查看: 3525|回复: 0
[RTE运行引擎] NI RF Signal Generators 18.0 Runtime Win32/64Eng NI RF信号发生器NI-RFSG18.0运行版
    3 小时前
  • 签到天数: 3734 天
    连续签到: 61 天
    发表于 2021-3-1 23:59:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    18.0RTE
    文件大小: 399508616 字节 (381.00 MB)
    修改日期: 2018-06-21 06:23
    版本: 16.4.0.0
    MD5: 43f7c4bd6ccd7fb9f2309d209f429468(官方正确)
    SHA1: 18130d1b4d74dfd7150ed718172f34621207655f
    SHA256: 7810b6d5271c7cf97c8c9ecafa7bedbd78583c4c8c675661c29d948a3a4c1670
    CRC32: febe19af
    RFSA18.0RTE.txt (583 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFSG 18.0 Readme
    May 2018
    This file contains important information about NI-RFSG, including new features, supported hardware, a partial list of bugs fixed for NI-RFSG 18.0, and known issues.
    This software installation provides support for customers using RF signal generator hardware, as specified in the Supported Hardware section. To program your RF signal generator, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using a RF signal generator.
    NI-RFSG 18.0 adds support for LabVIEW 2018 (32- and 64-bit)
    NI-RFSG 17.1 includes the following new features:
    • Support for the PXIe-5820
    • Support for RF list mode on the PXIe-5820/5840
    • Support for System Configuration API and Measurement & Automation Explorer (MAX) for module temperature and self-calibration date and time
    • Support for sub-sample trigger and marker resolution on the PFI line for the PXIe-5820/5840
    NI-RFSG 17.0 adds support for LabVIEW 2017 (32- and 64-bit)
    NI-RFSG 16.0 includes the following new features:
    • Support for the PXIe-5840
    • Improvements to the initiate performance on the PXIe-5644/5645/5646
    • NI-RFSG Soft Front Panel 16.0, which includes the following new features:
      • Support for configuring I/Q impairments and external gain for the PXIe-5644/5645/5646
      • Support for the preceding new features listed for NI-RFSG
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductHardware ModelNI-RFSGNI-RFSG SFP
    RF Signal UpconverterPXI-5610
    I/Q ModulatorPXIe-5611
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5840
    RF Analog Signal GeneratorPXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with
    PXIe-5696 Amplitude Extender
    Vector Signal GeneratorPXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    Note  Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime.
    Note  MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    • 4 GB RAM*
    NI-RFSG 18.0 and NI-RFSG Soft Front Panel 18.0 support the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-RFSG dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-RFSG 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG 18.0 to an unsupported OS. Additionally, after installing NI-RFSG 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2015 SP1, 2016, 2017 SP1, or 2018
    LabVIEW Real-Time Module2015 SP1, 2016, 2017, or 2018
    LabWindows/CVI2010 and later
    LabWindows/CVI Real-Time Module2010 and later
    Note When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5654/5654 with PXIe-5696, and the PXIe-5820/5840 are not supported.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSG C dynamically linked library by adding a reference to:
    • (32-bit) Program Files\IVI Foundation\IVI\Bin\niRFSG.dll
    • (64-bit) Program Files (x86)\IVI Foundation\IVI\Bin\niRFSG.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSG_64.dll for 64-bit development.
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • Hardware device overviews
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    NI-RFSG ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFSG no longer installs IVI Compliance Package. NI-RFSG supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 18.0 and NI-RFSG SFP 18.0.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI-RFSG.
    NI-RFSG 17.1.2
    664698Fixed an issue where a timeout error occurred when TClk was used with the PXIe-5820/5840 using the WLAN Toolkit.
    NI-RFSG 17.1
    601860Fixed an issue where an error occurred when changing the device name of the PXIe-5840 in MAX.
    515837Fixed an issue where the PXIe-5654 device name persisted for other devices inserted into the same slot.
    640124Fixed an issue where the PXIe-5840 could show a slow phase drift below 400 MHz.
    541356Fixed an issue where attribute names did not show up correctly in I/O trace.
    479015Fixed an issue where the niRFSG Reset VI and the niRFSG_reset function did not re-enable the output for the PXIe-5645.
    573420Fixed an issue where the default value of the Impairment Enabled property and the NIRFSG_ATTR_IQ_IMPAIRMENT_ENABLED attribute for the PXIe-5644/5645/5646 was incorrect.
    637641Fixed an issue where the PXI-5671 would incorrectly error with markers on a quantum of two when the DUC (digital upconverter) was enabled.
    NI-RFSG 16.0
    560185Fixed an issue where the power level is incorrect until the amplification path is specified on the PXIe-5654 with PXIe-5696.
    570905Fixed an issue where after first commit, changes to the Waveform Repeat Count property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT attribute and Waveform Repeat Count Is Finite property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT_IS_FINITE attribute are ignored.
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSG SFP.
    NI-RFSG SFP 16.0
    Bug IDFixed Issue
    575506Fixed an issue where changing external gain was not available for the PXIe-5644/5645/5646.
    NI-RFSG SFP 15.0.3
    Bug IDFixed Issue
    549309Fixed an issue where incorrect power output occurred after self-calibration on the PXIe-5672.
    © 2004–2018 National Instruments. All rights reserved.
    374769L-01
    GMT+8, 2025-12-6 15:29
