查看: 2815|回复: 0
[RTE运行引擎] NI RF Signal Generators 17.1 Runtime Win32/64Eng NI RF信号发生器NI-RFSG17.1运行版
    3 小时前
  • 签到天数: 3734 天
    连续签到: 61 天
    发表于 2021-3-1 23:56:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    17.1RTE
    文件大小: 605650824 字节 (577.59 MB)
    修改日期: 2017-07-26 22:51
    MD5: 139bd18ddb9552a7a658d1287d89f858(官方正确)
    SHA1: 4ae601594c65b751aa1b4205bf7a87a79d0f535f
    SHA256: edab27635a745c06545cf68eecca18e13971fb0014495daf2191b54fee06a162
    CRC32: 8daaef4f
    RFSA17.1RTE.txt (569 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFSG 17.1 Readme
    June 2017
    This file contains important information about NI-RFSG, including new features, supported hardware, a partial list of bugs fixed for NI-RFSG 17.1, and known issues.
    Accessing VIs and Functions
    Uninstalling NI-RFSG
    This software installation provides support for customers using RF signal generator hardware, as specified in the Supported Hardware section. To program your RF signal generator, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using a RF signal generator.
    NI-RFSG 17.1 includes the following new features:
    • Support for the PXIe-5820 vector signal transceiver (VST)
    • Support for RF list mode on the PXIe-5820/5840
    • Support for System Configuration API and Measurement & Automation Exolorer (MAX) for module temperature and self-calibration date and time
    • Support for sub-sample trigger and marker resolution on the PFI line for the PXIe-5820/5840
    NI-RFSG 17.0 adds support for LabVIEW 2017 (32- and 64-bit)
    NI-RFSG 16.0 includes the following new features:
    • Support for the PXIe-5840 vector signal transceiver (VST)
    • Improvements to the initiate performance on the PXIe-5644/5645/5646 devices
    • NI-RFSG Soft Front Panel 16.0, which includes the following new features:
      • Support for configuring I/Q impairments and external gain for PXIe-5644/5645/5646 devices
      • Support for the preceding new features listed for NI-RFSG
    NI-RFSG 15.0.3 includes the following new features:
    • Improvements to the external calibration procedure for the PXI/PXIe-5650/5651/5652 devices
    • NI-RFSG Soft Front Panel 15.0.3, which includes the following new features:
      • Improvements to the self-calibration procedure for the PXI-5670/5671 and PXIe-5672 devices
      • Support for reading and downloading a single precision waveform from a TDMS file in Arb Waveform generation mode
    NI-RFSG 15.0.2 includes the following new features:
    • Improvements to the self-calibration procedure for PXIe-5644/5645/5646 devices
    NI-RFSG 15.0 includes the following new features:
    • Support removed for LabVIEW 2011
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductNI-RFSGNI-RFSG SFP
    PXI-5610
    PXIe-5611
    PXIe-5644
    PXIe-5645
    PXIe-5646
    PXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with PXIe-5696
    PXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    PXIe-5820
    PXIe-5840
    Note  Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime.
    Note  MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    NI-RFSG has the following minimum requirements:
    • 4 GB RAM*
    NI-RFSG 17.1 and NI-RFSG Soft Front Panel 17.0 support the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-RFSG dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-RFSG 17.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG 17.1 to an unsupported OS. Additionally, after installing NI-RFSG 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFSG 17.1 does not support Windows Server non-R2 editions.
    NI-RFSG supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2014 SP1, 2015 SP1, 2016, or 2017
    LabVIEW Real-Time Module2014 SP1, 2015 SP1, 2016, or 2017
    LabWindows/CVI2010 and later
    LabWindows/CVI Real-Time Module2010 and later
    Note When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5654/5654 with PXIe-5696, and PXIe-5820/5840 devices are not supported.
      • (32-bit) Program Files\IVI Foundation\IVI\
      • (64-bit) Program Files (x86)\IVI Foundation\IVI\
        • (32-bit) Program Files\IVI\
        • (64-bit) Program Files (x86)\IVI\
      • (64-bit) Program Files\IVI Foundation\IVI\
    ItemInstalled Location
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files (32-bit)\Lib
    NI-RFSG DLL (32-bit)\Bin
    NI-RFSG SFP\Drivers\niRFSG
    NI-RFSG SFP Example Waveforms\NI-RFSG Soft Front Panel\examples\Waveforms
    Additional File Locations for 64-bit Operating Systems
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    Note  To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • An introduction to RF Fundamentals
    • Hardware device overviews
    • A complete reference for all NI-RFSG programming VIs and functions
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    NI-RFSG ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI-RFSG function panel (.fp), select Instrument»Load, and navigate to \Drivers\niRFSG\niRFSG.fp or \Drivers\niRFSG\niRFSG.fp.
    In LabVIEW and LabWindows/CVI, you can use the NI Example Finder to search or browse examples. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. NI-RFSG examples are classified by keyword, so you can search for a particular device or measurement function. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI-RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI-RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    You can also access all the installed NI-RFSG examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFSG»Examples.
    Examples are also available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    As part of the NI-RFSG 17.1 installation, the following software is installed. To completely remove the NI-RFSG 17.1 installation from your system, you must also remove all of the following packages:
    • NI-RFSG Runtime 17.1 for DAQmx-Based Devices
    • NI-RFSG Runtime 17.1 for NI PXIe-5654
    • NI-RFSA/NI-RFSG Runtime 17.1 for NI PXIe-5644R/5645R/5646R
    • NI-RFSA/NI-RFSG Runtime 17.1 for NI PXIe-5820/5840
    • NI VST Runtime 17.1 for NI PXIe-5820
    • NI VST Runtime 17.1 for NI PXIe-5644R/5645R/5646R
    • NI VST Runtime 17.1 for NI PXIe-5840
    • NI-RFSG Soft Front Panel 17.0
    • NI-FGEN Runtime 17.0
    • NI-DAQmx 17.0.0
    • NI-DAQmx MAX Configuration Support 17.0.0
    • NI-RIO 17.0
    • NI-HWS 17.0
    • NI-VISA 17.0
    • NI I/O Trace 17.0
    • NI Measurement & Automation Explorer 17.0
    • NI System Configuration Runtime 17.0
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    IVI Compliance Pacakge Functionality
    NI-RFSG no longer installs IVI Compliance Pacakge. NI-RFSG supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 17.1 and NI-RFSG SFP 17.0.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI-RFSG.
    NI-RFSG 17.1
    601860Fixed an issue where an error occured when changing the device name of the PXIe-5840 in MAX.
    515837Fixed an issue where the PXIe-5654 device name persisted for other devices inserted into the same slot.
    640124Fixed an issue where the PXIe-5840 could show a slow phase drift below 400 MHz.
    541356Fixed an issue where attribute names did not show up correctly in I/O trace.
    479015Fixed an issue where the niRFSG Reset VI and the niRFSG_reset function did not re-enable the output for the PXIe-5645.
    573420Fixed an issue where the default value of the Impairment Enabled property and the NIRFSG_ATTR_IQ_IMPAIRMENT_ENABLED attribute for the PXIe-5644/5645/5646 was incorrect.
    637641Fixed an issue where the PXI-5671 would incorrectly error with markers on a quantum of two when the DUC (digital upconverter) was enabled.
    NI-RFSG 16.0
    560185Fixed an issue where the power level is incorrect until the amplification path is specified on the PXIe-5654 with PXIe-5696.
    570905Fixed an issue where after first commit, changes to the Waveform Repeat Count property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT attribute and Waveform Repeat Count Is Finite property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT_IS_FINITE attribute are ignored.
    NI-RFSG 15.0.3
    N/AFixed an issue where some PXI/PXIe-5650/5651/5652 devices fail calibration verification after calibration adjustment.
    562364Fixed an issue where incorrect power output occurred on the PXI-5670/5671 and PXIe-5672 for signals less than 2.5 MHz during Arb Waveform generation mode with digital equalization enabled.
    NI-RFSG 14.5
    489122Fixed an issue where the PXI/PXIe-5652 appears outside of the composite device in MAX.
    NI-RFSG 14.0.1
    492490Fixed an issue where LabVIEW Run-Time Engine 2013 SP1 does not install with NI-RFSG.
    NI-RFSG 14.0
    466905Fixed an issue where set frequency and power level execution time takes longer than expected on the PXIe-5644/5645/5646.
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSG SFP.
    NI-RFSG SFP 16.0
    Bug IDFixed Issue
    575506Fixed an issue where changing external gain was not available for the PXIe-5644/5645/5646.
    NI-RFSG SFP 15.0.3
    Bug IDFixed Issue
    549309Fixed an issue where incorrect power output occurred after self-calibration on the PXIe-5672.
    © 2004–2017 National Instruments. All rights reserved.
    374769J-01
    GMT+8, 2025-12-6 15:32
