NI-RFSG 14.0.
    • Select NI-RFSG 16.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFSG 16.0 installation, the following software is installed. To completely remove the NI-RFSG 16.0 installation from your system, you must also remove all of the following packages:
    • NI-RFSG Runtime 16.0 for DAQmx-Based Devices
    • NI-RFSG Runtime 16.0 for NI PXIe-5654
    • NI-RFSA/NI-RFSG Runtime 16.0 for NI PXIe-5644R/5645R/5646R
    • NI-RFSA/NI-RFSG Runtime 16.0 for NI PXIe-5840
    • NI VST Runtime 16.0 for NI PXIe-5644R/5645R/5646R
    • NI VST Runtime 16.0 for NI PXIe-5840
    • NI-DAQmx Runtime 15.0.1 with Configuration Support
    • NI-FGEN Runtime 16.0
    • NI-RIO 16.0
    • NI IVI Compliance Package 16.0
    • NI-VISA Runtime 16.0
    • NI Measurement & Automation Explorer (MAX) 16.0
    • NI I/O Trace 16.0
    • NI System Configuration Runtime 16.0
    • NI Hierarchical Waveform Storage 16.0
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Note:Do not attempt to uninstall by manually deleting files.
    NI-RFSG 15.0.3
    • Removed the reference level and resolution bandwidth outputs from niRFSG 5652 Configure Attenuator Calibration VI, which reflects changes to the NI PXIe-5650/5651/5652 Calibration Procedure (part number 373084F-01) and NI PXI-5650/5651/5652 Calibration Procedure (part number 375104F-01).
    NI-RFSG 14.5
    • When you delete a configuration list, NI-RFSG automatically resets the Active Configuration List property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST attribute to "" (empty string), which indicates no list is active, and the Active Configuration List Step property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST_STEP attribute to 0. Both properties or attributes immediately return an error if you try to set an invalid active list or active step.
    NI-RFSG 1.9
    • The NI-RFSG Soft Front Panel (SFP) replaces the MAX test panel functionality for your device. In NI-RFSG 1.8.5 and earlier, you could use the MAX test panel with LabVIEW Real-Time targets. NI-RFSG SFP 1.9.5 does not support Real-Time applications.
    • The NI-RFSG SFP 1.9.5 does not support the NI PXI-5610 with an external arbitrary waveform generator (AWG) module. In NI-RFSG 1.8.5 and earlier, the MAX test panel supported the NI PXI-5610 with an external AWG module.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 16.0 and NI-RFSG SFP 16.0.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI-RFSG.
    NI-RFSG 16.0
    560185Fixed an issue where the power level is incorrect until the amplification path is specified on the NI 5654 with NI 5696.
    570905Fixed an issue where after first commit, changes to the Waveform Repeat Count property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT attribute and Waveform Repeat Count Is Finite property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT_IS_FINITE attribute are ignored.
    NI-RFSG 15.0.3
    N/AFixed an issue where some NI 5650/5651/5652 devices fail calibration verification after calibration adjustment.
    562364Fixed an issue where incorrect power output occurred on the NI 5670/5671/5672 for signals less than 2.5 MHz during Arb Waveform generation mode with digital equalization enabled.
    NI-RFSG 14.5
    489122Fixed an issue where the NI 5652 appears outside of the composite device in MAX.
    NI-RFSG 14.0.1
    492490Fixed an issue where LabVIEW Run-Time Engine 2013 SP1 does not install with NI-RFSG.
    NI-RFSG 14.0
    466905Fixed an issue where set frequency and power level execution time takes longer than expected on the NI 5644R/5645R/5646R.
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSG SFP.
    NI-RFSG SFP 16.0
    Bug IDFixed Issue
    575506Fixed an issue where changing external gain was not available for the NI 5644R/5645R/5646R.
    NI-RFSG SFP 15.0.3
    Bug IDFixed Issue
    549309Fixed an issue where incorrect power output occurred after self-calibration on the NI 5672.
    © 2004–2016 National Instruments. All rights reserved.
    374769G-01
    GMT+8, 2025-12-6 15:31
