查看: 3621|回复: 0
[NI驱动程序] NI-SCOPE 3.5 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE3.5
    9 小时前
    发表于 2021-3-16 23:07:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    3.5
    文件大小: 1058337657 字节 (1009.31 MB)
    修改日期: 2010-04-25 07:46
    MD5: fb4eef40098245400d67989133d081b6(官方正确)
    SHA1: 0c7ae5b16ed2dfcd6195ca324a90ff35f26c6e59
    SHA256: b514908f66871fd11923ec9749b280ba0a690dc1bf4889fb884064c7d696fdb5
    CRC32: 83a2d614
    SCOPE3.5.0.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE ReadmeVersion 3.5
    July 2008
    Thank you for using the NI-SCOPE instrument driver for Windows Vista/XP/2000. This file contains important information about NI-SCOPE, and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Installing/Uninstalling/Modifying NI-SCOPE
    • Programming in NI-SCOPE
    • Bug Fixes
    • Known Issues
    New Features in NI-SCOPE 3.5New Hardware Support
    • NI PXIe-5622
    • NI PXI/PCI-5153
    • NI PXI/PCI-5154
    New Software Support
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation.
    • Support for LabVIEW 8.6.
    • Support for LabVIEW Real-Time Module 8.6.
    • Support for LabVIEW Real-Time on PC desktops.
    • Addition of FFT and XY plots to NI-SCOPE Soft Front Panel
    • New behavior: Error and self-test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    • New VIs/functions:
      LabVIEW VIsC/C+ Functions
      niScope Get Frequency ResponseniScope_GetFrequencyResponse
      niScope Cal Adjust Frequency ResponseniScope_CalAdjustFrequencyResponse
      niScope_GetErrorMessage
    • New properties/attributes:
      LabVIEW PropertiesC/C++ Attributes
      Fractional Resample EnabledNISCOPE_ATTR_FRACTIONAL_RESAMPLE_ENABLED
      Bandpass Filter EnabledNISCOPE_ATTR_BANDPASS_FILTER_ENABLED
      Dither EnabledNISCOPE_ATTR_DITHER_ENABLED
      Data Transfer Maximum BandwidthNISCOPE_ATTR_DATA_TRANSFER_MAXIMUM_BANDWIDTH
      Data Transfer Preferred Packet SizeNISCOPE_ATTR_DATA_TRANSFER_PREFERRED_PACKET_SIZE
    Discontinued Support
    • Support for LabVIEW 8.0 has been removed. This will affect you if you are doing development using the NI-SCOPE API or the ni5660 API in the LabVIEW 8.0 (or 8.0.1) environment.
    New Features in NI-SCOPE 3.4New Hardware Support
    • NI USB-5132
    • NI USB-5133
    New VIs/functions:
    niScope Cal Adjust Offset RangeniScope_CalAdjustOffsetRange
    niScope Cal Adjust Compensation AttenuatorniScope_CalAdjustCompensationAttenuator
    Trigger ModifierNISCOPE_ATTR_TRIGGER_MODIFIER
    Trigger Auto TriggeredNISCOPE_ATTR_TRIGGER_AUTO_TRIGGERED
    Start Trigger (Acq. Arm) Output TerminalNISCOPE_ATTR_EXPORTED_START_TRIGGER_OUTPUT_TERMINAL
    Ref Trigger Output TerminalNISCOPE_ATTR_EXPORTED_REF_TRIGGER_OUTPUT_TERMINAL
    End of Record Output TerminalNISCOPE_ATTR_END_OF_RECORD_EVENT_OUTPUT_TERMINAL
    End of Acquisition Output TerminalNISCOPE_ATTR_END_OF_ACQUISITION_EVENT_OUTPUT_TERMINAL
    5 Volt Power Output TerminalNISCOPE_ATTR_5V_OUT_OUTPUT_TERMINAL
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductWindows XP/2000Windows Vista
    32-Bit
    Windows Vista
    64-Bit
    NI PXI/PCI-5102
    Yes
    Yes
    No
    NI PCMCIA/USB/AT-5102*
    Yes
    No
    No
    NI PXI/PCI-5105
    Yes
    Yes
    Yes
    NI PXI/PCI-5112
    Yes
    Yes
    No
    NI PXI/PCI-5114
    Yes
    Yes
    Yes
    NI PXI/PXIe/PCI-5122
    Yes
    Yes
    Yes
    NI PXI/PCI-5124
    Yes
    Yes
    Yes
    NI USB-5132/5133
    Yes
    Yes
    Yes
    NI PXI/PCI-5142
    Yes
    Yes
    Yes
    NI PXI/PCI-5152
    Yes
    Yes
    Yes
    NI PXI/PCI-5153
    Yes
    Yes
    Yes
    NI PXI/PCI-5154
    Yes
    Yes
    Yes
    NI PXI-5620
    Yes
    Yes
    No
    NI PXI-5621
    Yes
    No
    No
    NI PXIe-5622
    Yes
    Yes
    Yes
    NI PCI-5911
    Yes
    No
    No
    NI PXI/PCI-5922
    Yes
    Yes
    Yes
    *NI PCMCIA/USB/AT-5102 are Legacy products.
    Note: MXI-4 is supported on Windows Vista/XP/2000. MXI-3 is supported only on Windows XP/2000.
    This section lists the minimum system and the recommended system for using NI-SCOPE.
    Minimum System Requirements
    • RAM—
      • Windows 2000/XP: 128 MB
      • Windows Vista: 512 MB
    • Windows Vista/XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows 2000/XP: 256 MB
      • Windows Vista: 1 GB
    One of the following application development environments (ADEs):
      • LabVIEW 7.1.1, 8.2.1, 8.5.1, or 8.6
      • LabVIEW Real-Time Module 7.1.1, 8.2.1, 8.5.1, or 8.6 (If you are running your application on an RT target, at least 128 MB of memory is required)
        Note: Not all devices are supported by the LabVIEW Real-Time Module.
        NI 5105
        NI 5114
        NI 5122
        NI 5124
        NI 5142
        NI 5152
        NI 5153
        NI 5154
        NI 5622
        NI 5922
      • LabWindows™/CVI™ 7.1 or later
      • LabWindows™/CVI™ Real-Time Module (If you are running your application on an RT target, at least 128 MB of memory is required)
      • Microsoft Visual Basic 6.0
    • National Instruments file folder location, :
      • Windows 2000/XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows Vista: Users\Public\Documents\National Instruments
      • Windows 2000/XP/Vista 32-bit: Program Files\IVI Foundation\IVI\
      • Windows Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
    [tr][/tr]
    Notes:$(NIIVIPath) is configured as an environment variable on the target system.
    If you upgraded an installation of IVI, your files may be in the following locations:
    • Windows 2000/XP/Vista 32-bit: Program Files\IVI\
    • Windows Vista 64-bit: Program Files (x86)\IVI\
    ItemInstalled Location on Windows XP/2000
    and Windows Vista
    NI-SCOPE\Drivers\niScope
    NI-SCOPE Function Panel\Drivers\niScope\niScope.fp
    NI-SCOPE Examples\NI-SCOPE\examples
    NI-SCOPE Header files\Include
    NI-SCOPE Import Library files\Lib
    NI-SCOPE DLL\Bin
    Most documentation is available at Start»All Programs»National Instruments»NI-SCOPE»Documentation. The documentation set is composed of the following documents:
    • NI High-Speed Digitizers Help
    • NI High-Speed Digitizers Getting Started Guide
    • NI 5102 Specifications
    • NI PXI/PCI-5105 Specifications
    • NI PXI/PCI-5112 Specifications
    • NI PXI/PCI-5114 Specifications
    • NI PXI/PXIe/PCI-5122 Specifications
    • NI PXI/PCI-5124 Specifications
    • NI USB-5132/5133 Specifications
    • NI PXI/PCI-5142 Specifications
    • NI PXI/PCI-5152 Specifications
    • NI PXI-5620 Specifications
    • NI PXI-5621 Specifications
    • NI PCI-5911 Specifications
    • NI PXI/PCI-5922 Specifications
    • NI 5102 Calibration Procedure
    • NI 5105 Calibration Procedure
    • NI 5112 Calibration Procedure
    • NI 5114 Calibration Procedure
    • NI 5122/5124 Calibration Procedure (Note: This procedure also applies to the NI 5142)
    • NI 5911 Calibration Procedure
    • NI 5922 Calibration Procedure
    Note: Printed copies of device specifications are shipped with each device.
    Installing/Uninstalling/Modifying NI-SCOPEInstalling NI-SCOPE
    This section provides information on installing NI-SCOPE and NI-DAQ and upgrading from previous versions of NI-SCOPE.
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    Upgrading from NI-SCOPE 1.0 and 1.1—NI-SCOPE 3.5 does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing NI-SCOPE 3.5.
    Upgrading from NI-SCOPE 1.5 and later—NI-SCOPE 3.5 automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    For Windows XP/2000, complete the following steps:
    • Click Change/Remove.
    • Select NI-SCOPE 3.5 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    Do not attempt to uninstall by deleting files, which may be shared with other programs. The following additional software packages may have been installed as part of the NI-SCOPE installation. Exercise care when removing these packages because they may be used by other NI products:
    • IVI Compliance Package
    • NI-VISA
    • NI-DAQ and NI-DAQmx
    • Measurement & Automation Explorer
    • NI Hierarchical Waveform Storage
    NI-SCOPE provides an intuitive, full-featured interface for programming your hardware. NI-SCOPE is IVI-Scope compliant. For more information, refer to \Drivers\niScope\Documentation\niScopeIVIComplianceDocument.txt.
    Software Examples
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    The NI-SCOPE Soft Front Panel (SFP) is a software oscilloscope application for NI high-speed digitizers. It has the following features:
    • Familiar interactive user interface
    • Robust architecture
    • Scalar measurements
    • Save/load waveforms
    • Save/load configurations
    • Low CPU usage
    The NI-SCOPE SFP demonstrates some of the capabilities of NI high-speed digitizers and enables you to start using your new digitizer immediately without the need to know a programming language. The NI-SCOPE SFP is installed by default as a feature of the NI-SCOPE installation. To remove the NI-SCOPE SFP use the Add/Remove Programs option.
    The following items are changes from earlier versions of NI-SCOPE to NI-SCOPE 3.5. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE.
    NI PXIe-5122
    A firmware update for the NI PXIe-5122 is available with NI-SCOPE 3.5. Under some circumstances, "Error -50500: A synchronization object was not acquired within the time limit. The operation could not be completed as specified." may occur while fetching data from the digitizer using the previous firmware. This is resolved by updating the NI PXIe-5122 firmware by running NI PXIe-5122 Firmware Updater.exe, the updater utility which installs with NI-SCOPE 3.5 into the following location:
    • Windows 2000/XP/Vista 32-bit: Program Files\National Instruments\NI-DAQ\fpgafiles\ni5122\
    • Windows Vista 64-bit: Program Files (x86)\National Instruments\NI-DAQ\fpgafiles\ni5122\
    For more details regarding the firmware update, refer to Knowledge Base 4MJGCSAY at ni.com/support.
    Bug IDFixed Issue
    NI-SCOPE
    36906Added bandwidth governing attributes to control PXIe devices' usage of bus bandwidth.
    45209Fixed an issue where simply opening and closing a calibration session without performing adjustments could reset calibration constants to factory defaults.
    59726Fixed an issue where repeatedly opening and closing a sesion to an NI USB-5132/5133 device leaked memory.
    57540Fixed an issue where resetting a device repeatedly using LabVIEW Real-Time leaked memory.
    55257Fixed an issue where the NI 5105, NI 5114, NI 5132, NI 5133, and NI 5152 could not be configured to use the minimum sample rate.
    45355Fixed an issue where changing sample rate or record length during an acquisition would behave correctly but result in incorrect attribute values.
    43648Fixed an issue where a confusing error was reported when using an unsupported trigger type with the NI USB-5132/5133.
    41750Removed the obsolete NI-SCOPE Quick Reference Guide from the installer.
    41738Fixed an issue where the driver would not report an error if the NI USB-5132/5133 were configured with unsupported trigger attributes.
    42255Fixed an issue where closing an external calibration session could change the product revision that the driver reports for the NI USB-5132/5133.
    39972Removed the obsolete VI Tree.vi.
    36840Fixed an issue where certain records of a TClk synchronized, multi-record acquisitions using an NI 5152 could be skewed in time.
    42641Fixed an issue where applying gain to waveform data using the NI-SCOPE measurement library processing steps could be done incorrectly for two-channel waveforms.
    99501Fixed an issue where the driver would report an error if the Minimum Trigger Holdoff attribute were queried.
    108832Fixed an issue where the driver would report an error when setting the Probe Attenuation attribute to certain values on the NI 5922.
    41141Improved the documentation for the Calibrate example for LabWindows/CVI.
    111196Fixed an issue where the driver would report an error or incorrect value if the Trigger Modifier attribute were queried.
    45749Fixed an issue where the C examples did not claim support for devices released in recent years.
    102518Fixed an issue where the NI 5142 would not auto-trigger correctly.
    112261Fixed an issue where some C examples did not have MSVC 6 project files.
    105401Fixed an issue where fetching data from an NI PXIe-5122 using the NI PXIe-8130 (or faster) controllers could report error (-50550).
    112316Fixed an issue where the behavior of auto-setup was not consistent on the NI USB-5132/5133.
    45446Fixed an issue where querying the Backlog or Points Done properties would return incorrect values if channel 0 were disabled.
    45269Fixed an issue where auto-setup would not consistently detect wide-band signals.
    40107Added attributes to query the maximum and negotiated PCIe link width for certain devices. Refer the NI-ModInst Help file for more information.
    101226Fixed an issue where certain HWS examples could not be run on LabVIEW Real-Time.
    NI-SCOPE Express VI
    103868,
    57320
    Fixed an issue where LV code generated from a Signal Express project using synchronized NI-SCOPE and NI-FGen blocks was not executable.
    114961Fixed an issue where overloading a digitizer channel with a large input signal could lead to an infinite warning loop in the Soft Front Panel.
    99679Fixed an issue where the Soft Front Panel could hang if auto-setup failed.
    99481Fixed an issue where using the keybord shortcuts for the cursor windows could make the Soft Front Panel unresponsive.
    110906Fixed an issue where the Soft Front Panel would not distinguish between RIS mode and TIS mode at the highest sample rate of the NI 5152.
    103602Fixed an issue where, in certain cases, the Soft Front Panel would not update plots on the waveform graph if channels were enabled or disabled.
    60257Fixed an issue where imported traces would display in the wrong color.
    60202Fixed an issue where the wrong number of horizontal divisions was displayed in the waveform graph while using the NI USB-5132/5133 at certain sample rates.
    59102Fixed an issue where cancelling a dialog box at one step of a file import would cancel the entire import.
    96807Fixed an issue where cursors would not work in Classic mode.
    101774Fixed an issue where switching between Classic and Benchtop modes did not work correctly.
    103595Fixed an issue where switching between Classic and Benchtop modes did not allow the user to save reference channels.
    104716Fixed an issue where the units in the cursor position window were displayed incorrectly.
    106496Fixed an issue where imported reference channels could not be deleted in Classic mode.
    60558Fixed an issue where the first reference channel created in Classic mode could not be deleted.
    106581Fixed an issue where selected cursor colors would not be restored on subsequent runs of the Soft Front Panel.
    Known IssuesUSB Device Stops Responding
    If you observe that a USB device stops responding when you insert or remove another USB device in the system, see Knowledge Base 4D4BO9AY at ni.com/support.
    Function Reference Help
    If you click a topic link in the NI-SCOPE Function Reference Help section of the NI High-Speed Digitizers Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    LabWindows/CVI
    The hyperlinks in the function panel context help in LabWindows/CVI versions 7.1 and 7.1.1 do not work unless you have downloaded the most recent version of the launchhelp.js file. Instructions for downloading and installing the file can be found in the KnowledgeBase (KB) entry Why Do I Get "Object Expected" Error When Opening Links in Function Panel Help? You can access this KB by visiting ni.com/info and entering rdnkbe in the Info Code field.
    Windows Power Management
    NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using NI-SCOPE. These modes terminate any NI-SCOPE operation in progress. In Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    Security Prompts
    When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    LabVIEW Support for Traditional NI-DAQ 7.4.2
    Starting with version 7.4.2, Traditional NI-DAQ (Legacy) will install support for the latest version of LabVIEW found on the system. If you require support for more than one version of LabVIEW, complete the following steps:
    • Install Traditional NI-DAQ (Legacy) 7.4.2 (included in the NI-SCOPE installer).
    • Restart the system.
    • Copy the following folders from the latest version of LabVIEW to the folder of the older version of LabVIEW. [LVDIR] indicates the folder of the latest LabVIEW version.
      • [LVDIR]\vi.lib\daq
      • [LVDIR]\examples\daq
      • [LVDIR]\help\lvdaq.chm
      • [LVDIR]\menus\default\daq
    You should now be able to use Traditional NI-DAQ (Legacy) with both versions of LabVIEW.
    The Traditional NI-DAQ (Legacy) API is mass-compiled in LabVIEW 7.0. This will not affect the functionality of your VIs. However, LabVIEW will prompt you to save the Traditional NI-DAQ (Legacy) subVIs if your LabVIEW version is greater than 7.0. To avoid the prompts, mass-compile the folders referenced above. If you require Traditional NI-DAQ (Legacy) support for earlier versions of LabVIEW, you need an earlier version of Traditional NI-DAQ (Legacy).
    NI-SCOPE Soft Front Panel Keyboard Shortcuts
    Beginning with NI-SCOPE 3.1, the following shortcuts have changed in the NI-SCOPE Soft Front Panel:
    • Increment trigger coupling has changed from to .
    • Decrement trigger coupling has changed from to .
    • now toggles the cursors.
    NI-SCOPE Express Step in NI Signal Express 1.0
    The NI-SCOPE Express step that ships with NI-SCOPE was designed for use with NI SignalExpress 1.1 or later. The NI-SCOPE Express step is compatible with NI SignalExpress 1.0 with the exception that software start triggers are not supported.
    TClk Connector Alignment in NI-SCOPE 2.7 and Later
    If you are using NI-TClk to synchronize non-identical devices (for example, an NI PXI-5122 with an NI PXI-5124), you will notice a change in behavior in the skew associated with synchronization when you upgrade from NI-SCOPE 2.6.1 to a later version. The new behavior compensates for delay associated with the input path. This delay varies from device to device. Because the driver now handles this delay, synchronizing any SMC-based products should produce data that has a small constant skew over all sample rates.
    NI 5102
    Board revision 183612F-01 of the NI PCI-5102 and board revision 184603E-01 of the NI PXI-5102 must be used with NI-SCOPE 2.6.1 or later. Board revision 183442G-01 of the NI PCMCIA-5102 must be used with NI-SCOPE 2.8 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI 5112
    You can now read data as soon as it is acquired. However, on a single record acquisition, the fetch functions do not wait for the trigger holdoff to expire. If you configure a trigger holdoff on a single record acquisition, you must make sure the trigger holdoff period has expired before initiating another acquisition. Call niScope_AcquisitionStatus to find out when the entire acquisition, including trigger holdoff, has completed.
    NI 5122
    • To change the rate of the external clock within the same session, you need to first change the rate by setting the Sample Clock Timebase Rate attribute, then change the rate of your source, then call the function niScope_Commit. If you change the rate of the source before setting the attribute, you may get an error. Another option is to abort the acquisition after fetching the data but before changing the rate.
    • Board revision 190100B-01 of the NI PXI-5122 must be used with NI-SCOPE 2.7 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version of NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI PXI/PCI-5142, NI PXIe-5622
    TClk synchronization is not fully supported for certain cases. When the DDC Enabled attribute is set to True, there are certain configurations for which shared triggers cannot be TClk synchronized. The following table explains which triggers can be TClk synchronized for different configurations. For all cases, it is assumed that the DDC is enabled. If the DDC is not enabled, there are no restrictions on TClk synchronization.
    Configuration
    51425622
    Start Trigger
    Reference Trigger
    (Digital)
    Reference Trigger
    (Analog Edge)
    Reference Trigger
    (Power Edge)
    Start Trigger
    Reference Trigger
    (Digital)
    Reference Trigger
    (Analog Edge)
    Reference Trigger
    (Power Edge)
    Fractional Resampling Off, All Cases
    Y
    Y
    Y
    N
    Y
    Y
    N/A
    N
    Fractional Resampling On, Single-Record, Homogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    Y
    N/A
    N
    Fractional Resampling On, Single-Record, Heterogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    N
    N/A
    N
    Fractional Resampling On, Multi-Record, Homogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    Y
    N/A
    N
    Fractional Resampling On, Multi-Record, Heterogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    N
    N/A
    N
    Note: Reference triggers that cannot be TClk synchronized (such as power edge reference triggers) can still be shared between devices by exporting them using the niScope Export Signal VI or the niScope_ExportSignal function.
    NI 5911
    When you synchronize multiple NI 5911 digitizers in master-slave mode, the sample rate must be 100 MHz, 50 MHz, or 25 MHz/n, where n is any positive integer. The master-slave operation may also cause trigger jitter.
    Link Library
    NI-SCOPE 2.1.4 and previous versions installed a duplicate version of the NI-SCOPE C link library called niscope_32.lib. This duplicate version has been obsoleted and now only niscope.lib is installed. Programs linking against the duplicate name need to be changed to link against niscope.lib.
    Visual Basic
    ViConstString, ViChar, and ViString are used as parameters for the NI-SCOPE functions. However, these types are invalid in Visual Basic. Visual Basic users should declare variables of type String.
    IVI
    The trigger type (NISCOPE_ATTR_TRIGGER_TYPE) for immediate triggering used to be returned as NISCOPE_VAL_EDGE (1). It is now returned as NISCOPE_VAL_IMMEDIATE_TRIGGER (6).
    © 1999–2008 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 19:09
