查看: 3635|回复: 0
[NI软件产品] NI Multisim Professional 13.0.1 Win32 Eng/Ger/Jpn NI电路设计软件13.0.1
    1 小时前
  • 签到天数: 3816 天
    连续签到: 9 天
    发表于 2021-3-13 23:03:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Multisim Component Evaluator Mouser Electronics Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    文件大小: 736511438 字节 (702.39 MB)
    修改日期: 2014-04-04 00:06
    MD5: 0583775af300ed511f6befebc4bb8aa5
    SHA1: e32a67f43f68a7a24a9a9b70b9b61205b9f3a124
    SHA256: 7f6fb277ab44d6bbc16e6b1f52ed941dc2025b70398629e7b4a7db328b3de8ce
    CRC32: cccd0029
    Multisim_Professional13.0.1.txt (510 Bytes, 下载次数: 3, 售价: 10 圆)
    NI Circuit Design Suite 13.0.1 Readme for Windows
    March 2014
    This file contains important last-minute information about Circuit Design Suite 13.0.1 for Windows, including installation and compatibility issues.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 13.0»Documentation»Circuit Design Suite 13.0 Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 13.0.1
    New Components
    Supported Platforms
    Circuit Design Suite 13.0.1 supports Windows 8/7/Vista 32-bit and 64-bit editions, Windows XP 32-bit edition, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Circuit Design Suite 13.0.1 does not support Windows 2000/NT/Me/98/95, Windows XP 64-bit edition, or the Windows Server non-R2 editions.
    NI Circuit Design Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Circuit Design Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Circuit Design Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about Circuit Design Suite's product life cycle, visit NI Multisim OS Support and System Requirements. The information on this page applies to Multisim and Ultiboard.
    Installing Circuit Design Suite 13.0.1Installing Multiple Versions
    Circuit Design Suite 13.0.1 installs over version 13.0 and side-by-side with previous versions of Circuit Design Suite.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Circuit Design Suite 13.0.1 Updates and Notifications
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    You cannot install Circuit Design Suite 13.0.1 on Windows Vista Starter edition.
    Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    The following is a subset of the issues fixed since the last release of Circuit Design Suite.
    Multisim ( 30 )
    Bug IDDescription
    351776Printing in Black and White removes text.
    383114Hyphen in model name prevents table view of SPICE parameters.
    448013Cannot unpack projects to another drive location other than where it was created from.
    451958Adding a model from a component can cause mapping errors.
    453679RefDes sometimes becomes incorrect after gate swaps and gate optimizations from the Advanced RefDes configuration dialog.
    452928Annotation sometimes does not find a specific footprint and will pick an incorrect footprint instead.
    351727Editing a selection font, changes font of all components placed after it.
    451442Swapping sections with different models for a multisection component will lead to errors.
    443556Netlist view window sometimes does not display data after selecting regenerate netlist.
    366729Pasting different connector types with the same name to a new design renames the connectors.
    447805Swapping RefDes's using Advanced RefDes Configuration will sometimes produce duplicate RefDes's.
    358433The lock subcircuit restriction does not seem to apply to hierarchical blocks.
    429068In a multisection component, changing its footprint pinout breaks mappings for any sections from there on.
    439226Ladder diagram fails to simulate due to large resistor in NC and NO contacts.
    445183Unable to replace the footprint of an interactive component from the spreadsheet view.
    440274Multisim Full edition should not have the Model Maker button active.
    445770Back annotating to Multisim when a component is not found in the database will sometimes lead to a crash.
    443648DC operating point failure fallback method sometimes produces inconsistent results.
    443867Cannot replace a multisection component after the third attempt.
    443230Netlist errors when one section of a component doesn't have a model.
    274991The size of a model seems to affect the time it takes to open its property window.
    274589Component wizard does not warn user if .subckt is not terminated with .ends.
    442364RefDes duplication sometimes happens after component replace.
    441098Interactive DC sources sometimes do not preserve slider position on import.
    423563SVG circles are always imported with radii multiple of 3 with OECL import.
    429474Negative temperature coefficient for a resistor is causing simulation error.
    438559Sometimes Multisim is unable to edit the user fields for a corporate database.
    274687Multisim does not import OrCAD file correctly sometimes.
    435191IRAM section of MCU memory view is not being displayed properly.
    422933Multisim cannot communicate with some boards using Xilinx ISE 12.4.
    Ultiboard ( 19 )
    Bug IDDescription
    456570Some landpattern changes in Ultiboard sometimes do not correctly backannotate to Multisim.
    4565033D DXF files do not export board thickness correctly.
    452986NC Drill settings are not restored from scheme file if NC drill window is open.
    453023Cancelling netlist editor dialog makes hidden changes to grouped net settings.
    453286Net settings for clearances does not always properly adhered to.
    450388Ultiboard design file sometimes gets corrupted after importing a bitmap file.
    450425Ultiboard security copy file sometimes gets overwritten by a corrupt file.
    449740Trace width changes in Net Group dialog not working for Edu, Full or Student tiers.
    447448Forward annotating a file with a ground net may sometimes lead to a crash.
    443872Unable to ungroup a group comprising of only attributes.
    443838Number of layers in the place powerplane dialog box doesn't match the design toolbox.
    447750A DRC is not generated whenever a trace crosses a round board outline and a net.
    442363Text attributes disappear when multiple text attributes are grouped together.
    440757Gerber files are sometimes being exported incorrectly due to default imperial precisions.
    439841DXF data doesn't appear on the workspace when the 'closed polyline to polygon" is checked.
    439868Creating a rounded rectangle custom pad image with modified xy coordinates will not show it properly once placed.
    440292Autorouter sometimes does not work correctly with custom pads.
    443226Swapping layers no longer auto deleting vias.
    406117Confusing Labels In Select Groups for Replica Place Dialog.
    New ComponentsADI
    48 new.
    Avago Technologies
    207 new.
    Efficient Power Conversion (EPC)
    13 new.
    Infineon
    715 new.
    Maxim
    19 new.
    Microchip
    55 new.
    NXP Semiconductors
    193 new.
    ON Semiconductor
    166 new.
    Texas Instruments
    507 new.
    Vishay
    457 new.
    Important InformationCopyright
    © 2006-2014 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-5 09:32
