查看: 2921|回复: 0
[NI软件产品] NI Circuit Design Suite 13.0 Edu Win32Eng/Ger/Jpn NI电路设计套件13.0教学版
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2021-3-13 00:22:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    13.0EDU
    zip
    文件大小: 747825994 字节 (713.18 MB)
    修改日期: 2019-06-25 02:41
    MD5: 052aa176724e9484b81a0ccb1f73c1a5(官方正确)
    SHA1: 8107ffc3770c7a4382512f9e183e8d2b474bcfa2
    SHA256: d942e2374f3a6da38ad7672a36137b45322f34b3010324a87b68ce1af9d5f7ed
    CRC32: 53c32330
    exe
    文件名: NI_Circuit_Design_Suite_13_0_Education.exe
    文件大小: 748561240 字节 (713.88 MB)
    修改日期: 2013-07-30 17:23
    MD5: 1b053e691762b6989a18826cefb239a3
    SHA1: e2d4ffcbd8e3dec624c44cd49c0d9debcb797628
    SHA256: 6591bc8e780ca6ed3127bccee4a8b8513dec8a0a0c276ec349d509eb6ec7447c
    CRC32: 50e1bb64
    CDS13.0EDU.txt (1.31 KB, 下载次数: 0, 售价: 10 元)
    NI Circuit Design Suite 13.0 Readme for Windows
    August 2013
    This file contains important last-minute information about Circuit Design Suite 13.0 for Windows, including installation and compatibility issues.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 13.0»Documentation»Circuit Design Suite 13.0 Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 13.0
    New Components
    Supported Platforms
    Circuit Design Suite 13.0 supports Windows 8/7/Vista 32-bit and 64-bit editions, Windows XP 32-bit edition, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Circuit Design Suite 13.0 does not support Windows 2000/NT/Me/98/95, Windows XP 64-bit edition, or the Windows Server non-R2 editions.
    NI Circuit Design Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Circuit Design Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Circuit Design Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about Circuit Design Suite's product life cycle, visit NI Multisim OS Support and System Requirements. The information on this page applies to Multisim and Ultiboard.
    Installing Circuit Design Suite 13.0Installing Multiple Versions
    Circuit Design Suite 13.0 installs side-by-side with previous versions of Circuit Design Suite.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Circuit Design Suite 13.0 Updates and Notifications
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    You cannot install Circuit Design Suite 13.0 on Windows Vista Starter edition.
    Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    The following is a subset of the issues fixed since the last release of Circuit Design Suite.
    Multisim ( 139 )
    Bug IDDescription
    402858The hierarchical block names in the RefDes Setup dialog don't correlate with the names in the design toolbox window
    406154Using the model maker in Component Wizard will override the user specified model name
    414345Disabling Include components without models filter does not find Ground
    382685Save component to database doesn't save instance parameters properly
    415653Duplicated simulation names shown in the post processor
    404623Cannot copy text from the text boxes to the Description box editor
    413808Sometimes transient simulation can lead Multisim to become non-responsive
    367615Adding a bus vertex on selected bus is behaving erratically
    406399Opening netlist with circular SUBCKTs causes Multisim to crash.
    406520Simulating a netlist with circular SUBCKTs causes Multisim to crash.
    402989Changing parameter sweep settings does not mark design as modified.
    394555Cannot compile multiple obj files using HiTech compiler.
    412244Transient analysis incorrectly shows a negative power output for a BJT.
    399208Calling COM API method disconnect() will crash Multisim randomly.
    372025Quotation marks used in expression causes some output parameters to be left out of analysis.
    402798Some components have their Refdes and value reversed after flipping an already flipped component.
    404505Saving a component to database that had ERC markers creates an unusable component.
    351431Closing ELVIS/LabView instrument's window will not return focus to Multisim window.
    409692Using the Grapher's Export to Excel will not work when traces are hidden.
    400769Switching model view from SPICE template to table clears any existing parameters.
    382456Cannot create packages that link to land patterns having a space or special characters in their name.
    373134Adding sections to a component and then manually clearing footprint mapping does not display them correctly.
    406121Variable Inductor components have a Coil Resistance parameter that is not used at all.
    372026Node names that start with operators are not simulated when used in output expressions.
    404674Backward annotate certain files may crash Multisim.
    404667Triangular current source should say current offset and not voltage offset.
    404737Parameter sweep dialog removes selected circuit parameters and voltage variables when switching tabs.
    404137Internal simulation error caused by a function that divides by zero.
    402783Simulating current through a component in the Fourier analysis doesn't work.
    392977Incorrect values shown for noise contribution from individual contributors.
    394560When editing the sub-circuit symbol the text locations are unpredictable.
    401669The pulse width doesn't work in the Phase Angle Controller 6 Pulses component.
    400933Net changes in the spreadsheet view do not prompt the user to save file before exiting.
    374557Operator != does not work correctly in SPICE expression.
    383256Multisim copy and paste graph properties overwrites plot names in legend.
    402613Cannot edit components in database that have open square bracket "[" in their name.
    401579Multisection RefDes's become inconsistent across subcircuits after deleting components.
    401876Pasting the sections of a multi-section component will not always preserve the refdes names correctly.
    400228Advanced Pin Mapping generates an incorrect mapping when sorted by Symbol pins.
    380269SPICE Netlist Viewer does not show unicode characters correclty.
    399200COM API method EnumInputs() returns duplicate names.
    399204COM API method WaitForNextOutput() returns incorrect or empty string instead of output name.
    399115Performance degradation caused by oscilloscope intruments.
    274958Missing Delete Page from context menu on multi-page designs.
    373910Save As in Symbol Editor window sometimes leads to confusion.
    393411Deleting time value from PWL sources data tables clears the entire row.
    396828.NODESET and .IC settings for nets throw netlist errors when net names contain '-', '+', or '@'
    389228Denormalized corner frequency in the Transfer Function Block does not work as expected
    396348Device parameters sometimes show internal SPICE syntax in the analysis settings dialog
    394837In the component wizard, entering the same model name with different data for multi-section components should not be allowed.
    367903Copying symbol from another component with same pin names updates poorly.
    395603Multisim does not save Interactive Simulation settings.
    264232Cannot edit params if the params statement is not present.
    275102Changing the windows temp environment variables to a non-existing folder will affect multisim negatively.
    356061Snippet Drag behavior changes between minor Internet Explorer builds.
    390898The spreadSheet view does not scroll up with shift + up arrow key.
    391044Keyboard arrows not moving a group of selected parts in any direction.
    393290Docked window views improvements
    274599XSpice Laplace device has simulation issues.
    273993Adding device/model parameter does seem to do anything for submodule parameters.
    337145Provide a better description of the error message when the PLD device is not detected.
    389624Saving an older file using a current Multisim version will have incorrect behavior.
    390078Unchecking a checkbox associated to Clock trigger value for CONTROLLED_ONE_SHOT will lose entered data.
    383070Locked sub-circuits can be opened if dragged onto the schematic from design toolbox.
    380838In the spreadsheet view selecting components from multiple pages does not show the option to Replace selected components.
    381432Word Generator pins 0-15 should be on the right side for improved convenience.
    387017Multisim may crash when switching from mil to mm in PCB sheet properties.
    268850Components with swappable pins don't work well with pin highlighting and ELVIS 3D view.
    388626Noise analysis can sometimes produce "-1.#INDO T" as a result.
    383991Unable to simulate an expression in a worst case analysis.
    272318Some analyses results do not have column headers
    389344The cm_static_integrate routine does not implement the Trapezoidal integration method correctly.
    334937Support for EDA parts XML files was removed.
    389531Display duplicate components in the result tab fails for certain components.
    389500Pressing enter in LabVIEW Co-simulation Terminals window causes entire window to go blank.
    376684Netlist errors are generated at simulation after pasting digital component and probe.
    367411Sometimes an expression cannot be deleted in an analysis.
    373734Incorrect labels in the filter wizard's explanation image.
    389069Title block properties resets to default values when design border is not visible.
    366002Checking for common pin in the Advanced RefDes Configuration dialog is not working.
    386538Spiky response during AC analysis for certain circuits.
    265616Convergence assistant does not correctly roll back initial conditions simulation settings for certain files.
    271623DC Sweep analysis performs unnecessary solution cycles.
    319412User data for Multisim v11 is not being converted.
    268203Xspice command line interface does not always work properly.
    274263Placing an on-page connector sometimes generates a net conflict message.
    271503Pasting an instrument will not always maintain the instrument's settings.
    271384In the XSPICE Command Line Interface setting the inertial delay does not seem to work.
    286275Multisim does not follow Pspice compatibility using parenthesis and curly braces.
    354632Simulator error when TDM source is not provided with a file name.
    275078The default size for the bill of Materials dialog should be increased.
    269328COM API should have more descriptive error messages on failure.
    363394Oscilloscope adding function gives incorrect values when changing V/div settings.
    363423Exported VHDL does not complile in some cases because of duplicated connectors.
    319959Results tab displays an incomplete message when a virtual connection is made.
    326044Certain circuits use large amount of memory that may crash the simulator.
    326706Adding a description box label does not immediately show in the labels dialog.
    351708COM API methods for the bill of materials and netlist reports do not obey the variant settings.
    274562The update components window does not include subcircuit components.
    274584Copy and paste a component's multisections does not keep the sections on same component.
    295957Footprint names in the bill of materials for Multisim are different from the bill of materials for Ultiboard.
    352988Cancelling the action to open multiple component snippets does not work as expected.
    358820COM API methods DoACSweep and SetOutputRequest should use int/int32 type instead.
    383404Degree symbol does not show properly in text exports from bill of materials report.
    269819ELVIS II 3D breadboard have inconsistent pin numbers of the I/O blocks compared to the physical board.
    329684Virtual transistors sometimes have inconsistent 3D representations
    268961COM API EnumInputs method shows clock current incorrectly as a voltage source.
    346910The select button is greyed out when adding a new SPICE model.
    352295Unable to import user fields data for most components.
    352726The add a footprint dialog does not populate footprint names correctly.
    268614COM API needs proper input data validation on all inputs of type variants.
    359051Multi-selecting components seems to only work when clicking on drawn areas of a component.
    3711404-channel oscilloscope incorrectly flips A/B graph.
    274229CLOCK_VOLTAGE and CLOCK_CURRENT sources are no good past 100MHz
    263369ELVIS net does not change colour when two of the nodes are on the ELVIS rails.
    267416MCU wizard does not check for invalid characters in the workspace path until the end of the wizard.
    317666Buses do not follow grid when rotated.
    3567103-phase power sources have incorrect AC analysis phase
    359237Running MCU assembly source using C compiler causes Multisim to stop simulating other files.
    354674Cancelling a replace by subcircuit will lead to an orphan subcircuit in the design toolbox.
    304367SPICE params statements with no parameters following will be treated as subcircuit names.
    267840MS COM method DoACSweep should not accept 0 as starting frequency.
    324659Simulation errors are poorly described.
    269179The models for 12AT7 and 12AX7 are incorrect
    273976Some counter components do not behave as expected.
    321791Editing text in schematic does not prompt the design to be saved.
    275149Interactive simulation seems to get stuck without generating convergence error.
    361670Breakpoints are completely missed for D/A bridge component.
    372141Renaming connectors in a subcircuit or hierarchical block adds duplicate pins to the block symbol.
    284662Multisim simulation fails due to calling a breakpoint in the past.
    309665SYNC output for the Agilent Function Generator has incorrect rise/fall time.
    362333Function generator instrument should not be setting TMAX.
    365444The option to select a RefDes numbering based on a Hierarchical Block instance is not working.
    364792Replacing a multi-section component will sometimes lose hidden pin's connections.
    364797No merging warning of hidden pins for multi-section components in different circuits levels
    274419Disallow creating Family names with space characters.
    345454Pasting sections of a component into one instance of a subcircuit does not keep section consistency on the second instance of the subcircuit.
    275455Placing wire using keyboard shortcut during component copy/paste operation crashers Multisim.
    351776Printing in Black and White removes text.
    Ultiboard ( 44 )
    Bug IDDescription
    413655Voiding is not being redrawn when resizing holes.
    413844A Net bridge causes a copper area cut-out that's on a different layer
    374621Overlapping pads that belong to the same net does not trigger a DRC error.
    412733Cannot exclude Courtyard layer from keep-in/keep-outs
    369042Print dialog is missing drill and drill symbols layers in list of available layers.
    400219Power plane not showing in 3d preview when placed on top copper layer.
    392931Grid & units settings in PCB properties are not imported properly by Ultiboard v12 and later.
    402542A via that is about to be placed uses copper grid instead of via grid.
    387142Importing DXF with too many layers crashes Ultiboard.
    400706Autofilled value is a nuisance when typing digit zero first into a field.
    400710Part Wizard in Ultiboard discards changes when back button is pressed.
    274323Placing a netbridge directly on the nets to connect creates invalid DRC errors.
    392957Gerber drill exports do not honor "Minimum tool size for slot drilling" design rule.
    388793Snap to grid is ignored when moving existing traces.
    390079Unable to set multiple traces to "use net settings".
    369041Clearances are temporarily enabled upon applying changes to holes.
    383057Wrong net is highlighted when a SMT pad is selected.
    389667Drawing a line from a via does not use trace settings in PCB properties.
    375198Unable to autoroute due to a blind via being enabled on a two layers board.
    357790Cutting and pasting pins which are placed directly on a board will cause a crash.
    387690Cancelling Get a part from the Database dialog and then switching tabs can make Ultiboard crash.
    364244No option to separate drill symbols gerber file export from a multi-layer design.
    377973Upgrade option in PCB properties causes power planes to connect with pins in other nets.
    388335Drag and drop file path to 3rd party file type is assumng it is a DXF file.
    268564Unplacing parts takes too long compared to previous versions.
    269043Unable to place text on copper layer in the footprint editor.
    380186Composite merge of silkscreen top and bottom corrupts the gerber export.
    269004The maximum pin count warning dilaog only appears once.
    274453Upon disabling the DRC check and undoing a copper trace move, it will disconnect the pad from the net.
    348345Multi-select custom pads and then change clearances will cause all pads to be identical.
    268441Follow-me tool ignores keep-in/keep-out causing DRC errors.
    268445Connection machine ignores keep-in/keep-out causing DRC errors.
    356987Cannot export drill symbol and drill holes in DXF Format.
    273255Corner mitering is behaving inconsistently.
    282135Cannot move objects from PCB layers to information layers.
    3251703D view does not refresh when design is updated.
    273270In 3D view the show/hide height mode cannot be disabled once it was enabled.
    383044While in In-Place Edit mode, placing a land pattern will lead to a crash.
    3622503D View cannot properly display mirrored Windows font text.
    382206DRC net length check no longer distinguishes nets with no length.
    272209Pad edit layer shows up as a routing layer.
    274406Custom pad can incorrectly be pasted on to PCB from pad edit.
    351249Width and height reversed in Advanced Hole Properties.
    358385Ultiboard incorrectly connects two nets when using perpendicular-cross shaped thermal relief type.
    Other ( 2 )
    Bug IDDescription
    274642Unable to copy and paste footprint name from dialog window.
    275094Closing the application window when a modal dialog is active will lead to crashes.
    New ComponentsADI
    98 new.
    EPC
    6 new.
    Infineon
    9 new simulatable diodes.
    88 new layout only microcontrollers.
    Maxim
    1173 new.
    Microchip
    57 new.
    NXP
    499 new.
    ON Semi
    417 new.
    Miscellaneous
    56 new simulation-only photodiodes (models provided by Analog Devices.)
    75 new connectors (connector family was reorganized for ease of use.)
    Important InformationCopyright
    © 2006-2013 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-2 08:46
