查看: 3549|回复: 0
[NI软件套件] NI Measurement Studio 2019f3 and Drivers Win32/64Eng NI MStudio 2019f3和驱动
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-3-11 00:19:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Measurement Studio
    Measurement Studio是Microsoft Visual Studio的扩展软件,提供了用于创建测试和测量应用程序的.NET工具。
    Measurement Studio是一套专为构建工程应用程序而设计的.NET工具。您可以使用与硬件采集数据类型兼容的工程UI控件,以清晰明了地展示数据。Measurement Studio通过高级、直观的面向对象硬件类库简化了硬件通信。您可以使用业界最快、最灵活且最适合将测量数据存盘的文件格式TDMS,将自定义信息添加到采集的数据。您还可以对采集的信号进行实时在线分析,而无需编写自定义解析算法。
    Win32/64Eng 专业版/企业版/标准版/评估版
    2019f3 and Driver
    文件大小: 10141853696 字节 (9.45 GB)
    修改日期: 2020-01-21 14:12
    MD5: ddaccdf38809c36fe449a83b39305d25(官方正确)
    SHA1: 282e81def56ed2fc5b358bee94fe530e2c21c16f
    SHA256: 13104260920caf243f34d703dcbcc48354dba702f6433afd5bed6d040eefb14d
    CRC32: 8b175fcd
    MStudio2019f3 and Driver.txt (680 Bytes, 下载次数: 0, 售价: 30 圆)
    Measurement Studio 2019 f1 Readme
    May 2019
    This file contains important information about Measurement Studio, including system requirements and installation instructions.
    Driver Support
    Features
    Getting Started with Measurement Studio
    NI Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Measurement Studio is an integrated suite of tools, controls, and class libraries designed to help developers create measurement and automation Windows Forms, Windows Presentation Foundation (WPF), and Web Forms applications using Microsoft .NET technologies.
    Measurement Studio 2019 has the following requirements:
    • Microsoft .NET Framework 4.5 (minimum)
    • Microsoft Visual Studio 2015, Visual Studio 2017, or Visual Studio 2019
      • Enterprise Edition
      • Professional Edition
    • 1.6 GHz or faster processor
    • 1.2 GB of free hard disk space
    • 1 GB (32-bit) or 2 GB (64-bit) RAM
    • DirectX 10-capable video card
    System Recommendations
    In addition, Measurement Studio 2019 recommends the following:
    • 2.6 GHz or faster processor
    • 4 GB (32-bit or 64-bit) RAM
    • DirectX 11-capable video card
    Measurement Studio 2019 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21, 64-bit
    • Windows Server 2016 R2, 64-bit
    Installation Notes
    • The first time you open Visual Studio 2019 after installing Measurement Studio 2019, the Visual Studio Performance Manager window appears and displays the following text: "NI Measurement Studio Support for Visual Studio: The extension uses deprecated APIs and will not be compatible with a future Visual Studio update." This text appears because Visual Studio will be deprecating the technology it currently uses for extensions after Visual Studio 2019. Measurement Studio is fully compatible with Visual Studio 2019 and will be updated to continue to work with Visual Studio 2019 and future versions of Visual Studio.
    • If you installed the Measurement Studio 2019 Beta, uninstall all Measurement Studio 2019 Beta files before installing the released version of Measurement Studio 2019.
    • This version of Measurement Studio supports, and was tested with, the latest Visual Studio updates and the latest operating system updates that were available at the time this version of Measurement Studio was released. National Instruments strongly recommends using Measurement Studio with the latest Visual Studio and operating system updates.
    • If you want to upgrade your operating system from one major version to another, National Instruments recommends first uninstalling all National Instruments software, including application software and drivers. This is typically not necessary when installing an operating system update.
    Note  In 2016, Measurement Studio dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Measurement Studio 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Measurement Studio 2019 to an unsupported OS. Additionally, after installing Measurement Studio 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI automates Measurement Studio installation using NI Package Manager. If you do not already have NI software installed, Measurement Studio 2019 installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate Measurement Studio. For more information on Measurement Studio activation, refer to National Instruments Software Activation.
    • NationalInstruments.Common.dll uses a publisher policy file to redirect applications to always use the newest version of NationalInstruments.Common.dll installed on the system. National Instruments exerts extra effort to ensure that NationalInstruments.Common.dll is backward-compatible so that applications built against prior versions of Measurement Studio continue to work as expected.
    Driver Support
    To use .NET class libraries that interface to National Instruments device drivers, you must install the underlying device drivers in addition to the .NET class libraries. You can run the underlying device driver installers using the installation media included with Measurement Studio or you can download the device driver from ni.com. Refer to National Instruments .NET Driver Support for information on what drivers are supported for each version of the .NET Framework and the download location of the installer files.
    Features
    Measurement Studio 2019 includes the following new features.
    • Support for Visual Studio 2015, Visual Studio 2017, and Visual Studio 2019
    • Debug Visualizer Support
    • Graph Thumbnail WPF Control
    • Updated Format and Style for Installed Measurement Studio Help
    • Additional Features
      • TDMS API Updates
      • Support for NI Package Builder
      • Bug Fixes
    Note    Measurement Studio 2019 f1 contains support for Visual Studio 2019. Use NI Package Manager to ensure that you have the most recent version of Measurement Studio. You can access NI Package Manager by selecting National Instruments»NI Package Manager in the Windows Start menu.
    Refer to the New Features in Measurement Studio 2019 topic in the installed Measurement Studio Help for more information on enhancements to Measurement Studio. You can access the Measurement Studio Help from within Visual Studio by selecting Measurement Studio Help from within the Measurement Studio menu.
    Refer to Measurement Studio Release Information for a list of incompatibilities introduced in Measurement Studio 2019.
    Refer to Measurement Studio Release Information for a for an up-to-date list of known issues in Measurement Studio 2019.
    Refer to Measurement Studio Release Information for a list of bugs fixed in Measurement Studio 2019.
    Select Measurement Studio Examples from within the Measurement Studio menu in Visual Studio to launch the directory containing Measurement Studio example code projects.
    If the NI product you are installing uses a version of Microsoft .NET that is not already installed on the system, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins.
    Activating Measurement Studio Licenses
    If you do not activate Measurement Studio during installation, you can activate after you install. To activate after you install:
    • Use NI License Manager; or
    • If you have Measurement Studio Visual Studio-integrated tools installed, open Visual Studio, and select Measurement Studio»Activate Measurement Studio.
    After launching NI License Manager, you can use one of the following methods to activate Measurement Studio:
    • If you received a USB memory stick for your installation media, then your serial number is printed on the box you received. Use your serial number to use NI License Manager to activate Measurement Studio. You can also use your serial number to activate Measurement Studio by selecting Measurement Studio Activate Measurement Studio from within Visual Studio environment.
    • If you downloaded Measurement Studio, then you can sign in to your NI account and activate Measurement Studio using your NI credentials.
    The first time you use a Measurement Studio licensed component, a dialog box appears to confirm your license activation.
    For general license activation information, refer to ni.com/activate. Refer to ni.com/mstudio to purchase a Measurement Studio license. Contact a local National Instruments representative at ni.com/contact for more information or for questions about specific licensing needs.
    Note    NI LabWindows™/CVI™ is no longer included in the Measurement Studio Enterprise Edition. For more information, please contact customer service at 1-866-519-6285.
    Note   Activating the NI TestStand™ Debug Deployment license will activate the Measurement Studio Debug Deployment license.
    Measurement Studio Editions
    National Instruments offers a variety of Measurement Studio licenses, with certain licensed features available for each license type: Standard Edition, Professional Edition, and Enterprise Edition. Refer to ni.com/mstudio for more information on Measurement Studio editions, and the Licensing Measurement Studio topic in the installed NI Measurement Studio Help for more information about licensing Measurement Studio.
    Tip    To move to a different Measurement Studio edition, you can activate the new edition by using NI License Manager. Launch NI License Manager from the National Instruments folder in the Start menu or from NI Launcher in Windows 8.1.
    Concurrent Licensing
    Measurement Studio supports concurrent licensing as part of a volume license agreement. If your software is a part of a Volume License Agreement (VLA), contact your VLA administrator for installation and activation instructions.
    NI will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2003–2019 National Instruments. All rights reserved.
    GMT+8, 2025-12-6 06:54
