查看: 3248|回复: 0
[LV工具模块] NI Multisim Component Evaluator Analog Devices Edition 11.0.2.1 Win32 Eng/Ger/Jpn NI电路设计软件Miltisim CE ADE 11.0.2.1
    1 小时前
  • 签到天数: 3584 天
    发表于 2021-3-13 23:12:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI Multisim Component Evaluator Analog Devices Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    Multisim_Component_Evaluator_Analog_Devices_Edition_11_0_2_1
    文件大小: 325282536 字节 (310.21 MB)
    修改日期: 2011-11-08 07:02
    MD5: 5c665e684da78963396f848241eb1ff8
    SHA1: 920ab8d851bebf6c23bddd4acf9cad1e0c9c3797
    SHA256: 5db84801222789a18c2cca8b921b2a8418f6ec55505b8215a0bb1d8e8b83ba35
    CRC32: 5aca99f0
    Multisim_Component_Evaluator_Analog_Devices_Edition11.0.2.1.txt (604 Bytes, 下载次数: 0, 售价: 5 元)
    National Instruments Multisim Component Evaluator Analog Devices Edition Readme for Windows
    November 2011
    This file contains important last-minute information about Multisim Component Evaluator for Windows.
    Refer to the Multisim Tutorial chapter of the Getting Started with NI Circuit Design Suite manual for information about getting started with the component evaluator edition of Multisim. You can access this PDF from Start»All Programs»National Instruments»Multisim Component Evaluator 11.0»Documentation»Getting Started.
    Supported Platforms
    Supported Platforms
    Multisim Component Evaluator supports Windows Vista/XP 32-bit editions, Windows Vista 64-bit edition, Windows 7 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Multisim Component Evaluator does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Multisim Component Evaluator on Windows Vista Starter edition.
    Multisim
    • Multisim leaks GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    License Expiry Date
    The license expiry date that displays in the screen capture of the Multisim Component Evaluator dialog box, found in the release notes and the Launching Multisim Component Evaluator Help, may not match the expiry date for your software. Please refer to the actual dialog box for the correct expiry date.
    This version of Multisim Component Evaluator includes an updated license file, which will let you run the software until November 30, 2012.
    Updates to Component Database
    A number of database improvements are included in this distribution:
    - 43 Analog Devices components have been added.
    - 102 Analog Devices components have been updated.
    - 8 Analog Devices models have been added.
    - 16 Analog Devices models have been updated.
    Included in the above are connectors for the Analog Devices System Demonstration Platform (SDP) controller board and breakout board.
    The database version is now 11.0.c. To verify this, select Help»About Multisim. The database version is shown in the About Multisim Component Evaluator box that displays.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The EKV MOST model used in this software was developed, implemented and tested by the Electronics Laboratory (LEG) of the Swiss Federal Institute of Technology (EPFL).
    GMT+8, 2025-7-4 09:35
