查看: 2396|回复: 0
[NI软件产品] NI Circuit Design Suite 11.0 Edu Win32Eng/Ger/Jpn NI电路设计套件11.0教学版
    1 小时前
  • 签到天数: 3582 天
    连续签到: 2 天
    发表于 2021-3-12 23:54:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    11.0EDU
    (MD5)
    9d4468cd3e359a37f7ee947fadc4778f
    (SHA256)
    c4e3b90e4de52d629195b67a85347f6abd77b33f516a069ed0875dff649f2ca8
    无资源
    NI_Circuit_Design_Suite_11_0_Education
    文件大小: 417245728 字节 (397.92 MB)
    修改日期: 2009-12-18 13:45
    MD5: c31c64c469dac2e38d852865a9563ac5
    SHA1: 7ba5f983b665011a53b7ed51fc3c9a8580b2bc64
    SHA256: c22078d946d0aa024bbcecccbd73e8053724dc37491e517daedab445585f3925
    CRC32: ecf63c9e
    CDS11.0EDU.txt (825 Bytes, 下载次数: 0, 售价: 10 元)
    NI Circuit Design Suite 11.0 Readme for Windows
    January 2010
    This file contains important last-minute information about Circuit Design Suite 11.0 for Windows, including installation issues, compatibility issues, bugs fixed, and changes from Circuit Design Suite 10.1.1. Refer to the NI Circuit Design Suite Release Notes for a complete list of new features in Circuit Design Suite 11.0 . You can access this document by selecting Help»Release Notes in Multisim or Ultiboard or navigating to Start»All Programs»National Instruments»Circuit Design Suite 11.0»Documentation»Release Notes.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 11.0»Documentation»Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 11.0
    New Components
    Supported Platforms
    Circuit Design Suite 11.0 supports Windows Vista/XP 32-bit editions, Windows Vista 64-bit edition, Windows 7 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Circuit Design Suite 11.0 does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the Info Code windows7.
    Installing Circuit Design Suite 11.0Installing Multiple Versions
    Circuit Design Suite 11.0 installs side-by-side with version 10.1.1.
    Installing Circuit Design Suite Silently
    You can install Circuit Design Suite without viewing any installation dialog boxes. Refer to the silent_install.txt file in the Supportfiles directory in the Circuit Design Suite distribution for more information about installing Circuit Design Suite silently.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Circuit Design Suite 11.0 on Windows Vista Starter edition.
    • MultiVHDL will not install on Windows Vista or Windows 7.
    • Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    The following is a subset of the issues fixed between Circuit Design Suite 10.1.1 and Circuit Design Suite 11.0
    Bug IDDescription
    Multisim ( 131 )
    111005Grapher title/axis text does not show up correctly on Japanese operating systems.
    111194Some CMOS components have random outputs when they are powered up.
    111291Bill of Materials reports all Hierarchical Block variants when no parent variant exists.
    111336Undo and Redo menu items are not translated in the Symbol Editor / Title Block Editor
    111465Merging database from older version gives assert and error about wrong password
    111506Opening a Multisim project file as read-only does not work as expected.
    111534Line driver SN75173 does not work correctly.
    111557Visibility tab settings never saved.
    111612Netlist import does not import sources correctly.
    111614Convergence Assistant doesn't use LabVIEW or ELVIS instruments
    111649Multisim does not work correctly if the corporate/user database exists on a network and the network access is not available.
    111732Node does not change to digital type if all analog components disconnected and only digital components are connected.
    111766Component color not saved correctly.
    111786CD4538 doesn't work as expected.
    111837Enabled status of ELVIS 2 instruments in hierarchical block file are not set correctly when first loaded.
    111839Multisim instruments in ELVIS 1 schematic do not work when simulating in hierarchical block
    111874Missing functionality in Component Properties window
    111883Adding a new section to multi-section component does not keep pin/gate swap consistent for the other sections.
    111885Default pin/gate swap should be enabled for components that have this information setup.
    111954Saving and Save As are confusing when hierarchical blocks are used
    112094DC Sweep analysis incorrectly allows using 0 as an increment step.
    112115The dip switch initial condition doesn't behave correctly.
    112225The value of current sources is shown as voltage in Sweeping analyses.
    112233Paths with spaces are not accepted for certain XSpice commands
    112265Variable list missing items after you click Change Filter.
    112268Worst Case is not saving new tolerances added.
    112347Components still showing up as non-virtual even though it has no footprint.
    112376Printing an instrument over a wireless network takes a long time in some cases
    112474Measurement probe displays a 5V value in an unconnected wire
    112563Word generator properties window resizes itself when changing display format
    112599Rated LEDs have unrealistic parameters.
    112622Spare Gates Report updates incorrectly after backannotating from Ultiboard after using advanced gate swap.
    112632Multisim crashes when opening files saved with Multisim Textbook Edition (.mst)
    1126484018 does not behave like a Johnson Counter.
    112713Models for Voltage Controlled Capacitor and Voltage Controlled Inductor do not behave as expected.
    112733Resistance value on the DMM doesn't seem to reset in some cases.
    112777Multisim crashes when trying to change values of lumped elements in Match Net. Designer
    112796XSPICE interface cannot handle "listing" command for large files
    112836Footprint Pins and Symbol Pins columns disappear when switching windows.
    112839DC Operating point algorithm routine cannot be paused by the user once it starts.
    112859In the ELVIS scope instrument, changing the timebase setting from lowest value to another value does not work correctly.
    112876Inductor Device power parameter is incorrectly calculated for AC analysis
    112929Electrolytic Cap symbol pin ordering causing footprint mapping issues.
    112936Logic Converter auto-circuit generation does not handle placement of the auto-generated components correctly.
    112947Multisim crashes after backannotating a Renumber Parts task.
    112969Multisim crashes when deleting the only open page of a multi-page design.
    112972Pre-processor allows expression using parameters whose device no longer exist
    112980Post/pre processor grpdelay() function returns incorrect results.
    112981Description box does not save the wrap setting.
    112995Variable capacitor doesn't change on the fly
    113049Ready pin on Word Generator no longer work correctly in some cases.
    113102Bipolar voltage source does not show useful information on the schematic
    113137Adding layers in MS does not preserve layer settings
    113138SPICE subcircuit params are being counted as pins in the pin to model mapping table.
    113167Component editor is incorrectly displaying pin parameters in some cases.
    113192Piecewise linear voltage source rounding off time values in some cases.
    113198NC_CONTACT and NO_CONTACT have wrong DIN symbol
    113220Using the hat symbol ^ to place a negation bar on pin names makes the pins disappear in some cases.
    113258Entire wire disappears when rewiring endpoint of existing wire and clicking anywhere on the wire as the final endpoint.
    113284Multiplicity Parameter 'M' is not supported by BSIM.
    113297PGA17X17 package has incorrect pin list
    113343The Temperature parameter in the resistor property pages does not validate out-of-range values correctly in some cases.
    113379Parameter sweep is failing in DC OP in some cases.
    113393Multisim incorrectly reports current source device parameters.
    113408Parameter sweep is limited to 50 values.
    113502Agilent oscilloscope does not perform auto-scale correctly
    113503Agilent oscilloscope has wrong averaging function
    113504Agilent function generator handles user input for offset voltage poorly.
    113505Agilent oscilloscope truncates measurements on single run.
    113509Agilent oscilloscope vertical zoom can go up to 1nV/div
    113514Simulated instruments should have jog dials respond differently to keystrokes.
    113515Multisim oscilloscope cannot handle large vertical offsets.
    113542Colour of grapher background reverts to black when copying and pasting a graph.
    113560TLV2372IDGK has incorrect footprint mapping
    113566Net routing layers in Multisim "all on" and "unset" are the same thing
    113583Multisim changes refdes' when saving files with components with 8 or more pins in the GROUND section
    113743Project view should not allow adding a file that does not exist
    11376074*109* digital components have incorrect component to package mappings
    113769Entering the quit command in XSPICE Command Line Interface crashes Multisim
    113934BC817-16 footprint mapping is incorrect.
    114075Connector and bus names do not display all unicode characters
    114125ADC does not work as expected.
    114241Footprint mappings for J201 and J202 are incorrect
    114282Component context/pop up menu cannot be triggered by keyboard
    114349Multisim crashes when the added expression in analysis is too long
    114431Virtual component warning doesn't always show when exporting to PCB
    114477Footprint mapping for ADG413BRZ is incorrect
    114586IV Analysis tool enforces wrong range on number of steps in simulation parameters.
    114621'Show User Data Columns' settings are lost every time the Database Manager is closed.
    114725Unable to unset value for component spacing in some cases.
    114972The shortcut key Ctrl-F does not open the find dialog window in the Description box editor.
    115055Last selection in Add Device/Model Parameter dialog should be remembered
    115056Analysis dialog should not allow selecting duplicate device/model parameters.
    115143LabVIEW instrument Signal Analyzer is not saving Interpolation Method.
    115148LabVIEW Microphone doesn't save or copy its Sample Rate setting.
    115192Spice output function "imag()" is not correct
    115245Cut or copy and pasting a partial wire pastes a junction.
    115271LVM sources do not allow you to switch between tabs in the property pages without selecting a source file.
    115470Multisim and Ultiboard do not exporting to Excel correctly when using CTRL-A to select everything in the spreadsheet.
    115585Dragging multiple components does not shrinking the wire attach to the junction
    115670Closing an unsaved design will close immediately and then prompt to save.
    115706Unicode characters are not displayed in LabVIEW Instruments.
    115719Ruler bars disappear after exiting from full screen mode
    115765Update circuit components on ELVIS schematic will create components to be placed in breadboard view
    115802File Information date format is not localized
    1159163D potentiometer has incorrect resistance.
    115936Multisim allows renaming components when the schematic is read only.
    115973Schematic comments can be edited even if the read-only schematic restriction is set.
    115974Schematic text can be edited even if the read-only schematic restriction is set.
    116089Deactivate Edit Footprint button for multi-section components.
    116160Grapher tables can't be sorted in numerical order.
    116163Graph cursors show up in color in print preview
    116247Integration method is being translated before passed to simulator.
    Ultiboard ( 78 )
    105433Copper areas are being voided around a via that should be connected.
    106154Density bars show incorrect information in some cases.
    108065Hitting the delete key while renaming a part in the Database Manager is misinterpreted as attempting to delete part.
    108273Layer toolbar combo box does not display the layer when switching between different view types
    108290DRC for max vias per net is not immediately recognized as a DRC error
    108769A group of components cannot be repositioned using the arrow keys.
    109510Gerber export cannot oversize/undersize custom pads.
    110869Strings with unicode characters do not show up on the workspace.
    111056Renamed layer name does not get updated in the Favorite Layers tab.
    111108The Density Bars are activated after doing a print preview.
    111342Ultiboard not saving project views correctly in some cases.
    111344Shape column in Spreadsheet View allows to type any name
    111474Selecting a part in the Parts Position tab does not highlights the footprint in the layout.
    111873Gerber and NC Drill file names should follow the same format.
    111916Redo does not capture changing the remove islands smaller than setting
    111935When changing board outline dimensions, When changing board outline dimensions, clearances do not refresh upon click apply.
    111955Printing of vias and all circular shapes is incorrect
    111971Still able to select invisible copper pads after turning off Copper layer
    112148Ultiboard doesn't export paste mask layer correctly when reflection was selected.
    112208Part mask functionality does not allow entering numeric characters.
    112300Using Alt+O shortcut in Ultiboard RefDes editing window causes blank tab.
    112315Gerber Export does not export pie shape line width.
    112387Ultiboard hangs when opening certain DXF files.
    112439Change Shape command does not work correctly when selecting multiple parts.
    112465Trace width are different in Ultiboard Nets Spreadsheet and Net Edit dialog.
    112567Default file name for exporting 2D formats is incorrectly labeled 3D
    112623Unit of measure for hole properties dialog is always nm.
    112624Hole Properties Dialog arbitrarily changes fields when you type in another field.
    112631The connectivity report is incorrect if real-time checking is disabled
    112691Copying and pasting a pad into the 'Custom Pad shape edit mode' does not allow you to save the shape.
    112739Board extents are not correctly determined after placing a board outline from database
    112745Ultboard displays multiline text as one line when using Line font.
    112747Components created by menu item "Add Selection to Database" does not capture text properly
    112750Incorrect Gerber file is generated if the design contains a component that is rotated and the reflection option selected.
    112816Ultiboard does not remember global colour preferences.
    112832Ultiboard crashes when Place>>Via dialog loses and gains focus.
    1128983D-Data (specified on the component level) is not being flipped when placing a component on the bottom side of the board.
    112900Bounding box is incorrectly computed for rotated custom pads
    112937Drawing arc on copper plane causes DRC error even with sufficient clearance.
    112953Layer Properties don't shift over properly when you add new layers.
    113014Ultiboard status bar not updated after object is modified.
    113133Spreadsheet View not advising user about deleting the part value
    113460When importing a Protel .pcb file, vertical pads are being imported horizontally.
    113708Part mask is incorrectly allowed to be empty after warning message
    113948Silkscreen info placed with a pad doesn't get export to gerber.
    114004Unable to change layer for SMD pad in the footprint editor via the property page.
    114015Gerber Export does not export copper Attributes
    114366Ultiboard does not refresh preview box if selection is made in the spreadsheet view using keyboard.
    114415DRC Not Indicating Overlapping Components in some cases.
    114545Clicking on Lock button toggles locked status in multiple selection situation.
    114582Locked button status does not reflect selection for Parts tab.
    114608Duplicate D-codes permitted when entering values through keyboard
    114618Circles with a wide thickness are expanded in the Gerber file.
    114875Removing a net from a net group will revert Max via count to 2147483647.
    115053Autoplacement will affect the spreadsheet part preview in some cases.
    115058It is possible to enter invalid clearances in the group editor.
    115060Group editor component spacing values are not validated.
    115100Aperture mapping list should be sortable.
    115174Dialog should check for valid values when assigning D-Codes.
    115275Pin layer properties are not preserved when component changes board side.
    115321SVG doesn't export the pad copper ring correctly - layer settings are ignored.
    115370Part spacing DRC error indicator can be misleading sometimes.
    115476Ultiboard allows for duplicate category names in its database tree.
    115671Bus group drc message is cryptic
    115674DRC errors appear inconsistently for overlapping parts
    115687Pin and gate swapping should not use use group settings if the part is not in a group.
    115691Right clicking on checkbox for visibility shows context menu for wrong layer.
    115696In the Ultiboard part wizard when changing any value with the spin controls, the preview doesn't update
    115698Autoroute does not use daisy chain settings.
    115722Duplicate text causes DRC errors
    115723All Ultiboard text is anchored to (15, 15) mm
    115737Dialog box title keeps counting up after placing board outline with multiple connectors
    115760Entering values into Pad Diameter control in Pad property page is difficult because of auto-correction
    115948Ultiboard crashes when opening the 3D View in some cases.
    116156PCB Matrix land patterns that do not have RefDes' specified crash Multisim.
    116159Database manager no longer groups items alphabetically.
    116192Multi-select edit is not setting properties as expected.
    116203Entering a new via pad diameter does not accept the new value if only OK is clicked.
    New Components
    The following components are new in Multisim 11.0:
    • 227 Microchip components
    • 140 Texas Instruments components
    • 194 Linear Technology components
    Microchip
    MCP6542-I/MSMCP6V03-E/SNMCP6544T-I/SLMCP6542-I/PMCP6544T-I/STMCP6541UT-I/LTMCP6541-I/PMCP6541T-I/LT
    MCP6541-I/SNMCP6541T-I/OTMCP6541-I/MSMCP6542-I/SNMCP6543-I/PMCP6543-I/SNMCP6543T-I/MSMCP6544T-I/P
    MCP6541UT-E/OTMCP6541RT-E/OTMCP6V02-E/SNMCP6V02-E/MDMCP6V01T-E/MNYMCP6V01T-E/SNMCP6V03-E/MNYMCP6004-I/SL
    MCP6004-I/PMCP6002-I/SNMCP6004-I/STMCP6001T-I/LTMCP6001T-I/OTMCP6002-E/MCMCP6002-I/MSMCP6002-I/P
    MCP604T-I/SLMCP604T-I/PMCP602T-I/SNMCP602T-I/PMCP601-I/STMCP601-I/PMCP601-I/SNMCP604T-I/ST
    MCP603T-I/STMCP603T-I/SNMCP603T-I/PMCP603T-I/CHMCP602T-I/STMCP601T-I/OTMCP6022-I/STMCP6022-I/P
    MCP6021-I/PMCP6023-I/PMCP6021-E/MSMCP6021-I/SNMCP6024-I/STMCP6022-I/SNMCP6021T-E/OTMCP6023-I/SN
    MCP6024-I/SLMCP6024-I/PMCP6023-I/STMCP6021-I/STMCP6034-E/STMCP6031T-E/OTMCP6034-E/SLMCP6031-E/SN
    MCP6033-E/SNMCP6033-E/MSMCP6031-E/MSMCP6032-E/SNMCP6032-E/MSMCP6044-I/PMCP6041-I/MSMCP6044-I/SL
    MCP6043T-I/CHMCP6041T-I/OTMCP6043-I/SNMCP6042-I/PMCP6042-I/MSMCP6044-I/STMCP6043-I/MSMCP6043-I/P
    MCP6041-I/SNMCP6042-I/SNMCP6041-I/PMCP607-I/STMCP609-I/STMCP608-I/SNMCP607-I/SNMCP606-I/SN
    MCP606-I/STMCP606-I/PMCP608-I/PMCP609-I/SLMCP607-I/PMCP608-I/STMCP606T-I/OTMCP609-I/P
    MCP6141-I/PMCP6141-I/MSMCP6143-I/PMCP6141T-E/OTMCP6144-I/STMCP6144-I/SLMCP6144-I/PMCP6143-I/MS
    MCP6143-I/SNMCP6142-I/MSMCP6142-I/SNMCP6142-I/PMCP6143T-E/CHMCP6141-I/SNMCP619-I/PMCP616-I/MS
    MCP619-I/STMCP619-I/SLMCP616-I/SNMCP617-I/MSMCP617-I/PMCP616-I/PMCP617-I/SNMCP618-I/MS
    MCP618-I/PMCP618-I/SNMCP6234-E/STMCP6231-E/MCMCP6231-E/SNMCP6231UT-E/LTMCP6232-E/MSMCP6231-E/MS
    MCP6234-E/PMCP6232-E/SNMCP6232-E/PMCP6234-E/SLMCP6231UT-E/OTMCP6231RT-E/OTMCP6231T-E/OTMCP6231-E/P
    MCP6241-E/SNMCP6241RT-E/OTMCP6244-E/STMCP6241T-E/OTMCP6241-E/MCMCP6241-E/PMCP6241UT-E/OTMCP6242-E/P
    MCP6242-E/SNMCP6241UT-E/LTMCP6244-E/PMCP6242-E/MSMCP6244-E/SLMCP6241-E/MSMCP6273-E/SNMCP6274-E/P
    MCP6272-E/MSMCP6271RT-E/OTMCP6271-E/PMCP6275-E/MSMCP6271-E/SNMCP6273-E/PMCP6272-E/PMCP6272-E/SN
    MCP6273T-E/CHMCP6273-E/MSMCP6275-E/SNMCP6275-E/PMCP6274-E/SLMCP6271T-E/OTMCP6271-E/MSMCP6274-E/ST
    MCP6285-E/SNMCP6285-E/PMCP6284-E/SLMCP6282-E/SNMCP6283-E/MSMCP6283-E/PMCP6283-E/SNMCP6284-E/P
    MCP6282-E/PMCP6284-E/STMCP6285-E/MSMCP6281T-E/OTMCP6283T-E/CHMCP6282-E/MSMCP6281RT-E/OTMCP6281-E/SN
    MCP6281-E/MSMCP6281-E/PMCP6294-E/STMCP6295-E/MSMCP6295-E/SNMCP6293-E/PMCP6295-E/PMCP6294-E/SL
    MCP6291RT-E/OTMCP6293-E/MSMCP6291-E/PMCP6294-E/PMCP6292-E/PMCP6292-E/MSMCP6291-E/SNMCP6292-E/SN
    MCP6293T-E/CHMCP6293-E/SNMCP6291-E/MSMCP6291T-E/OTMCP6549-I/PMCP6548-I/MSMCP6548-I/SNMCP6546UT-I/LT
    MCP6549-I/STMCP6546RT-E/OTMCP6546UT-E/OTMCP6547-I/PMCP6548-I/PMCP6549-I/SLMCP6546-I/SNMCP6546T-I/OT
    MCP6546-I/MSMCP6547-I/MSMCP6546-I/PMCP6546T-I/LTMCP6547-I/SNMCP6V06-E/SNMCP6V06T-E/MNYMCP6V08-E/SN
    MCP6V08T-E/MNYMCP6V07-E/SNMCP6V07-E/MD
    Texas Instruments
    THS4081CDGNTHS4081IDTHS4081IDGNTHS4082CDGNTHS4082IDTHS4082IDGNTHS4082CDTHS4081CD
    THS4061MFKTHS4061MJGTHS4061IDTHS4061IDGNTHS4062IDTHS4062IDGNTHS4062CDTHS4062CDGN
    THS4226DGQTHS6002CDWPTHS4225DGKTHS4225DGNTHS6002IDWPTHS6012IDWPTHS6012IGQERTHS6007IPWP
    THS6012CDWPTHS4221DBVTHS4221DGKTHS4221DTHS6022CPWPTHS4221DGNTHS4222DGNTHS4225D
    THS4222DTHS4222DGKTHS4061CDGNTHS4031MJGTHS4032CDTHS4031IDGNTHS4031MFKTHS4032IDGN
    THS4041CDTHS4032CDGNTHS4032IDTHS4031IDTHS3001CDGNTHS4022CDGNTHS6093IPWPTHS3001CD
    THS4031CDTHS4031CDGNTHS4022IDTHS4022IDGNTHS4041CDGNTHS4051MJGTHS4052CDTHS4051IDGN
    THS4051MFKTHS4052IDGNTHS4061CDTHS4052CDGNTHS4052IDTHS4051IDTHS4042CDTHS4042CDGN
    THS4041IDTHS4041IDGNTHS4051CDTHS4051CDGNTHS4042IDTHS4042IDGNTHS4503CDGNTHS4501CDGN
    THS4631DGNTHS4503IDGNTHS4500CDGKTHS4500IDTHS4500CDGNTHS4500CDTHS4631DDATHS4601CDDA
    THS4601IDTHS4601CDTHS4601CDG4THS4631DTHS4501IDGNTHS4601IDDATHS4601IDG4THS4500IDGK
    THS3122CDTHS3061DGNTHS3122IDTHS3122CDDATHS3001IDTHS7002CPWPTHS3061DTHS3001IDGN
    THS3122IDDATHS4021IDGNTHS4021IDTHS4500IDGNTHS4022CDTHS4001IDTHS4001CDTHS4021CDGN
    THS4021CDTHS6052IDDATHS6053CPWPRTHS6052CDDATHS6052IDTHS6062CDTHS6062CDGNTHS6053ID
    THS6053IPWPTHS6052CDTHS6042IDDATHS6042IDTHS6022IPWPTHS6042CDDATHS6043IDTHS6043IPWP
    THS6043CDTHS6043CPWPTHS6062IDTHS6182DWTHS6182DWPTHS6093IDTHS6182DTHS7001IPWP
    THS7002IPWPTHS6182RHFRTHS7001CPWPTHS6093CPWPTHS6072CDGNTHS6072IDTHS6062IDGNTHS6072CD
    THS6092CDDATHS6092IDDATHS6072IDGNRTHS6092ID
    Linear Technology
    LT1763CDELT1962EMS8LT1010CDDLT1763CS8LT1763IS8LT1763IS8-1.8LT1763CS8-1.8LT1762EMS8
    LT1962EMS8-1.5LT1962EMS8-1.8LT6005HGNLT6235CGNLT6558CDHCLT6235IGNLT6003CDCLT318AJ8
    LT6559CUDLT318AN8LT6003IDCLT6003HDCLT1328CS8LT1328CMS8LTC2053CMS8LTC2053IMS8-SYNC
    LTC2053HMS8LTC1152CN8LT1077IS8LT1815CS6LT1672CN8LT1815IS8LT1763CDE-1.5LTC1100CSW
    LT1763CS8-1.5LT1763CDE-1.8LT1763IS8-1.5LTC2053HDDLTC2053CDDLTC1043CNLTC1100CN8LTC1043CSW
    LT6005IGNLTC6244IDDLTC6244IMS8LTC6244HMS8LTC6244CDDLTC6244CMS8LT6002CDHCLT6002IDHC
    LT6558IGNLT6557IDHCLT6557IGNLTC6241IDDLTC6241IS8LTC6241HS8LTC6241CDDLTC6241CS8
    LTC6242IDHCLTC6242IGNLTC6242CDHCLTC6242CGNLTC6242HGNLT6002IGNLT6004CMS8LT6002CGN
    LT6001CDDLT6001IDDLT6558CGNLT6005CGNLT6004IMS8LT6005IDHCLT6004HMS8LT6004IDD
    LT6004CDDLT6003HS5LT6003CS5LT6003IS5LT6001CMS8LT6001IMS8LT6000CDCBLT6004HDD
    LT6000IDCBLT1077S8LT1819IMS8LT1819CS8LT1819CMS8LT2078ACS8LT2078AIS8LT1818CS8
    LT1674ISLT1818IS5LT1819IS8LT1818CS5LT1816IMS8LT1816CS8LT1816CMS8LT1816CDD
    LT1816IDDLT1817IGNLTC1152CS8LT1817ISLT1816IS8LT1815CS5LT1818IS8LT1784IS6
    LT1674CSLT1673IS8LT1674CNLT1995IDDLT1739CFELT1995IMSLT1995CMSLT1815CS8
    LT1672CS8LT1672IMS8LT1817CSLT1817CGNLT1468IS8LT1673CS8LT1673IN8LT1673CN8
    LT1672IN8LT1672IS8LT1816ACMSLT6005HDHCLT6558IDHCLT1102IN8LT1008S8LT1102ACN8
    LT1721CSLT1721CGNLTC1444CDHDLT1739CUELTC1444IDHDLT1672CMS8LT1995CDDLT1784CS6
    LT1468IN8LT1815IS6LT1568CGNLT1568IGNLTC1444CSLT1739IUELT1739IFELT1457S8
    LT1413ACN8LT1457CN8LT1222CN8LT1222IS8LT1468IDDLT1674INLT1468CDDLT1816AIMS
    LT1815IS5LT1719IS8LT1720CDDLT1719CS8LT1720IS8LT1720IMS8LT1720CMS8LT1102CN8
    LT1721IGNLT1720IDDLT1720CS8LTC6240IS8LT6402CUD-20LT6402CUD-12LTC1444INLT6402CUD-6
    LT6402IUD-6LT6402IUD-20LT6402IUD-12LTC1444CNLT1394CMS8LT6005CDHCLTC1444ISLT1016CN8
    LT1016IS8LT1016IN8LT1016CS8LTC6240HS5LTC6240CS8LT6557CDHCLTC6240HS8LT6553CGN
    LT6553IGNLTC6240CS5LT6557CGNLT6552IDDLT6552CDDLT6552CS8LT6411IUDLT6552IS8
    LTC6240IS5LT6411CUD
    © 2010 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The EKV MOST model used in this software was developed, implemented and tested by the Electronics Laboratory (LEG) of the Swiss Federal Institute of Technology (EPFL).
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-7-2 10:33
