查看: 3158|回复: 0
[NI驱动程序] NI RF Signal Generators 20.0.0 Win64Eng NI RF信号发生器NI-RFSG20.0.0
    9 小时前
    发表于 2021-3-2 00:15:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win64Eng
    20.0
    文件大小: 4280012800 字节 (3.99 GB)
    修改日期: 2020-07-25 01:03
    MD5: 0d0f12e2e35f6e1f079e577434e4df85(官方正确)
    SHA1: 323e5c98f3836c1ab0f044b2b118438ecd047f2b
    SHA256: 30f5a474447f7d17f9c96c2f77c08ab775c251ca7a209f3310484b7588d03893
    CRC32: fbb3b229
    RFSA20.0.0.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 20.0 Readme
    July 2020
    This file contains important information about NI-RFSG, including new features, supported hardware, a partial list of bugs fixed for NI-RFSG 20.0, and known issues.
    NI-RFSG Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for RF list mode on the PXIe-5841 with PXIe-5655
    NI-RFSG 19.6 includes the following new features:
    • Support for checking module connections on the PXIe-5830/5831 with intermediate self-test in MAX or System Configuration API
    • Support for power level in configuration lists on the PXIe-5830/5831
    • Support for clearing self calibrate range data on the PXIe-5820/5830/5831/5840/5841
    NI-RFSG 19.2.1 includes updates to align with NI-RFSA 19.2.1
    NI-RFSG 19.2 includes the following new features:
    • Support for the PXIe-5841 with PXIe-5655
    • Improvements to determinism and latency when responding to script triggers on the PXIe-5820/5831/5840/5841
    NI-RFSG 19.1.6 includes improvements for the PXIe-5831 in the Semiconductor Test System
    NI-RFSG 19.1.5 includes support for the PXIe-5841
    NI-RFSG 19.1 includes the following new features:
    • Support for the PXIe-5830/5831
    • Support for LO sharing on the PXIe-5830/5831 to improve phase noise performance
    • Support for the PXIe-5830/5831 in the NI-RFSG SFP
    NI-RFSG 19.0 includes support for LabVIEW 2019
    NI-RFSG 18.2 includes the following new features:
    • Support for de-embedding measurements on the PXIe-5840
    • Improvements to communication performance on the PXIe-5820/5840
    • Support for automatic LO sharing for the PXIe-5840 in the NI-RFSG SFP
    • Support for specifying external calibration date for the PXIe-5644/5645/5646 and PXIe-5820/5840 in System Configuration API and MAX
    NI-RFSG 18.1 includes the following new features:
    • Improvements to initiate performance on the PXIe-5820/5840
    • Support for associating the PXIe-5840 with the PXIe-5653 LO source
    • Support for the PXIe-5840 with PXIe-5653 in the NI-RFSG SFP
    • Support for controlling the RF IN LO OUT terminal on the PXIe-5840
    • Support for PXIe-5820/5840 self-calibration in System Configuration API
    • Support for modifying temperature resolution for automatic thermal correction
    • Support for modifying DMA buffer size to improve NI-RFSG write arb waveform performance
    • Support for clearing self calibrate range data on the PXIe-5644/5645/5646
    • Improvements to NI-RFSG write arb waveform and streaming performance
    NI-RFSG 18.0 includes the following new features:
    • Added support for LabVIEW 2018
    • Added the NI-RFSG .NET Class Library and NI-RFSG .NET examples to the installer
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductHardware ModelNI-RFSGNI-RFSG SFP
    RF Signal UpconverterPXI-5610
    I/Q ModulatorPXIe-5611
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5840
    PXIe-5841
    PXIe-5841 with
    PXIe-5655 RF Analog Signal Generator
    RF Analog Signal GeneratorPXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with
    PXIe-5696 Amplitude Extender
    Vector Signal GeneratorPXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    Note  Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime.
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5840/5841 if you choose to install the runtimes independently.
    Note  For best memory performance on the PXIe-5831, NI recommends using only 64-bit applications.
    • 4 GB RAM*
    Note  NI-RFSG 20.0 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 20.0.
    NI-RFSG 20.0 and NI-RFSG SFP 20.0 support the following operating systems:
    • Windows 10/8.11/7 SP12 (64-bit)
    Note  In 2019 NI-RFSG dropped support for all 32-bit Windows operating systems. NI-RFSG will not install or run on an unsupported OS. Refer to NI-RFSG Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2016, 2017 SP1, 2018 SP1, 2019, or 2020
    LabVIEW Real-Time Module2016, 2017, 2018 SP1, 2019, or 2020
    LabWindows/CVI2010 to current
    LabWindows/CVI Real-Time Module2010 to current
    Note When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5654/5654 with PXIe-5696, and the PXIe-5820/5830/5831/5840/5841 are not supported.
    NI installs NI-RFSG using NI Package Manager. If you do not already have NI software installed, NI-RFSG installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • Hardware device overviews
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    NI-RFSG ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    The following are behavior changes in NI-RFSG 19.1 from NI-RFSG 18.2:
    • NI-RFSG SFP (32-bit) is no longer installed with NI-RFSG.
    The following are behavior changes in NI-RFSG 18.2 from NI-RFSG 18.1:
    • NI Script Editor is no longer installed with NI-RFSG.
    • The NI-RFSG Express VIs are now obsolete and are no longer installed.
    • The NI-RFSG RF Out LO Export Enabled property no longer requires the NI-RFSA LO Out Export Configure From RFSA property to be set to Enabled. NI-RFSG can change the export state of NI-RFSA without an open NI-RFSA session on the PXIe-5840. Ensure the NI-RFSA LO out export is generating a useful signal before using that signal for NI-RFSG operations.
    You can access the NI-RFSG and NI-RFSG SFP known issues lists online at the following locations.
    • NI-RFSG 20.0 Known Issues
    • NI-RFSG Soft Front Panel 20.0 Known Issues
    You can access the NI-RFSG and NI-RFSF SFP bug fix lists online at the following locations.
    • NI-RFSG 20.0 Bug Fixes
    • NI-RFSG Soft Front Panel 20.0 Bug Fixes
    These lists describe a subset of issues fixed in the NI-RFSG instrument driver and NI-RFSG SFP. If you have a Bug ID, you can search these lists to validate that the issue has been fixed.
    NI-RFSG will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    374769AA-01
    GMT+8, 2025-12-8 19:07
