查看: 2781|回复: 0
[NI软件产品] NI Multisim Component Evaluator Analog Devices Edition 13.0.0 Win32 Eng/Ger/Jpn NI电路设计软件Miltisim CE ADE 13.0.0
    11 小时前
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2021-3-13 23:16:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI Multisim Component Evaluator Analog Devices Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    Multisim_Component_Evaluator_Analog_Devices_Edition_13_0_0
    文件大小: 576344920 字节 (549.65 MB)
    修改日期: 2013-07-30 19:33
    MD5: 5a74889e180a7bf8c7b75ec56b29be71
    SHA1: 0e77750323a08135bd1dc93196faaea656b0fa34
    SHA256: 469ce7cc791d3b41e51d9ae84b59008801c3c2660ab353248c28307477c97b37
    CRC32: f04a0170
    Multisim_Component_Evaluator_Analog_Devices_Edition13.0.0.txt (707 Bytes, 下载次数: 0, 售价: 5 元)
    National Instruments Multisim Component Evaluator Analog Devices Edition 13.0 Readme for Windows
    August 2013
    This file contains important last-minute information about Multisim Component Evaluator for Windows.
    Refer to the Multisim Tutorial chapter of the Getting Started with NI Circuit Design Suite manual for information about getting started with the component evaluator edition of Multisim. You can access this PDF from Start»All Programs»National Instruments»Multisim Component Evaluator 13.0»Analog Devices Edition»Documentation»Multisim Component Evaluator 13.0 Getting Started.
    Supported Platforms
    New Components
    License Expiry Date
    Supported Platforms
    Multisim Component Evaluator supports Windows Vista/XP 32-bit editions, Windows Vista 64-bit edition, Windows 7 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Multisim Component Evaluator does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    NI Multisim Component Evaluator Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Multisim Component Evaluator will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Multisim Component Evaluator that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about Multisim Component Evaluator's product life cycle, visit NI Multisim OS Support and System Requirements.
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Multisim Component Evaluator on Windows Vista Starter edition.
    Multisim
    • Multisim leaks GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    New Components
    Refer to NI Multisim Component Evaluator Analog Devices Edition Components for a detailed list of the components included in Multisim Component Evaluator Analog Devices Edition.
    License Expiry Date
    The license expiry date that displays in the screen capture of the Multisim Component Evaluator dialog box, found in the release notes and the Launching Multisim Component Evaluator help file, may not match the expiry date for your software. Please refer to the actual dialog box for the correct expiry date.
    Important InformationCopyright
    © 2007-2013 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-13 19:29
