查看: 2787|回复: 0
[Patch补丁] NI Circuit Design Suite 11.0 Patch Win32Eng/Ger/Jpn NI电路设计套件11.0补丁
    发表于 2021-3-12 23:56:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    11.0Pro/Edu Patch
    文件大小: 18554021 字节 (17.69 MB)
    修改日期: 2010-05-26 03:05
    MD5: 0e4c4c5b76e37924a40b68dffcba0de8(官方正确)
    SHA1: 04e636062e8d8712ce6d85350bc41380a8c1ba67
    SHA256: 223ffaffc5198fb5f64bd0b3691e6dc9952c0718dadd4d0402f7fe20ce573991
    CRC32: 9ba67590
    CDS11.0Patch.txt (600 Bytes, 下载次数: 0, 售价: 1 圆)
    NI Circuit Design Suite 11.0.0.2 Readme for Windows
    June 2010
    This update includes the bug fixes listed for Circuit Design Suite 11.0.0.2 and 11.0.0.1.
    The following issues were fixed in the Circuit Design Suite 11.0.0.2 update.
    Multisim ( 7 )
    Bug IDDescription
    117007Power Factor reading from the wattmeter is incorrect in some cases.
    117016Multisim crashes in some cases while displaying the Database Manager.
    117111Multisim crashes while simulating using certain instruments in some cases.
    117257Hiding RefDes using Sheet properties in a SC/HB removes the hierarchical connection information.
    117273Printing a PLD design crashes Multisim in some cases.
    117065Changing a setting in the function generator instrument during simulation inverts the duty cycle percentage.
    116517The function generator instrument does not respect setting changes made during simulation when connected in certain configurations.
    The following issues were fixed in the Circuit Design Suite 11.0.0.1 update.
    Multisim ( 12 )
    Bug IDDescription
    116486Connecting a component to pins in Ultiboard will not correctly back annotate when it is in a hierarchical block.
    116625Disabling the NI ELVISmx Arbitrary Waveform Generator output signal while simulating will crash Multisim.
    116837RefDes change is not back annotated if component is not present in any of the component databases.
    116873Hidden pin information gets cleared after a RefDes rename in some cases.
    116890Multisim crashes when importing older files in some cases.
    116911Renaming multisection component RefDes to lower case can crash Multisim.
    116928Flipping a voltmeter or ammeter horizontally crashes when only one pin is connected.
    116957Back Annotation crashes Multisim in some cases after Rename/Renumber Components has been used.
    117004Dragging components is slower in Multisim 11.0.0 than it was in Multisim 10.1.1 in some cases.
    117036ERC is flagging NC pins as warning for unconnected pins.
    117054Undoing a delete trace action in the grapher can crash Multisim.
    117075RefDes visibility setting is ignored for power source components.
    Ultiboard ( 5 )
    116910Placing a hole causes the DXF export to generate a large file.
    116956Incorrect gate swap, pin connections and conflicts when forward annotating in some cases.
    116966Ultiboard can become unresponsive while trying to open certain designs.
    117033Ultiboard crashes when closing an open design in some cases.
    116874Thermal relief settings for copper areas are inverted in some cases.
    © 2010 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-12-8 07:36
