查看: 3238|回复: 0
[NI软件产品] NI Measurement Studio 2013_VS2010 Win32/64Eng NI MStudio 2013_VS2010
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-3-10 23:48:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Measurement Studio
    Measurement Studio是Microsoft Visual Studio的扩展软件,提供了用于创建测试和测量应用程序的.NET工具。
    Measurement Studio是一套专为构建工程应用程序而设计的.NET工具。您可以使用与硬件采集数据类型兼容的工程UI控件,以清晰明了地展示数据。Measurement Studio通过高级、直观的面向对象硬件类库简化了硬件通信。您可以使用业界最快、最灵活且最适合将测量数据存盘的文件格式TDMS,将自定义信息添加到采集的数据。您还可以对采集的信号进行实时在线分析,而无需编写自定义解析算法。
    Win32/64Eng 专业版/企业版/标准版/评估版
    MStudio2013_VS2010
    文件大小: 684690496 字节 (652.97 MB)
    修改日期: 2013-03-14 02:27
    MD5: b0d46c049277d7f0ff49343c08e5380f(可秒传)
    SHA1: 600940be9cfecaace606e3fe76fc16d58eb015d5
    SHA256: 0f8705f9de4f59d5de0217f9596a745bf392fec6b0bda0c96081f7599a4dfccc
    CRC32: ad5129f6
    MStudio2013_VS2010.txt (642 Bytes, 下载次数: 0, 售价: 10 圆)
    Measurement Studio 2013 for Visual Studio 2010 Readme
    Measurement Studio 2013 includes separate, parallel sets of class libraries, integration features, and support documentation for developing with Visual Studio 2012, Visual Studio 2010, and Visual Studio 2008. This readme documents only Measurement Studio support for Visual Studio 2010. Measurement Studio support for other versions of Visual Studio includes separate readme files; refer to these respective readme files or the Measurement Studio Release Notes for more information about Measurement Studio support for other versions of Visual Studio.
    For information on the new features and functionality that have been introduced in Measurement Studio since version 2012, refer to the What's New in Measurement Studio 2013 topic in the installed NI Measurement Studio Help.
    Installing Measurement Studio 2013
    To install and run Measurement Studio support for Visual Studio 2010, your computer must have the following:
    • Microsoft operating system:
      • Windows 8 (32-bit or 64-bit)
      • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
      • Windows Vista, Service Pack 2 (32-bit or 64-bit)
      • Windows XP, Service Pack 3 (32-bit)
    • Microsoft .NET Framework 4.0
    • Visual Studio 2010:
      • Ultimate Edition
      • Premium Edition
      • Professional Edition
      • Visual C# Express Edition
      • Visual Basic Express Edition
      • Visual Web Developer Express Edition
      Note    You must have Visual Studio 2010 Service Pack 1 or later installed on your machine for Measurement Studio to function properly.
    • Intel Pentium III class processor, 1.6 GHz or higher
    • DirectX 9-capable video card running at 1024 x 768 or higher-resolution display
    • 1 GB (32-bit) or 2 GB (64-bit) RAM
    • 1.2 GB of free hard disk space
    • Microsoft-compatible mouse
    • Microsoft Internet Explorer 6.0
    Installation Notes
    • Measurement Studio does not support:
      • Windows Vista Starter Edition
      • Non-R2 editions of Windows Server
    • Microsoft Visual Studio Express Editions do not support Measurement Studio Visual Studio-integrated tools.
    • This version of Measurement Studio supports, and was tested with, the latest Visual Studio service pack and the latest operating system service pack that was available at the time this version of Measurement Studio was released. National Instruments strongly recommends using Measurement Studio with the latest Visual Studio service pack and the latest operating system service pack.
    • If you want to upgrade your operating system from one major version to another, National Instruments recommends first uninstalling all National Instruments software, including application software and drivers. This is typically not necessary when installing an operating system service pack.
    • There are additional considerations for installing the Measurement Studio Help for Visual Studio 2010. Refer to the Installation Notes for Integrated Visual Studio 2010 Help section of this document for more information.
    National Instruments recommends that you exit all programs before running the Measurement Studio installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Log on as Administrator or as a user with administrator privileges.
    • Launch Autorun.exe, either from the installation media or from the location to which you extracted the downloaded disc image. Select Install Measurement Studio 2013.
    • In the Select Installation Option window, you can choose to activate Measurement Studio if you have a serial number, or you can choose to evaluate Measurement Studio.
    • Select Measurement Studio 2013 support for the version or versions of Visual Studio you want to install support for.
    • Select Device Drivers to install support for hardware.
    Tip    You can use a spec file to programmatically control the Measurement Studio installer for a single distribution or for the entire suite. An example spec file for a single distribution is located on your installation media at :Distributions\Measurement Studio for VS20xx\Bin\template_spec.txt. For more information, refer to KnowledgeBase Article 4CJDP38M: Automating the Installation of a Single Installer on ni.com. Alternately, you can generate a spec file for the entire Measurement Studio suite. Refer to KnowledgeBase Article 4GGGDQH0: Automating the Installation of a Suited Installer on ni.com for instructions on how to generate a spec file for your suite.
    Driver Support
    To determine what drivers are supported for each version of Visual Studio, whether the driver supports 32-bit or 64-bit applications, and the location of the installer files, refer to the Driver Support section of the Measurement Studio Release Notes.
    Activating Measurement Studio Licenses
    National Instruments offers a variety of Measurement Studio licenses, with certain licensed features available for each license type: Standard Edition, Professional Edition, and Enterprise Edition. Refer to the Measurement Studio Editions topic in the installed NI Measurement Studio Help for more information on Measurement Studio editions, and the Licensing Measurement Studio topic in the installed NI Measurement Studio Help for more information about licensing Measurement Studio.
    Tip    To move to a different Measurement Studio edition, you can activate the new edition by using NI License Manager. To access NI License Manager, select Start»All Programs»NationalInstruments»NI License Manager or, in Windows 8, select NI Launcher»NI License Manager.
    Measurement Studio supports concurrent licensing as part of a volume license agreement. If your software is a part of a Volume License Agreement (VLA), contact your VLA administrator for installation and activation instructions.
    Refer to the Learning Measurement Studio section for more information on accessing the NI Measurement Studio Help.
    Installing the Current Version of Measurement Studio over Previous Versions of Measurement Studio
    If you install a newer version of Measurement Studio on a machine that has a prior version of Measurement Studio installed, the newer version installer replaces the prior version functionality, including class libraries. However, the prior version assemblies remain in the global assembly cache (GAC); therefore, applications that reference the prior version continue to use the prior version .NET assemblies.
    Note    NationalInstruments.Common.dll uses a publisher policy file to redirect applications to always use the newest version of NationalInstruments.Common.dll installed on the system, for each version of the .NET Framework. However, prior versions of NationalInstruments.Common.dll remain in the GAC after you install a newer version of Measurement Studio. National Instruments exerts extra effort to ensure that NationalInstruments.Common.dll is backward-compatible so that applications built against prior versions of Measurement Studio continue to work as expected.
    Deployment Requirements
    Using NI Launcher
    Current Application
    Icon Location
    Pin to Action
    Windows 8 Desktop
    Desktop Taskbar
    Right-click application and select Pin to Taskbar
    Windows 8 Desktop
    Start screen
    Right-click application and select Pin to Start
    Windows 8 Start screen
    Desktop Taskbar
    Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    Getting Started with Measurement Studio 2013
    Within Visual Studio, you can launch the NI Measurement Studio Help by selecting Measurement Studio»NI Measurement Studio Help.
    Bug Fixes in Measurement Studio 2013
    You can access the known issues for Measurement Studio 2013 online. Refer to the Measurement Studio 2013 Known Issues Web page for a complete, up-to-date listing of known issues in Measurement Studio 2013.
    Measurement Studio 2013 Incompatibilities with Previous Versions of Measurement Studio
    The Measurement Studio life cycle support policy states a commitment to support the three most recent versions of Microsoft Visual Studio. As a result, Measurement Studio 2013 does not provide feature support for Visual Studio 2005, Visual Studio 2003, Visual C++ MFC, and Visual Studio 6.0. However, legacy support is available in the following products:
    • Measurement Studio 2012, which includes support for Visual Studio 2010 (Visual C#, Visual Basic .NET), Visual Studio 2008 (Visual C#, Visual Basic .NET), Visual Studio 2005 (Visual C#, Visual Basic .NET), and compatible hardware drivers.
    • Measurement Studio 2009, which includes support for Visual Studio 2008 (Visual C++ MFC, Visual C#, Visual Basic .NET), Visual Studio 2005 (Visual C++ MFC, Visual C#, Visual Basic .NET), Visual Studio 2003 (Visual C++ MFC, Visual C#, Visual Basic .NET), Visual Studio 6.0 (Visual Basic 6.0, Visual C++ 6.0), and compatible hardware drivers.
    • Measurement Studio C++ MFC for Visual Studio 2010 (Measurement Studio MFC 10), which includes Visual C++ MFC support for Visual Studio 2010.
    Refer to ni.com/mstudio/legacysupport for additional information about Measurement Studio legacy support, including installation and configuration information, or contact a Technical Sales Representative at ni.com/contact.
    Important InformationCopyright
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2025-10-29 15:32
