查看: 1965|回复: 0
[NI软件产品] NI-WLAN Test Toolkit 17.0 Win32/64Eng NI无线局域网测试工具包17.0
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-3-3 23:48:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    WLAN测试工具包
    WLAN测试工具包为WLAN 802.11a/b/g/j/p/n/af/ah/ac/ax测试应用提供了信号生成和分析功能。
    WLAN测试工具包是一款应用软件,旨在扩展NI RF仪器用于WLAN 802.11信号生成和分析的功能。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/af/ah/ac/ax信号进行分析。WLAN测试工具包具有灵活的配置,可进行减损处理,提供每用户测量结果报告以及MIMO和分集配置,因而可支持多站点信号。借助WLAN测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    Win32/64Eng
    17.0
    文件大小: 1767563264 字节 (1.65 GB)
    修改日期: 2017-05-11 16:21
    MD5: 1b37d3bd90e078a8db86757ddd80fa4c(重复下载一致)
    SHA1: a253e181322f19e1375022d004e244c4c88dcd01
    SHA256: 7d7218ae5806c290ec5a9c69f549cc6962962e87b8f0df44ec0fc4c6c5f79b0c
    CRC32: e49ca907
    WLAN17.0.txt (573 Bytes, 下载次数: 0, 售价: 10 圆)
    NI WLAN Toolkit 17.0 Readme
    May 2017
    Thank you for using NI WLAN Toolkit. Refer to the following product-specific readme files:
    • NI WLAN Analysis Toolkit Readme
    • NI WLAN Generation Toolkit Readme
    © 2009–2017 National Instruments. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, s5.5 toring in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    374871D-01
    NI WLAN Analysis Toolkit 17.0 Readme
    May 2017
    This file contains important information about NI WLAN Analysis Toolkit. This file contains important information about the NI WLAN Analysis Toolkit and is organized into the following sections:
    Accessing VIs and Functions
    Toolkit Version Naming Changes
    Uninstalling/Modifying NI WLAN Analysis Toolkit
    New FeaturesNI WLAN Analysis Toolkit 17.0 includes the following new features:
    • Support for IEEE Standard P802.11ax/D1.2
    • Support for all PPDUs of 802.11ax: Single-User (SU), Multi-User (MU), Extended Range SU and Trigger-Based PPDUs
    • Support for all channel bandwidths of 802.11ax: 20 MHz, 40 MHz, 80 MHz, 80+80 MHz and 160 MHz
    • Support for Downlink OFDMA and MU-MIMO for 802.11ax
    • Support for Uplink OFDMA for 802.11ax
    • Support for 8X8 MIMO for 802.11ax
    • Support for MCS 0 to 11 for 802.11ax
    • Support for noise compensation for EVM for the OFDM Demod measurement
    • Support for LabVIEW 2017 (32- and 64-bit)
    NI WLAN Analysis Toolkit 16.0 includes the following new features:
    • Support for LabVIEW 2016
    • Support for 8x8 MIMO for IEEE Standard 802.11ac-2013 in NI WLAN Analysis Soft Front Panel
    • Support for querying power spectrum (dBm/RBW) trace in spectral mask measurement
    • Support for querying single EVM result per stream of an 80+80 MHz, 802.11ac signal in NI WLAN Analysis Soft Front Panel
    • Support for querying single TxP result per channel of an 80+80 MHz, 802.11ac signal in API and NI WLAN Analysis Soft Front Panel
    NI WLAN Analysis Toolkit 15.5 includes the following new features:
    • Support for spectrum measurements of both frequency segments of an 80+80 MHz, 802.11ac signal using a single NI RF vector signal analyzer
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    • Support for querying EVM of each user signal in a Downlink Multi-User MIMO 802.11ac signal
    • Support for creating reference data files for combined signal demodulation of 802.11n and 802.11ac signals using NI WLAN Analysis Soft Front Panel
    • Support for using reference data files created using NI WLAN Analysis Soft Front Panel for combined signal demodulation of 802.11n and 802.11ac in a programming environment
    • Support for the detection of scrambler seed during combined signal demodulation of 802.11n and 802.11ac signals
    • Support for combined signal demodulation of 80+80 MHz and 160 MHz 802.11ac signals
    • Support for Offline Analysis mode in NI WLAN Analysis Soft Front Panel to analyze I/Q data from the device memory or an NI TDMS file
    NI WLAN Analysis Toolkit 15.0 includes the following new features:
    • Support for IEEE Standard 802.11af-2013
    • Support for channel bandwidths of 6 MHz, 7 MHz, and 8 MHz for IEEE Standard 802.11af-2013
    • Support for one basic channel unit (BCU) transmission mode, also known as TVHT_MODE_1 for IEEE Standard 802.11af-2013
    • Support for single spatial stream for IEEE Standard 802.11af-2013
    • Support for MCS 0 to 9 for IEEE Standard 802.11af-2013
    • Support for normal and short guard intervals for IEEE Standard 802.11af-2013
    • Support for binary convolution coding (BCC) and low-density parity-check coding (LDPC) for IEEE Standard 802.11af-2013
    • Support for non-HT duplicate mode in IEEE Standard 802.11n, IEEE Standard 802.11ac-2013, and IEEE Standard 802.11af-2013 (only in APIs)
    • Support for In-Band Emission measurement specified by the ETSI EN 301 598 standard for signals conforming to IEEE Standard 802.11af-2013 (only in APIs)
    • Support for performing measurements on packets filtered based on the data rate or the MCS index
    • Support for 1024-QAM (MCS 10/11) for 802.11ac signals
    • Support for LabVIEW 2015 (32-bit and 64-bit)
    NI WLAN Analysis Toolkit 14.5 includes the following new features:
    • Support for 802.11ah/D1.3 standard
    • Support for channel bandwidths of 1 MHz, 2 MHz, 4 MHz, 8 MHz, and 16 MHz for IEEE Standard P802.11ah/D1.3
    • Support for MCS 0 to 9 and MCS 10 (1 MHz PPDU only) for IEEE Standard 802.11ah/D1.3
    • Support for spatial streams up to 4 for IEEE Standard 802.11ah/D1.3
    • Support for binary convolution coding for IEEE Standard 802.11ah/D1.3
    • Support for normal and short Guard Interval for IEEE Standard 802.11ah/D1.3
    • Support for fixed pilots for IEEE Standard 802.11ah/D1.3
    • Support for NI PXIe-5668R vector signal analyzer and spectrum analyzer
    • Addition of ACP measurement
    NI WLAN Analysis Toolkit 14.0 includes the following new features:
    • Support for Windows 64-bit operating system
    • Support for a separate run-time installer
    • Support for LabVIEW 2014 (32-bit and 64-bit)
    • Support for performing measurements on packets filtered based on standard and bandwidth
    • Support for disabling burst detection during transmit power measurement
    • Support for OFDM Demod measurement on one transmit channel of an STBC signal with two space-time streams
    • Support for span up to 264MHz (increased from 240MHz) for measuring power spectrum of 802.11ac, 80MHz signal on the NI 5644R/45R in IQ power edge triggered gated spectrum mode
    • Support for automatically routing PXI trigger lines for synchronization between multiple NI 5644R, NI 5645R or NI 5646R devices for multiple-input multiple-output (MIMO) operation using the WLAN Analysis Soft Front Panel
    The following list shows the supported hardware products:
    • NI PXIe-5665
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5668R
    • NI PXIe-5840
    NI WLAN Analysis Toolkit 17.0 supports the following operating systems:
    • Windows 10/8.1/7 SP12 (32-bit and 64-bit)
    • Windows Embedded Standard 7 SP12 (32-bit and 64-bit)
    Note  The NI WLAN Analysis Toolkit 17.0 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • Processor—Pentium IV or equivalent
    • Free hard drive space—1 GB
    • RAM—2 GB
    • Microsoft Internet Explorer 8 or later
    • Supported RF vector signal analyzer with minimum 256 MB of onboard memory
    Recommended System
    • Free hard drive space—2 GB
    • RAM—4 GB
    • NI LabVIEW Modulation Toolkit 4.3.4 or later
    • PXI Platform Services 14.0
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI WLAN Analysis Toolkit. To add support for ADEs installed after installing NI WLAN Analysis Toolkit, modify your NI WLAN Analysis Toolkit installation or launch the NI WLAN Analysis Toolkit installer again.
    • LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    • LabWindows/CVI 8.5.1 or later
    • TestStand 4.2.0 for TestStand sequences
      • Windows 10/Windows 8.1/Windows 7: \LabVIEW
      • (32-bit OS) windows\system32
      • (64-bit OS) windows\SysWow64 for 32-bit programs and windows\system32 for 64-bit programs
    ItemInstalled Location
    WLAN Analysis Soft Front Panel\WLAN Toolkit\WLAN Analysis Soft Front Panel.exe
    DLL
    WLAN Calibration Utility\WLAN Toolkit\Calibration Utility\WLAN Calibration Utility.exe
    VIs\vi.lib\RF Toolkits\WLAN\
    Examples\examples\RF Toolkits\WLAN\
    LabWindows/CVI
    Header Files\Shared\CVI\Include
    Static Libraries\Shared\CVI\bin\msvc
    .lfp/.sub Files\Shared\CVI\bin
    Examples\CVI\samples\WLAN
    C
    Header Files\Shared\ExternalCompilerSupport\C\include
    Import Library\Shared\ExternalCompilerSupport\C\lib32\msvc
    Examples\WLAN Toolkit\Examples\C\Analysis
    TestStand
    Examples\WLAN Toolkit\TestStand
    Select Start»All Programs»National Instruments»NI WLAN Analysis Toolkit»WLAN Analysis Soft Front Panel to launch the NI WLAN Analysis Toolkit Soft Front Panel.
    Documentation for the NI WLAN Analysis Toolkit is located at Start»All Programs»National Instruments»NI WLAN Analysis Toolkit»WLAN Analysis Toolkit Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI WLAN Analysis Toolkit HelpHTML/Windows HelpInformation about NI WLAN Analysis Toolkit. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI WLAN Analysis Toolkit
    • A complete reference for all NI WLAN Analysis Toolkit programming functions and VIs
    NI WLAN Analysis Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI WLAN Analysis palette VIs are available from the Functions»RF Communications»WLAN»Analysis palette.
    NI WLAN Analysis functions are available in LabWindows/CVI from the Library menu.
    You can also access all the installed NI WLAN Analysis examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»WLAN Analysis Toolkit»WLAN Analysis Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI WLAN Analysis Toolkit 17.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI WLAN Analysis Toolkit 17.0 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI WLAN Analysis Toolkit 17.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI WLAN Analysis Toolkit 17.0 to an unsupported OS. Additionally, after installing NI WLAN Analysis Toolkit 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI WLAN Analysis Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: <;ProductName>. For example, NI WLAN Analysis Toolkit 17.0 is the version released with LabVIEW 2017. The last version released under the old numbering scheme is NI WLAN Analysis Toolkit 4.1. The first version released under the new numbering scheme is NI WLAN Analysis Toolkit 14.0.
    • Select NI WLAN Analysis Toolkit 17.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    The following are the behavior changes in NI WLAN Analysis Toolkit 17.0 from NI WLAN Analysis Toolkit 16.0:
    • The default value of the LO Sharing Enabled property has been changed to False.
    • The default value of the OFDM Common Clock Source Enabled property has been changed to True.
    • The NI-RFSA Downconverter Loop Bandwidth property is set to Narrow for NI 5646R.
    The following are the behavior changes in NI WLAN Analysis Toolkit 14.5 from NI WLAN Analysis Toolkit 14.0:
    • AMPM properties are obsolete in toolkit version 14.5.
    The following are the behavior changes in NI WLAN Analysis Toolkit 14.0 from NI WLAN Analysis Toolkit 4.0:
    • The IQ Power Edge Reference Trigger Enabled property is not obsolete.
    • Analysis of MCS32, 802.11n signals is not supported.
    The following are the behavior changes in NI WLAN Analysis Toolkit 4.0 from NI WLAN Analysis Toolkit 3.0:
    • The Carrier Frequency property is no longer obsolete in toolkit version 4.0.
    The following are the behavior changes in NI WLAN Analysis Toolkit 3.0 from NI WLAN Analysis Toolkit 2.0:
    • The Carrier Frequency, Maximum Input Power, and IQ Power Edge Reference Trigger Enabled properties are obsolete in toolkit version 3.0. Configure the corresponding NI-RFSA properties when using the NI WLAN Analysis Toolkit with NI-RFSA.
    You can access the software and documentation known issues list online. Refer to the NI WLAN Analysis Toolkit 17.0 Known Issues List at ni.com for an up-to-date list of known issues in NI WLAN Analysis Toolkit 17.0.
    The following items are changes in WLAN Toolkit 17.0 from WLAN Toolkit 16.0.
    Bug IDFixed Issue
    632242Fixed an issue where there was a small error (<0.1 dB) in computation of Channel EVM on 802.11ac and 802.11n MIMO signals.
    616590Fixed an issue where incorrect generator matrices were used for LPDC encoding for the following cases for 802.11n and 802.11ac standards:
    • LDPC codeword block length of 648 bits with coding rate of 1/2 or 5/6
    • LDPC codeword block length of 1296 bits with coding rate of 2/3 or 5/6
    635715Fixed an issue where in a 64-bit process, changing center frequency caused transmit spectrum mask test to give incorrect results.
    578886Fixed an issue in the transmit spectrum mask margin vector results of 802.11ac 80+80 MHz combined spectrum mask, there was no frequency offset at the center of the spectrum when the separation between carrier frequencies of the frequency segments was 160 MHz or 240 MHz.
    The following items are changes in WLAN Analysis Toolkit 15.5 from WLAN Analysis Toolkit 15.0.
    Bug IDFixed Issue
    576440Fixed an issue where an error message was not displayed when the Reference Data Constellation input was empty and the Combined Signal Demodulation was enabled.
    576138Fixed an error where the user-defined mask creation was incorrect if the start and end offset values were not equidistant from the center.
    572279Fixed an error where some payload properties were not getting saved in the TDMS file when the PPDU type was MU PPDU.
    572274Fixed an error where the spectral mask violation result was incorrect for 802.11ac, 80+80 MHz signal.
    569961Fixed an error where the power spectrum computation was incorrect when IQ In Port was used, and the IQ In Port Carrier Frequency was non-zero.
    528989Fixed an error where the niWLANA RFSA Auto Range VI retained a higher burst length value even after it encountered a lower sized burst when the VI was called again.
    The following items are changes in WLAN Analysis Toolkit 15.0 from WLAN Analysis Toolkit 14.5.
    Bug IDFixed Issue
    510404Fixed an issue where 802.11b Ramp Down Time varied with different payload sizes.
    519150Fixed an issue where the Gated Power Measurement was incorrect for 802.11ah standard.
    519151Fixed an issue where enabling Amplitude Tracking was giving bad EVMs for 802.11ah 3x3 and 4x4 cases.
    518829Fixed an issue where the 10 MHz bandwidth was disabled for 802.11j in WLAN Analysis Soft Front Panel.
    515678Fixed an issue where the spectrum measurement was incorrect for the first run in WLAN Analysis Soft Front Panel.
    494858Fixed an issue where opening the second instance with the same 'Resource Name', displayed an error in the first instance of WLAN Analysis Soft Front Panel.
    The following items are changes in WLAN Analysis Toolkit 14.5 from WLAN Analysis Toolkit 14.0.
    Bug IDFixed Issue
    515428Fixed an issue where the L-SIG Length property was ignored when the Header Detection Enabled was set to False for 802.11ac signals.
    513240Fixed an issue where the trigger synchronization configuration was incorrect for multi-segment case in Multiple Device Synchronization VI.
    512578Fixed an issue where TxP Measurement was failing at power levels lower than -30dBm.
    510794Fixed an issue where the gated power result for 802.11n standard was incorrect.
    510663Fixed an issue where the transmit spectral mask measurement was measured at an incorrect center frequency for 802.11ac, 80+80 contiguous case in WLAN Analysis Soft Front Panel.
    510067Fixed an issue where the Auto Route PXI Trigger Lines was returning an error on the NI PXIe-1078 & PXIe-1082 chassis in WLAN Analysis Soft Front Panel.
    508047Fixed an issue where the Channel Bandwidth property was not ignored for channel power measurement when the standard was set to 802.11b.
    499394Fixed an issue where the Occupied Bandwidth, Max Spectral Density, Channel Power and Reference Level Used results were incorrect for 802.11ac, 80+80 signals.
    499378Fixed an issue where the LO and clock were exported when number of devices were 1 in the Multiple Device Synchronization VI.
    494807Fixed an issue where 'Stop' did not abort IQ measurements in WLAN Analysis Soft Front Panel.
    412512Fixed an issue where the EVM measurement was incorrect on the 802.11b signal when equalization was enabled and the power of the input signal was low.
    The following items are changes in WLAN Analysis Toolkit 14.0 from WLAN Analysis Toolkit 4.1.
    Bug IDFixed Issue
    493614Fixed an issue where the spectral acquisition measurement length could not be set to -1 when multiple measurements were enabled.
    493603Fixed an issue where the second segment carrier frequency was not read while loading a previously saved TDMS file in WLAN Analysis Soft Front Panel.
    492974Fixed an issue where no error was returned if spectrum measurement results were queried before averaging was complete when performing simultaneous IQ and spectrum.
    492125Fixed an issue where spectral mask violation is NaN when performing spectral mask measurement on an 802.11ac, 80+80 signal.
    487077Fixed an issue where there was incorrect mask reference level during spectral mask measurement on 802.11ac, 80+80 signal with Mask Reference Level Type = Peak Signal Power.
    486447Fixed an issue where there was incorrect results with Spectrum Averaging Type = Log during simultaneous (composite) IQ and spectrum measurement.
    486379Fixed an issue where there was incorrect 80+80 spectral mask when analyzing multiple-channel 802.11ac, 80+80 signal.
    486355Fixed an issue where there was incorrect constellation trace for the second segment when analyzing 802.11ac 80+80 signal in WLAN Analysis Soft Front Panel.
    486168Fixed an issue where the automatically computed span was incorrect for simultaneous IQ and spectrum measurement.
    481362Fixed an issue where the timeout input on niWLANA RFSA Read Gated Power Spectrum VI was ignored.
    480239Fixed an issue where the preamble frequency error trace was not available if Standard was set to 80211A/G/J/P OFDM.
    The following items are changes in WLAN Analysis Toolkit 4.1 from WLAN Analysis Toolkit 4.0.
    Bug IDFixed Issue
    453862Fixed an issue where the pre-trigger duration was not set to 0 when the hardware is configured for spectrum measurements after performing I/Q measurements.
    453528Fixed an issue where the Swap I and Q Enabled property was not applicable for TxPower, AMPM, and Spectral measurements.
    438756Fixed an issue where the Common Pilot Error returned 0 if you set the OFDM Combined Signal Demodulation Enabled property to True.
    436656Fixed an issue where the Sample Clock Rate Factor property was not applicable to Demod, TxPower and Spectral (in the niWLANA Analyze VI) measurements.
    429958Fixed an issue where OFDM demodulation failed for multiple channel signals if you set the OFDM Burst Start Detection Enabled property to False.
    The following items are changes in WLAN Analysis Toolkit 3.0 from WLAN Analysis Toolkit 2.0.
    Bug IDFixed Issue
    321647Fixed an issue where the NI-RFSA IQ carrier frequency is now restored inside the niWLANA RFSA Read Gated Power Spectrum (Cluster) VI and niWLANA_RFSAReadGatedPowerSpectrum function.
    279714Fixed an issue where averaging of average gated power is now changed to linear averaging instead of log averaging.
    279679Fixed an issue where constellation trace for 22 Mbps and 33 Mbps DSSS signals is corrected.
    279638Fixed an issue where the order of elements in EVM per symbol (chip) trace for 22 Mbps and 33 Mbps DSSS signals is corrected.
    279627Fixed an issue where the computation of the number of chips present in the received signal, based on payload length detected in the header, is corrected for DSSS signals.
    278535Fixed an issue where the coercion of average gated power to integer values for OFDM signals is corrected.
    258242Fixed an issue where applications (.exe files) can now be built when the Disconnect type definitions option is selected.
    The following items are changes in WLAN Toolkit 2.0 from WLAN Toolkit 1.0.
    Bug IDFixed Issue
    201056Fixed an issue where the error description for error code –42914 now correctly refers to transmit power number of averages.
    147109Fixed an issue where DSSS power ramp-up and ramp-down measurements are more accurate and repeatable now.
    How to Use NI Software with Microsoft Windows 8.1
    374870F-01
    NI WLAN Generation Toolkit 17.0 Readme
    May 2017
    This file contains important information about NI WLAN Generation Toolkit. This file contains important information about the NI WLAN Generation Toolkit and is organized into the following sections:
    Uninstalling/Modifying NI WLAN Generation Toolkit
    New FeaturesNI WLAN Generation Toolkit 17.0 includes the following new features:
    • Support for Trigger Frame generation
    NI WLAN Generation Toolkit 16.0 includes the following new features:
    • Support for 8x8 MIMO for IEEE Standard 802.11ac-2013 in the NI WLAN Generation Soft Front Panel
    NI WLAN Generation Toolkit 15.5 includes the following new features:
    • Support for generation of both the frequency segments of an 80+80 MHz, 802.11ac signal using a single NI RF vector signal analyzer within its device instantaneous bandwidth
    NI WLAN Generation Toolkit 15.0 includes the following new features:
    NI WLAN Generation Toolkit 14.5 includes the following new features:
    • Support for S1G_1M, S1G_SHORT and S1G_LONG PPDU formats for IEEE Standard 802.11ah/D1.3
    • Support for MCS 0 to 9 and MCS10 (1 MHz PPDU only) for IEEE Standard 802.11ah/D1.3
    NI WLAN Generation Toolkit 14.0 includes the following new features:
    • Support for automatically routing PXI trigger lines for synchronization between multiple NI 5644R, NI 5645R or NI 5646R devices for multiple-input multiple-output (MIMO) operation using the WLAN Generation Soft Front Panel.
    • NI PXIe-5673
    • NI PXIe-5673E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI WLAN Generation Toolkit 17.0 supports the following operating systems:
    Note  The NI WLAN Generation Toolkit 17.0 and later does not support Windows Server non-R2 editions.
    • RAM—2 GB
    • Supported RF vector signal generator with minimum 256 MB of arbitrary waveform generator onboard memory
    Recommended System
    • RAM—4 GB
    • NI-RFSG 14.0 or later
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI WLAN Generation Toolkit. To add support for ADEs installed after installing NI WLAN Generation Toolkit, modify your NI WLAN Generation Toolkit installation or launch the NI WLAN Generation Toolkit installer again.
    WLAN Generation Soft Front Panel\WLAN Toolkit\WLAN Generation Soft Front Panel.exe
    DLL
    LabWindows/CVI
    C
    Examples\WLAN Toolkit\Examples\C\Samples\Generation
    TestStand
    Select Start»All Programs»National Instruments»NI WLAN Generation Toolkit»WLAN Generation Soft Front Panel to launch the NI WLAN Generation Toolkit Soft Front Panel.
    Documentation for the NI WLAN Generation Toolkit is located at Start»All Programs»National Instruments»NI WLAN Generation Toolkit»WLAN Generation Toolkit Documentation. The documentation set is composed of the following documents.
    NI WLAN Generation Toolkit HelpHTML/Windows HelpInformation about NI WLAN Generation Toolkit. The help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI WLAN Generation Toolkit
    • A complete reference for all NI WLAN Generation Toolkit programming functions and VIs
    NI WLAN Generation Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI WLAN Generation palette VIs are available from the Functions»RF Communications»WLAN»Generation palette.
    NI WLAN Generation functions are available in LabWindows/CVI from the Library menu.
    You can also access all the installed NI WLAN Generation examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»WLAN Generation Toolkit»WLAN Generation Toolkit Examples.
    NI WLAN Generation Toolkit 17.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI WLAN Generation Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI WLAN Generation Toolkit 17.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI WLAN Generation Toolkit 17.0 to an unsupported OS. Additionally, after installing NI WLAN Generation Toolkit 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI WLAN Generation Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: <;ProductName>. For example, NI WLAN Generation Toolkit 17.0 is the version released with LabVIEW 2017. The last version released under the old numbering scheme is NI WLAN Generation Toolkit 4.1. The first version released under the new numbering scheme is NI WLAN Generation Toolkit 14.0.
    • Select NI WLAN Generation Toolkit 17.0 from the dialog box that appears.
    The following are the behavior changes in NI WLAN Generation Toolkit 17.0 from NI WLAN Generation Toolkit 16.0:
    The following are the behavior changes in NI WLAN Generation Toolkit 15.0 from NI WLAN Generation Toolkit 14.5:
    • RF blanking marker positions are written per waveform basis in TDMS.
    The following are the behavior changes in NI WLAN Generation Toolkit 14.5 from NI WLAN Generation Toolkit 14.0:
    • Window length is different for OFDM signals. Refer to the OFDM Window Length (samples) property help topic for more information about windowing for OFDM signals.
    • The Guard Interval property is obsolete. Use the Guard Interval Type property instead.
    • LO sharing between multiple NI vector signal generators is enabled by default in the NI WLAN Generation Soft Front Panel.
    The following are the behavior changes in NI WLAN Generation Toolkit 3.0 from NI WLAN Generation Toolkit 2.0:
    • The Carrier Frequency and Power Level properties are obsolete in toolkit version 3.0. Configure the corresponding NI-RFSG properties when using the NI WLAN Generation Toolkit with NI-RFSG.
    • Windowing is applied differently for OFDM signals. Refer to the Window Length property help topic for more information about windowing for OFDM signals.
    • The Max Expected PAPR property has been renamed to Headroom.
    You can access the software and documentation known issues list online. Refer to the NI WLAN Generation Toolkit 17.0 Known Issues List at ni.com for an up-to-date list of known issues in NI WLAN Generation Toolkit 17.0.
    Bug IDFixed Issue
    The following items are changes in WLAN Toolkit 15.5 from WLAN Toolkit 15.0.
    Bug IDFixed Issue
    575479Fixed an issue where the value of the MU Coding bit was incorrect when the corresponding MU NSTS field value was 0 in the VHT-SIG-A field of the 802.11ac signal.
    549495Fixed an issue where there was a spelling error in the name of the niWLANG RFSG Create and Download Waveforms (Multiple Channel) VI.
    The following items are changes in WLAN Toolkit 14.5 from WLAN Toolkit 14.0.
    Bug IDFixed Issue
    516761Fixed an issue where enabling STBC All Streams Enabled property for 802.11ac multi-user PPDU gave memory full exception.
    511419Fixed an issue where ‘Invalid Input Seed’ error was returned when the number of frames was more than one for MU PPDU format.
    510067Fixed an issue where the Auto Route PXI Trigger Lines was returning an error on the NI PXIe-1078 and PXIe-1082 chassis in WLAN Generation Soft Front Panel.
    502841Fixed an issue where the RF blanking marker positions were invalid when the idle interval was 0.
    The following items are changes in WLAN Toolkit 14.0 from WLAN Toolkit 4.1.
    Bug IDFixed Issue
    495015Fixed an issue where reducing the number of generators does not release hardware sessions in WLAN Generation Soft Front Panel.
    The following items are changes in WLAN Toolkit 3.0 from WLAN Toolkit 2.0.
    Bug IDFixed Issue
    324232Fixed an issue where windowing is now corrected for power ramp-down for 33 Mbps DSSS signals.
    279591Fixed an issue where the PBCC encoder for DSSS signals is corrected.
    245320Fixed an issue where the reversed bit in L-SIG part in the HT packet of 802.11n mixed mode generation is now set to zero. In previous versions, it was set to 1.
    374869F-01
    GMT+8, 2025-10-29 15:36
