查看: 14905|回复: 5
[LV工具模块] NI Vision Development Module 2013 SP1 Win32/64Eng 视觉开发模块VDM2013SP1 适用LabVIEW2013SP1
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2014-3-29 00:28:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 移动
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE版为NI早期压制,ZIP版为NI后期压制,内容一样):
    请购买附件下载查看
    下载器:
    请购买附件下载查看
    VDM2013SP1.txt (482 Bytes, 下载次数: 75, 售价: 10 圆)
    Download Language: English
    Product Line: Vision Software
    Version: 2013SP1
    Release date: 02-14-2014
    Software type: Addons
    Operating system: Windows 8 32-bit; Windows 8 64-bit; Windows 7 64-bit; Windows 7 32-bit; Windows Vista 64-bit; Windows Vista 32-bit; Windows XP 32-bit; Windows Server 2008 R2 64-bit; Windows Server 2008 64-bit; Windows Server 2003 R2 32-bit
    NI Vision Development Module 2013 SP1 Readme
    January 2014
    This file contains important information about National Instruments Vision Development Module and is organized into the following sections:
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Development Module.
    Installing this program may remove previous versions of the NI Vision Development Module that are currently installed.
    The NI Vision Development Module 2013 SP1 supports LabVIEW 2010, 2011, 2012, and 2013; Visual Studio 2005 and 2008; and LabWindows™/CVI™ 8.1 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module:
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    1.4 GB
    Operating System
    Windows 8/Windows 7/Vista/XP (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 6.0 or later
    This release of the NI Vision Development Module includes the following new features:
    • Support for LabVIEW 2013 SP1 (32- and 64-bit)
    • New IMAQ ImageToEDVR VI, which exposes an image as an external data value reference. This allows you to manipulate image pixels using an In Place Element structure in LabVIEW and avoid making unnecessary copies of image data.
    • Improvements to calibration:
      • Using the NI Calibration Training Interface or the IMAQ Set Calibration Axis Info 2 - Reference Points VI, you can define a calibration axis using three nonlinear points and their corresponding real-world coordinates. Use this when the origin of the calibration axis is outside of the image.
      • The IMAQ Correction Learn Setup VI provides the option to ignore the calibration axis while correcting an image. Ignoring the calibration axis will not rotate or flip the image when you call IMAQ Correct Calibrated Image.
    • Increased JPEG performance when streaming images from remote targets to the host machine.
    NI Vision Assistant includes the following new features:
    • Vision Assistant 64-bit executable. This allows you to open and proces larger images.
      Note: The 64-bit version of Vision Assistant does not generate C or .NET code.
    The following list describes issues in previous versions of the NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the NI Vision Development Module.
    432530Edge-based geometric pattern matching using an indirect axis crashes.
    432149IMAQ Read Data Matrix Barcode 3 crashes with some images.
    427986Geometric Pattern Matching returns incorrect calibrated results for some axis angles.
    424322Multiline OCR does not detect very small characters.
    415530The Calibration Training Interface angle might not be set correctly in some specific cases.
    426542Optical Flow Feature Tracking corrupts memory and crashes during execution in LabVIEW 64-bit.
    290354Passing an Image Display Control by reference to a subVI inside of a DLL will crash LabVIEW from the run-time environment.
    286686LabVIEW crashes when reading some TIFF image files.
    364612Passing references of empty images to IMAQImage Property Nodes can cause a crash in built executables for some properties.
    437842Overlay colors are not displayed correctly in snapshot mode in LabVIEW 64-bit.
    432798Max caliper repeatability is improved for two parallel edges.
    383515IMAQ Particle Filter 3 returns an incorrect number of particles in LabVIEW 64-bit.
    363415Data Matrix detection does not support rotated or flipped rectangle barcodes.
    439066IMAQ Convolute returns a black image for 7x7 kernel with only 1's on the first row.
    431102ROIs around each read OCR character do not tilt to match the overall angle of the line of text.
    428419IMAQ Absolute Difference does not support the RGB64 image type.
    432528Vision Assistant and the Calibration Training Interface do not correct for distortion information in calibrated images.
    440607In the Calibration Training Interface, an invalid coordinate system error is returned when using edit calibration axis.
    417571The IMAQ AVI2 VIs cannot create uncompressed AVIs.
    403508The IMAQ AVI2 VIs cannot read some uncompressed AVIs.
    428422IMAQ Extract Single Color Plane does not support the U16 image type for the destination.
    411296Bad pixels toward the end of the row when decoding using certain Bayer pixel formats.
    428437IMAQ Extract does not support the RGB64 image type.
    430001Cannot use extended ASCII code in the IMAQ AVI file name for IMAQ AVI2 VIs.
    Remote Target Support
    NI Vision Development Module 2011 SP1 was the last version of NI Vision Development Module to provide support for the NI 1762 Smart Camera and the NI 1764 Smart Camera. New software features of NI Vision Development Module will not work on these devices. Backward compatibility for existing applications will be maintained.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the Vision Development Module CD.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the run-time engine installer for NI Vision. The run-time engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the Drivers and Updates section of ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module CD. The NI Vision Development Module CD ships with one run-time license. Contact a National Instruments sales representative or visit ni.com to purchase additional run-time licenses.
    Note: Additional NI Vision Run-Time Licenses do not include a CD. To install additional licenses, use the original NI Vision Development Module CD and the serial number provided by National Instruments.
    Using the NI Vision Run-Time Engine
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    To use the NI Vision Run-Time Engine installer, you must add /qn as a command line argument to the run-time engine installer. For example, enter \Run-Time Engine\vision2012rte.exe /qn to run the NI Vision Run-Time Engine installer, where is the location to which NI Vision is installed.
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    • The IMAQ Edge Tool 3 VI can cause a fatal error in LabVIEW when using a large ROI.
    • Specifying a negative angle in the IMAQ Learn Pattern 4 VI causes error -1074395249.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux® Real-Time targets.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large, 32-bit image in the Image Display in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    • Using NI Vision with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
    The NI Vision Development Module documentation set consists of the following manuals and help files:
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—Describes how to create machine vision and image processing applications in LabVIEW using the NI Vision Development Module. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module.
      This document also contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. In LabVIEW, select Help»NI Vision for LabVIEW Help.
      Note: The NI Vision for LabVIEW Help combines the NI Vision for LabVIEW User Manual and NI Vision for LabVIEW VI Reference Help from previous releases into one document.
    • NI Example Finder—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision for .NET Documentation
    The NI Vision .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
    • Example programs for specific applications are installed at is the location to which NI Vision is installed.
    NI Vision Assistant Documentation
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    Using NI Launcher
    Finding All Programs
    NI Vision Development Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Vision Development Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Vision Development Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2014 National Instruments Corporation. All rights reserved.
  • 签到天数: 15 天
    发表于 2016-1-21 10:35:25 | 显示全部楼层 来自:江苏省苏州市 电信
    NI Vision Development Module 2013SP1 for LabVIEW2013SP1 Win32/64Eng VDM2013SP1视觉开发包适用32位/64位LV2013SP1版下载
    谢谢分享,下载使用!
  • 签到天数: 7 天
    发表于 2017-3-28 07:25:35 | 显示全部楼层 来自:广东省深圳市 电信
    谢谢分享,下载使用!
  • 签到天数: 2 天
    发表于 2021-4-22 23:39:35 | 显示全部楼层 来自:河南省郑州市 电信
    XUEXI.kexiwo meijifen a
  • 签到天数: 2 天
    发表于 2021-4-22 23:40:06 | 显示全部楼层 来自:河南省郑州市 电信
    可不可以便宜点嗯,太对了啊
  • 签到天数: 2 天
    发表于 2021-4-22 23:40:21 | 显示全部楼层 来自:河南省郑州市 电信
    谢谢分享,下载使用!
    谢谢分享,下载使用!
    GMT+8, 2025-12-5 13:22
