查看: 3148|回复: 0
[Patch补丁] NI Circuit Design Suite 10.1 Edu Patch Win32Eng/Ger/Jpn NI电路设计套件10.1教学版补丁
    发表于 2021-3-12 23:49:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    10.1Edu Patch
    文件大小: 55968657 字节 (53.38 MB)
    修改日期: 2012-09-12 23:50
    MD5: 30ec49999678b8f9e6e52a3dc0155ded(官方正确)
    SHA1: 85803e09d509383711f25f39e09594b31debc250
    SHA256: dc282f8f3ea08a9ae67dd2a2a4caa2a3237ab9cf03a928ca5f5f37cff22dd192
    CRC32: c8a301ab
    CDS10.1Edu Patch.txt (604 Bytes, 下载次数: 0, 售价: 1 圆)
    NI Circuit Design Suite 10.1.1 Readme for Windows
    January 2009
    This file contains important last-minute information about Circuit Design Suite 10.1.1 for Windows, including installation issues, compatibility issues, bugs fixed, and changes from Circuit Design Suite 10.1.0. Refer to the NI Circuit Design Suite Release Notes for a complete list of new features in Circuit Design Suite 10.1.1. You can access this document by selecting Help»Release Notes in Multisim or Ultiboard or navigating to Start»All Programs»National Instruments»Circuit Design Suite 10.1»Documentation»Release Notes.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 10.1»Documentation»Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 10.1.1
    New Components
    Supported Platforms
    Circuit Design Suite 10.1.1 supports Windows Vista/XP/2000 32-bit editions and Windows Vista 64-bit edition. Circuit Design Suite 10.1.1 does not support Windows NT/Me/98/95, or Windows XP x64.
    Installing Circuit Design Suite 10.1.1Installing Multiple Versions
    Circuit Design Suite 10.1.1 upgrades Circuit Design Suite 10.1.0. You cannot install Circuit Design Suite 10.1.1 side-by-side with version 10.1.0. You must reactivate Circuit Design Suite after you install it. It will not activate itself automatically.
    Installing Circuit Design Suite Silently
    You can install Circuit Design Suite without viewing any installation dialog boxes. Refer to the silent_install.txt file in the Supportfiles directory in the Circuit Design Suite distribution for more information about installing Circuit Design Suite silently.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Circuit Design Suite 10.1.1 on Windows Vista Starter edition.
    • MultiVHDL will not install on Windows Vista.
    • Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is and issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    The following is a subset of the issues fixed between Circuit Design Suite 10.1.0 and Circuit Design Suite 10.1.1
    Multisim
    Bug IDDescription
    111150AC Relay Coil not releasing when power is disconnected.
    110220The model for the TL431 component is incorrect.
    110855Sorting using the user fields for RLC components in the Database Manager no longer works.
    110932The Print Instruments dialog does not list any LabVIEW or NI ELVIS Instruments in its list.
    110935ERC does not report section names for warnings.
    1109392N3055A has wrong footprint mapping.
    111517Adding unused Multisim instruments to a circuit slows down simulation.
    111090LM301AD model mapping is wrong for the LM301A model.
    111346The corner frequency in the Transfer function component in Multisim is incorrectly defined.
    111361THREE_PHASE_DELTA component is modelled incorrectly.
    111386NC marking for pins common between multiple sections of components does not work as expected.
    111418Copying RLC components to the user or corporate databases does not copy over any associated footprint information.
    111455AD584JH footprint pin mappings are incorrect.
    111087Setting schematic to read only does not fully restrict changes to the schematic.
    106456The spreadsheet sometimes adds components to non-existent variant.
    108400An MCU workspace could not be saved until after saving the main circuit file.
    1087857492 Counter did not operate correctly.
    108816Multisim is not saving the MCU workspace path, after searching and finding an MCU workspace.
    108986The transconductance for a Voltage Controlled Current Source in Multisim could not be negative.
    109171Multisim crashes if a component's model is changed via the spreadsheet view.
    111536Agilent scope autoscaling with connection to digital inputs causes the simulation to slow down.
    112068Linear LM101A model for LM101AD is not mapped correctly.
    111981Multisim Multimeter does not refresh correctly when used with the Elvis Variable Power Supply.
    112016Case29 footprint remapped pin incorrectly.
    112047TS_POWER_10_TO_1 transformer gives incorrect results.
    1115021m and 1M resistors are being grouped together in the Multisim Bill Of Materials Report.
    112052The PSpice temperature parameters do not work correctly when using AKO models.
    111852Routing layer does not default to route on all layers in some cases.
    112070BAT54S has incorrect mapped symbol to land pattern pins.
    112118Noise Analysis uses incorrect temperature.
    112218Current control voltage symbol doesn't match with simulation.
    112224Using the Set X Value cursor in the grapher causes a crash when used in a Japanese locale.
    112241Loading a model from file in the component wizard fails if the file's path contains Unicode.
    112374Multisim crashes when adding separator to Analysis toolbar button menu.
    112418Multisim crashes when deleting the current variant from right click on the hierarchy tab.
    112050AKO models which are not referenced by any devices are not passed to XSPICE.
    11168074HC163 is triggering on the wrong clock edge.
    111588The component 74HC162 does not simulate in Multisim.
    111590RCO (TC) pin not modeled correctly for 74HC163.
    111615Convergence errors occur when using ELVISmx instruments in some cases.
    111636Multisim saves edited footprint data to the database even if the changes are cancelled by user.
    111645Switches do not pass current on simulation run if initially closed.
    111663Symbol Editor Spreadsheet View Not Sorting In Numerical Order.
    111673Component is incorrectly saved to the database if it is flipped before saving.
    111674The model for the 74HC163 does not use the correct propagation delay constants.
    111675The clk pin for 74hc163 is incorrectly marked as active low.
    111687The Bill of Materials Report does not sort by RefDes.
    111708LabVIEW 8.5.1 instrument interface causes hang on close.
    111713Bode plotter and Function generator do not work together.
    111776Copy and Flip operation causes Ammeter to switch polarities.
    111779Noise figure analysis outputs negative frequencies in some cases.
    111826Hierarchical block symbol becomes uneditable in some cases.
    112514GND does not appear in Components tab of Spreadsheet View.
    111676Section B of the 74LS74 component has an incorrect netlist.
    112650Back annotating a footprint (or shape) change from Ultiboard deletes component in Multisim.
    111834The pin mappings for SOD-123 is incorrect, causing incorrect results when the circuit is exported to Ultiboard.
    112217The ohm symbol doesn't show up on the multi meter when using Multisim under Windows 2000 and under XP when the XP Classic theme is enabled.
    Ultiboard
    110792Pin hole can't be changed back to Standard hole after it is changed to an Advanced drill hole.
    110824Undo does not work correctly with the netlist editor.
    1109123D Preview does not work with Aero enabled on Vista.
    111052Adding or removing layer pairs will revert the mechanical layers to one pair layer.
    109184Adding an attribute to a new hole placed on a design that has nothing else on it causes Ultiboard to crash.
    111275Autorouting/Autoplacing while netlist editor is open deletes all changes that might have been made since the netlist editor was opened.
    111276"Mid-air" drc errors occur if parts are moved during netlist editing.
    111280Undoing a net then pressing ok in netlist editor crashes Ultiboard.
    111441Fiducial marks lines are too small.
    103964Placing a Power Plane covers a cutout on a board.
    108409Exported SVG could not be viewed with some 3rd party viewers.
    106729The Default Layout Colors could be changed.
    107859Via layers could not be changed after placing a via.
    107939Searching for part of text did not work in Ultiboard.
    107949Moving between steps in the Part Wizard sometimes changes the pad size.
    107966Ultiboard sometimes crashes when showing 3D if there are incorrectly formed polygons.
    107997Ultiboard crashes after Undo then Redo of Renumber Parts.
    108054Exporting bill of materials, Ultiboard prevents modification of the folder after export has completed.
    108135SVG export does not export THT pads correctly.
    108248Ultiboard complains about the board outline being incomplete while drawing the board outline via coordinates.
    109454The autorouter ignores pad rotations when routing nets.
    109431TO220_7 footprint is incorrect.
    108850Net bridges are being removed when forward annotating circuits from Multisim to Ultiboard.
    108860Ultiboard does not print correctly if the printer is configured to use a high DPI setting.
    109088Gerber drill table should include slot information.
    109095Zooming to an area in rapid succession in Ultiboard caused the application to crash.
    109147Ultiboard does not export slot holes correctly when exporting as an NC Drill file.
    108392Copper areas sometimes do not void correctly.
    111895Pressing the * key to enter coordinates while editing a component does not work.
    111901Printing the silkscreen layer takes a long time in Ultiboard 10.1.
    111906Exporting a Gerber File that contains the SOIC127P600X175-14Nt footprint causes Ultiboard to become unresponsive.
    111931Pin 1 indicator is incorrect for the TSOP65P488X117-8N footprint.
    111934Clearances on board outlines are not accurate for small outlines.
    112035Closing Ultiboard while the netlist editor is open will lead to a crash.
    112114Selecting Custom Pad Shape in Part Wizard will crash Ultiboard in some cases.
    112116Selecting many multiple custom pads and right-click Properties, crashes Ultiboard.
    112333Ultiboard crashes when editing the Radius of a Net Bridge Pad.
    111601Removing a vertex from a polygon does not properly update the polygon.
    111884Ultiboard 10.1 crashes with moving or editing a component in some cases.
    111677Placing a Net Bridge will not include its pins in the nets that were previously selected.
    111864Deleting a trace causes the power plane island to be the entire power plane and the user cannot remove it anymore.
    111785Show dimensions does not work if mechanical layers are turned off.
    111790Unable to create a composite of the drill symbol and mechanical layer.
    111809Autoroute short nets together in some cases.
    New Components
    The following components are new in Multisim 10.1.1:
    • 82 Analog Devices components
    • 235 National Semiconductor components
    Analog Devices
    AD536AJDAD536AJHAD536AJQAD536ASE/883BAD636JDAD636JHAD636KDAD636KH
    AD795JRZAD8000YCPZAD8000YRDZAD8003ACPZAD8031ANZAD8031ARTZAD8031ARZAD8031BNZ
    AD8031BRZAD8032ANZAD8032ARMZAD8032ARZAD8032BNZAD8032BRZAD8048ANAD8048AR
    AD8062ARMAD8062ARMZAD8062ARZAD8065ARTZAD8065ARZAD8066ARMZAD8066ARZAD8099ACP
    AD8099ARDAD8139ACPAD8139ACPZAD8139ARDAD8139ARDZAD8502ARJZAD8506ARMZAD8538ARZ
    AD8538AUJZAD8565AKSAD8565AKSZAD8627AKSZAD8627ARZAD8631ARTZAD8632ARMZAD8632ARZ
    AD8638ARJZAD8638ARZAD8646ARMZAD8646ARZAD8663ACPZAD8663ARZAD8669ARUZAD8669ARZ
    AD8692ARMZAD8692ARZAD8694ARUZAD8694ARZADA4000-1ARZADA4000-1AUJZADA4000-2ARMZADA4000-2ARZ
    ADA4000-4ARUZADA4000-4ARZADTL082ARMZADTL082ARZADTL082JRADTL082JRZADTL084ARUZADTL084ARZ
    ADTL084JRADTL084JRZOP2177ARMZOP2177ARZOP27EPZOP27GJZOP27GPZOP27GSZ
    OP4177ARUZOP4177ARZ
    LF411MH/883LF411MWG/883LF412MH/883LM111E/883LM124AWG/883LM158AWG/883LM2902MTLM2904ITP
    LM324MTLM358TPLM4250J-MILLM4562HALM4562MALM4562NALM6142AMJ-MLSLM6152ACM
    LM6152BCMLM6172AMJFQMLLM6172AMWGFQMLLM6181IMLM6211MFLM7121IMLM7121IM5LM7171AMJFQML
    LM7372IMALM7372MRLMC6035IBPLMC6035IMLMC6035IMMLMC6035ITLLMC6036IMLMC6036IMT
    LMC6442AIMLMC6462BIMLMC6462BINLMC6464AMWG-QMLLMC6464BIMLMC6464BINLMC6484AMWG/883LMC660AIM
    LMC660AINLMC662AIMLMC662AINLMC6762AIMLMC6762BIMLMC6772AIMLMC6772AIMMLMC6772BIM
    LMC6772BINLMC7111BIM5LMC7211AIMLMC7211AIM5LMC7211BIMLMC7211BIM5LMC7215IMLMC7215IM5
    LMC7221AIMLMC7221AIM5LMC7221BIMLMC7221BIM5LMC7225IM5LMC8101BPLMC8101MMLMC8101TP
    LME49710HALME49710MALME49710NALME49720HALME49720MALME49720NALME49740MALME49740NA
    LMH6321MRLMH6321TSLMH6502MALMH6502MTLMH6503MALMH6503MTLMH6505MALMH6505MM
    LMH6550MALMH6550MMLMH6551MALMH6551MMLMH6552MALMH6552SDLMH6559MALMH6559MF
    LMH6601MGLMH6609MALMH6609MFLMH6618MKLMH6619MALMH6622MALMH6622MMLMH6624J-QML
    LMH6624MALMH6624MFLMH6628JFQMLLMH6628MALMH6628WGFQMLLMH6639MALMH6639MFLMH6642MA
    LMH6642MFLMH6643MALMH6643MMLMH6644MALMH6644MTLMH6645MALMH6645MFLMH6646MA
    LMH6646MMLMH6647MALMH6647MFLMH6655MALMH6655MMLMH6657MFLMH6657MGLMH6672MA
    LMH6672MRLMH6702J-QMLLMH6702MALMH6702MFLMH6703MALMH6703MFLMH6714J-QMLLMH6714MA
    LMH6714MFLMH6715JFQMLLMH6715MALMH6718MALMH6720J-QMLLMH6720MALMH6720MFLMH6722J-QML
    LMH6722MALMH6722MTLMH6723MALMH6723MFLMH6733MQLMH6738MQLMH6739MQLMP2011MA
    LMP2011MFLMP7701MALMP7701MFLMP7702MALMP7702MMLMP7704MALMP7704MTLMP7707MF
    LMP7708MMLMP7709MTLMP7711MKLMP7712MMLMP7715MFLMP7716MMLMP7717MALMP7717MF
    LMP7718MALMP7718MMLMP7731MALMP7731MFLMP7732MALMP7732MMLMP8270MALMP8271MA
    LMP8272MALMP8275MALMP8276MALMP8277MALMV2011MALMV2011MFLMV321M5LMV321M7
    LMV324MLMV324MTLMV331M5LMV331M7LMV339MLMV339MTLMV342MALMV342MM
    LMV358MLMV358MMLMV393MLMV393MMLMV551MGLMV552MMLMV554MTLMV641MA
    LMV641MGLMV651MGLMV652MMLMV654MTLMV711M6LMV716MMLMV7219M5LMV7219M7
    LMV721M5LMV721M7LMV7271MFLMV7271MGLMV751M5LMV771MGLMV791MKLMV792MM
    LMV796MFLMV797MMLMV822MLMV822MMLMV824MLMV824MTLMV841MGLMV842MA
    LMV842MMLMV844MALMV844MTLMV851MGLMV852MMLMV854MTLMV951MKLMV981BL
    LMV981MFLMV981MGLMV981TLLPC660IMLPV321M5LPV321M7LPV324MLPV324MT
    LPV358MMLPV358MXLPV511MG
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-12-8 07:37
